Threshold and InConcert interconnects
Has anyone experienced or heard any of the InConcert cables that were manufactured or distributed under parent company Threshold at the time? It seems InConcert manufactured or distributed interconnects and speaker cables. Though familiar with InConcert's distributed WeberWire speaker cable, I searched the internet but could not find any other information on InConcert cabling -- namely interconnects -- though there is ample information on the Phantom Acoustics Shadow, which InConcert distributed. I never came across the interconnects for sale after several years of searching. It would be interesting to hear how the interconnects and speaker cables, supplementing the WeberWire line, complement Threshold amps and preamps.
Matching solid state preamp to OTL
Good evening,
in order to build an OTL to drive the LCD-2 (at the specific request of a friend) I was wondering if it was possible to create a low impedance circuit for headphones with e.g. somenthing like SRPP, WCF, etc. with suitable tubes preceded by the "external" preamp stage.
That is, he would like to use a good solid state preamp he owns. He doesn't want an OT amplifier, only OTL.
Yet my doubts are 2: being the headphones at 70ohm with such a thing it will result in a mediocre damping factor, unless you introduce a decent feedback. And then they are headphones that require no low current.
Moreover, usually tube pre-amplifiers are usually preferable followed by s.s. power amplifiers (there are also examples in the opposite way, but as far as I know they are few in comparison).
All that is a good idea?
Problem with an Advance Acoustics MCD-203 CD-player
Hello all,
I´ve got an Advance Acoustics CD player type MCD-203. It is a well built player, with an analog output with tubes, designed in France and built in China. But the digital board, with the DAC and drive electronics seem to be very cheap, of the kind in cheap DVD-players, but this board don´t have the components for the video signals equipped.
My problem is that there is a noise in the output when the mute disengages, regardless of signal when playing or in pause. The noise is maybe -40 dB, havn´t had the possibility to measure it yet.
The DAC is an AD1853, and the electronics are of the type with a buffer, so the disc is spinned faster than a normal CD-player. At the moment I´ve no access to my osciloscope, so I want to ask, if anybody may have an answer to what may cause the noise. I have reflowed the dac and main IC type MT1389QE. Maybe the buffer memory, a K4S641632H can cause this problem?
So if anybody can have a clue or answer, I´d be very grateful. I have a good knowledge of electronics, and access to all needed tools at work, but don´t want to start doing the faultfinding at my work, if you understand.
Thanks in advance,
Seppo from Sweden.
Two Toroidal transformers vs. One with four secondaries for dual mono?
Hello,
Looking to build a dual mono power amplifier that requires a 600va dual +/-50v PSU.
What is the difference between using two 300va toroidal transformers with dual 35v secondaries to two PSU boards vs using one 600va toroidal transformer with quad 35v secondaries to two PSU boards?
Does it make a difference?
Or do you really need two separate toroidal transformers to be true dual mono?
Thank you,
David.
Throwing an idea out: Corner sound bar with 7.2HD 1/4 wave?
Before I go into analysis paralysis - am I barking up the wrong tree with this idea is the man aim of this post.
The TV sits in the corner and on glass corner stand at the moment. I've been eyeing up the concept of making a sound bar but combining a 1/4 wave into the mix. This would be a simple stereo TV with whatever amplification I have around. The pyramid of the corner is roughly 0.7x0.7x1m by 0.6m deep. That gives a total outside volume of 147 litres.
If the 7.2HDs are 100mm cone diameter and a 35Hz is about 2.44m long QW, then the volume is about 19.16 litres. Which, in theory, would give plenty of space within 147/2 including 18mm or double up 12mm for the walls. A QW TL could then be spiral wrapped inside the volume. I suspect that each corner would then absorb energy thus you end up with frequency peaks?
The room is not that large - about 5m by 3m, so the sound is likely to be quite unpredictable.
I have an "imposing" (read not in the house now), pair of Castle Harlechs so I'm happy with quality of extension rather than quantity.
