I built a pair of Linsley-Hood 1969 Class A amps and they sound so good
tl;dr: I built 2 Linsley-Hood 1969 amps from kits I bought on amazon, swapped some parts, and they are amazing.
So I gotta be honest, of all the diy audio stuff I get into, I have stayed away from amps because the waters seem so full of snake oil, and also, I'm afraid of shocking my nuts off with 1000 watts of accidental test tone. Anyway, a friend got the hook baited just enough for me to bite, and I bought that Linsley-Hood 10W amp that you can buy on amazon right now. A cute little kit with all the parts, and it's a mirror-imaged stereo PCB setup, to boot.
I built one up, it tested ok, but I wasn't much moved. Immediately suspected that the components that came with the kit were worth testing. One thing I do know is that a good Class A amp should sound super nice and clean, which wasn't what I was hearing. (Whenever I hear a known good Class A amp, I'm usually pleasantly surprised.) I popped out the power 2N3055s and sure enough, the Beta values were all over the map. I bought a bunch of legit ones from Mouser, tested them all (they were great; the beta values were consistent across the entire batch), and installed those, then replaced the coupling caps with better ones. Not like, break-the-bank prices, just good ones from Mouser. Like $8 or so for film and $2 for electro.
Anyway, I put it all together and matched them up with suitable meanwell power supplies and put it all in a little red tool box.
Boys, it sounds freaking great. Really, really good. I haven't even dialed it in yet. Tests on the scope look great. Passes audio beyond 100kHz.
Caladan by Clayton Shaw DIY
Inspired by New Record Day video about the Caladan by Clayton Shaw, I decided to do it DYI since shipping costs to Japan are ridiculous (and no international deliveries at the moment provided). My MiniDSP serves as an active crossover for two ICEPower 125ASX2 amplifiers. They sound amazing, using a Linkwitz-Riley filter 48db at 1kHz and some gain in the low end, Never thought open baffle speaker can have such a lot of low end, while the speaker membrane is barely moving. The speaker disapear and you feel like in a live concert. This works also for my music with distorted guitars, not only for the high end demo music. Bass guitars sound so real. This is the first day listening to them after waiting 3months for the delivery of the 12inch speaker drivers....I guess no burn in needed. Clayton Shaw chose the perfect drivers.....
The construction of a multicell horn
I'll try my best to inspire and to show to you that everything is possible. To do a multicellular horn takes a while due to all different moments but they are all kind of nice and it feels good to see the horn grow with every hour of work.
These horns are NOT a Altec 1505B copy. They are pure exponential with a flare frequency of 183 Hz, the same, or at least what was my and reVintages intentions bacause the throat flare in JBL 2441 and 2445.
The horns are built out of 3 mm Baltich Birch plywood, filled with polyester and the outher sides are covered with polyester and glass fibers.
Enjoy😎
Reactions: decramer
250.8 mains voltage
Hi all, I am considering a 250.8 as a replacement for my current amp - PSA BHK 250.
I am facing a possible relocation to Europe from the US though and will move most of my equipment as well. Is this possible to convert the 250.8 power supply for 220v operation? I did read somewhere in these pages it being possible with a previous version (i think the 250.5) but not sure. All my other gear preamp, DAC etc can have their wiring adjusted for 220v.
Many thanks
Ion Obelisk that will be repaired in the future
I know the nytech well, I know the Ion well, but this one, I can not understand his problem and I'm tired of the disassemble / reassemble to repair it.
one channel works well, the other explodes.
I repair the exploded channel, it is the other that fails, and so on 9 times.
no preliminary symptoms, bias / temperature / stable tension,
then he explodes.
all the transistors have been changed several times, only Philips and ST semi originals, all the diodes changed, all the capacitors, almost all the resistances.
several attempts with transistors of the same family but slower, nothing works, it explodes.
I could see the last time for a split second, the consumption mounted on my meter, I did not have time to note the final value but when I looked it exceeded 1A.
the only thing I did not try is another power transformer, but then I'm fed up, I gave up.
maybe one day in the future, someone will have the same problem and find the solution and maybe he'll post it here.
Introduction
I am a friend of the son of Eric Thomas, who used to own and run Beauhorn. Eric recently passed away and left a number of interesting and unusual pieces of hifi equipement to his family. This included a Tentlabs CD player, which is unfortunately only working on one channel.
Does anyone know anyone in the UK (preferably south east) or possibly Europe that would be able to look at this with a view to fixing it?
Thanks for your help.
Reactions: Drbulj
Hello!
Hi all,
I'm Connor, a Mancunian currently living in London. I have lots of vintage music equipment and have been recently interested in electronics repair and design. I have been on a quest this year to fix all my broken gear, as well as seeing how the electronics work inside the gear. I teach music production at the Uni of Westminster, and have a strong background in studio and live music production.
Kind regard
Connor
Reactions: Drbulj
Opinions on how to take care of this hum?
I received a 6 channel headphone amp from a friend of a friend asking me to take a look at it as a couple of channels have hum on them. I figured it wasn’t a power supply thing since only couple channels had the hum on them.
I took a listen and found that channels 1-3 were quiet. Then channel 4 had a very light hum, 5 a bit louder and 6 the loudest. I felt it wasn’t a coincidence that as you get closer to the power transformer the louder the hum gets. Being these three.
It has a single center tapped secondary winding and each side of the winding goes into a 1N4001 and their cathodes are tied together providing a single rail of 30.8V. So at the cathode of one of the diodes I tapped in with one of my power supplies.
With my power supply running the amp it functioned perfectly and not a hint of hum on any of the channels, dead quiet. So this told me it had to be the power transformer. There is a steel sheet barrier, but I used copper tape help seal any opening and create a better shield. First wrapping the power side in kapton for safety.
This really hasn’t helped at all, maybe slightly reduce the hum in channel 4 which was pretty low already, but 5 and 6 are still pretty loud.
Can anything be done?
Dan
Bose Media Center RJ45 cable pinout
I've recently bought a Bose model AV18 Media Center and its brother PS28 II Powered Speaker System. Unfortunately, I do not have the cable to digitally connect the two items (8pin mini DIN connector on the media center, RJ45 on the speaker).
The cable can be found on ebay (for instance here: https://www.ebay.co.uk/itm/16618116...128FgunGWRBezGQ1UoRQ0p7g==|tkp:Bk9SR7qel_icYg ), but frankly speaking I don't want to spend more than 50-60 EUR for it...
Any idea about the connectors' pinout scheme of both ends?
As usual, thx a lot in advance to everyone 🙂
Which PCB to use?
I have been building tube amps/preamps for years and a few solid state phono preamps along the way (I am an ex CET). I am intrigued by the many versions of the gainclone type of chipamp and want to build one. I see no point in having my own PCBs made with the many that are out there.
The prices are all over the place some too cheap to be true (ebay etc.) and others quite pricey. Not keen on spending a couple of hundred dollars on 2 signal and 1 power supply PCB. BTW I make my own enclosures.
Are there any decent PCBs for the LM**** chipamps available? Or does anyone here have any? I am not as concerned about the power supply
PCB as that is pretty standard.
Thanks!
Amplifier circuit help
I am currently trying to design a portable bluetooth audio DAC, and have made a schematic that I think might work.
I know that the bluetooth wiring works (have tested direct audio from the chip, but not through the amplifying circuit).
I have been getting quite confused on how many capacitors/resistors to use, and what ohms. I want to maintain audio quality/reduce noise, as much as possible.
Am I on the right track, and will the op-amp circuit work? (I haven't tested it on a breadboard, as some of the parts haven't arrived yet).
