Driving RGB LED's
Maybe not the right place here on an audio forum but in "Everything Else" we can post other things .
I've been looking for a way to drive RGB LED's so that with like up/down buttons I can fluently change the colours.
Looking at the IC's on Mouser or Texas Inst sites , I can't see the trees through the forest. So many LED driver IC's but not what I am looking for.
Closest I've come to designing it myself is an up/down counter that drives the addresses of an EPROM , and its output drives the PWM of the 3 LED colours.
Problem with this is progamming the EPROM.
Even with 5 bit resolution/LED , that's near 100.000 adresses of a 1Mbit EPROM ... by hand .
There must be an easier way but without an uP using only custom IC's with logic and EPROMs.
How does Philips Hue do it ? How would you do it ?
NC400 general input Q's
Hi -
(OK - covered elsewhere, but all a bit disparate/technical for novice - looking for summary of input Q's - therefore hope this is relevant/helpful to others)
I am driving NC 400 via balanced out from DAC.
1; NC400 passive pot wiring; was recommended as in fig A - have been running fine for some years - though would fig B be better?
(I did run S.E. for a while, and I think A is Hypex's recommendation for this...)
2; I'm considering the addition of an external buffer (n.b. have no long runs...) - some say; more dynamics, a bit more warmth, though I understand this is less if at all applicable to NC400 as it has built in input buffer stage. A simple 'KISS' ('keep it simple, stupid'!) or 'ACT' (active!) opinion without the trouble of huge technical explanation would be hugely appreciated.
I understand my Q's are painfully basic, thank you for perseverance!
Transformer orientation
Hi, I asked this question in another thread, but perhaps here is the right place to ask.
I just copy-paste it, hope this is ok.
"After a very long time on a MDF board my D3 will receive a case. I bought a Linn Intersekt case for very little money and now mod it to my needs.
My question is : Which way to mount the PSUs would you prefer and why ? Is there a difference if the transformers are side by side, facing away from each other or even one on the floor one on the wall ? Which would make sense ? Here are my possibilities."
Perhaps i should have asked in the PSUs section first.
Improving the hollow plastic phase plug in Seas driver
I've just bought a pair of Seas CA18RNX/P drivers, and the phase plugs are a hollow moulded plastic item. They sound hollow when tapped and fall off when twisted. So now curiosity has got the better of them, I could fill the hollow with resin or silicone etc to fill and dampen them. Or go full nut job and machine a new pair of plugs from aluminium or copper and fit them with a bolt through the 'pole vent'.
What would be the better option? Is there an issue with copper or aluminium above the gap only, forming an eddy current shorting ring for the positive stroke only?
OR should I just fill them with 2 part silicone to deaden them and stick them back in with some epoxy?
thanks
Tango FX-40-5 Output Transformers (Pair) 5k
These are used but in superb condition. Ideal for 45, 2a3 or 300b push-pull. For inspiration check here: "Fatboy" 300B Push-Pull Amp
I am looking for 450 swiss francs for the pair plus shipping.
Shipping to Europe and UK is 50 swiss franks
Shipping to USA is 75 swiss francs
Shipping to Japan and Australia is 90 swiss francs
These are original Hirata Tango transformers. Secondary connection for 4, 8 and 16 ohm.
I really hate to part with them, but need to reduce. PM me if you have interest. I will post photos soon.
Ian
Lii Audio W-15 in an aperiodic enclosure?
Given the big Lii Audio driver is of a high Qtc of 0.79...and has a 8+mm of Xmax...and a very uncontrolled Qms value...The driver sims as wanting to be sealed, has a mid-twenties F3...the enclosure size is rather impractical....has anyone tried an aperiodic enclosure?
No, my cheap open-baffle days are long gone, and I "don't believe" the hype of baffle-less proponents.
The actual mathematical science of Aperiodics has not been put to paper & calculator as of yet.
Thoughts?
-------------------------------------------------------------------------Rick....
Designs similar to the BD-Pipe
Back in the mid-Naughties, I had 4 of the Radio Shack 40-1197 drivers, and spent many a happy hour checking out speakers that used them. The BD-Pipe always appealed to me. Folded pipe, with a 45-degree rear facing driver for added spatial neat-o-ness. But I never built anything.
So, now, a decade, a divorce, and a lot of livin' later, I am once again seated in front of a computer, looking at small full-range speaker designs. And I still like the ideas in the BD-Pipe design.
So, are there current designs that are similar? 4" - 4.5" FR drivers, compact tower, easy build, easy load for low-powered amplification, and with that angled, (or upward-facing,) psuedo-omni driver. Corner placement is a must in my tiny, weirdly shaped living room. and it's an upstairs apartment in an old house, so lotsa bass isn't a goal.
--Shannon
Parts in Mumbai (India)
I had this strange experience. I was looking for polypropylene capacitor in Lamington
Road Mumbai. I got a reference from one shop that Apex electronics in one of the lane
has such capacitors. Apex said it can be made only in bulk order and it is not
available usually as these are very expensive capacitors. So I looked for some more time
and then gave up being too tired of hopping around shops on that road. Finally looked for
in the internet and ordered from Futurlec. It took about a month and I got the caps. Happy!
Only day before yesterday I searched the net with the cap number (AC-X2) which I got
from Futurlec and surprised to find that these were available in Visha Electronics. I went
to Visha at least twice before, they always said they DO NOT have polypropylene caps.
They do not even know what they have. Then yesterday the moment I said AC-X2 they
said yes yes we have.
What do we do????
So my request to all fellow DIYers from India/Mumbai that we maintain this thread for
this purpose of posting names/addresses of shops where we can find certain parts.
Or for any such strange stories.
I start:
AC-X2 (polypropylene) capacitors (less than or equal to 1uF): Visha electronics, Lamington Road.
They take online order also. Online Shopping in Mumbai
Roushon.
Cinemag 1254 SUT Round II
There have been several requests to do another Cinemag 1254 step up transformer group buy. Delivery time will likely be 8 weeks from date of placing the order. Price for the standard configuration would be $190 per pair. The center threaded bushing would be $200 per pair. Only one type per order, minimum 10, so we need to decide on the most desired configuration.
Price breakdown is as follows:
The price for standard mount will be:
CM-1254 pair $190.00
CA Sales Tax 9.5% $ 18.05
Pro rated shipping from Cinemag $ 5.00
Priority Mail Insured (U.S.)* $ 10.75
Total $223.80
The price for center threaded bushing mount will be:
CM-1254 pair $200.00
CA Sales Tax 9.5% $ 19.00
Total $234.75
* International Priority Mail Small Flat Rate Box will be quoted individually, but expect $27-$40 USD
Payment to confirm your order should be made immediately after the GB is officially closed. This will allow me to commit to the exact number of transformers and confirm production scheduling with Cinemag. I would look to the GB being closed on August 31, to get the order in before the U.S. Labor Day holiday.