Advance Acoustic mcd-204 board replacement
My mcd 204 still doesn't recognize discs after having changed the laser pickup today
I guess it is the board that controls the laser, as suggested by the importer's technician by phone.
Board would cost me a lot if bought from importer's warehouse, so I ask myself if there are other sources for this as it is a chinese product, or if there is something to try to repair it.
EOI - Power tools etc for the Loudspeaker builder - Newcastle NSW AU
SOLD
Before I list this stuff on eBay, there may be somebody who is a Loudspeaker builder who would be interested in these items as a bulk purchase. Pick up only from the Newcastle NSW AU area.
Makita 3612 Router with selection of bits
Makita 5740NB Circular Saw with additional used blade
Jantzen Router Guide 014-0300
Progrip 50" FM-50N straight edge / fence with Router Base FM-14
Dick Smith Q-1559 LCR Meter
All items in very good condition and the Makita items are from their trade range. There may be more items that I'll throw in after I go through the workshop.
Right or wrong!?
Wondering if both of these are correct or not and in that case why?
Question came to me since I have trouble balancing positive/negative sides and want to know if the transformer in the example HAS to be center tapped in this application or you can use a transformer with only single secondary without center tap? (picture borrowed from; https://www.circuitstoday.com/dual-adjustable-power-supply-using-lm-317-lm337 and redrawn by me)
SG should be Star Ground connected directly to main ground and do I need to connect the SG to be able to adjust positive and negative side?
Dayton BR-1 help. Have only cabinets and want high efficiency build
So... I have lost the components box to a set of Dayton BR-1 and have only the cabinets and the foam. I'm a speaker building newb and usually only go for headphones but I would like a pair of high efficiency monitors for a desktop setup. The amp that I will use is the Bottle head S.E.X. 2.1 I would also like to keep the crossovers external but that's not a must. I can put together a crossover but would love a PCB if possible. Can someone recommend drivers, tweeters, and a crossover?
Assistance buying CD player in Germany
Hello, I wonder if somebody here, from Germany, close to Herner Straße 4, 44787 Bochum - Bochum-Mitte, could kindly pay and collect a CD player to be shipped to Spain. Obviously, payed in advanced and no rush or hurries, at all. If it's doable, great, if not, then next...😅
I've tryed to negotiate with the german shop, via ebay kleinanzeigen, but he will not ship.
The CD player is a kenwood midi size (34 cm) and these scarce, or at least I don't find them. This particular model has digital output and seems very weel looked after.
Please send PM. Thanks very much!!
Teufel One S searching for unknown part.
Hey Guys,
I`m currently trying to repair a Teufel One S speaker.
I think i found the defective part, but can`t find something when searching for the part marking online.
The part has the marking 4202 and is 3mm on the longest side.
The same part beneath the part im searching is functional:
Pin 1 is down left.
Pin 3: 24V
Pin 4: 2.2khz
Pin 5: 6V
Also soldered to the PCB are:
40P13S MOSFET (Power Rail MOSFET i think)
TPA3118
AUDA1701
STM32
Can someone please take the time helping me find the part number?
4x MTH-46LC with The Box 18-500/8-A
Hello!
I have a question about building 4 horns.
I found picture in the web:
In this picture there are 4 separate boxes for each driver.
I was wandering what would happen to make 1 big box for 4 drivers, like this:
But to save materials not to install RED and GREEN baffles ?
It would look something like that :
And to make it rigid to use scrap narrow scrap planks just to connect bottom and top sides etc...
Will that work ?
I think it would be possible to remove GREEN part without change in response, but what about removing the RED part ?
Is there any way to model this in HornResp?
Thank you 🙂
First PCB attempt
Hi all, looking for some advice on PCB layout, and improvements, it's my first attempt at a 2 layer PCB.
The following is for the IV stage and output for a Denon DCD820 2x PCM56P-L +/-1ma.
After reading the threads I have opted for the OPA861 with the LM6172 as the buffer, as it can deliver a high current if needed.
