Death of Gain Clone
Need Power Supply Recommendation
Hi Guys,
I'm building the current version of Bora's amp (post #314 above) but don't have a power supply yet. Can someone recommend a nice regulated shunt ps I could use with this amp?
Thanks -
Bruce
Re: Need Power Supply Recommendation
abpea said:
Hi Guys,
Thanks -
Bruce
shunt?
you have wall of heatsinks or you can put all power transistors in near lake?
shunt reg for A class amps isn't economical solution ....... even for A class afficionado
Regulated Snubberized PSU +/- 30V
Zen Mod said:
either brute force PSU (read - mucho uF ) or series reg .
go to Rod Eliot's page and you'll find few useful pages ;
look for Death Of BOZ ............
Why not build a regulated snubberized PSU, like Carlos Filipe (destroyer X) proposition for gainclone amps:
Ver. 1.2 in Nuuk's Dongeon with all explanations, which was published first in this forum.
Kind regards
sonobox
Here is a schematic of DC version of this amp:
Bias current for 9610 is higher than necessary (in this case), so unstability is not much important value...
Is it possible to get thermal stability without any emitter resistors at the output stage?
Output transistors ("dumpers") are near class B - approx. 320-350mV Ube (depending on temperature range).
This is a feedforward error correction amp.
Dumpers originally working without idle current.
Kolega, haresva mi usilvatelq - slushah go v edin priqtel, no iskam samo da otbeleja...na kartinkata za izhodqshtite droseli pishe (0.86 with lack isolation) ... lack na angliiski oznachava lipsa na neshto i edva li horata sa razbrali kakvo se ima vpredvid, spored men po-dobre za lakovata izolaciq e da se izpolzva varnish. S netyrpenie chakame pdf-a na platkata, za da izprobvame i pravotokovata versiq. 😀
This is also an interesting approach (unfortunately only to find only by chance regarded the therm "Death of Gainclone" insted the actually term for this topology), especially for translate into a CSPP topology (Circlotron).
I will study this thread next time.
In this case also this thread could be of interest:
http://www.diyaudio.com/forums/chip...ed-topologies-yamaha-mx-10000-quad-405-a.html
Here an inspiration for a solution for an enclosure/cabinet
Synergy - LM3875 Gainclone Amplifier (Chip Amp)