Geary
Urgent help needed with NE5532 OPAMPS
Hi all,
At the end of doing my final project for university (making guitar pedals), and have run into a wierd issue. One of the pedals utilises a spring reverb tank to acquire its effect, so i've been following a schematic found online that uses NE5532 opamps to drive, recover and mix the circuit. However, whenever they are plugged into the +15v and -15v power supply, as required, they turn on and off again repeatedly. I absolutely cannot figure out why this is! Any sort of help would be massively appreciated.
See links for the circuits:
https://sound-au.com/articles/rvb-f5a.gif
https://sound-au.com/articles/rvb-f9.gif
https://sound-au.com/articles/rvb-f12.gif
F/S Mil Spec 2 Cond 12 & 10 Awg Silver Plated Wire
I just bought a good quantity of some Mil Spec 2 Conductor 12 & 10 Awg Wire
Mil Spec M22759/44 Silver Plated Copper Wire. Have 12 & 10 Awg Silver Plated Copper Braided Shield and one 10 Awg 2 conductor Unshielded.
Great for Speaker Wire, Car Amplifier wiring, and vacuum Tube Audio
Here are the part numbers
M27500A 12SR2M23 - 12 Awg 2 conductor Shielded $4.00ft
M27500A 10SP2M23 - 10 Awg 2 conductor Shielded $4.50ft
M27500A 10SP2U23 - 10 Awg 2 Conductor Non Shielded $4.00ft
Now in Stock
not yet listed on my website
Marshall Valvestate vs230r repair tips?
A friend of mine has a valvestate amp that has let out the magic smoke. He said he was in the middel of playing Smoke on the water, so he was clearly asking for it. 🙂
It is this specific model : https://schematicheaven.net/marshallamps/vs230r_2x30w_stereochorusrev.pdf
R18 has clearly burnt, everything else looks Oke. Can anyone shed some light on the possible cause? I’ve measured sec. on the transformer which seems to be oke at 17,5 volt.
Also ordered 2 new TDA2050 as they are dirt-cheap. But before I replace them, what should I check?
Infinity Kappa K4 distortion
This is a 4 channel class-d amp. The output is highly distorted. It had this issue brand new out of the box. This is my first attempt at repairing an amp. I have been trying to troubleshoot the issue by following Perry's tutorial, which is amazing, but it is a lot of information to digest and I am stuck.
The output is highly distorted at all gain levels, but gets worse as the gain is increased. None of the other switches or knobs have any effect on the distortion. The distortion is the same through both the RCA inputs and audio played through the amp's BT connection. All 4 channels are distorted. When just one (any) RCA input is connected, the audio is present on all 4 channels and all are distorted. The output is a little louder on the connected channel, but is easily heard on all channels.
I have checked the power supply rails at the rectifiers and I see clean rails of approx +40v and -40v on my scope.
I checked for oscillation on the output FETs and I see a square wave that peaks at approx +40v to -40v.
I don't really know where to go from here and could use some direction. Thanks in advance.
Threshold amplifier help, please!
Good morning, all,
I'm hoping that Nelson Pass or another expert here might be able to give me any advice on any electronic components I might be able to test (and replace) myself as I have a hissing sound coming from the right channel of my T800. When I power down the amplifier, I also get a fairly long hiss with high-pitched sounds mixed in, only on the right channel.
It wasn't likely that this was going to be any of the top fuses but I did verify that those fuses are all OK.
Any help much appreciated!
Best,
Ross
Boring question: What's the common order of input-/output-connections
Good evening
After my 3rd or so back-plate (attempts included), I'm still not sure if there's a common order of what goes where (and why).
Functionally, as long as stuff is done reasonably, I guess it doesn't really matter if the IEC is on the right or left side. But then, should things have a certain order,
  • for technical reasons?
  • Just because it's quasi standard?
  • or is it lastly just sheer aesthetic reasons and maybe a brand's ID?
probably a bit of all, but the technical and "historic" reasons are those I'm most curious about ...
JBL's take on the Unity Horn
There's a bunch of threads on here regarding the Unity horn; it's basically a three-way D'Appolito array, folded around a conical horn, with a coupling chamber inserted to reduce harmonic distortion.
Geddes pioneered the use of reticulated foam in waveguides. In a horn or waveguide, a significant percentage of the radiated sound is delayed in time. This is because a percentage of the sound is reflected off the mouth, and a percentage of the sound does not travel down the center of the horn or waveguide. Those waves are absorbed more than axial waves, as they travel further.
Geddes and Duke LeJeune, from about six years back
Looks like JBL was listening - they've created a loudspeaker which combines a bit from both.
In the three loudspeakers above, the tweeter is at the apex of the horn, just as in a Unity horn. And the midranges flank the tweeter, as in a D'Appolito. But there's a coupling chamber in front of the midrange(s) - just like a Unity. The reticulated foam is used here to good effect, particularly in the line array. Here's quote from the patent:
"The RBI is a substantially solid boundary that is placed over the mid-range speakers to provide smooth, wave-guiding side walls to control the angular radiation of the high-frequency sound waves emanating from the high-frequency sound sources. To allow the mid-range frequency sound waves generated from mid-range sound sources to pass through the RBI, the RBI is designed with openings. To further prevent the possibility of having high-frequency sound radiate through the openings in the RBI, the RBI may be designed with porous material in the openings of the RBI. The porous material would be transparent to the mid-range sound radiation, but would prevent the high-frequency sound radiation from being disturbed by the openings in the RBI."
The graphs show performance with and without the RBI device. (the coupling chamber, like a unity horn.) The difference looks subtle, but keep in mind each segment is TEN dB. Note how the off-axis response is improved, particularly near the crossover point. This is right in the important vocal range, where six dB dips are surely audible!
If anyone would like to learn more, take a look at patent 7134523
Tube subwoofer amp
Hi all,
Well after getting my 6V6 PP stereo amp sounding real nice, (check my other threads) I am looking for a new project.
I have a 10"sub in a box sitting around, and access to a variety of big *** tubes (some smaller transmitting triodes and stuff) which I can get for free. I am wondering about using a single-ended triode amp with negative feedback, using one of these tubes. My question is: what kind of power/output transformers would I need?
I was thinking I would need a reasonable power tranny, however the amp would probably only have 2 tubes: an octal triode like the 6SN7 as a preamp (heck, maybe even a 6V6 as a preamp!) and a big coke bottle power tube. So maybe I could get away with a scrounged tranny from a big console radio... Maybe?
I am thinking around 30W RMS would be good enough for a fair bit of bass, could I use a toroidal power transformer as an opt? I only need a freq range of 20-120 Hz, and I am using NFB, so would that be good enough?
Any other crazy person thought about this (or done it 😀)
~~H~~
Measuring T&S parameters using current drive
Something that just popped into my head and I haven’t really thought it through yet... what if you measured a driver's Thiele and Small parameters using very high impedance current drive instead of the usual low impedance voltage drive? For one thing, the Qes would measure a great deal higher. Given that the measured parameters would be different, you then go about constructing a bass reflex box according to these new parameters and feed the driver with a current source amplifier. I wonder what sort of results you would get? For one thing, the cone displacement would likely shrink right down at the box/port resonant frequency, more than usual.