I've run the simulation in Tina and LTSpice, all looks good. C5/8 & R9/10 are there because the lm6172 requires them in unity gain mode.
I've done a fair amount of research watched quite a few video lectures including Altium and Cadence.
One of the key points was to try and get all the traces on one side and use the other for GND with a clear unbroken signal return path.
I know it may need local voltage regulators depending on where I take the power from, as this CD has a +/- 10V and +/-5V both used on the analogue circuits.
The power rails are 50mils and the signal is 24mil. I'm not happy with the top left as it is not too neet.
Thanks, Tom
Very basic DSD ADC made with op-amps and logic gates
Hi all,
Just for fun I've made a pair of very basic DSD ADCs, that is, sixth-order chaotic sigma-delta modulators that work on the DSD64 or DSD128 sample rate. It tried to construct it out of through-hole components on a double layer board, but some of the capacitors were actually 0805 SMDs because through-hole ceramic class I capacitors in E12 values are hard to get nowadays.
The dynamic range in DSD64 mode is only a mere 80 dB(A) measured with A-weighting and a steep 20 kHz low-pass. That's a consequence of keeping everything as basic as possible: the main feedback DAC is simply a 74AHCT02 gate with a series resistor. I haven't measured the dynamic range in DSD128 mode, but when I just listen to it, the noise appears to drop a few dB when switching to DSD128 mode.
I haven't built the USB interfacing part with the UM245R yet. I use the raw DSD output from U16/P3 (see the attached schematic).
Marcel
  • DSDADC.pdf
    DSDADC.pdf
  • DSDADC.zip
    DSDADC.zip
Panasonic VP-7721A mods
I recently acquired a beautiful Panasonic VP-7721A distortion analyser to replace my ageing Sound Technology 1700B. It has had minimal repair work done, as far as I can tell. A poorly implemented PCB fuse re-repair and a new NiCd battery pack and it is as good as new. Literally. Not only are all power supply Voltages within 1% of published specs, but the oscillator meets it's published distortion specs as well. It is a complete delight to use. Very fast and, FWIW, it looks cool too.
Anyway, I was wondering if anyone has modified one of these beasts to elicit superior performance?
I'm happy to leave it alone, but, well, you know....
Reactions: wiseoldtech
Pensil 10.2 speakers DONE!
DIY Pensil 10.2 speakers are finished! Quite a project saving the bamboo cabinets that simply didn't want to cooperate! I'll be doing a whole article on my web page soon...www.rvbprecison.com
Patterson Industries Canadian speakers
I'm hoping someone can tell me more about a Canadian speaker manufacturer from the 1970s, Patterson Industries. Yesterday I found what appear to be a solid pair of PI 913s in a thift right shop for $30. 8 ohms 5/25. I was just about to take the dive when I decided to wait and try and and gather some info before buying. Anyone familiar? Are there particular characteristics I should be familiar with? Thanks!
mp3 data viewing software
The mp3 file is made up the following way according to this file:
<a title="Traced by User:Stannered, original by en:User:Kim Meyrick, CC BY 2.5 &lt;https://creativecommons.org/licenses/by/2.5&gt;, via Wikimedia Commons" href="https://commons.wikimedia.org/wiki/File:Mp3filestructure.svg"><img width="512" alt="Mp3filestructure" src="https://upload.wikimedia.org/wikipe...estructure.svg/512px-Mp3filestructure.svg.png"></a>
Opening an mp3 file in a text editor results in the following picture. Is there a way to view the mp3 file data values, I have used Audacity, but maybe as a set of values in a text file.
Luxman 38FD Conversion
Hello all,
I have a chance to grab a 38FD for a decent price, well not a 38FD technically but more like an unfinished CL35. What happened was one of the OTs decided to take a vacation and with the scarcity of the output tubes the owner decided to convert into a preamp instead. He had a new custom transformer made by Voller but the project was never completed. I figured there are pre-outs built into the original design so there is no need to even add those, probably just need to complete the power supply for the preamp tube section and tidy up the wiring and it'd be good to go?
