Death of Gain Clone
Because I received a lot of PMs regarding this project...
Due to the engagement with my work (yes, the money is not
a good thing, but still works when you need to buy some stuff),
I don't have enough time to spend it with my hobbies. The other
reason is that I already moved to the vacuum team. It is simpler
and long time short circuit at the output is not a big deal at all 😀
Attached is the schematic of DoGC with some little improvements.
Will try to test the offset stability at different ambient temps and
will report the results here ASAP. Thank you!
P.S. Still have some PC boards for this project, PM or mail me if you
have any interest or questions: widowmaker@mail.bg
@metal
I think you are a little too much questioning this circuit.
It has several interesting parts.
And my opinion it is rather simple.
We can not make too simple if we want a good amplifier.
If we do that we run into troubles and sound will not be good.
@widowmaker
Thanks for sharing this circuit once more.
It might bring me back to diyadio.com ....
I have been away for so many years.
Open-loop gain decreases proportionally to frequency. Amplitude of sensed error increases proportionally to frequency. And it uses an interesting mixture of parts.
Long life to Death of Gain Clone!
Let me put some exotic taste (in the attachment) in this very old thread 🙂
I have also another, less exotic version with bootstrap instead of inductor.
LTSpice shows interesting things (values and pictures) when simulate both
of them. 2SK369 still can be found on ebay, I use factory matched K369s
with Idss 13.5mA from Japan.
I don't like cascode stages, constant current sources and other similar stuff,
that makes some schematics to look let's say cooler, the only exception here
is the current mirror, not because I like it, no, simply there is not enough gain
without it. In other words it is a necessary evil in this schematic with only two
voltage gain stages.