This question is not simply about the usual ins and outs of feeding a driver with a current source signal. That has been done to death. This is about feeding a driver with a current source signal while it is in a bass reflex box that has been calculated from a driver that has had its parameters measured using a current source signal.
Edit-> I just realised that the resistor you put in series with the speaker to do the measurements in the normal fashion turns the signal into more or less a current drive anyway. Told you I hadn’t thought it through...
ASTRODYNE Finned Heat sinks 1 TO-3 Transistor Amplifier Amp Power Supply heatsinks
I don't know if they are all ASTRODYNE / IERC heatsinks.
Some have no writing on them.
$20 a piece or best offer for the large ones
$10 a piece of best offer for the small one
Selling in the lots you see in the pics.
Shipping is included and via USPS medium flat rate box.
Dimensions are in mm.
Quantity is written on them too, most are circled.
Critically damped parameters
I read that a critically damped woofer is 6db down at resonance (q=0.5).
A woofer (ATC SB75-150SL) has a resonant frequency of 57hz, and in the sealed 20 litre SCM20 monitor, the -6db point is 54hz. Does this mean it has a q of just over 0.5 in this system?
The qms and qes of the driver is 0.89 and 0.84, so I'm wondering how it's possible to have a lower q. I believe Vas is listed as 7 liters, and the Cms is 2 (I forget the units). I'm not an expert, far from it, but these values would lead me to expect a sealed enclosure between 4 and 6 liters would be required for this. What am I missing?
Edit: I remembered Qms wrong, it's 7.6. Discussed further in the thread
Pair 3.5k PP Japan Output Transformers
Hi All
I have a pair of nearly new Tomiko Japan 3.5K OPT's. These sound pretty nice for the price. I am looking for 220 Swiss Francs plus shipping for them.
Here are the specs:
Primary impedance 3.5K
With UL tap at 43%
Approx. 1.1Kg each
4 and 8 ohm secondary taps
Quoted Primary DC 225mA (max)
Quoted 35 Watt with 42 Watt max
DCR 185 Ohms, 29H
The seller I originally got them from quoted frequency range of 10Hz-88KHz (-3dB) but this is at 1 watt... nonetheless I found them pretty decent.
Also he quoted they are good with 300B, 2a3, 211, KT66, 6550, 6L6, KT88, EL34, etc...
I tested them with 2a3 and EL34. Sound was very good with 2a3 (sorry, no frequency sweeps or square wave evaluations). For EL34 in pentode, sound was also very good but I did not push them hard.
Pm me if you are interested.
Class AB vs Class D
I must confess that I'm very new to amplifier building. I'm more familiar with speaker building though.
I'm wondering that, with nowadays technology, where does the trend go for amplifier comparing between Class AB and Class D?
My friend told me that Class D is now becoming more popular than before because of the advancement of technology that can break the limited of the old Class D. Is it true?
To my understanding, Class D in those days is limited by its operation where it performs like PWM to form sine-wave. Hence, the sine-wave wasn't enough smooth compared to Class AB's. But nowadays Class D amplifier can operate the samplig rates in higher frequency than before, thus, the sine-wave is more smoother and perhaps better than some worse desinged Class AB's. Am I correct?
Changing TAOHS-JP3 vs TAOHS-KP1
Hi
Sorry about my bad english!
My Question is:
Is it possible to change a TAOHS-KP1 Laser Pickup from a good working Yamaha CDX-810 CD-Player vs a TAOHS-JP3 Pickup in a non working CDX-1030. Both Players are perfect adjusted. I think the JP3 Pickup is bad.
Both Pickups look as same, only the Pins look difficult. But that`s no Problem. Could anyone help me?
Thanks from Germany
ICEPOWER 125ASX2 for my Yamaha WXC-50
Hello guys,
i have brought me a nice little preamp, the yamaha w-xc 50 which is currently feeding my old Yamaha M-45. i want to replace the power amp with something less room-heating but still nice sounding.
For this task i have ordered an icepower 125asx2.
The wxc has a low impedance ( 2V 470Ohm output), therefore i dont need a buffer stage.
I am wondering about the enable pin of the icepower module. It´s active high (5V) and must be short to ground to deactivate the amp.
Do you think a simple active open relais to GND will be enough to control the Icepower with the help of the 12V Trigger signal? (WCX off = 0V = Relais short to ground = Icepower switched off)
Sorry for my bad english and the spelling.
Greetings from germany Kai
And I thought MBL were over the top-
Never heard of this boutique of very over the top looking gear, but boy have they pushed to envelope. I saw some pictures of the Minotaur tower on pintrest, in raw aluminum form, and it looks to be solid billet plates of aluminum from top to bottom. Fascinating stuff. I don't suppose anyone has ever seen or heard a set?
EDIT: They confirm on the website, 4000 Kg of aluminum is used!
Audiovisual Art | Collection
FS: Musical Paradise MP-701 MKII Tube Preamplifier
Musical Paradise MP-701 mk2 tube preamp for sale.
Used two weeks. Perfect condition.
This unit does not have balance in/out.
XLR are provide for user convenience.
See end of manual.
Highlights
User replaceable caps without soldering/desoldering.
Volume remote
Includes:
Remote with battery
Original box
NOS Tesla ECC88 tubes
Original supplied tubes
ClarityCap CSA 4.7uF caps (one set)
Original caps
Basic power cable
Will include spike bases not normally included with preamp.
MP-701 MK2 Tube Preamp Pre Amplifier
Will waive pay paypal fee. Buyer pays shipping.
$700.00 US.
Thanks for looking
Vince
Small value inductor in crossover network
Some of my crossover design have parallel notch filter using several small value inductors(under 100uH)
Most of audio inductor brands usually have above 100uH so small values need custom order and it will cost some times also a little pricey.
I would like to ask if the industrial inductor could be bought from Mouser like this https://www.mouser.jp/datasheet/2/212/1/KEM_LF0062_SNG-1608324.pdf
or this https://www.mouser.jp/datasheet/2/445/74437529203470-1721700.pdf could be used for the crossover.
Thanks a lot!
Salas hotrodded blue DCB1 (Nelson Pass )
All with genuine parts ; Toshiba 2sk170 matched to .2ma , Vishay/Sfernice metal foil at critical place, Holco/Resista all over
MUR 860 diodes 8A/600v.
There is a soft start/time delay on this preamp, no surprise no noise and DC off set is very low.
125$ USD
EMT/ shipping extra
Edit: Please disregard the diagram.
Salas hotrodded blue DCB1 build
Kenwood 11G repair advice
Hello All
I came across this Eleven G a few weeks ago that basically just needed the pots clean. When running the balance and volume pots, they made noise and the speakers would cut in and out left and right while turning the balance. Both channels sounded fine though when testing at sellers place. I went through and cleaned the pots. I had to move around a few of the bottom boards not taking them all the way out, but just unscrewing them so I could get better access to the pots. Well pots now are smooth and accurate, however my left channel sounds a little distorted. Not horribly bad, but I can hear it. Right side is clear. I took out the jumpers and just ran the pre out to a small amp and left channel is fine, so it’s in the amp section. Could this be a grounding issue? The sound level between the channels is the same, left channel is not lower, just a little distorted when the bass kicks in. Any thoughts? Your input would greatly be appreciated.