Am I right in assuming that's all it'd take or am I wrong? Opinions are much appreciated.
Oh and I'm trying to match this with my Quad IIs. They are current matching with an Audiolabor Pure, although very nice but I thought the 38FD would be a better match.
Aaron
Crestron (ATI) CNAMPX-2X60 pics
Hey everyone:
I picked up a couple of these amps used, but in very good condition.
Earlier, I had posted a thread requesting schematics for for the Crestron (ATI-made) CNAMPX-2X60 amps. I finally got the time to take a few pics of the internals, in case anyone is interested.
The first things that I noticed, compared with my ancient Mac 2105: The bass control is drastically better than my old McIntosh. Imaging is much better than the Mac too. The dynamics are much more lively. And the amps are very quiet. At full volume, I hear nothing through the speakers, even if I'm right beside them.
Kicker 06 ZX750.1
Kicker “Redline” 06 ZX750.1
All power supply mosfets literally exploded. Shielding on top inductor compromised, shielding on bottom inductor starting to flake off as well but not nearly as bad so I rewrapped both cores with 14AWG high-temp 200’c magnet wire, similar # of wraps @ 55 each, 30 on 1st layer, 25 on 2nd layer, to get near spec 135mH rating, ended up near 140mH (side note, idle current draw went from .7XXa to 1.1a after inductors rewrapped and reinstalled, I also replaced all power supply mosfets, a gate resistor on PS side and Output side, bi-polar transistors @ Q03, Q05, Q11, and Q103 and rewrapped inductors. Amp powers on out of protect and idles at 12v/1.1a with no output FETs installed.
Power Supply Mosfets
Gate: +4.25v
Drain: +12v & Square wave
Source: ~
Rectifier In
Cathode: square wave
Anode: +59v
Gate: square Wave
Rectifier Out
Anode: -59v
Gate: square wave
High Voltage Regulator
Gate: +19v
Source: ~
Drain: +12v
Low Voltage Regulator
Gate: ~
Source: -19v
Drain: -12v
Hi Output mosfets (No FETs in board)
Gate: +50v
Drain: ~
Source: +59v
Low Side Output Mosfets (No FETs in board)
Gate: -59v
Drain: ~
Source: -59v
Updated values as of 3/18/21 with DMM checking square waves with Oscope. Perfect square waves up to LM361N before a slip on a voltage regulator caused a very audible fizzle somewhere and now squarewaves on lm361n are gone and 10 Ω resistor @ R260 looks to have a hole and measures 17ohm. Both removed and waiting on replacements.
Thank you for any and all help Perry 🖖🏼
voltage dropping resistors
In a 2 stage SE amp, both plate voltages are both coming off of one B+ source as simple split wires going into the two tubes. Given that the plate voltage for V2 is correct and comes directly out of the B+ without any problem; also given: the plate resistors are correct for both tubes and biasing for V2 is correct.
Problem: V1 needs a voltage dropping resistor and I can't seem to adjust for the correct plate voltage even with Ohms law.
Where is my mistake?
Do I also need to adjust the bias of V1?
Do I need another choke between the two tubes to "separate" their voltages?
Please advise.
Crossover recommendations for 600hz horn and JBL 2225H
Hi! Got a DIY 600hz horn with a 2" Compression Driver (Paudio DE99) and JBL2225H 15" Woofer bi amplified and active crossover by minidsp.
Listening distance from the speakers is about 3meters away.
Looking for some crossover recommendations that would improve the "centering" of the vocals to improve the sound, and a more solid midrange.
Tried out different points and crossover slopes but I keep coming back to HP at 1200hz 6db/octave butterworth and LP at 600hz 6db/octave butterworth.
The one octave underlap between the crossovers is deliberate since that seems to sound the best for me and sounds more "live".