The raw audio output volume from the bluetooth chip is about half what I would like, so the amplifier circuit should be wired to produce 2x gain.
Everything is powered by a single battery.
Thanks!
Photos of my completed 2-way with Purifi W/M, Beyma AMT, and 2X Passives - Steinway Piano finish
For more than 20 years I have made myself available to Steinway & Sons, when they had questions that were up my alley. So, when I had a loudspeaker design client who was willing to pay, I asked Steinway's outside contractor for special finishes (such as a grand piano in high-gloss Danube Blue Polyester) to do the final finishes on the Richlite cabinets. The front panel perimeters however, got seven hand-rubbed coats of violin varnish. The rear panels, also Richlite, are held on by Silicon-Bronze boat-building screws. Gotta Luvvit. BTW, it's my LS/5.25.
QUAD current dumping class A output power?
I recently encountered a request on another forum as to the suitability of Quad 405 for driving Stax headphones as a Class A amplifier. There seems to be a number of about 10 Watts class A output floating around, based on the quiescent dissipation of the "class A" amp of around 5 watts (which is hopelessly wrong in this circuit). I have long been interested in the circuit, impressionably growing up in the 70's 80's. I dusted off the simulation that I did 10+ years ago, of the 306 circuit. I approximately calculated the class A output into 8 ohms of 100uW of the 306 which has a bias of one diode drop between the basses of the "dumpers".
Unfortunately the thread is in a bit of a backwater of that forum and hasn't been critiqued sufficiently for my satisfaction, of if I am in the right ball park, it is a bit of a controversial claim. So peer review please. I am quite happy for my slightly flippant comment about the bridge inductor filtering out the crossover glitch to be criticised, and I know there is more than just that going on with the bridge feedback, but that's what it looks like.
Cut and paste from "another Forum"
Morning, I too have been fascinated by the current dumping spiel of the 405, and a general lover of pre 90's Quad in general. So much so that I did try and build one when I was young (didn't work) and more recently as a grown up engineer decided to simulate the circuit (of the 306, because the audio is not going through an op-amp). Stable biasing of the class AB amplifier is a problem and the Quad seems to present a neat circumnavigation, hence my curiosity.
Most transistor amplifiers have a class A Vas stage, the 405 / 306 is no exception, except it is a bit beefier and is connected to the output by a resistor of around 47 ohms. The voltage generated across this resistor determines when the current dumpers are turned on. Due to the biasing arrangement that is approximately +- 300mV.
300mV / 47ohms is about 6.4mA.
6.4 mA x 8 Ohms = 51mV
Convert that into RMS about 36mV of class A at the 8 ohm speaker 100uW (if my maths is correct) before current dumping occurs. I don't know what the input impedance of the headphones is but presumably significantly more than 8 ohms and everything works out!!
I have not built or tested a current dumping amp in person, yet, but in my simulation of the 306, the area where the magic happens, in my opinion, is the bridge. The basic current dumping amplifier is a class B (sorry) output stage rescued by feedback, to plaster over the switching discontinuity. Yes the super fast class A amplifier huffs and puffs through its 47 ohm resistor, but the magic happens in the bridge.
The switching discontinuity appears to be filtered out by the inductor. I don't really understand what precisely is going on, but it does the trick. It is a remarkable piece of work IMO, especially considering they didn't have the tools available we have today.
Voltage across the inductor simulating 1KHz 8W.
All comments are for entertainment purposes only.
https://www.hifiwigwam.com/threads/rekindling-interest.124470/post-2529901
For Sale Yamaha C-4 preamp and DAC TEAC D-T1
I want to sell:
- Yamaha C-4 preamplifier - price 400 Euro. It looks very good and in original condition without repairs
- DAC TEAC D-T1 - price 380 Euro. It looks very good and in original condition without repairs
I can send in EU only and the shipping is around 25 Euro/item.
Please send me DM if you are interested or if you need more details.
Vlad
Reactions: pinnocchio
For Sale Marantz CD 50 player, no-oversampling and tube output
I am selling one upraded Marantz CD 50 player.
Is in very good condition and the changes have been made are:
- changed few capacitors from power supply;
- the standard op-amps output stage replaced with tube output stage;
- put in no-oversampling mode;
- changed the decoupling capacitors of the TDA1541 DAC.
The price is 350 euro (shipping included). I can ship only in EU countries.
Please send DM for more details.
Reactions: passive420
Tentlabs CD player repair
Help me with this DSP thing MV silicon BP1048B2 2.1
On the effects is only "2" and "4" the 4 is for the subwoofer, and 2 is for stereo i think(2 and 4 from the total of the 4 outputs of the chip in theory)
I need separate efects for each channels! Not only the "2 " output, otherwise is useless, what to do? 🙁
Bluetooth frankenspeaker with old full range chassis
Hi!
I found two old speakers with fullrange chassis. My idea is to build a bluetooth-corner-frankenspeaker out of them. While I don't think they would be exactly HiFi, I thought the typically warm sound with good point-sourcey understandabillity can be achieved. Subjectively they have a certain quality to them and go quite loud, as proven by feedback. Ooops!
I meassured them in their old enclosures and they seem to have some problems:
There is a huge phaseshift when the small cone starts to load at 1kHz, unpleasant harshness caused by the bump around 2,4kHz (?) and uneven hights, which could be caused by my quick meassurement setup.
Good part: despite the issue around 1kHz, phase response is really nice and it seems to me like they only need an EQ around 2,4Hz (-6dB/Q=1 maybe) to get that pleasant warm sound for a kitchen radio.
Next up would be finally soldering my measuring cable for T/S params, designing a BR enclosure out of scrap parts and buying a china bluetooth-dsp-amp board.
One question: is the phaseshift immanent to that kind of speakers?
All the Best! robo-klaus
ICEpower 1000a
Good afternoon all from a rainy England (summer "eye roll" )
I have 2x icepower 1000a boards with the same issue.
The board powers up ok, however produces no audio. It does not trigger standby or trigger the protection shut down. It just sits there with the peotection circuit happy as Larry just producing no sound.
Is there a common issue on these boards that would produce the same symptoms? As I have 2x boards with the exact same issue.
Unfortunately I do not have an oscilloscope, I am very DIY. I do however have a multimeter and good basic knowledge of circuitry.
TCP/IP to AES3 Converter (STM32 + DIT4192)
Hello everyone,
I'm working on a device that converts audio data received over TCP/IP to AES3 format.
For this, I plan to use the DIT4192 chip together with an STM32F407/417 microcontroller.
The device is intended to support:
  1. Sample rates up to 192 kHz
  2. Up to 24-bit resolution
  3. No audio proccessing is needed
I would really appreciate any help or suggestions, especially with the following:
  1. What do you think about the choice of DIT4192 + STM32 for this task?
  2. Are there any good C/C++ libraries (for Linux or bare-metal) that can handle audio decoding (MP3, WAV, etc.) and output via I2S (my guess STM HAL/LL does the work, but not sure)?
  3. Do you know of any open-source or DIY projects that are similar or could be helpful as a reference?
Thanks in advance!
Reactions: eclipsevl
FET-hex explendit amplifier
Hello
Recently I have build VSSA amp (shaan version bit modyfied) and I am very happy with it.
I had few irfp240/9140 pairs in stock so I decided to build another version (as I am not an expert some upgrades may be needed).
Bellow schematic, board, and measurements. The measurements were done on prototyp board and all components weren't matchet (just taken stright from the box).
