Free: Centre and Rear HT speakers (Newcastle AU)
GONE
I'm giving away a centre speaker and a pair of floorstanding rear speakers. Pick up only in the Newcastle NSW AU area.
Centre: Vifa NE19VTS-04 + SB12PAC25-4, Vb=5 litres, F3=71Hz, 417mm W x 142mm H x 200mm D, 2nd order xo, comes with spare tweeter, grey grille cloth, oak timber veneer, birch ply top.
Rear: SEAS 27TFFC + Peerless 850488, Vb=7.3 litres, F3=60Hz, 270mm W x 416mm H x 140mm D, classic series xo, grey grille cloth, designed as mirror pair (tweeter out) to sit beside the sofa, beech timber veneer.
For Sale Peerless 830452 XLS based subwoofer (Newcastle NSW AU)
SOLD
Before I list this on eBay I'm listing it here for $150.
For sale is a 10" Subwoofer based around the Peerless 830452 XLS driver with a Parts Express 300-793 Subwoofer 250W Amplifier with remote control. This is side firing to the left and the B&W dimpled FlowPort is down firing. Made from Tassie Oak veneered MDF and both the inside and outside are sealed with a polyurethane finish. Cleats are used in the corners and the baffle is braced behind the driver. Comes with the remote control, IEC power lead and the amplifier manual. Used in a HT system in a 4.2m x 5.7m room with 2.4m to 4.2m ceiling height and provide plenty of bottom end for movies and was used at sensible levels.
Vb=40 litres, F3=27Hz, 376mm x 376mm x 476mm high.
Help repairing a NAD C315BEE (-17V line missing)
Hello all!
I've been given a NAD C315BEE by a friend on the vague hope to repair it. From my diagnosis there is a distortion/muffled sound on some sounds. It's much more noticeable when the music has more sounds (ie. playing a sequence of sine waves from a youtube video from 10Hz to 20K Hz does not cause a problem).
All the inputs suffer from the problem, so I ruled out the input multiplexer circuit. The problem is also consistent across the full volume range so I also ruled out the power amplifier. Also, it happens on both channels.
I'm very dumb in terms of electronics but I started poking around and decided to test the voltages provided by the PSU board. From my tests the multiple voltages provided by the PSU board are ok (-45/+45V; 8V).
I then turned my attention to the +17V/-17V circuit (service manual, page 17) I noticed that the +17V rail is OK BUT the -17V is reading -1V ! (Amp on, no speakers connected, no inputs). Also the 5V regulator is working fine. I took the measurements between J169 (DGND) and J13 for +17V and J90 for -17V
For reference:
Phx4uLiKC4upr29nampqT96a4UQQohPSoIAIYQQQgghhBDiCyJBgBBCCCGEEEII8QWRIEAIIYQQQgghhPiCSBAghBBCCCGEEEJ8QSQIEEIIIYQQQgghviASBAghhBBCCCGEEF8QCQKEEEIIIYQQQogviAQBQgghhBBCCCHEF0SCACGEEEIIIYQQ4gvyfwD4SoyW78yQWAAAAABJRU5ErkJggg==
I measured +35V and -35V on the right side of the circuit, so that rules out the big capacitors after the full bridge rectifier. So, this leaves me with the -17V rail and I'm at the limit of my electronics skills here 🙁
I removed C330 and C315 for ease of access which appear ok (I'm unable to measure 2220uF with my meter but since the -35V rail is OK the cap should be ok too).
I then removed the capacitors from the left side: C308, C309, C310. All checkout fine. I finally removed the Q305 transistor but I'm unsure how to test it.
So, I would like to ask for your assistance. What can I test, is there an obvious culprit for the missing -17V? Should I replace all the bottom transistors ? (Q305, Q307)? Should the top part components also be replaced?
Something appears shorted here but then again I'm measuring -1V between the -17V rail and GND which (I think) rules out that possibility
Thanks!
Alternative Recorder
I want to replace an iPhone 5s that does a good job of recording far-field sounds with its MEMS mic and +10.00 mic gain. It is probably doing AGC and noise cancellation.