I may be exhibiting a bias since Im a fan of 1st order crossovers so any recommendation would help and I can immediately try it out since I have a minidsp.
Attaching pictures of the measurements and the speakers.
Priorities are dynamics and a more solid center vocal image.
Thanks in advance!
Stetsom HL 800.4 Proteck mode after 2 minutes without signal
hi, good evening I am working with a Stetsom HL 800.4 multi channel amp. which goes on protect mode after 2 minutes even without signal. I Replaced the outputs FETs of same parameters but the problem still the same. There are 4 banks in the output 2 FET each and driven each by IRS2092 , when the chips gets a little hot then it goes protect mode. Are the chips causing it to protect? I double check the FETs and the signal drive on the gates are identical only that there is difference of +or - 2 khz on the frequency readings. Rail to rail is good at +and - 38Vdc. I can't find any faults in the components I believed. Can anyone came to this problem, need help bros.
Paradise phonostage pre-regboard, psu group buy v2
There were a lot more Paradise phonostage boards made than Paradise pre-reg boards, so on the basis that there must be people looking for pre-reg board kits I put the idea to start a new group buy for the psu to Benedetto.
The minimum kick off would be ten pairs of boards, any more than that and we'll run the group buy. There's a decent price break at twenty five pairs.
Benedetto is willing to handle sourcing the parts again and we think we'll be looking around Euro 250, for a pair of boards and all the caps, chokes, coil, resistors and sundry parts. No mains transformers, find your own quiet ones.
We'll know more on pricing as we move forward. If you are interested please add you name and how many sets you require. One set equals enough parts to build two channels worth of pre-regboard.
Converting Crossover Schematic To DSP Filters
I am curious if there is a simple way to convert a crossover schematic to DSP filters? Do I still need to do the whole measurement route?
Basically, how do I figure out where on the FR(DSP) I put the capacitor and what does each electrical component represents. I know the basics that a capacitor rolls off and with a specific crossover type it gives a specific roll off but how do I know what shelf, unity or boostcut is represented on the schematic?
emi filters
Hello,
I am tested various emi filter on the market. And decided to design my own with trial and error method and get very good results better than commercial units.
You can find the test results unfiltered ac line vs my design filtered in the attached picture.
With my design, i got better noise figure than any commercial unit i tested and i tested more than 30 unit.
I am not an filter expert i just make lots lots of trial to find a good solution.
But after all these effort none of mine or commercial units not able to filter under 10Khz noise.
I am glad if any one know any solution or any comments.
hum bucker pot adjustment
I have a Yoshiba 50 SET amp and it has pots across the heaters on the output tubes. I am assuming these are hum buckers and my question is how to adjust them? I guess they could also be for cathode biasing, but I don't know enough to be sure.
Do you just turn them up until the valve emits hum and then turn back a bit, or is it more complicated than that?
My first real SET amp so excuse my ignorance.
Real-time conversion of symmetric signal by software from asymmetric sound card input
My plan is to e.g. there is a balanced microphone and say a phantom power supply and it would be connected with a balanced cable to a standard sound card jack. So e.g. one sign would be on the left, the reverse phase would be on the right. And there would be a program that would reverse one of the phases and perform the subtraction. All this by creating an extra tool that could be selected to be used for recording and streaming.
Low pass filter for subwoofer.
Hi all,
I recently acquired a Sony SA-WMSP87 amplifier which has a mono input, and am needing a low pass filter as I currently only have a 3.5mm to rca jack as an input (homemade, joined L/R connections of the 3.5mm cable together and connected to 1 rca cable along with the ground). The subwoofer only has a mono rca input, so I'm looking for something cheap to use as a low pass filter to cut out frequencies >90-100Hz. Would something like this diy board suffice? - NE5532 LOW Pass Filter Subwoofer Process Circuit Frequency Volume FOR Amplifer | eBay
Something like this even? http://www.ebay.com.au/itm/100Hz-lo...602?pt=LH_DefaultDomain_0&hash=item1c495a3fb2
If so, how would I safely connect it to the subwoofer over RCA? The source is a HifimeDIY Sabre DAC which puts out well enough power for the sub.