Bias is stable, cold amp seted to 100mA (15C) hot amp 92mA (78C), I didnt have irf540/530 so I used irf840 instead. I think that amp can use bit higher power supply than +/-35V.
Amp is playing really good.
Thanks to LazyCat and Shaan
Ps
I was thinking If it would be recommended to leave 0,1R source resistors and put 47R gate resistors instead 100R ?
My sound card is not the top notch and is creating some high order harmonics artefacts (there are present at the same place on different amplifiers measurements).
  • FET-hex ccs v4.pdf
    FET-hex ccs v4.pdf
  • FET-hex ccs v4 top.brd.pdf
  • FET-hex v4 zelazko.pdf
For Sale Salas DCB1 Hypnotize with hotrodded options
I'm selling a DCB1 board with three current bias options: 1.5, 8 Ohm (Caddock MP930s) and 20 Ohm (Xicon 5W) so you can choose between > 850mA, 200mA or 90mA bias current. In my opinion the higher the bias the better the sound quality.
All parts are very good quality mostly if not all from Mouser
All fets signal and psu are original Toshiba's bought from Mouser, the signal ones are 2SK170GR fets ( > 6mA ) closely matched resulting DC offset which starts at 0mV and settles around -2mV and -3mV for each channel
Psu caps - 10.000uf Nichicon Gold Tune KG, 100uf Elna Silmic II, Wima MKP10
Signal resistors - Dale RN60C precision 0.1 % 50ppm
Soldered with Kester 44 (63/37)
135 euros included shipping worldwide. Paypal for friends
Reactions: naca5
How to connect driver with spring loaded connectors
I'm planning to build Troels Gravesen The loudspeaker 3, the drivers has arrived. The bass unit - 18 Sound 15W700, has spring loaded connectors with big holes.
What is the best way to connect the speaker cables, do I just strip the wire and let the spring make the connection, or shall I put banana plugs on the cables and push them through the hole? I feel like this is a stupid question but I want to make sure the cables don't come loose .
There are plastic caps on the top of the connections, similar to speaker terminals but I don't think these are to be removed, as there would be no way to differentiate between the positive and negative terminals.
Hi from Italy!
Hi everyone! I'm Stefano from Italy.
I'm a master student in electronic engineering (relatively) close to graduation. I normally work on digital stuff (digital radios and digital design for mixed signal applications) but I have a long standing fascination towards analog design, with focus on music and audio in general.
I started out with a thrifted Sony AVR (DB840) with thrifted Revac HP 102 loudspeakers. Now I'm working on a malfunctioning Nikko NA-400 and I'm trying to build my own version of the STK465 amplifier module with modern discrete components to make it available to the community since reliable new old stock by Sanyo is dwindling and clones available on the internet come from unknown sources.
Boyuu hifi Equis A10 EL34B+6N2 SE Tube Amplifier with 5Z4P rectifier: review and mod
I admit I was highly reluctant to buy a Chinese product, like most of the people in my country, but at the end I did it, and have absolutely no regrets: this Chinese tube amps is probably one the biggest bargains in the audio world.
Description:
12Wx2 EL34B+6N2 SE Tube Amplifier with 5Z4P rectifier
Official Features:
- Input voltage: 220V
- Power supply: 160W
- Output power: 12W x 2 (ultra-linear connection)
- Frequency response: 20Hz - 28KHz
- military grade dual triode 6N2J as voltage amplifier
- Shuguang EL34B as power tube
- Shuguang 5Z4PJ as rectifier
- THD: <1% @ 1KHz
- Output impedance: 4Ohm and 8Ohm
- Input Impedance: 100KOhm (two input signals)
- Input sensitivity: 750mV
- SNR: >88dB
- Power transformer: 96x50mm 0.35mm z11 using imported 96mm slicone steel plates in 0.35mm thickness,Stack thickness is 50MM to ensure sufficiant power and low heating.
- Output transformer: 66x36mm 0.35mm z11 using 66mm slicone steel plates in 0.35mm thickness,Stack thickness is 36MM.
- Mirror surface stainless steel enclosure
- Diamond cutting corner feet
- Alps potentiometer
- Powder coating transformer enclosure
- Dimension: LxWxH 310×268×165mm
- Weight: 12Kg
- Price c.a. $250.00 + $110.00 shipment (purchased at 300 euro in Italy)
Additional circuital info:
-PRO: really amazing quality/price ratio: this amplifier has without any doubt a superb design for its price
-PRO: The mids are clean and the bass/highs are all there (I'm listening with 16 ohms fullrange loudspeakers). Not too much bright (which I really like), it sounds quite veiled and rolled-off (with stock EL34) but sufficiently detailed, thus there is no way you will get ears fatigue with this tube amp
-PRO: voltage amplifier with triodes in parallel to reduce noise and increase gain
-PRO: hybrid bridge rectifier using a valve rectifier and a pair of silicon diodes. You will still get the valve sound without the harshness of the silicon diode cutoff in reverse bias.
-PRO: choke is used as a power supply filter element
-PRO: Panasonic, Philips and Nichicon brand capacitors
-PRO: all components are well dimensioned and never run hot
-PRO: PCB and very clean wiring
-PRO: safety: the amplifier is internally correctly grounded/earthed
-CONS: the noise floor is quite poor, but this noise is modest and does not at all interfere with the listening
-CONS: missing 16 ohm output
-CONS: missing EL34 grid stopper resistor
-CONS: the inside iron core inductor looks not to be well fixed to the chassis (only from one side), which, I think, could be a problem if you think to a very long shipping distance
-CONS: shipping box content is minimal, that is just the amplifier without brand, marks or labels and no documentation (but this is fully justified by the price)
______________________________________________________________________________________________________________
MAJOR IMPROVEMENTS OF MINE (have immediately void the warranty!):
1) Stock version: Ultra-Linear mode connection only
Modification: added front panel “bright chrome” switch to select between Triode and Ultra-Linear mode
Triode mode is more pure, with less distortion and more open sound but the UL has more power and dynamic...it is your liking. In every amp with user-switchable triode/ultralinear circuits, triode usually sounds better.
2) Stock version: EL34B power tubes
Modification: replaced with KT66 power tubes
No self-bias adjustment is required (according to Weber Bias Calculator) since KT66 has the same plate dissipation than EL34 (25W), but KT66 has higher load impedance requirement than EL34. That is also recommended if you run, like me, a 16 ohm speaker to the 8 ohm output since you are doublig the reflected impedance. Optimal burn-in times range from 100 to 300 hours. Most changes are happening in the first 150 hours. Also the 6L6GC high-power tubes have high internal impedance and work great in this amplifier on a 16 ohm load without requiring bias adjustment since exhibit similar consumptions to the EL34B (see last page measurements).
3) Stock version: two 1N4007 (in the hybrid power supply)
Modification: replaced with two ultra-fast SF4007 diodes, bypassed by 10nF snubbing caps
Walt Jung article gives the reasons for using fast recovery diodes and has actual measurements showing the large amount of RF hash generated by common 400x rectifiers.
4) Stock version: 220uf Panasonic Electrolytic (FC Series) cathode bypass capacitor (in the power output stage)
Modification: replaced with bipolar Sic-Safco 470+470uF back-to-back (+--+) capacitors, plus 2u2F polyester cap
Many folks have found that Bipolar Electrolytic Capacitors can make a noticeable difference when used as cathode bypass capacitors in tube amps. Read "Bipolar Electrolytic Capacitors" by Matt Seniff.