I could get a Zoom H5 with a Clippy XLR ECM mic (Primo EM272 capsule) using phantom power to provide 8v to the mic or the Clippy ECM mic (same capsule), but only 2.5v from the mic/line input port of the H5.
Or I could get either of those mics, but use a single-board computer connected via USB to a Scarlett Solo or RODE AI-1 audio interface that connects to the mic via XLR or instrument port.
So far the budget portable recorders don't provide the Clippy capsules with enough power via the mic/line input port (Zoom H1n 2.5v, Sony PCM-A10 3v).
The Zoom H1n with onboard mics is not good enough to replace the iPhone: low audio levels (+39dB mic input gain) and noisy XY mics.
Crescendo 6K
Amp came in stuck in protection mode .
I pulled the output driverboard and the amp powered up .
Amp is producing +- 12 volts to all opamps .
Amp is also producing rail voltages .
Any ideas where to start checking ?
Audio Note Kit Power Transformer
Audio Note Kit Transformer. For DAC 2.1 kit.
I built the kit and have since created a custom chassis. This involved replacing this transformer.
In perfect working condition.
Unfortunately I do not have the current ratings for the taps, nor do I know the volt-amp rating for the transformer as a whole. It's just not in the documentation.
Approximately 3.75" tall, 3" wide, 4" deep (measured tip of tap on one side and tip of tap on the other side).
Comes with an integrated grounding wire.
Weighs quite a bit--maybe 8 pounds.
To give you an idea of current capability, here are the intended purposes for each tap:
  • 9-0-9: AD1865 DAC implementation, including voltage regulators. I estimate 2A minimum.
  • 8-0-8: 2x DC regulated 6922 heater supplies. I estimate 2 amps minimum.
  • 300-0-300: 2x 6922 Supply, tube regulated. I estimate .1 A minimum.
  • 6.3-0: 6X5 Rectifier + 6BM8. Estimate 4 amp minimum
Looking for $50 + shipping, which may be at least $20.
Audial AYA 4 Fully Assembly by Audial
Hi I would like to sell my lovely AYA4 (2018) fully built-up by Audial. It is the model with USB to PCM input and SPDIF input
The condition is almost as New
220V input
Euro600 for your consideration, shipment will be depended on where to post to.
NeatAMP Pre : a digital preamp for NeatAMP
Last year during first lockdown, I build a TAS3251 Class D amplifier by joining a project of DIYA member JMF11. This amp is named NetAMP, build threat is: [design log] Neat 2x170W I2S in, I2C controlled, integrated DSP amp (TAS3251).
I was very happy with the result and decided to use it as my main amplifier in the living room. I then decided to build a preamp, then an enclosure. One design goal was to have something user friendly (easy to use) intended to all family and friends usage.
As the project as reach a point where I can confirm it is viable, I can publish information and progress in this thread
NeatAmp Pre handle:
  • Remote management of NeatAmp board, including fault and error handling.
  • 7 sources: 2 spdif, 2 toslink, 2 Bluetooth (1 open and 1 dedicated as a bridge with the TV), and 1 USB.
  • Bt sources are 44.1 or 48k, spdif and toslink 44.1, 48, 88.2 and 96k and SUB will be 44.1 or 48k.
  • IR receiver (NEC & Sony protocols).
  • UI made of an OLED display and two rotary encoders.
  • Soft start / power control for the SMPS.
  • User presets memories.
  • Auto power-off.
NeatAmp Pre allow user to manage:
  • Volume, Mute, L&R balance, mono/stereo, DSP presets, balance of the input level of each source, IR remote code learn.
The block diagram shows Pre is made of four different boards: one for the rear panel with the inputs connectors; one for the front panel with display, IR receiver and encoders; one for the main board and the last for the power supply controller. This design mostly address large enclosure, this choice was dictated by NeatAmp board size and also the SMPS size. Boards are connected via flat cables and JST connectors.