CD-Rs and Laser Life?
Is there any correlation between the longevity of CD lasers and the type of CD played?
Does the laser work harder to read a CD-RW compared to a factory pressed CD?
Or is it like shining a torch (with only one brightness setting) at something reflective which can then be seen by your eye compared to something less so, the result being "nothing to see here".
My understanding is as a laser unit gets older it provides less light and therefore the reflections are less so a tired laser will stop being able to read CD-RW first, then CD-R and eventually wont even read factory CDs.
I can also remember reading or hearing about some CD players having variable output lasers but that was not the norm. (sorry I can't remember from where).
The purpose of all this is that if it is kinder to a CD player to only play original pressings, I will refrain from playing any of my home burned compilations on my favourite player to make it last longer, but if it really makes no difference to the player itself and playing/or not playing CD-Rs and has no detrimental effect on the players longevity, then I will continue.
Many thanks in advance for any input.
AC in my DC to OPT
Hi all,
Firstly sorry if I have posted this in the wrong area was tossing up to post in the power supply space, never the less.
I have a perplexing issue in my current build (2x EL84 PP Guitar amp). I have about 50VAC in the 260V DC OPT center tap. (this DC voltage a little lower than it should be but i am running through a light bulb at the moment)
The design itself is very common, the secondary of the PT is being rectified by a EZ81 this DC is being filtered by a 32uF cap. At this point the OPT center tap is connected.
I have considered magnetic interference, by my scope trace doesn't resemble a sine (AC) wave as I would expect. It looks like a sine wave with the negative side flattening at 0.
I have considered a faulty cap, and connected another in parallel to see its effect... none at all still the same trace.
Something I haven't measured that comes to mind as I write, is the frequency of this half sine wave (rookie mistake)
I would be very grateful for ideas/experience/wisdom/sage advice that you might be able to share.
FS: 3 way BMR speakers
For sale again, a pair of speakers built this calendar year. All new components from PE.
1. Inspired by the Philharmonitor BMR, a pair of active speakers with Hivi RT1.3 tweeter, BMR mid and Dayton RS180p-4 woofer. A pair of Minidsp 2x4 for crossover and eq included. Cabinets are 3/4” mdf with solid red oak baffles. The finish on the mdf needs sanding and repainting to obtain a perfect finish. The mid driver is in its own sealed enclosure similar to the Phil, stuffed with eco core insulation. Fiber glass lining plus polyfill in the main cabinet. Baffles are detachable. I am so impressed with these that I plan on building the real version.
Speakers and two 2x4 minidsp. $400 plus shipping from 28901.
Will sell speakers without minidsp if preferred.
All components brand new this year and perfect order.
Peter
Tube Phono stage dilema
HI, having recently redescovered the delights of vinyl I am looking to build a moving coil compatible tube phono stage, for a low to medium output mc cartridge, 0.3mV output.
Previously i have used the first version of the Curcio Daniel, set up in the higher gain option, this comprised a single ECC88 cascode with 100R cathode, and 20K plate load, Passive eq and a further Parallel ECC88 Common Cathode with 392R on each sections cathode and a
20K plate load.
Great sounding, but I found the noise levels not really acceptable for a 0.3mv output moving coil. Not in the long term anyway.
So what to build?
I would prefer a zero feedback topology, all tube if possible. with minimum number off stages
I have considered a hybrid similar to the Daniel, only with a Jfet as the first input device aka Allen Wright, Erno Borbelly amongst others. I guess this would solve the noise and gain issues, but i would still prefer an all tube design
Or perhaps a parrallel input tube like the Steve Bench or Toccata Loesch preamp, or the later Curcio Sarah would just be quiet enough.
Would it be better to build a 2 stage low gain moving magnet RIAA equaliser and build an extra moving coil stage such as the Hampton or MC Hammer , trouble is 3 stages off amplification.
Has anyone tried a cascode with multiple tubes on the bottom section, operating with near zero grid bias?
Any sugestions or ideas welcome
Antique headphone guy
Hi, I'm joining because I am interested in refining my antique headphones, and hoping to find others who share the interest or can provide helpful advice.
Image: My 1910 Wireless Special Apparatus Company headphones with balanced XLR cabling.
I have recabled some sets, and enjoy them on modern amplifiers, but believe there must be ways to combine modern materials and technologies with the amazing design and innovation of these items.
Simulating current feedback issue
I am about to wire up some LM1875s for a subwoofer amp. I know, relative low power for a sub, but it's for my flea amp setup.
I would like to try the current feedback topology instead of the voltage feedback.
So, I try to sim, using a high current output opamp because I dont have LM1875 model. The circuit is modded for 10x higher load impedance so the opamp can drive it realistically.
I have a LCR load in parallel to give a 'difficult' load. I would expect the current feedback version to have a smaller dip in the response, but they seem to be identical.
Why no difference in the voltage vs current feedback.
I must be doing it wrong.
Are my values off? I am giving same gain to easier compare. (EDIT: the feedback res on VFB should be 21400 not 21500 ohms, sorry)
Topping D30Pro: -135 dB harmonics with CS43198
Topping D30Pro Review (Balanced DAC) | Audio Science Review (ASR) Forum
Amir measured -135 dB 2nd and -138 db 3rd. This DAC supposedly uses 4x CS43198. Noise shaping corner is north of 40 kHz, which is maybe the only thing that limits use as a signal generator for mesurements
I didn't really have Crystal on my shortlist for the very lowest distortion DACs. Is the chip this good or did they implement a super nifty circuit?
Edit: the data sheet of the chip does not look all that stellar. -115 dB THD+N typ, -109 max with 24 bit data. With 16 bit, only -94 dB typ, 88 max. What's going on about the poor 16 bit performance? A TDA1541A-S1 was better than that. Can't be noise, so is it distortion?
E180F Preamp
I was looking for a preamp design using a pair of E180F Pentode's and found this on an old website.
My question for the experts is...... from this design what voltage would I expect to see at socket pins 7 & 9 without the E180F fitted.
My transformer has 235 - 0 - 235 outputs and I am seeing 218vdc on pin 9 (Grid 2) and 303vdc on pin 7 (Anode) offload. Is this not on the high side when the E180F datasheet states a grid voltage of 160v (400 max) and the Anode should be 190v (400v max)😕
Cheers🙂
Delta linear PSU modules
Hi, these were bought in a lot by me. They are older but unused as these were kept as spares for Röntgen machines but none broke down 🙂 As can be seen they are +/- 12...15V 0.2A and 1 x 5...6V 1A.
Quality of Delta stuff is excellent and these practically never break down. Official data sheet ripple/noise figures are 0.5 mV ripple/noise till 20 MHz but they are more silent. A good transformer is used and only the bulk cap is electrolytic. The circuit is discretely built around a MOSFET pass transistor and it is LDO which surprised me really. I changed the bulk caps on a few but the old cap was OK so maybe unnecessary. The 5V version only has 1 x 10,0000 µf 16V cap which I replaced for CDE 381LX in a few I use myself. The other caps are the famous Philips Solid Aluminium which are very good. Both 230V and DC connections are made with flat AMP connectors.