5) Stock version: unbypassed gain bias resistor (in the common-cathode triode amplifier)
Modification: added bypass cathode capacitor (bipolar Rubycon 1000+1000uF back-to-back (+--+) capacitors, plus 1uF polyester cap)
By adding bypass cathode capacitor you increase gain (recommended by KT66’s higher gain requirements) and rise mostly even harmonics. Being an even order harmonic, this is not a critical tonal issue, since even order harmonics stay musical (multiples of an octave).
6) Stock version: 220nF/400V Philips (MKT series) coupling capacitor between stages
Modification: replaced with 220nF/500V metallized paper-in-oil K42Y-2 Soviet Military Capacitor
PIO dielectrics are appreciated for their tonal balance that is very neutral and smooth. Audiophiles, studio guys, vintage collectors can all hear the difference with their own opinions on what is best. The main thing is that I agree that the cap upgrade is a good thing.
7) Modification: added bypass film 1uF/47nF capacitors in power supply (on the back side of the PCB) in parallel to electrolytics to filter out high frequency noise.
8) Stock version: three-pronged power cord with ground (earth) connected to the chassis
Modification: remove earth connection by plugging into a continental power adaptor which breaks the ground (earth)
By removing earth connection, the amplifier sounds quieter and better.
9) Stock version: no Global Negative Feedback
No Modification: give up to any Local/Global Negative Feedback
I tried from -1 to -6dB of NFB which makes a great influence in the final sound, but additional NFB made the amplifier sounding more and more as "solid-state". I preferred the stock version (no GNFB at all) since it sounds more harmonically rich which results pleasant to me.
10) Stock version: for safety reasons the common (or zero ohm) end of the OPT is grounded
Modification: floating outputs, and separated isolated L/R zero ohm returns
Amplifiers with no global feedback can leave the output transformer secondary floating, even if it is electrically unsafe. This opens the soundstage a little bit. Probably the floating outputs provides the (RF) noise-reduction benefits of balanced lines.
11) Stock version: EL34B self-biased at plate dissipation of about 15W (out of 25W max) by 500 ohm cathode resistor. That means cold/average dissipation.
Modification: KT66 self-biased at plate dissipation of nearly 19W (out of 25W max) by a reduced 410 ohm cathode resistor. That means hot dissipation.
Biasing the power tubes hot gives it a brighter and fuller sound.
12) Stock version: 5Z4 rectifier
Modification: replaced with Sovtek 5V4 rectifier (or even JJ GZ34)
The KT66s’ new adjusted bias is now drawing extra current, about 120ma, so too much close the maximum forward current of the 5Z4 (125ma max, 350V, 20V drop). The replacement with 5V4 (175ma max, 375V, 25V drop) or with GZ34 (250ma max, 450V, 17V drop) is just recommended because both tubes are low drop-out equivalents. At the end, after listening test, I even prefer 5V4 to the GZ34, probably due to the highest voltage drop and sag: the GZ34 is too close to “solid state” in the response and in some cases it yields voices quite metallic and fuzzy, for sure never as smooth and natural as delivered with the 5V4. Of course by using the 5V4 makes the KT66s running a bit less hot due to the higher drop in power voltage supply.
13) Stock version: the shared cathode resistor of the parallel 6N2 triodes is Rk= 2Kohm
Modification: triodes in the driver stage are re-biased hotter (Rk=840ohm)
The optimal plate load for a triode is around two to three times the plate resistance (which is nearly 47Kohm for the 6N2), thus the stock anode resistor looks well-dimensioned and I didn’t modify its value (75Kohm). Remember that parallel operation needs shared plate and cathode resistors at half the single triode value.
Pay attention that 6N2J (or 6N2P, 6N2P-EV) is not full equivalent to ECC83 (or 12AX7): both have an amplification factor nearly of 100, but, a part of the filament connections, the last has higher plate resistance (62.5Kohm) and slight shifted grid-voltage vs. cathode-current curves.
Since 6N2 triodes are now bypassed by a capacitor for a higher gain, changing the cathode resistor doesn’t modify the voltage gain, but only shifts the bias point: this modifies the headroom of the driver stage and the distortion level. As the bias point is shifted, the amplifier will clip more on the top or bottom portion of the waveform.
By lowering the cathode resistor from 2K to 840ohm, not only we increase and better centre the bias current, but also we obtain a better sounding harmonic distribution, the so called waterfall of 2nd > 3rd > 4th > 5th. Cathode resistor value was in fact chosen where the measured third harmonic component was minimum and the second harmonic dominant at an output power of 1 Watt. The soundstage turned out to be more "open" and "natural" that confirms all Psychoacoustics studies which say that even harmonics give a warmer, organic, and natural sound while odd harmonics impart a more harsh and metallic sound.
14) Added a Zobel RC network between the amp and the full-range 16 ohm speaker
Any amp is inductively loaded by a speaker, so the correct form for interpreting an inductive load on a plate current/voltage curve is an ellipse which may exceed the Max dissipation curve limit. A Zobel RC Network is designed to achieve a flat impedance, safer load.
This amplifier looks to sound more comfortable driving a flat-impedance resistive-like 16 ohm load, (from its 8 ohm output taps), which results in a better 3D image and stable focus
15) Stock version: input grid stopper resistor (in series with the grids of the driver triodes) is 10Kohm
Modification: input grid stopper resistor lowered to 3.3Kohm
The stock input stopper grid resistor is 10Kohm (but the triode, originally unbypassed, had a lower voltage gain of nearly 20). After bypassing the common cathode resistor of the parallel driver triodes for a higher gain, the voltage gain reaches nearly 70, and the grid resistor needs to be reduced of about one third, from 10K to 3.3K, due to the increased input Miller capacitance.
In fact the Miller capacity (that is twice for parallel triodes) is:
Cin = Cgk + Cgp*(A+1) =~ Cgp*(A+1) =~ Cgp*21 (when unbypassed)
or
=~ Cgp*71 (if bypassed)
then, Cin_bypassed =~ 71/21 Cin_unbypassed =~ 3.3 Cin_unbypassed thus, Cin_bypassed =~ three times Cin_unbypassed
The input capacitance of the tube (Cin), in conjunction with the impedance of the grid stopper resistor (Rg), forms a simple RC lowpass filter with a -6dB/octave slope. To maintain the original low roll-off frequency, Rg resistor should be reduced to one third, since Cin has been tripled. Frequency response is now back to be ± 1dB at 16 to 20000Hz.
16) Stock version: the interstage coupling capacitor is C=220nF and the KT66/EL34 grid leak resistor is R=470Kohm. Also the 6N2 grid leak resistor is R1=470Kohm.
Modification: coupling capacitor doubled to 440nF and KT66/EL34 grid resistor halved to 220Kohm, preserving the original RC cut-off frequency. The 6N2 grid leak resistor is cut from 470Kohm to 150Kohm.
A lower value grid leak resistor will be harder to drive, but will give a more constant load at different frequencies, and hence a more extended high frequency performance. In fact, the grid to plate internal capacitance of the following stage (whose value is also multiplied by the gain of the stage, due to the Miller effect) reinjects a fraction of the output signal back to the grid. It is nothing else that a local negative feedback whose effect increases with frequency and the gain. The Miller effect can cause loss of treble if the grid resistor is too high; the lowest the grid leak resistor, the lowest the feedback, the wider the bandwith. Miller capacitance not only affects high frequency response but it adds phase intermodulation distortions as well.
By halving the size of the grid leak resistor, we double the cut-off frequency and increase it by an octave, cutting the bass response. Viceversa, by doubling the size of the interstage coupling capacitor we halve the cut-off frequency and reduce it by an octave, allowing more bass response. By choosing a lower value of the grid leak resistors, we also lower the gain a tad, but not significantly. If we make both the modifications, the two effects will compensate each other, maintaining the original RC time constant, thus the original the cut-off frequency.