NeatAmp Pre is built around a STM32F303, an AK4118 and two CSR Bluetooth modules. CSR, now Qualcomm, provide AptxLL (Low Latency) codec which is required for TV sound.
Power distribution is a bit weird, during development I encounter overheat issues on main board +5V reg and I installed a pre reg on the front panel board. This could be simplified.
NeatAmp Pre manage NeatAmp through a serial link. For this purpose, NeatAMP receive a specific software which manage low level TAS3251 duties including error management and communication with NeatAmp Pre. NeatAmp Pre also run its own software. Both software are made with ST suite: STM32Cube, they’ll be available on GitHub once acceptable quality level reached.
Current project status is ongoing, but everything now is stabilized and is viable.
What remains to do?:
  • Power controller board. I am not satisfied with the current one, I’m currently switching to something closer to the one of Mark Johnson with an ‘always on’ supply made of a AC/DC converter module. I’ll update later when tested ok.
  • Software modules:
    • Storage and management of the DSP presets
    • IR Learn
    • Shut off screen
    • Some minors enhancement
    • USB Audio (will be made last after the enclosure)
  • Make an enclosure.
Block diagram is attached.
  • Locked
OPA627 VS Burson V5 VS Burson V6 Classic op-amps perceived quality of musical reproduction
Images show OPA627, Burson V5 and Buson V6 Classic op-amps and their relative size and Cyenne Dac 3100 with OPA627 and two V6 Classic op-amps in sockets.
In exchange for two Burson Classic dual op-amps I writing my honest review of their performance in comparison to OPA627 and the Burson V5s I already own. My system is composed of an Asus Gaming Computer running JRiver media center 28 which I modified to up samples all files to 96 KHz which are stored on a Passport external hard drive. I have an external Musiland external soundcard I use with optical out through a glass optical interconnect to a Cyenne 3100 DAC with three replaceable op-amp sockets. The DAC output goes to a Cambridge Audio CXA60 amp. I have Mordaunt-Short Aviano 6 speakers and a Wharfedale subwoofer. The Mordaunt-Short speakers are very neutral and I can hear differences in op-amps in the DAC typically. Lm4562 DAC chips came with the Cyenne Dac originally, but I found that despite their low THD, they sounded clean, but lean in expression. I previously owned a Maverick D2 DAC with 3 OPA627 op-amps and found them more textured and open. So, I am reviewing the OPA627 as a baseline vs the two Burson op-amps to see any difference. My dedicated music room is highly acoustically treated and has a fairly straight equalization curve along the x axis, according to Room EQ Wizard, without any equalization required in the JRiver application to achieve this.
Above example of ceiling room treatment in dedicated music room.
I plan to look at the factors Buson uses to describe their op-amps: transparency, details, color and texture, and dynamics and soundstage when reviewing the op-amps previously noted.
Definitions:
Transparency: the sound is reproduced accurately without adding much extra.
Detail: hearing the small, fine sounds of a recording; the most delicate parts of the original sound.
Color and texture: Tone color or texture of a sound is the quality that allows you to separate two instruments playing the same instrument. It is hearing the different layers and harmonies of music.
Dynamics and soundstage: variation in loudness between notes in the spatial sound image presented to the listener.
The Cyenne Dac has 3 removal socketed op-amps. One serves as the combiner op-amp for the DAC. The other 2 are gain op-amps. The gain sockets will vary from OPA627 to the Burson V5 to V6 Classic. I will listen to a playlist of Flac files with a minimum 44.1 KHz and make note of the above features of transparency, etc. for any sound characteristics noticeable for each op-amp.
The flowing listening set began with OPA627 in all three op-amp sockets followed by the Burson V5 in the gain op-amp sockets and OPA627 in the combiner op-amp socket.
Just Like A woman, live 1966 by Bob Dylan.