Good for upgrades of digital stuff with A quality linear PSU's. In a DAC they can supply both the output stage and the digital part. I haven't found the opportunity to check if the 5V can be modified to 3.3V.
40 Euro a piece so a PCB with 1 x 5U15-15 and 1 x 5U5. Ex shipping. Within Germany, the Netherlands, Belgium, France I should be able to do it for 50 all in.
NO shipping to the UK (30 Euro!!) or outside EU.
For sale Asus chromebook c223na
Brought this new from Amazon at the end of March to have a go at streaming music and is no longer needed.Only used a few times so is as new condition and has been reset comes with everything that came with it including box.Cost me £197.00 will be looking for £160.00.If interested pm me.Uk only.
https://audioabattoir.s3.dualstack.eu-west-
[IMG]https://audioabattoir.s3.dualstack.eu-west-1.amazonaws.com/optimized/3X/8/7/876d6b91752f57e69465770a3c51426c74ef84c4_2_552x500.jpeg1.amazonaws.com/optimized/3X/b/b/bba0be6501e7dc4c86346e377340cf0ab52449eb_2_690x490.jpeg[/IMG]
Tube horizontal mounting position
Hello Gents,
I am preparing to build an amplifier with several different tubes. Because of the enclosure that I am using I am forced to mount the tubes inside the enclosure in a horizontal position. I have looked up the datasheets for the tubes that are involved in this project and I found that most tubes can be mounted in any position, the only tube I could not find this information for is the PL519.
The tubes that I will be using are: ECC83, 8CG7, 6080, EL84 and PL519.
Can the PL519 be mounted in any position as well and are there any general guidelines in horizontal mounting positions for tubes?
A NAS+HTPC+RoonCore+HQPlayer build, all in one ?
Dear Members,
I have a PC and the intention to use this as a HTPC.. (Basic cinema in stereo, focus is 2-ch audio use with TV off).
- Then I thought why not use it as a NAS ?
- Then I got familiar with Roon.. why not build a Roon Core ?
- Then I saw HQPlayer's capabilities (crossover building) - why not using that for a fully active & digital filtering & Room correction ?
- Then I saw it can be combined easily with Roon, in such a case Roon is feeding HQPlayer with the stream of choice and puts HQPlayer into a dedicated Zone - that simple. I only want digital crossovers and all that magic for that main hi-fi, so 1 zone is enough with HQPlayer.
- Price seems to be not that small, I try to overcome this. Roon is one thing but HQPlayer itself is also a couple of hundreds..
Anyway. I decided to do all that.
The hardware is right now:
- ASUS TUF B450M-Pro Gaming (mATX)
- AMD Ryzen5-3600 (6C/12T)
- 2x16G Samsung DDR4-2400 unregistered/unbuffered ECC UDIMM
- 1x GeForce GT710 (passive)
- 1x Intel 250 SSD
- 1x 500G Samsung SSD
- 3x 8T Seagate Ironwolf (NAS) HDDs
- 1x Topping E30 DAC via USB
Functioning as a desktop rig+NAS combo, no gaming.
Software is (right now):
- Debian Linux (Testing)
- KDE Plasma full
- ZFS on Linux, 3x 8T HDDs encrypted with LUKS2 and ZFS raidz1 (raid5-like) on top of that
- QEMU/KVM virtualization, I sometimes fire up my Windows10 if I need to use Windows programs which won't run on Linux at all, not even with Wine. I also play around with several other Linux instances, learning stuff etc. (I'm an IT guy).
To-Be scenario:
- I'd replace the GF 710 with some more recent nVidia, with at least CUDA Compute Capability level 5.2. I run proprietary drivers from nVidia, not the Linux-shipped nouveau so I hope the best here with let's say a GTX 1030 or better (with compute capability level > 6.1).
- I'd use HQPlayer with CUDA offload
- I'd set up a Roon Core of course
- not sure if I want to put the Roon Core into a virtual machine or just run it on the host OS itself.. probably host.. it won't compute that much I assume if HQPlayer is doing the heavy lifting anyway
- I have a second home far away, with good internet at both locations. I would connect the routers via OpenVPN and try to have one network be seen by the other and vice-versa, so from my Summer location I still will be able to control the main location's Roon Core via my phone (sitting on WiFi) while that Roon Core is streaming to my remote location's Raspberry Pi4 via this site-to-site VPN connection.
- occassionally I might watch Netflix or other movies, not sure if in that case digital crossovering can be applied System-wide, not only in HQPlayer itself, else I can forget watching movies. The main purpose is audio 2.0 of course.
For all that I think above config should be a good start.
What do you think ? Is it a feasible story ?
Furthermore, if I'm going 3-way active with 3 integrated stereo amplifiers (or 6 little monoblocks), I assume I'll need either an Octo DAC8 8-ch DAC, or at least 3x USB DACs (like my existing Topping E30), right ? Given these Toppings' price/performance ratio and the amazing sound of these AKM chips inside, I think it's still acceptable from cost point of view.
Would you change something ?
Any ideas or opinions are welcome. :worship:
Preamp torture test?
While back in a different thread i was talking about a modified whammy circuit i came up with, that was even before the simulation physicalized on a breadboard by me with subjectively excellent results.
I recently turned that into a full blown preamp and have been visiting local hobbists for an audition. However last weekend it ran into a problem when connected to an old sansui amp. One channel went into oscillation, dc spike to the rail and almost blew the amp and the speaker!
I know the sensible thing to do now would be to actually learn simulation and catch the mistake in digital domain, but i also wanna solve this issue physically since the circuit is already built.
So i'd like to ask what kind of test jig i can build for a preamp output that will torture test the circuit. A massive cap to the ground, perhaps?
Voltage Regulator Tube with MOSFET Follower for SEP Screen Supply
I am working on a SEP amp with the 6BG6GA tube. To regulate the screen supply, I have a pair of 0D3 VR tubes in series to provide a voltage reference to a MOSFET source follower:
attachment.php
It seems to work fine on the breadboard, but I have this little nagging voice in the back of my head wanting to stick a resistor between the source and ground. I know a MOSFET does not care where the ground is, as long as the drain is higher than the source, and the gate is somewhere in between. Should I stick a, say, 300k resistor from source to ground to ensure that the MOSFET is always on, or should I drown out the little voice with a bunch of fermented beverages?
Conversion to Balanced
I have Two Sources that are both produced with Valves.
One is a Valve Input>Output Phonostage.
One is a Valve Output DAC.
I am having later this year my Mono Block 845 Power Amps converted to being a Balanced Amplifier.
I am also changing tack on my Korg B1 build and it will be produced as Balanced Design.
A Second Board has been ordered.
I have not raised questions about the following until now.
The Phonostage is in a sealed box, almost impossible to gain access within, without being destructive.
Are there options available to produce a off board Balanced Output for the Phono Stage to operate as Balanced ?