It is important that we should always aim for a corner frequency of one tenth of 20Hz (2 Hz) to avoid any phase shift in the lowest bass region.
We can easily double the existing capacitance by putting another identical capacitor in parallel. Putting two identical caps in parallel is a good thing and brings small advantages because we halve the intrinsic resistance and the cap's inductance.
Many folks have done intensive testing of input capacitors: parallel film capacitors sound better to their ears as they were found to sound "faster" than a single capacitor of the same value, but we are straying into highly subjective territory here.
Moreover, we could test to put a "PIO" together in parallel with a film and foil capacitor of the same value to create a tone circuit, because a pure PIO capacitor has been found to sound smooth but rolled off in the highs.
The output impedence for two 6N2 parallelled triodes (output taken from the plates, bypassed cathodes) is about:
Rs= Ra/2||Rp/2 = 47K/2||150K/2 = 23.5K||75K = 17.9Kohm
The impedance of the following stage (KT66/EL34) is just the grid resistor reduced to R= 470K/2~ 220Kohm.
The coupling interstage capacitor has been increased to C=0.22x2= 0.44uF
The new cut-off frequency at -3dB of the low end of the band will result equal to 1/[2*pi*(Rs+R)*C]= 1.5Hz, that is a desired pole frequency less than one tenth of 20Hz.
To change the grid leak resistors brings major tonal improvement to the tube amplifier, creating a soundstage with focus and realism.
17) Stock version: single value of cathode bias resistor on power tubes
Modification: added a front panel “bright chrome” switch to select among three different BIAS options: HOT, AVERAGE and COLD
This three-positions switch allows you to select among different cathode resistors (connected in parallel) that determine three different BIAS currents and consequently let run the power tubes slight colder or slight hotter than the average.
In Single Ended amplifiers (which always run in Class A, ergo do not suffer from crossover distortion) decreasing or increasing the bias current brings little tonal improvement due to the asymmetrical clipping and waveform compression which increases the content of the second harmonic distortion and enhances its ratio compared to the third and odd harmonics.
Bias adjustment is highly recommended after having swapped different tubes or after having switched between Triode and UL mode: you can observe in the attached table that various tubes (EL34/6L6GC/KT66) show slight different measured voltages and consumptions, thus exhibit distinctive tonal behaviours.
Hot bias shortens tube life and usually sounds more dynamic and fuller, but potentially harsher. On the other side, cold bias, for which tubes will last longer, in certain circumstances produces more natural tones, even if sometimes the sound results thin and lifeless.
_________________________________________________________________________________________________________________
Attached curves of the A10 amplifier after all my modifications, both simulated via LTSpice and measured on a PC-soundcard.
I measured a maximum power of 3.5 Watt on 15 ohms (10% THD) in Triode mode and 6 Watt in the Ultralinear operation, both channels working.
I would not comment the curves since I think almost everything is self-explanatory: I just ask you to bear in mind the mismatched impedance between the amp and speakers (I’m running a 16 ohm cab through the 8 ohm amp tap) and that now there is neither global nor local negative feedback in the triode mode, and just a negative feedback applied to the screen grid in the ultralinear operation.
I can't disguise the fact that the ZERO LOCAL/GLOBAL FEEDBACK TRIODE CONFIGURATION satisfies me completely regardless of the higher distortion and lower power output.
ANY COMMENTS ARE WELCOME!
:c_flag: :c_flag: My Homemade Tube Amplifier website: The Sound Grail, design, schematic, simulation and measurements http://tubeamplifiers.wixsite.com/thesoundgrail :c_flag: :c_flag:
Reactions: Pashka
Linkwitz transform on a tweeter?
I have a DIY build that is effectively a Cura CA10 - the cabinets were remaindered when the company went out of business, and it seems they had PL18s and Seas H519 25TFFC tweeters. I managed to get new old stock of both, and I have them set up active with minidsp crossovers. I never found a crossover schematic for them. They've been 'on the bench' for a while but are now back in-system.
I've had a fairly simplistic crossover running on them with a very steep filter at 2.5k but I'm wondering if I could do better.
The tweeter nominally resonates at 1200, has stored energy between 1200 and about twice that, and it rolls off second order with -3db at about 1800 and flat at about 3500, it looks like Q is about 0.5.
I'm wondering if I could:
  • use an LT to flatten the tweeter's response and push the natural rolloff down so its flat above about 1000
  • then add a 4th order (might try 2nd) LR at about 2300, maybe a bit less.
The PL18 cone geometry means that the 60degree plot diverges from about 1800 and the 30degree plot from about 2500, so I would like to keep the crossover as low as I can given the tweeter's limitations.
Does that sound sensible? I don't think the woofer is up to higher than 2.5k without directivity issues
The 'ears' on the tweeter are next to each other and the cabinet is cut for that rather than the more spaced out terminals on newer tweeters, otherwise I'd probably replace with an SBAcoustics or similar. I may yet take a saw to the cabinet, but I thought I'd try first.
Not sure how I'd approach a passive crossover for these without using the tweeter's rolloff and accepting all the stored energy and raised distortion, but that's not my immediate problem.
B1-R2 PVG version with Power Supply, Volume control and Gain stage on board
I finally finished the extended B1-R2 buffer I have been working on after receiving the chassis and finding the time to do the work.
For those not familiar, the B1-R2 is the Rev 2 version of the Pass B1 single ended buffer re-designed by Papa to work with a bipolar, rather than single ended, supply.
This build is for my office that also uses an ACA-Mini with boards created so it will mount in a more standard chassis with heat sink.
I modified the B1-R2 to use the output buffer pretty much as designed by Papa (Thanks Papa! 🙏) but I also added a few other things I wanted,
This one has an adjustable LM317/337 based power supply w/RCRC front end, a volume pot and a configurable gain stage on the same board.
The AC source is a 24V AC wall transformer connected by a standard 2.1 mm barrel connector.
It is laid out so the gain stage, which uses an LM4562 op-amp, can be omitted or the gain can be easily changed. The gain resistors and the op amp are all socketed and easily changed, bypassed or omitted. Or could be soldered in if no changes are expected.
The pot is an Alps RK27 at 20k Ohms. The next build will use a slightly wider chassis that will function the same but have an additional front panel 1/8" input, an LED power indicator and use a 10k pot with a higher input Z. Using that 20k Pot with 50k input impedance was pretty silly of me. The new build will go in the main rig.
So how does it sound? I think it sounds utterly fantastic! Really open, detailed and dynamic. My office stereo has never sounded this god. It's quite a change, But of course I may have builder's bias. 🙂
I created the board in KiCad. If anyone is interested and wants the design files or Gerbers I'd be happy to share. I can also share the chassis source at AliExpress. Drop me a PM if interested.
Attached is the schematic as built. I have a new rev with tiny improvements not yet built, And it probably never will be built. I ordered the five board minimum for the first build and expect to only build one or two more.
So
Reactions: Ixnay and zoom777
Rare garage sale finds
I have to share this. Found these beauty’s at two different garage sales last week, got them for $10.00 per pair. The holey basket had one where the surround was separating from the cone and the other was perfect. I have only seen pictures of the black non rib cones holey baskets. The AKAI had surrounds partially separating from the cones. All have good surrounds, not stiff. I have glued the surround on them. What a great find!
