Influence of the delay amplifiers for listening characteristics
I would like to ask what, who sees the link between delays and the impact of listening to the amplifier characteristics.
The decrease in gain of 3 dB is a phase shifted by 45°, the sine of 0.707 of the maximum value, consider this very poor, for feedback and Vdif.
Thank
Vdif and conditions of the input amplifier.
Fundamental change Vdif and conditions of the input amplifier delays 10 °.
No audio amplifier should exhibit phase shift over the 20-20khz range unless the response is modified by for example tone controls which phase shift.
What has a 741 got to do with all this, configured with a gain of +10 and a low input impedance 🙂
Use a faster opamp and the problem will diminish.
Edit... the lack of speed of the 741 is why you are seeing the "differential" voltage between the inputs increase as frequency increases.
This would be useless without discussing topology. Due to heavy emitter degeneration in my input stage, the input stage cannot be dynamically saturated. This is very different from input differential BJT stage without any emitter degeneration. Anyway, your wish fulfilled:
Please show your good example
You showed what? Only crazy simulations of unrealistic circuits...
Your pictures of phase shifts have nothing to do with "skreslení" (distortion), but with finite SR of real components. Very poor uA741 gives poor results, nothing new. Show measured results of yours circuits, please .