This is a beautiful 6:45 version of his studio song which only totals 4.42. With three OPA627 op-amps the song sounded less detailed than I remembered. I choose my music in this evaluation for its familiarity. Reference material I believe has to be used so elements like detail and transparency can be assessed as different from a typical presentation. Dylan’s guitar and voice had a sadly muted color and texture. It is actually a beautiful version of a song in which we hear Dylan during a grueling tour in 1966 play an emotionally different version of his studio album while leaning over his stool and expressing longingness and compassion during the song, not the derision found in his studio album. But the OPA627 did not convince me I was listening to a live performance of a wasted Dylan generously sharing his feelings of tenderness with the audience.
The Burson V5 turned the concert and song live. We hear the echo in the room and his harmonica notes are more present. The detail is enhanced. The whole texture and color of the song in his strained voice emoting his regret, not his signature emotional sneer. I was enveloped in the large soundstage during the recitation.
Visions of Johanna by Dylan, the studio track from Blonde on Blonde
The song sounded less textured as well with OPA627. Details were diminished. The notes were compressed and the soundstage was narrow. The music was colored, but with all the instruments the same color.
The Burson V5 again brought out more realism and detail. The bass is strong and Dylan sounds real, unfortunately the soundstage is medium but with clear textured sound separation with sharp details and accuracy.
Hotel California by The Eagles, MTV Live.
With the OPA627 texture is diminished in the guitar work and soundstage is small. Details seem muted. Henley seems to be singing through a cloth. There is a lack of presence.
The acoustic guitar beginning Hotel California with V5 sounds beautiful in its richness of color and texture. Its presence jumps out. The bass is stronger and more defined than with the OPA627 and the music seems more accurate. The instruments keep increasing as the music plays, but textural space is created for them. The vocal could be a bit more forward. But a great performance.
Maggot Brain by Funkadelic
In Maggot Brain with the OPA627 the echo in the left speaker of this beautiful guitar solo brings me right into the studio. The OPA627 shines when outputting the distorted gritty sounds displayed on this cut. I would like a little more transparency here but otherwise great performance.
With the Burson V5 the vocal is more authoritative at the beginning. The drum slap and echo is more detailed and colored. The solo is more in our face but cleaner than with the OPA627, although I like the OPA627 distortion guitar solo sound better. But the sound separation and soundstage are excellent with the Burson V5.
Early in The Morning by Harry Nilsson
Nilsson’s bouncy bluesy keyboard and infectious voice and lyric wants to be heard. But despite some spatial openness and slight texture separating the notes and voice, it was a boring presentation with OPA627.
The Burson V5 again has more detail and bass, but still the song lacks a natural and intimate soundstage. I want it to feel live, but it doesn’t.
The Burson V5 performed better to my ears and with my equipment. It was less fatiguing than the OPA627. The frequency curves on the OPA627 and Burson V5 were identical with REW. The great details, texture, dynamics, presence, etc. with the Burson V5 made no change in frequency distribution. They were both flat.
Burson V6 Classic performance
The Burson V6 Classic has been reviewed frequently and most reviewers indicate it is a good fit for folk and jazz, but not necessarily for rock. I found this to be false in my evaluation. It is clear it is more evolved in design than the earlier produced V5 I already owned, particularly the better ventilation qualities on the V6. I chose the V6 Classic for review since the V6 vivid is based on the Burson V5 I already own and they seem to share many characteristics, if the published qualities in the bar graph are accurate. The V6 Classic seemed different enough from the V5 to interest me in hearing its advertised sonic qualities. Since the OPA627 was found lacking in previous listening tests, I filled the integrator op-amp socket of my Cyenne DAC with a Burson V5 and the gain op-amp sockets with the two V6 Classic op-amps I received from Burson.
Joni Mitchell The Asylum Albums CD 1 and CD 4
I could hear Joni’s deliberate pace in the music that reveals a more realistic music experience with a musical texture which was beautiful and a clarity that was a joy to listen to. Joni in her live performances on CD 4 sounded present in my listening room with a sweetness to her voice which was big and clear, yet textured with a beautiful timbre to her voice I had not previously heard; while the instruments encompassed me. The bass was strong amongst rounded vocals that echoed slightly, revealing the music hall acoustics. I had never heard such a beautiful voice, although I had heard Joni many times. Her phrasing was accomplished.