For Sale Faital Pro 15PR400, BG Neo3, BG Neo8, SEAS CA15RLY, Crossover Parts
Making other projects priority, so letting these go... photos to come.
Pair of NEW IN BOX Faital Pro 15PR400 4 Ohm.
$420 + Shipping
Bohlender Graebener (BG) Neo 3.5.
New old stock $140/pair + Shipping
Three near new Bohlender Graebener (BG) Neo 8, with gaskets.
$75/each + Shipping.
Used pair, but in excellent condition, Seas CA15RLY.
$80/pair + Shipping.
I also have wired up together...
Pair of near new Jantzen Audio 0.40mH 15 AWG Litz Wire Air Core Inductor
$30/pair + shipping
Pair of near new Jantzen Audio 3.3uF 800V Z-Silver Capacitor
$45/pair + shipping
I'll cover PayPal fees.
Open to reasonable offers.
Thanks.
Why is Intel Corp dying?
I just read an article written by Intel board members. "Professor Yoffie, Mr. Hundt, Ambassador Barshefsky, and Professor Plummer all served as longtime directors of the Intel board."
I worked for Intel Corp in the late 1980s until 1997. That was when Intel Corp ruled the CPU world- Intel 286, 386, Pentium. New wafer fabs were being built in NM and AZ. Intel Corp was/is highly dependent on corporate welfare. And there was a consortium of taxpayer funded photolithography research going on. It all ended when SVG corp was sold to ASML. I always wondered how a Dutch company could buy a US funded company?
The photolithography tools were the bottleneck because the geometry of the chips were limited by the frequency of light waves. Nanotechnology. In the 1990s, the limiting factor was the placement/position of the photolithograpy tool, but magnetics were used to resolve that resolution. Talk about a gnats ***.
Today, there is talk about TSMC taking over Intel chip factories. Intel Corp might die.
1967 all germanium Farfisa BR 80, 80 w head unit fully restored now, but still yielding rather loud 120 HZ hum
A few weeks ago I found this random cabinet in a dumpster that somebody alerted me to. It was a pristine farfisa cabinet for a br-80 amp combo. A whopping 80 watts of Italian made germanium-powered instrument amplifier, with a very nice pristine JBL d130 in the cabinet along with a tell Ray oil can Echo unit. I found the actual head unit on reverb in non-functional condition. I bought it and had it mailed to me and got it functioning straight away. A few weeks later I got an actual schematic and went about shoring up any other Loose Ends. I now have the unit as restored as can possibly be, thankfully to my large collection of germanium transistors that I've accumulated over the years. But it still has a rather present 120 Hertz hum, which is entirely from the power unit, as with all of the inputs shorted or even with the input cards removed the home is still there. I realize there is a lot of possible reasons for this. For instance that this was a unit made for 110 volts now getting closer to 120, and the age of the amplifier possibly having some incongruities. I figured there has to be some way to balance the hum, as I have seen on a lot of other amplifiers. I recapped the whole thing, or at least every electrolytic that was in it. I read some post somewhere that said that the Falcon caps that were in these things were usually pretty stable. That's complete nonsense by the way! Any capacitor from 1967 that I know of is in no way stable! Certainly not in an 80 watt monster from this era. There were very few solid state professional amplifiers back then that were 80 Watts. I'm wondering if they were limited by the state of the capacitor technology of the time, or the state of tech in Europe and Italy to be specific. If made nowadays if they would have capacitors with several thousands of microfarads versus the highest being I believe 1,000 or 2,000 in a preamp circuit. I think most of the larger capacitors in the power amp were only about 500 to 1,000. And a lot of those were hooked up in series with others which would make them lower. I'll include a few pictures and a YouTube link and the schematic that I scoured the planet to find! Thanks for all of your help and information in advance, though I know this is kind of a big ask! Also I'm trying to figure out how to turn one of the record heads in the Echo unit into an erase head, as I have heard of erase heads in these, but not being tape oriented I'm not sure what any race head would be!? I don't even know how they bias the record heads on this particular unit beings it is recorded via electrostatic energy and the regenerated Echo is gotten by simply not being erased entirely on the first pass. This unit is also significantly brighter than the others I've heard, and I made it even more so by speeding it up a little bit by increasing the width of the motor Drive pulley.
Login to view embedded media
Sheet Materials are not created equally ( UK perspective on Birch Ply and MDF ).
So I’m totally new to DIY audio and have yet to do my first speaker build, but I do have experience in building furniture cabinets and thought I’d pass on a few insights into the sheet materials available (as I’m in the UK this is obviously from a UK perspective).
Birch Ply (and it’s lesser sibling, Poplar Ply )
I personally love Birch Ply, or Baltic Ply as it is often referred to. If you’re going to build in Birch ply I personally would leave it on show in all its glory and not paint or veneer it (kind of a waste of money if you do this in my humble opinion). Troels’ speakers for instance all show off Birch ply in all its glory - especially that lovely layered cut edge.
Here in the UK, all of our high grade birch ply came from Russia. With the pandemic and then the Ukraine war this led to a total end to Baltic ply from Russia coming to the UK (some timber merchants doubt it will ever return). At present I am told all of our birch play now comes from Lithuania (it’s not quite as good as the high quality grade that came from Russia, so I am told). It also literally tripled in price over night and it still hasn’t, and is unlikely to ever return to pre-pandemic pricing.
Birch ply comes in many grades, and for the layman in the UK, it can be tricky to find the good stuff (during the pandemic this stuff was gold dust). You will not find it in the big DIY merchants here in the UK - you’ll need to find a specialist timber supplier.
It will come graded like BB/CP or BB/BB etc. For cabinetry you want the highest grade which at my supplier is classed as B/BB ‘unplugged.’ This is the important bit, a lot of so called premium birch ply here in the UK is often ‘plugged’ - this is the process of removing (literally cut out) a defect like a knot in the surface layer of the sheet, and glueing down a replacement patch. The repairs are highly visible and do not look nice and will ruin the look of your build unless you can cut around them - some sheets have multiple plugs which makes this difficult.
I have seen a number of online UK suppliers selling so called ‘premium’ birch ply which is plugged - my advice is read the small print or ask.
As of December 2024, at trade prices you could be looking at £110 per 8’ x 4’ sheet of 18mm ‘plug free’ birch ply. A 24mm sheet would be in the region of £140 (those prices are inclusive of VAT).
As an example, one online retailer is selling an 18mm 8’ x 4’ sheet of ‘plugged’ premium ply for £264!!!
Poplar ply can be found for less money here in the UK, looks like Birch Ply but is made up of fewer layers - not as strong, not as dense, not as nice, and still quite expensive so personally I wouldn’t bother (unless you plan on painting or veneering).
MDF
Again, there are lots of different types of MDF and they aren’t created equally.
Go into any large chain DIY store here in the UK and you will find MDF - it’s brown and comes in different thicknesses and is relatively cheap (compared to birch ply).
This is what we (in the trade) class as trade MDF and it really isn’t designed for making furniture with. Instead, I would look for Moisture Resistant MDF (often referred to as MR MDF). You can tell the difference because this stuff is more green in colour - certainly the inner section will be green in colour. A popular and well known manufacturer is Medite and this will be brown on the outside and have a distinctive green core to it.
Moisture resistant is more dense and cuts really cleanly - it is far superior to ‘trade’ mdf and this is what I would recommend for building furniture (speaker cabinets).
Medite is a brand name, and it’s quite expensive, but there are others that are a little cheaper, like Fibralux - still excellent quality, moisture resistant mdf. It looks a little different to Medite MR in that it is a greenish brown throughout, whilst Medite has a very distinctive green core compared to the brown outer. Medite also do another product called Optima - this is moisture resistant and also even higher density to the MR MDF.