The DAC is an easier to work with Device, as the Internal Workings are easy to access.
What are the difficulties to be met to successfully convert the DAC to Balanced Output ?
Any thoughts shared will be very appreciated.
Ultralinear with zener on the screen
This may have been covered before, but my search was useless.
Last night I was discussing Ultralinear output stages with a friend of mine and he mentioned using zener diodes to drop the voltage on the screen. This could be important if driving a vintage 6550 or perhaps a sweep tube. This reminded me of an old article in Sound Practices which I looked up:
from "The Classic Williamson 1993 Style" by Bill Kleronomos (Sound Practices #4)
"An unusual method of applying active screen voltages to the tubes is used. Instead of the usual dropping resistors, I used a set of 5 Watt Zener Diodes for special benefits : screen voltage is always held at or below manufacturer's recommended value regardless of screen current. Distortion products are materially lower because of the stiffer screen supply provided by Zener regulation - this is especially true for the EL-34 pentode with its wider ranging screen current than the usual beam power tubes. And less screen voltage requires less bias voltage and therefore less peak signal voltage from the driver at max. output. Bench tests with EL-34s and 6550s in the output sockets confirmed an approx. 20% reduction in THD when the original dropping resistors were replaced by Zeners."
Thoughts? I was going to give this a try on my current amplifier I've been playing with. I haven't seen anyone else use zeners in the UL taps like this.
I2S(via HDMI) hat- how to play MQA?
Hi everyone.
I recently bought this
RASPBERRY Pi AK4118 Coaxial I2S Optical Digital Interface For DSD DAC Sound Card | eBay
RPI hat so that I can switch from PC to RPI not having to pull out the USB cable from PC and put it back to RPI.
My plan was that I keep USB connection to PC and connect my DAC(Topping D70S) and RPI via either SPDIF coaxial or I2S.
Then I would just have to switch my DAC's setting from USB to IIS, except that I still have to connect power to RPI everytime...
As I have never tried I2S connection, I tried I2S first.
It worked - somewhat unexpectedly, as I have expected many troubles because I am relatively a total noob doing RPI FI.
But, just then, I realized that although I have succeeded to get it work by selecting 'generic I2S DAC' in the volumio's playback setting,
when I play MQA songs on my ipad's mconnect upnp app,
my DAC's screen was saying it was on PCM, not MQA.
Will there be any possible way to play MQA with this I2S connection?
My Topping D70S DAC supports MQA, and when I use USB connection, it plays MQA without any problem(volumio set to 'no I2S DAC' and 'Topping D70S' automatically selected).
Well, in fact not without any problem, because when bitrate changes for various MQA songs, I have to replay the song several times as often there is no sound.
If you have any idea whether this is my DAC's fault or TIDAL's fault, it would be really appreciated too.
Anyhow, have anyone successfully played MQA with RPI via I2S coaxial/optical/HDMI I2S hat?
If so, please share your setting/experience/how-to.
Arcam Alpha 5 Power supply query/concern
Hello,
I have posted this in relation to the Alpha 5, but it probably applies to many other amps.
I have just replaced the blown SMF045 Mosfets for IRF540Ns on one channel and set up IQ on both channels for 4mv across R1 and R101 as per service manual and amp works fine but I am concerned about the power supply voltages (and why Mosfets blew in the first place). Please can anyone advise or assure me.
My mains voltage is 249 AC which results in transformer output of 29.3-0-29.3 AC. After rectification and smoothing this becomes +39.1 and -39.1 against the service manuals indicated +37 and -37.
Regulated + 15.1 and - 14.7 volts for the preamp and tone stages are provided by 7815 and 7915 regulators with no heat sinks which are running very hot. The inputs to these are +34.3 and -34.7 which seem uncomfotably close to the 35v limits. Should I be worried or is this within normal design tolerances?
Peavey Bandit 112 Schematic? 1990s
This is the Solo Series with a teal stripe.
Bought this at a local auction and could use the repair manual if anyone has it.
I noticed on another thread that Enzo gave the email for Peavey and I just also
emailed them.
Power amp works from the return jack but nothing from the main input clean or
drive channel.
This is a seriously nice amp with a 12" Scorpion speaker.
Pete B
Faital Pro HF10AK Reistance(RE)
Hello there, first time here with Faital Pro CD's and wanted to ask a little question on this compression drivers.😱
Just decided and pulled the trigger on two of this HF10AK's since all the positive reviews and that TD-2001 performance similarity, however one has a RE of ~6.3 Ohms and the other ~5.8 Ohms(tested with a cheap DMM), I though considering the price of this CD's I would receive a matched pair or at least close, but that's not the case.
Also not having much luck with USPS lately either, the box was smashed on one side like if they were dropped:cuss:, and its clearly visible on the small HF10AK's packages, luckily they had a nice foam padding there, not Part Express fault though.
Hopefully this is no big deal as I will using them with DSP, and not worry about RMA them.:apathic:
P.S. they will replace a pair of PRV D280Ti-B on LTH102.
Edit: Will do some quick REW measurements side by side and see how they compare though.
Sorry for my English.
Regards!
EDIT: I spoke too early in my last post, I'm currently under an RMA process with PE since the 2~3dB drive sensitivity difference gets even worst(4dB+) the higher the volume becomes, effective smearing/unbalancing the audio image completely, definitely an defective unit unfortunately.
Audio Control DM-608 Hissing :(
I bought this for personal use. This should be a high-end DSP. AudioControl has been around forever and so I put some trust in them. Has the bluetooth module makes it a better value/expense. Id say this is $800 worth of DSP that I am planning to use personally.
The dang thing has a wicked hissing out of all speakers in my truck. When I physically bypass this DM-608, there is absolutely no hiss what-so-ever.
There are jumpers for ground setup. I tried all three positions (200ohm, isolated, grounded). I also tried 5v vs 10v, and the 10v is even way worse. Unbelievable.
Here is a photo and description from their site on the jumpers:
Where are the jumpers on my DM-608? | AudioControl
Device is using about 20+ JRC4560 opamps.
Device is wired to good distribution blocks like all other amps.
The only way I was able to marginally reduce the hiss was via software, where I notice the hiss only seems to be through the output stages. I was able to bump the input to +12db which adds no additional noise, and then reduce the output stages by -15db. Then the hiss practically goes away but that sure is messing with available bandwidth of control (clipping etc). Plus the hissing is STILL slightly AUDIBLE.
Head unit at all volumes. In fact, I can UNPLUG the head unit at the DM-608 and there hissing is still there. I'm 100% confident this device is causing the entire problem.
I cant believe it especially since this device cost quite a bunch. Anybody have experience with these Audio Control DM-608 DSPs? I'm about to go back to my Rockford DSR1 if I cannot find a solution.
Can a 70's Receiver Compress to Enhance Bass?
I have an old receiver that produces some of the nicest bass and midrange I've encountered, though not the ultimate in accuracy. The sense of almost endless, rumbling low-frequency extension and smooth, relaxed midrange made far superior gear sound thin or uninteresting by comparison. I have a $4000 amplifier that doesn't even get use because of it, and others sold off.
