Banned
Joined 2002
Funny, exactly those I ordered, and even from the same seller...
They look sexy, a bit pricey for 4 tho, Should be worth it i hope. How many did you order ?
Banned
Joined 2002
Here is my build with the energizer energi to go battery pack.
How much was your energizer Pack ?
J'
Banned
Joined 2002
The energizer pack with shipping was $92.
That is very cheap! voltage is above 18?
It has multiple connections that have various voltages. The one I am using ranges from 16-20. I'm assuming it is using 20 volts
Banned
Joined 2002
I think i might just try to find one
J'
J'
I got lucky and they had them on WOOT earlier this week for that price. Normally they range from $119 - $150 not including shipping.
OK, I give in!
I know BOGOF but WOOT ?
Andy
Woot : One Day, One Deal (SM) carries all kinds of different things at a discount some are new some are refurbished. The product changes to a new one at midnight. Sometimes they repeat products. Not sure if they ship outside U.S.
So with a full charge, the battery pack lasted about 8 days. Took 3 hours to fully charge again.
Here's a silly question ...
Can it charge while playing, like a laptop battery?
Cheers
Nigel
Banned
Joined 2002
Cheers
Nigel
Google ?
Cheers
Nigel
Yes it can, it has a led bar on it to show the current charge level so when it gets down to one bar I can plug the charger in and continue to play music as it charges.
Cool.. May have to look into one of these... (And I guess I should have googled first... sorry... )
Cheers
Nigel
turn your pot fully anticlockwise.
Measure across the terminals and find the pair that read near zero. That is the output.
turn the pot halfway round it's travel and find the pair that read the nominal resistance of the pot. That is the input.
One of each of these pair is common to both in & out. That is the Signal Ground.
- B1 builders thread
