OLD THREAD DAC End by Andrea Ciuffoli
the Parlist of DAC-END
Im very sorry all!
Thank !
This is the Parlist of DAC-END
hi quanghao, thanks for the email. I will take a full set and will send $60 now.
1. MarkLai : 2x DAC sets: DAC + Salas Shunt power for DAC
2. Jeffrey Davison : full set
3. TjongKristian : full set
4. gillib : full set
5. sugden : full set
6. toufu : 2 full sets
7. Yunick : full set
8. Michael : full set
9. COX77 : full set
10. Yunick : full set
11. jleaman : ?
12. fredlock : full set
13. Cobra2 : full set
14. tassosk: full set
15. pdcaceo:full set of PCB
16. pop music : 2 full set
17. Erwincantona : full set
18. numerik
19. Tea-Bag : full set
20. giabast : full set
21. Blitz : full set
22. Duc Tran: full set
23. agithegreat: full set - Paid
24. jims : full set
25. khaho : full set
26. ernesternest: full set
27. dvb-projekt: full set
28. quanghao: full set
29. Audiodesign: full set
30. frd__: 2 full sets
31. Ekkeri: full set
32. prooptiki: full set
33. NICKEL I/V Stage and Supply Boards only
34. Adamus: full set
Thank you all member
9. COX77 : full set
11. jleaman : ?
18. numerik
24. jims : full set
35: Sai Lee: full set
If you like Salas shunt you can at nick here
Thank you very much! I hop i can help all member like it!
9. COX77 : full set
11. jleaman : ?
18. numerik
24. jims : full set
Quanghao
I have paid but am not as yet on the list above. Forgive my ignorance, but is there some way I can be added or add myself to this list?
Thanks.
You can copy & paste the list.. plus add you name at the bottom of the list
D'oh!!
9. COX77 : full set
11. jleaman : ?
18. numerik
24. jims : full set
36. rolotube: full set
Thanks.
To get the best performances I have developed a new output stage for this DAC.
It use a pair of 5687 or E182CC to produce a low distortion stage with an output impedance near to 1Kohm so able to drive any amplifier.
Vout = 2Vrms
Vin = 154mVrms
THD = 0.2%
could there be gains here from led bias. 3.8v is approx two yellow led's. Typically i hear a good change with led bias.