I could never replicate the effect using a traditional digital parametric equalizer, so I'm entertaining a possibility that the receiver could behave like a compressor as a dynamic means of frequency response shaping.
I captured some casual measurements with REW. The levels of these measurements were normalized for comparison, since they couldn't be taken at the exact same levels. Measuring the amp output required a voltage divider network, while measuring the preamp output was done straight to a mic line in, so the levels were different prior to normalizing them.
In the first graph, the power amp section, pre amp section and the two together were tested between 0.5W and 1W, normal listening. Nothing special about the preamp section's response. I wonder if a condition, such as the input impedance of the power amp section was better suited to the preamp's output? Viewing the violet curve, the preamp has more extension when it's connected to the power amp section, but I can't compare levels to see if the response may have been compressed to extend it:
In the second graph, the measurements were also taken at slightly different levels and then normalized for comparison. We see the baseline amplifier reponse again (green), then the amplifier was operated with a real 3-way speaker load (brown). The response follows the speaker's impedance curve, due to the amp section's higher output impedance. It's also like something occurs between the pre and amplifier. I just don't know how to analyze a signal for compression.
Has anyone encountered a low-frequency enhancing behavior like this?
One wouldn't know it rolled off in the bass and would believe there was a 9dB tilt in response, though it's only 4dB as measured.
tiny open baffle, ribbon+woofer w/ low digi crossover. bad idea?
I was hoping to get some input on my first build, which I fear might be too weird to pull off. It's a desktop 2 way open baffle using a ribbon + woofer and DSP crossovers. I've never made a speaker before but have done a share of complicated DIY projects (drones and go-karts). After being blown away by a pair of spatials I thought I'd finally try my hand at a OB speaker, since according to the great Linkwitz, an OB is very hard to screw up.
For a tweeter with dipole behavior I picked up 2 dayton mid/tweeter ribbons that go from 250 to 20,000hz and a 4" aluminum woofer picked for flat FR, low group delay, and relatively high excursion for DSP purposes
Since I'd heard low crossovers are desirable the plan was to get the ribbons to cover down to ~500hz (or lower if possible). But since I heard crossovers can be the achilles heel for a speaker I opted for a minidsp which would split signals prior to 4-in-4-out 100W per channel class D amp so I could experiment with different crossover points and filter types. I was aiming to make the baffle as small as possible—which I know is detrimental to bass, but with a desktop system with a 4' woofer I'm not trying to dig into the sub-bass regions much at all. I just want some presence in the 100hz range.
With the sensitivities being different I wanted to know whether being able to independently control the gain to each driver through a miniDSP would compensate. My worry is that, should the spl-to-wattage response of the drivers be nonlinear, that there'd only be one gain sweetspot where the drivers would blend. Second, I was hoping to get some input on doing tiny open baffles. Why aren't they done more often? Given that small speakers aren't expected to have bass and that low bass is a common complaint for OB's, I'd figure mini OB projects would be more popular? Do the advantages of OB (less placement sensitivity, more open sound) not translate to small systems?
Finally, any recommendations or warnings? Thanks in advance!
Twisted Sounds TS150.4
Amp is using ZRF70N06 as the power supply fets with 33 ohm gate resistors .
I know the 3205’s are a good replacement
Wondering if the Z44’s will hold up in the power supply since this is a 4 channel amp and won’t see much abuse
Noise trouble with a device using AD1933 DAC
This is for car audio audio application, where I am personally using a device made by Audio Control called a DM-608. RCA analogue 6in-to-8out Digital sound processor. Should be a solid device, it wasn't cheap; but I'm finding its quite a noise maker. Hisses with no input. Hisses on my repair bench too. Hissing can be altered by way of software setting, where the AudioControl software has both input and output gain controls. Lowering the output gain has the best affect of reducing produced noise, but also consequences of inhibiting natural audio.
Output opamps are NJM4560, which some are connected to an AD1933 DAC.
So far, I see all Digital AND Analog grounds are connected including VSUPPLY, VDRIVE, VSENSE - which are all also connected to output RCA shields (All 8). Ground -CAN- be isolated from device's general power supply ground as an option, also direct connected, or through a 200-ohm resistor (3-way jumper setting), but all of the first statement not affected by the jumper.
Power supply pins are all also connected, thats Digital and Analog supply pins.
Is AD1933 a noisy device? I'm seeing noise on input pins of opamps, which some are connected to output pins of the AD1933.
AD1933 pin 1 is Right-most-bottom. Near the White little circle.
Photos attached
Thanks in advance
DSP recommendations. Decent performance for less than miniDSP?
Hi all
Purchased a MiniDSP 2x4 and set it up with two-way speakers and loved it. Tried a project with one of the Sure Electronics JAB3+ amps with built in ADAU1701 (same chip, right?) but it wasn't very good, lots of hissing and distortion but I do really like SigmaStudio! I also like having multiple general purpose potentiometer inputs.
I was wondering if you can give me some recommendations, can you get decent performance using the boards you can find on AliExpress?
I was looking at this Media Works board for a 2x4: ADAU1701 DSP Tuning Module/analog 2 in 4 Out (compatible with ADAU1401A)|Instrument Parts & Accessories| - AliExpress
I'm also looking for a 2x8 board for 3-way speakers:
ADAU1452_DSP Development Board Learning Board|Instrument Parts & Accessories| - AliExpress
I know some of you have tried these, is it a case of 'get what you pay for' and go with a MiniDSP for HiFi?
Also I'm curious, how big of a jump is it to go for something like a SHARC processor with FIR filters?
Tadeusz
Life after AD1865
Hello,
In the last ~ 10 years I have built a few DACs. A NOS PCM63 was quite good, I had TDA1541. I had several versions of these, different feeding, different output. A few years ago I have settled at the AD1865, fed buffered from an RPI and Moode/Volumio, output to a resistor than a Lundahl interstage transformer, than triode output stage. Power amp is a 2A3 PSE.
I had some (not very expensive, about under 4k EUR) commercial DACs and those could not beat it. On the other hand, I never had a top line DAC compared to it. I never had an ES9038 listened to.
I know the question is more complex, the DAC chip is just one thing. But, if you assume similar surrounding, do you think if I would replace the AD1865 section with an ES9038, would that be better?
The reason why I'm searching, I can not say that I enjoy listening through the DAC as I do from LP. I spent a lot of time to reach the level of a really good CD player (what most commercial DAC just can not do I think), but far away from the LP. I know it is a different world, but still, why not keep trying to reach further? Also, when I listen to high resolution audio (O.K., my DAC ignores above 18bits, but keeps up with high sample rates) of the same record, the difference is marginal sometime. Not on those high res demo records where it is so obvious, somehow they made it very significant, but on a general record.
So, do you guys has any suggestion?
Which DAC chip is considered to be the best on the market nowdays?
Thanks,
JG
Help wanted to my order from THAILAND
Hi
How in the title I wrote I would like to order a set of PC boards (only can find from Thailand) for my next DIY project.