Roger Water, Amused to Death
The first five tracks on Roger Waters album, known for its soundstage and imagery, were listened to with the Burson V6 Classic op-amps. The spacing and imagery of the sound was revealing. The texture and dynamics of the music, with pounding drums, electric solo and the chorus singing was three dimensional. The best I have heard it. The presence of Rogers is real. I had oddly read that V6 Classic op-amps were not good for rock, as previously noted, but I had a different experience, the realism the Classics added to my system was nothing short of fantastic. The sound wrapped around the back of my head. Roger seemed to be singing in my face, he is so close.
I was so disappointed in the OPA627 and Burson V5 presentation of Early in the Morning I wanted to give the V6 Classics a chance to properly present the song. With the Burson V6 Classics in the gain op-amp sockets, finally the song sounds real. The keys of the piano can be heard vibrating and Harry is singing next to me. There is a brilliant texture revealed by the Classic op-amps positioning the struck keys, voice and distant bass. The realism of musical timbre is heard with an energy in the sound not previously heard.
Kill City by Iggy Pop
Kill City with Iggy Pop followed, with Williamson on guitar. It is a textually dense and energetic album. Iggy is in your face while the listener is enveloped by this forceful performance. The songs are catchy and floor tapping. This is a vinyl quality performance in sound by the Burson V5 and Burson V6 Classic combination. There is an absence of distortion, only the authentic presentation of instruments and voice. A total musical presentation which envelopes you with its presence, but maintains its clarity and details. The tone of each note is cleanly offered, while grandly performed by Iggy in his musical prime.
Avenue B By Iggy Pop
Avenue B by Iggy is live and his spoken introduction echoed as he spoke in the theater. His guitar strings vibrate in front of me. His voice is huge. The texture and details of the sound is so real I believe I am in the theater. Details in his performance are brilliantly revealed in this live performance which I had not previously heard. It was obvious now the sounds were always present, but only revealed now with the V6 Classics by Burson in the Cyenne 3100 DAC.
Clearly many things affect my perception of the V5 combined with the V6. The V6 Classics are so much more realistic and texturally beautiful than the Burson V5. I am sure though they complement each other with their revealing musical presentation and clear sonic image and details previously never heard on my system. I would pay for the V6 Classic op-amps if they were not offered free for a review.
I do not know how Burson was able to design the V6 Classic to produce such a musically beautiful presentation, suitable for rock or folk in my view. I am convinced from my experience that op-amps can change the sound signature of a DAC for the better. The best op-amps I have found to my taste have been made by Burson. I realize an op-amp interacts with the DAC circuitry and another DAC might produce a difference in sound quality, but in my system, the sound was superb and these op-amps will remain in place.
The value of discrete op-amps is denigrated by many, however many such as PS Audio co-founder Paul McGowan mention the intolerance of heat of IC op-amps due to size limitations; while discrete op-amps are not limited in this respect. He further states that discrete op-amps can be designed with a certain sound in mind and the use of the highest performing circuits and endless designer choices. Of course, the success of the project depends on the ability of the designer.
Specifications can not alone explain an op-amps appeal. Claims that discrete op-amps have more distortion than IC op-amps is usually used by critics to support the claim discrete op-amps are not worth buying or using. Gaskell’s 2016 dissertation at McGill university mentions that many designers and critical listeners believe that low level distortion may impart a beneficial tonal, timbral, or transient quality. Small amounts of distortion in a signal affect the “warmth” of the sound. He lists several studies showing that distortion is preferred by many listeners and his dissertation’s conclusion is that low level capacitor and op-amp distortion was found pleasing to many listeners.
Metrics can only replace subjective testing if they correlate well with a jury response. Measurement equipment in audio has to correlate with what people find pleasing in music, not what measurements such as THD say is best. Gaslighting someone who says something sounds good when it has poorer specifications is not a way to improve the science of psychoacoustics in the development of measures which quantity what consumers find pleasing.
