Horn vs. Waveguide
attachment.php
attachment.php
Forward axis = Red, 2.60° above the midpoint between drivers.
Up toward waveguide = Org, Yel, Gry, Lt. Gry
Down toward woofer = Grn, Blu, Vio, Cyn
Eminence KappaLite 3012LF
B&C DE250 on QSC 152i waveguide
Dayton KD trapezoid cab kit
6-component passive XO
About $400 each, complete.... 😎
The QSC waveguide is compelling, but the cabinet is the tricky part. I own a JBL speaker which is similar to the design you've posted, and it's imaging is nowhere near as good as the Summa's. I believe the cabinet design plays a big part.
Patrick, what exactly is imaging? Not to be negative, but where does this come from, and from what basis do you come to this conclusion. From my side of wiew, the only way to be sure, is to record in the same room and then listen to an unaltered recording in the same room?
Peter