I'm quite new to this stuff so sorry if I'm not being informative enough.
Heathkit AR-1500A
Last post I see about Heathkits is dated in 2014 - time for a new one?
I've recently acquired a Heathkit AR-1500A from my brother. I actually built this thing back in February of 1971, and he has had it since. I've recently started 'collecting', so he dug it out of storage and returned it to me.
Does anyone know the whereabouts of a manual for a Heathkit AR-1500A? Of course I didn't save the one I had from 1971. Can't seem to find anything online.
This thing is *HEAVY*. I fired it up to get the dial lights so I could take a picture. Looks pretty good for a 48 year old receiver. Dusty on the top surfaces but clean on the underside. If I don't say myself, workmanship looks excellent! I'm going to be stripping this down and cleaning it the best I can, and then reassembling, testing, repairing any noted issues, and putting it in my collection.
Is there any interest in me posting more of the 'refresh'? If not I won't waste forum bandwidth.
Smallest Footprint Horn and Driver that can reach 500 Hz
Hi guys!
Any ideas on the smallest footprint Horn and Driver combo that can go down to 500 Hz?
Listening room is only 9ft x 9ft (hence I need something compact) so I think I can get away with crossing a compression driver (or fullranger) lower to meet a 12" woofer.
Will be using a minidsp for crossover duties and eq to tame the driver and horn.
I live in Southeast Asia and the only direct couriers we have are in the USA. I dont know if horns.pl or stereo-lab.de can ship affordably to asia. So a US supplier would be ideal.
Resolved - Not being investigated further Cannot delete images from a post when drafting a reply to it
I was trying to quote this post:
https://www.diyaudio.com/community/...ive-15-open-baffle-woofer.380714/post-6882266
The poster added several large images to their post. They take up a lot of room and are not necessary, but I would like to have the text. So I selected "reply" and attempted to delete the image links or references from the OP. They do not delete!
How to do that, apart from manually copying the text into a quoted section?
Martin Logan Sequel ii polarisation transformers
Looking for a source of small step up mains transformers. I have suffered a recent infestation of Martin Logan Sequel ii Electrostatics with lunched polarisation transformers. The incumbents are 115+115->460v on about a 6VA core. These don't feature in any of my regular suppliers catalogs so my McGuyver solution is to use a 6VA 230v-> 9+9v to a pair of 3VA 230v->9v backwards with their primaries in series.
Will it fit ? : YES.
Will it work ? : YES.
Is it an elegant solution : NO.
Looking for a better solution that doesn't involve my Chinese winder and a lot of very fine wire.
coaxial peaveys 115cx
Hello.
I scored a pair of Peavey 115-cx PA speakers at a yardsale.
Curious as I am I would like to make new Crossovers with new fresh caps and good aircores of my own standard....
the crossovers in the speakers now dont have any markings on caps and coils so I dont know the layout- but I do know it is crossed at 1500hz...Or so the sticker says.
Does anyone here have any information about theese speakers?
Thanks!
Audio Analogue Enigma dead display
Hello
I've got a "dead" Audio analog Enigma all in one system and I started to repair it.
The main fuse was dead and the valve (its an hybrid valve/solid state system) was fault on one channel. The fuse and the vavle were repaired and the unit is now working like a charm.
BUT the lcd display is showing some real issues to the point of making it useless.
I've opened the beast and I'm trying to replace it by a new one.
Its' a 16x1 LCD, marked E251530 94V-01. Google gives tons of possibilities and I can't find what could be the good replacement part.
The LCD is soldered on a specific board, but soldering is not an issue for me.
Can you help?