I contacted to the seller on FB everything is fine but he does not take Pay Pal as a payment and he does not want to ship abroad. 😱😱
Please if live in Thailand and would like to help me out contact me or leave me a PM. 🙂🙂
Thank you very much.
Greeting gabor
2.5-way, 2x 5", 1x 1", crossover frequencies?
Hi People,
I've built a fully active 2.1 - 2.5-way System with 2x Gradient W130 AL + a Monacor DTM 104/8 Tweeter left & right. Each chassis is powered by a LM3886 ChipAmp. As Crossover I use the EQ APO via my PC and an Asus Xonar D2X Soundcard. For the lowest Tunes there is a 12" Mivoc AW3000 Subwoofer, driven by two TDA7293 in parallel.
For my uneducated Ears, this all sounds pretty well, but I'm a complete Newbie and I'd like to hear YOUR Opinion. Where would you set the Crossover Frequencies, and which Crossovers would you choose?
best regards
J.
Troubleshooting an Alpine MRV-F352
Hello diyAudio,
I'm trying to troubleshoot an Alpine MRV-F352 5-channel amp, as per the title. I've searched and read through the other threads here and on other forums and haven't found anything that matches the issue I'm having.
Although it powers reliably, the audio cuts in and out of all channels: a second on, a second off. I've tested all the electrolytic caps with an ESR meter and replaced a few that read bad. Before I did this, the signal was extremely weak and crackly even with the gains maxed. Now it plays clearly with the gains at the setting marked "Nominal", but still a second on, a second off.
I believe the power LED is designed to go red if it's entering protect mode, which it does not do; it powers with the ignition switch and stays solid green while my truck is running.
The same speaker configuration plays normally with another amp I have, so the issue doesn't seem to be in the speaker wiring anywhere.
Given that the signal cuts in and out regardless of what output channels are connected, I suspect the issue is in the output stage or the EQ board, which is a separate unit from the main amp and power supply board. I've cleaned all the pots and switches with naptha and cycled them several dozen times each.
Any suggestions? I can post photos of the board if that would be helpful, there's not a lot out there for this amp.
Thanks!
Ideal coverage angle for outdoor movie viewing
In Sound Reproduction, Floyd Toole says:
"The optimum difference between the direct and reflected sound fields is about 3 dB for speech, 4 dB for a mixed program and 5 dB for music.
A good loudspeaker for this purpose would therefore be one that has two qualities: wide dispersion, thereby promoting some amount of reflected sound, and a relatively constant directivity index, so that the direct sound and reflected sounds have similar spectra... An associated requirement of considerable importance is that at least some of the off-axis sounds be allowed to reflect" (p. 186).
It seems tough to come up with an ideal design in the face of this for an outdoor system. I'm working on a unity horn design for my backyard, for movie viewing with 8-10 people. In the likely orientation, the sides of my deck will be to the left and right of the horn mouths. In other words: not much for sound to reflect off of. How should an ideal design deal with this kind of environment?
My audiophile friend told me off for having a volume pot in my tube amp!
I was like WTF, how do you think im supposed to control the volume?!
He said I needed a "line stage" (i was always planning to build a tube preamp, but he claims a line stage is something different)
Anyway, the amp works fine enough on its own with most digital sources, but will likely need some form of line level control, particularly with phono input.
He tells me the volume pot will screw up the sound quality, but looking at all the schematics I can see, there is typically only one way to install a volume pot and all the line stages I see simply have the pots across the input end and ground with the wiper attached to the grid of the tube.
I dont know what he is on about, but most audiophiles seem to get OCD about less components in the signal path anyway, so if im not using a "line stage" shouldnt he be happy? lol
One thing I must say is I do hear a little mains hum if you put your ear to the speakers, at different volume levels, the noise can either change or almost go away, it seems to be the most quiet when the volume pot is turned up to about half way.
All the cable is shielded to the pot and the grids, so not sure where its picking it up from, but the pot wont be creating the noise.
Paraflex Speaker Design
Hey everyone! just wanting to gauge the crowd here on what yall think of Paraflex subwoofer designs. I am pretty new to the technical side of speaker building, but have been enjoying big subwoofer sound systems for a few years now.
Just wanting to see what peoples thoughts/experiences are on performance of Paraflex designs vs say Front Loaded Horns or Bass Reflex subs.
I am looking into building some Paraflex Golden Formula C-2E 1x18" boxes as they have interesting looking frequency range and performance with a relatively simple design that seems doable with my skills and tools. However I have not yet had the chance to actually hear these to see if they are really my cup of tea so to say, and the only way I have been hearing about them is through the paraflex facebook page which gives them heavy praise (with an understandable bias).
Goals of this system would be to play low bass dubstep/DNB and will be paired with JBL SRX835p tops.
I have heard from some that believe the Paraflex designs to sound 'noisy' and 'honky' but others who just love em. So really just trying to gauge the crowd and see if others who have experience with these would like to share.
Hope I am doing this right, and will change the post as needed if this does not fit the forum, or needs to be posted somewhere else.
Thanks yall!
-JahManSurf
Characteristics of drivers with wide impedance curves
Just like the title says - drivers with wide impedance curves. It might seem like an odd question, but I've noticed some drivers, tweeters especially, have very narrow impedance peaks while others have very wide ones. Some are so wide they resemble an equilateral triangle. I've noticed it's usually the more expensive tweeters that have the wider peaks.
What is it about them physically that widens their impedance peak? What effect does this have on their sound (if any)?
I've noticed in passive crossovers the impedance peak is avoided or notched out. How would you notch such a wide peak? If you didn't and instead used an asymmetrical crossover (2nd order on woofer, 3rd tweeter), assuming that the impedance rise had the right slope and also over the right octave, could the 3rd order on the tweeter become a second order and integrate well with the woofer? (also assuming the tweeter frequency response was flat to impedance peak)
Looking for 12” sub driver for 70l
I’m looking to build a high sensitive sub in a 70l cabinet. The front baffle will be 38x60cm so 15” is probably difficult so I’m looking for a nice 12”. Music primarily. I will build two for stereo and have a separate 19” stereo PA amp of 2x200watt to run them, active xo 80Hz. Front ported. Budget is perhaps 300-400 eur for the driver pair. Room is currently around 25m2 but plan to move to something bigger. With a 70l is PA drivers perhaps most suited? I had a Cerwin Vega Stroker 12” many years ago which I liked even for home use but I prefer 8 ohm for home. I like rugged alu diy cast frame not bendable steel. Advice?
Turning an old stereo amp into a power amp with 12v trigger
Hello diyaudio community!
New to the forum, was wondering if maybe you could help me out or point me to the right direction.
I have an old akai am-49 stereo amplifier that I absolutely love and in a couple of months I will be moving to a new place where my audio setup would require a power amp.
Now i would hate to just decommission the akai since it was my dad's ... So I was wondering if there would be a way to use a 12 trigger in modification and maybe bypass the volume?
I have the service manual with schematics and everything if anyone is interested.
Thanks a lot!
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,738
Members
7,886,221
Messages
Filter
Forum Statistics
Threads
406,143
Messages
7,886,221
Members
507,738
Latest member
Tatsuyadono
