OLD THREAD DAC End by Andrea Ciuffoli
And Iv board
Hi quanghao,
1.do i need to use the L1 and L2 on DAC-end PCB board, is it 120uH inductor?
2.what is the actual value for c26 and c27, is 10nF or 2.2nF?
3.which schematic should we follow to build DAC-end?
Hi quanghao,
Hi Sugden ! Im sorry!
When DAc out put wiht tranformer do not use L1, L 2= 120uH and C26, C27= 0.01uF. that is filter
Im sorry,!
thank you!
Hi quanghao, it nothing to sorry. We all here are to learn from mistake. Appreciate if you can confirm all information we need to build this DAC. Especially which schematic we should use and value of the component, all must correct.
Best regard,Thanks.
