Compact Sized LME49810/11 +ThermalTrak Amp
Output inductor & Zobel network
Hi panson
A question about using your compact amplifiers inside active speakers. One amp to each element.
Is it really necessary to use those inductors and Zobel network when the connections between amplifier and speaker is only about 10 inch?
The answer is maybe the same for any other typical audio endstage?
Hi panson
Hi Radioman,
As AndrewT you need to take care of voice-coil inductance. However, cable effect is negligible for direct connection. I would recommend to have those parts to avoid problem in this part.
New Compact 4981x ThermalTrak board being made
I revised the schematic to include Vbe multiplier, two-pole compensation and ThermalTrak diode current by-pass. We now have many things to try!!!
The new board is being made. Here is the new schematic.
Dear Panson.
What is your reason to add the VBE transistor? My understanding was that the benefit of the Thermaltraks was that you don't need a VBE transistor anymore.
With kind regards,
Bas
Dear Panson.
With kind regards,
Bas
Hi Bas,
Good question! This is added for user to compare different bias schemes. I want users to have more fun with the new board. We can do simple bias with solely TT diodes, conventional Vbe without using TT diodes, Leach like Vbe with TT diodes, etc.
Panson
Hi Bas,
Panson
Thank you Panson. Ever have plans to develop a huge class A variant?
With kind regards,
Bas
balanced input?
Hi has anyone tried balanced input?
Even if it's a driver IC with two inputs I want some hints how to best connect it as a balanced input amplifier. Mostly to take advantage of my Behringer three way active filter, arriving this week. :)
The ground connection isn't important in my active speaker project so I may have no worries? :)
New boads back and tested. Super performance!!!
The new boards are back from the PCB house today. I just assembled one for LME49811 with single-pole cap = 22 pF. The performance is super!!! The THD+N for 1 kHz 50 W into 8 Ohm is 0.00053 %.
