Nice triode
I prefer this "Power Triode" more 😛
:happy2:
P.S. it is tube related, not OT
pentodes with NFB applied have even triodey curves than triodes with no NFB
That is, as I see it, correct if we talk voltage feedback.
If we add current feedback to a triode we get the opposite, pentodeish looking curves.
Still we want to find equidistant curves for linearity. This wether it is pentodes or triodes.
UH-Ohhh I can hear chopper sounds outside. OH-No..... They took my box! Darn!
Well they didn't get the $2 dollar ones at least: (a common high gm video amp tube in triode mode, see attached)
I'll give you a hint on the mystery "tube", it uses Schading and has a 6DN3 damper in series with the "cathode".
"The curves LOOK like an EL36, but that much current would cook 'em "
The 1st curves are for a 6HJ5, a rugged 24 Watt tube. The 100 mA and 200 V figures are for the full axis (not per div., if that's what you were thinking). But a 6HJ5 will do a 1/2 amp readily. Futtermann used them for one of his OTLs. The triode curves are fairly similar for the other horiz. output tubes (18 Watt class) that I have looked at. Most of them have a Mu of around 3 to 4.7
Well, lets take a look at some of the "black sheep" in the tube family now. Here is the triode in a 6KR8 or 6LQ8. Sort of an extreme version of the 12AT7. Notice the curves falling over to the right side. These may still work OK in P-P. But will have heavy 2nd Harmonic in SE.