JM
B&O 200ASC ICEPower stereo power amp
Great quality stereo power amp. Very efficient Class D design using Bang & Olufsen 200ASC amplifier modules rated at 200 watts per channel. Very clean sound, very cool running and very compact size. I'm asking much less than the amp costs to build. BTW,the volume knob on the front does nothing, no pot is attached. This is wired as power amp. There are two modules so each channle has its own power supply. Dual mono. And, if you have a mind to you can wire this up to turn on and off based on the presence of a signal. This amp is wired to turn on and off with the power button. Please let me know if you are interested. $190 + shipping from Colorado. The modules are these: https://www.parts-express.com/ICEpo...ier-with-Power-Supply-Module-1-x-200W-326-208
Roundover vs. 45º Chamfer vs. Double 22.5º Chamfer edge treatments for tweeter diffraction.
Hello,
I have always wondered how much difference there was between a roundover and a 45° chamfer. Jeff Bagby once told me to treat a chamfer as a roundover with modeling programs that didn't specifically list chamfer as an edge option.
An edge treatment I have not seen is a double 22.5° bevel, it would seem to be similar to a roundover, but not require a big expensive roundover bit or be hard to veneer.
While various modeling programs allow different sized roundovers and show specific angles, I have been curious to see the incremental difference in edge treatment size as a full range of off axis measurements.
Here are three test baffles that I will be testing incrementally larger edge treatments of roundover, 45° chamfer and double 22.5° bevel with a full range of off axis measurements.
Test tweeter will be a Seas NoFerro 900.
Here are the blanks I will be testing on.
Toyota Tundra audio parts to beat girlfriend's Harman Kardon in her Volvo.
I need help guys! My girlfriend has a premium Harman Kardon audio system in her car. We both love it. She is teasing me about my Tundra's crappy stock sound system all the time. Yes, it is not amazing for sure. I also LOVE clear real sounding music, opera, classical music and hip hop.
My plan is to build an amazing sound system in my Tundra which equals or sounds better than the all around rich, detailed sound of her Volvo.
So HELP ME!!! I am desperate.
My Tundra is a non JBL system, no amplifier and no subwoofer. It has 6 speakers. (2 front, 2 rear and 2 on the instrument panel. no tweeters. )
I would like to replace the stock radio. (Android audio wouldbe great and reverse camera input, the rest I don't care. I just wan to have crystal clear sound...)
Budget: under $1000 or maybe $1500? I am willing to buy used amplifiers, speakers, etc!
Please help a Toyota owner to impress his girlfriend!!!!
Looking for 1933 article - Franklin Institute
I recently got another classic - Fred Terman's* Radio Engineering. I came across a reference to what could be the first documented use of a cascode or SRPP or similar with tubes: The use of a Vacuum Tube as a Plate Feed Impedance by J. M. Morton. It was published by the Franklin Institute vol 216, December 1933.
Posting this in the small chance that someone has a copy and would be willing to share.
Jan
*Professor Frederick Emmons Terman was Bill Hewlett's promotor at the time and later helped him to set up Hewlett & Packard together with Dave Packhard.
QSC HPR152i waveguides
I have a couple of these waveguides (WG) and the Dayton D250P-8 compression drivers (CD). I first tried a passive crossover at ~1.5kHz to Beyma 15LX60V2. Used the Clio system and MLS measurements. I got the crossover to have a distinct 1.5kHz cancelation with the polarity of one of the drivers switched. So I think the phase at the crossover frequency isnt too bad. But it sounds like a pair of old megaphones. The beymas measure ok, but I dont know how well they actually sound up to 1.5kHz.
I tested a bit more with an old 8" woofer using minidsp for crossover. That sounded a lot better. Not honky, but very laid back. A bit distant even.
So I dont know if the problem is with the WG+CD or the combination of woofer and WG+CD.
One thing I also noticed is that the waveguides I have are quite rough. The first inch or so of the waveguide is not very smooth. It is a bit bumpy. Is this normal? Does anyone have these waveguides and can check? I am a bit worried that I got a bad pair of WGs.
🟢 loudspeakers SB Acoustics 4 way Under development.
Olá a todos do fórum!