As an example of trade prices here in the UK, 18mm MR Fibralux is in the region of £32 per 8’ x 4’ sheet, 22mm is £44 a sheet and 25mm is £51 per sheet. You can expect to pay more for Medite, and these are trade prices so likely 10% or so more to the public.
If you are planning on painting or veneering your cabinets I would opt for MR MDF or Optima, just note that a cut edge of MDF is easily damaged compared to Birch Ply so you have to be quite careful with it.
If you want coloured throughout MDF then the name banded around most often is Valchromat. I understand that Valchromat actually went out of business some years ago but another company bought the rights to the name and manufuctures the boards themselves under the Valchromat name. It's nice stuff, but it's expensive, very expensive! You can find black throughout MR MDF though from Fibralux though at cheaper cost - it's decent quality and can be sealed/treated much the same as valchromat with a hard wax oil etc to finish.
One of the biggest sheet material businesses here in the UK is a company called Lawcris - thankfully they are based near me but they will deliver (but I think you need to spend at least £300! ) They have an enormous selection of sheet materials in general - from mdf to plywood, from veneered to bendy ply etc so may be useful to someone perhaps.
Hope that helps some builders out there who may or may not be so clued up on the woodworking aspect. Please note I have no affiliation with Medite, Fibralux or Lawcris and these are just branded materials/companies that I am familiar with because I have used them - I'm sure there are others too.
Large Em-Ken Dampening
I hope Dave at Planet 10 doesn’t mind that I am posting this question here too. I’m sure he’s busy and I thought maybe others can benefit from the answer to this question and/or share their experiences with similar builds. (Dave, ignore my email lol)
I am building an Em-Ken using a 10” Eminence Beta10cx using plans Dave created for me back in 2021.
Basically, how much dampening is supposed to go into this thing? Dave’s plans say line the walls with 12mm felt and stuff the cabinet with UltraTouch, but all of the newer Fonken/Onken plans say line the walls or stuff the cabinet, not both. So, which is it?
If I did stuff it in addition to lining with felt, how much stuffing? 1lb per cubic foot like standard practice?
The plans say line the holey brace with lower density felt, but does that mean cover the holes? Or line around the holes?
I got the wood cut except for the front baffle as I’m trying to decide if I want dark cedar to offset the light maple cabinet or should I use curly maple veneer on the baffle and keep it all the same color? Hard decisions…lol….
JEDIA L2.2 - R.C.S./JD-MEDIA LX2.2 Service Manual
Hi all,
I'm desperately trying to find service manual/schematic of the JEDIA L2.2 / JD-MEDIA LX2.2 / R.C.S. LX2.2 power amp. I asked to the manufacturer but they didn't respond yet. Have you any suggestions to find service manual of this particular amp please?
I need to figure out input stage topology because this amp seems much more prone to the interference comparing the other amps that I have dealt with. I'm also trying to figure out purpose and equivalent schematic of the HIC-VOLT21 proprietary daughter board/module at the input stage.
Thanks in advance.
Hello to everyone!
Hi everyone!
I'm new to diyAudio and just getting into speaker building. I recently started my first big DIY speaker project because I wanted a good bluetooth speaker and figured I'd just build one myself.
For the main speaker, I’m using the Dayton TCP115-4 woofer and the ND25FW-4 tweeter. For the EQ and Crossover I'm using an ADAU1452 DSP. I also added a 128x128 OLED display with an ESP32 and a rotary encoder for controlling things like volume, source selection, bass boost, etc.
Since I like bass, I also built a wireless subwoofer using the GRS 8SW-4HE-8 driver. Both the main speaker and sub sound great, but I’m running into one big issue: port noise.
I was aware of chuffing as a problem before building and tried to keep air velocity below 20 m/s peak using WinISD, but in practice, especially on the sub, the ports are just too noisy. That’s why I signed up here, hoping to get some advice on where I may have gone wrong.
I’ll post more details about the sub in the subwoofer section soon. I'm looking forward to getting some advice on where I went wrong.
For Sale XA25 clone
With the age became a tube guy, hence sell this diy clone. Not my build so can't respond your smart questions except to post pictures. I recapped it 3 months ago, you know temperature ages fast.
I price it 750eur thinking it's fair but maybe I am wrong? That case just make me your offer and I might accept it. Shipping to Europe only. It's a heavvy beast, cost of packing will not be cheap side.
Some thoughts about a DS Audio optical cartridge equalizer
Lately I have become curious about the DS Audio optical pickups and I think sooner or later I will get me one.
They are a bit pricey, but it's possible to purchase a DS-pickup without the equalizer, so DIYing the equalizer safes a fair amount of money.
Here I just want to gather some ideas on the construction of such an equalizer…
There is a pdf "Optical cartridge technical info" which can be downloaded on the DS website https://ds-audio-w.biz/products_info/
I've got all my information from there.
PSU requirements
The pickup consists of an IR-LED (one for both channel for the 2nd generation pickups and one each channel for the 3rd generation pickups) which needs to be powered
and two photo-diodes -one each channel- which need an negative bias voltage.
An LED (the “front light”) is in parallel to the IR-LED and seems to be an on-indicator without further purpose.
The IR-LED is powered from 8V via 68Ohm resistor. Diode Current is said to be 65mA for the DSE-1 and 80mA for the DS003.
There is a resistor in front of the IR-diode shown in the pdf, which probably serves to decouple the IR-LED from the indicator LED.
So the IR-LEDs forward voltage is likely to be approx. 2,9V.
The Photo-Diodes are reverse biased (photoconductive mode) and need a -10V bias voltage each channel.
Output voltage of the DS-E1 pickup is said to be 50mV. The schematic has a 16kOhm resistors to convert the diode output current to a voltage.
Diode-current therefore must be 50mV/16kOhm=3,125µA (5cms/sec at 1kHz???)
In the DS Audio pdf the RIAA equalization is shown as a passive network right behind the 16kOhm resistor.
I’m not shure if this is the optimal position. Also the I-V-conversion could benefit from an active solution.
In the following schematic I use a transimpedance amplifier to transform the current to a voltage.
I “lifted” the output of the TIA to -10V by putting this voltage on the non-inverting input- which in turn sets the bias for the photo-diodes.
This reduces the headroom of the Opamp. One solution could be, to make the Opamp supply asymmetrical: +5 to -25V.
The following capacitor removes DC from the signal and can be part of the succeeding equilazation-network (can we call this still a RIAA-network?).
The channels are phase inverted to each other, so the right channel still needs an inverter stage.
Any comments so far?
Cheers, Boris
Reactions: meldano
2.5 ways versus 3 ways
The appearance of 2.5- and 3-way speakers look similar, actually identical for some designs. Suppose they both have 3 drivers per cabinet for the same; a tweeter, a midrange, and a woofer. The difference that I could realize is the presence of the “high-pass filter” for the midrange. That means the 2.5 ways will allow its midrange to simultaneously play woofer’s frequency. By the way, I couldn’t think of the benefits of the 2.5 ways except for economic purpose. Furthermore, it may yield inferior quality to the 3 ways as the midrange driver will play mid-frequency based on low-frequency waves. I’m not sure if it could be viewed as the midrange in the leaked box, couldn’t it? So anyone please tell me what’s the benefit of 2.5 ways speakers over 3 ways?
Marquardt SWITCHES 250V 2A 4-pole device power off switch Toggle LUND -- NH USA --
Make offer in thread and how many you want.
