Horn vs. Waveguide
Measuring each loudspeakers individually makes more sense (especially at frequencies above the Schroeder frequency) due to interference effects. Is the impulse response gated?
MLS with a 5.06 ms window, 197.53 Hz it says; I guess so.... 😉
It's a miniature of how we do listen, actually. Double or triple the dimensions, and it might be typical, even.
It'd be cool to do it with one of those dual-mic'd head models and sum the results to see the one-toothed comb. 😀
[Has Earl posted his system verticals anywhere yet, or does he still not care? 🙄 ]
I don't believe you're in the far field at 44" hence the sound field will look different when measured at 2 or 3 m (6.6'/9.8').
If you measure with a dummy head, you won't be able to derive anything useful (in terms of loudspeaker performance) from the frequency response.
"It's a miniature of how we do listen, actually."
It doesn't miniaturize the vertical dimensions of the woofer and horn, which I don't believe is accounted for just by noting the angle from the mike to their geometric centroids.
IOW I agree w/Markus, you're not accounting for nearfield effects.
Y'all are perfectly capable of replicating this work with variable measurement distance and reporting your findings.
Point is, let's see some system vertical polars, I mean, we've been blathering about it for what, over a year and 40 pages or so here?
Drawing a conclusion without any data is bad but drawing a conclusion from wrong data is even worse 😉
Bah. I'm concluding nothing.
Measure them Nathans; let's have it done right, then.... :yes:
Your link goes to this page, not where you intended.
To the best of my knowledge, Earl has never posted system verticals, merely whinged as to how difficult they are to do.
[For now, the Zilch protocol is the benchmark.... 😀 ]
Cool.
Here it is, one only, in 5° increments to 20° both up and down about the forward axis, at 22.5° horizontal, same as your Nathans, except 4.63" further into the farfield... 😉
attachment.php