Há anos procuro sites especializados em muitos projetos de 4 vias mas nada me agradou ou atendeu minhas expectativas.
Por isso resolver reunir pessoas interessadas no mesmo tema e juntos desenvolveremos um bom projeto.
Não sou especialista em análise acústica, mas sou mestre em marcenaria e sou apaixonado por áudio.
muito de realizar esse projeto gostaria com a linha SB Acoustics, separei os modelos:
Satori TW29RN-B-8
Satori MR16P-4 6"
Satori MW19P-4 7,5"
Satori WO24P-4 9,5"
ponto é que a rota outro deve ser fechado
https://www.madisoundspeakerstore.c...ori-tw29rn-b-8-ring-dome-tweeter-black-8-ohm/
https://www.madisoundspeakerstore.c...16p-4-6-egyptian-papyrus-cone-midrange-4-ohm/
https://www.madisoundspeakerstore.c...19p-4-7.5-egyptian-papyrus-cone-woofer-4-ohm/
https://www.madisoundspeakerstore.c...24p-8-9.5-egyptian-papyrus-cone-woofer-8-ohm/
Reactions: wasabii
Nakamichi MCT1 Mods
Dear all,
I'm planning to make some modifications to an old car stereo Nakamichi MCT1 (from late 80´s). Inspired by Lukasz Fikus from Lampizator, my plan is to put 2 Mullard ECC70 subminiature valves on the DAC outputs, creating an analog valve stage.
If that can be done, I want this device to convert the digital signal from other sources, such as a cell phone, multimedia system, etc... My idea is to transform the auxiliary input into a digital input for the Dac, in USB format.
This is the help I need from the more experienced members of the forum: - Is it possible to use a USB interface like the Amanero one, connecting its digital output (maybe i2s) to the Nakamichi's auxiliary inputs, and internally divert this signal to the DAC?
All connections are made via pins located on the bottom of the device support drawer, which fit into the back of the device.
Any help is welcome, and I appreciate everyone who can contribute.
1st issue digital CD releases vs streamed/downloaded later re-issues
Wonder how you guys feel to what I say below?
Playing "original non-remastered" CD's are usually so much better to my ears in dynamic range, than any new (just louder) CD's that been remastered, and that are usually used by streaming/download companies, which have been dynamically compressed.
(but compression does have it's place and is good for "music on the move in noisy background situations" car, iPod, ear buds etc etc)
Original first issues CD's are the best for dynamic range, which gives the music and your brain a "chance to breath", you can't have "loud" if you have no "quite"
Here is just one example of a classic one only made album but re-issued many times of a British–American supergroup consisting of Bob Dylan, George Harrison, Jeff Lynne, Roy Orbison and Tom Petty. " The Travelling Willburys"
Look what happens the younger the re-issues become
Green is good (uncompressed), yellow (fair), orange and red (compressed rubbish)
https://dr.loudness-war.info/album/list/year?artist=Traveling+Wilburys
Cheers George
Yamaha A-960 No audio output
Good evening everyone ! I have this Yamaha amplifier that does not deliver an output signal and when I turn on the relay does not activate! I have replaced all the electrolytic capacitors and measuring with the tester on the 2 pins TP4 and TP3 I have 9mv! Do you know anything about it?
Audio Note Double C-core
Hi all,
years ago I bought these transformer from Tom
https://www.diyaudio.com/community/threads/tubes-and-tube-stuff.126131/post-1559652
I used them, a friend of mine used them, and we both moved to different setups and these OPTs are not needed anymore.
For operation I made an "aluminum shroud", which I can take away, or just leave in place.
I think the current code is T305-3-55-H306H306-S
Who is willing to put them to good use? These are very heavy!
best regards,
Erik
Nakamichi MCT1 Mods
Dear all,
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,714
Members
7,885,551
Messages
Filter
Forum Statistics
Threads
406,104
Messages
7,885,551
Members
507,714
Latest member
sjun1019