I think these are used mostly as power switches, no?
Marquardt SWITCHES 250V 2A 4-pole device switch off switch Toggle LUND -- NH USA --
PPD subwoofer
Hi all! I was asked to create this topic as one of the authors of the acoustic design of subwoofers, which was called PPD (Petrenko Petrushevsky's Dipole). In fact, this design, in our opinion, is an improved version of the traditional ripole by Axel Ridtahler. Its main advantage compared to the Axel rippole is the absence of significant unevenness in the frequency response in the region of 150-300 Hz. Additional benefits are lower overall distortion in the subwoofer's operating range and smaller dimensions. With the right choice of TSP speaker parameters, very good results can be obtained, since the smooth frequency response allows the use of second-order filters.
In this video, an example of using a PPD subwoofer on a 15-inch speaker in triphonics.
Radiotron 2A3 values?
I am going back to the beginning and building the Radiotron 2A3 single-ended amp. I plan to start with the original and work from there listening as I go. My first mod will be taking the bypass caps to 100uf and the coupling cap to 0.22uf. My question regards the resistor values which are given as what looks like .25, .5, and 1,5. I assume those values are in mega-ohms, correct?
Happy listening,
John
Sony DTC 75ES DAT recorder cassette Dr closes automatically just 2-3 sec after opening without you pressing close door
hi everyone , I have a Sony DAT cassette recorder model DTC 75ES it has developed a problem in tape ejection process : when you press open tape compartment it opens normally but before you can remove or load a casette within 2-3 second of opening it closes automatically on it own without one pressing close button . I have tested all. Mechanical switches related to the door mechanism opening closes sensing two everything Checks out OK , I think the fault might be on the electronic side on circuit board or IC which controls the tape open/close sequence but I don’t know the correct way to go about trouble shooting electronically . Did someone of you had the same problem and what might be causing the problem. I will be very grateful for any help to solve this problem. Thanks
Hello colleages
Hi there. My name is Gena. I am and embedded engineer from Belarus. Previously, most of the time, i was developing software for uCs, but recently i changed the job and became a hardware developer as well. My current project includes audio data converting/transiving and would like to get some help from more expirienced embedders.
Hope to have some good time here, and wish you all the same <3
Best Nelson Pass amp kit or project to go with Frugel-Horn Joan with MA200 drivers?
Starting the research well ahead of time and right here obviously the best possible place to do so🙂
I have been reading a lot here but there is so many posts it is hard to dig through it all so I hope those with the great experience in these things can help me out.
I will not likely get to the speaker build until mid fall, depending on weather so no big rush.
These will obviously be very efficient and am sure the Baby Sophia 10w P/P amp will drive them well, it has been fully upgraded and a great amp but I want to explore a low power class Amp build for them as well. I have no specs on the current draw on the BS amp so will have to measure it once I have it setup when speakers are done.
We are in a 434sq ft RV, seating is about 8-9 ft from front of speakers, 8 ft ceilings, two apposing slides just past where the speakers will sit, going to need some treatments of course.
Requirements:
Size, as small as reasonable.
Mono or Stereo, likely try both
Power, not likely to need more than 5 to 10 watts, could be less but not a big factor.
Lowest energy use as reasonable, on the grid but plan to go off grid eventually if I live long enough.
SMD? That would be a bit tough with my about to turn 73 eyes but I have steady hands and patience so a good LED magnifier might be all I need.
Needs to be in a case, PS internal or external, likely external as need small case(s) size as reasonable.
Cost, a few hundred to $800 or more if needed? That is for two mono amps could go up to around $1500 if bought over a few months or I save my pennies up.
Sound quality, the very best I can do for the requirements above.
Thanks,
Rick
For Sale HA1452W "dual audio preamp" to standard so-8 opamp adapter boards
I designed and tested an opamp adapter to replace the HA1452W preamp chip, which appears to be a pair of externally compensated opamps.
It works just fine. There's a spot on the belly for an smd power bypass cap and two spots for small caps to filter ultrasonics out of the feedback loop, which may be needed to prevent oscillation depending on what opamp you use.
I have a bunch more boards. I can provide a complete kit with an lme49720 (aka lm4562), pin strips, a socket, smd 0.1uf cap and a pair of 22pf through-hole caps for $15, or w/o the chip for less.
Looking for help adding unbalance input to Pascal amp S-Pro2 and U-Pro2S
Hi, first post here. I hope this is an easy question to answer. I’m looking to add an unbalanced input, rca jack, to my amps. I have everything ready to be connected and installed but I thought this is probably the best time to add unbalanced input to the amps since they are all unconnected and easy to access. Its mainly to keep my options open but also because I have an old Integra Preamp and its HDMI board is a ticking time bomb and I’m lucky its still working. I have two Pascal amplifier modules S-Pro2 and U-Pro2S both with the Pascal input boards, and some Icepower 200ASC modules. The Icepower stuff has great instructions on how to add an unbalanced input and it seems very simple. However, on the Pascal amps, its not clear and I’m not confident to enough to try the same instructions from the Icepower manual and in fear I may screw something up. Any one know how to accomplish this?
Here is my desired Home Theater setup:
7.1 speakers
Integra DHC-80.3 Preamp
Pascal S-Pro2 for Front Mains
Pascal U-Pro2S for Side Surrounds
Icepower 200ASC amp for Center Channel
Icepower 200ASC amp for Subwoofer
Icepower 200ASC+200AC amp for Rear Surrounds
An Idea for a 6N1P-6N6P / 6H1∏-6H6∏ OTL Headphone Amp
Greetings, Friends. I've long wanted to build a simple headphone amp using the Soviet 6N6P double triode as output. Seeing the earlier post of a Morgan Jones 6DJ8 Headphone Amp - style build completed with 3x 6N1P tubes inspired me to whip up a schematic for a similar circuit.
Adapted from the Optimized Morgan Jones Headphone Amplifier circuit. R4 & R5 prob need to be adjusted to equalize voltages across each triode. Not sure about bypass caps.
Power Supply, expected voltages in Blue:
Most of the power supply designs from the original Headwize page feature CRC filters for the HT and a cap to float the LV. I'd rather use a traditional voltage divider to elevate the heater supply about 72v. Will this work as drawn? Do I need a cap somewhere in there?
Any advice on the subject welcome, thanks for taking a look!
w
Hack for JBL wireless subwoofer
Hi there - this sub looks pretty decent. I bought this sub quite cheap as working.
I want to get a signal into the sub, however it will only pair under a bluetooth connection with its own compatible soundbar (which didnt come with the sale). I assume this is a bespoke bluetooth connection as I cant see the sub coming up under a list of pairable bluetooth devices. I'm not 100% sure, but this may be a JBL "Bar 500" model.
So, my question is, does the amplifier module shown here look familiar to anyone (in terms of connecting a signal into it, and ideally bypassing the bluetooth connection?)
I'd say this coud be quite tricky. However I'd like to get this running, preferbly using the onboard amp and PS modules if possible.
thanks!
KEF B110 SP1003
Hi All,
I have a pair of Linn Kan Mk1 speakers from new (1982)
The rubber surrounds have torn and obviously the sound is not as it should be. I finally bit the bullet and opened them up.
I successfully removed the drivers, but I am at a loss of how to remove the rubber suspension from the cone.
I have tried a small amount of IPA but it removes the glossy coating on the cone.
Does anyone have an idea of how to do this?
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
508,504
Members
7,922,399
Messages
Filter
Forum Statistics
Threads
407,888
Messages
7,922,399
Members
508,504
Latest member
Samadhana