Finally, Harman’s “How to Listen” is a computer-based, self-guided software program which teaches listeners how to identify, classify and rate the quality of recorded and reproduced sounds according to their timbral, spatial, dynamic and nonlinear distortion attributes. Other critical listening programs are available and can be used to improve the evaluation and improvement of audio systems through trained listener evaluations of products. Many audio companies do this to improve speakers, DACs, Amps, etc. Improvement of listening skills may improve the opportunity for agreement between critics as to what sounds good. One study found audio salesmen had the best listening skills, better than music critics.
I would be happy to review any discrete op-amps that manufacturers wish to have honestly evaluated.
Reactions: adason
Who else has 3 or 4 projects All on the go at once?
It's been a bit hectic in the shed since I decided to give skiing away. If you think building speakers is expensive try skiing in Australia.
Anyway I just counted up what I am doing and I think I need a bigger workbench.
I have a RoadKill set I am testing to determine real world power handling; now playing Chill-Out annual 3 non stop.
I need new bedroom speakers and i am cutting wood for a small 3-Way
I have 2 big cardboard boxes set up as well. One a Bloody Big Box; again a 3-Way and a smaller 3-Way using the recently purchased Peerless dome and in the back of my mind is changing the small box to a big 4-Way.
Although I am having fun I probably start more projects than I'll ever finish.
Anybody else have a similar affliction?
Sourcing LM4780 chips, and the rest of the bom for Audio Sector amp project.
Good morning all!
I just heard from Peter at Audio Sector and he's currently selling pcbs only. No worries, I'm fine with buying my own parts. I've heard nothing but good this about this kit but might as well make the opportunity to make a few improvements.
What you your thoughts on ways to improve these kits in terms of components selection? Better capacitors or diodes, etc. I have experience buying components to spec but no idea how they might affect sound in audiophile equipment.
Also, who the hell is selling lm4780 chips right now?! I can't seem to find them anywhere
Thanks everyone!
KEF KUBE 104/2 modification
Hi, I recently acquired a KEF KUBE 104/2 active bass equalizer. I know it was designed to use specifically with the KEF 104/2 speakers. But, I’m thinking to use it with the non-KEF speakers—ADS L1590/2. Regrettably, the brochure and the owner’s manual of the KUBE 104/2 have no technical literature anymore. Does anyone know its specifications, such as tuning frequency and Q? Also, it would be really appreciated if anyone know how to modify its tuning frequency and Q.
Small mic preamp
I needed a small cheap mic preamp to add an input for a project and I was surprised to find very few kits for that (at a reasonable price at least). So I decided to roll my own. It's a bit overkill for my current application but I wanted something I could re-use later on.
It's a mix of datasheets for the ina217-ssm2019-that1512. It has provisions for phantom power and a volume control in between the ssm2019 and the output if desired.
Values for c8-r9-r10 depend on application.
PCB size is 5*3.5cm. All connectors molex kk.
I'll order the pcb soon. So if anyone has corrections to suggest, I'll gladly listen.
XT25 + Visaton WG 148 R with pictures
Hello everyone,
I just mounted the Vifa/Peerless XT25TG30-04 on a Visaton 148 R waveguide and thought that I'd post some pics of how I did it in case someone is interested.
First here is the couple:
Due to the slightly curved front plate of the XT25 a small ~2 mm gap remains between the tweeter and the wg which I thought might not do any good to the sound:
A cheap solution was found from blutack or what ever this sticky stuff is called in English. I made a thin donut and placed it to the very edge of the opening in the waveguide:
I also put three small blobs of blutack on the tweeter face while I aligned the wg to make sure that it stays in place while I mark the holes.
I don't have any pics of the alignment process itself, but it's of course very straightforward. I used a 4 mm wood drill bit to push small marks on the wg wg back plate as the bit fit the holes nicely and was thus centered well enough automatically.
Some of the holes go close to the original mounting holes with thread inserts on the wg, but the original holes are not at the same distance from the center point as the XT25 mounting holes so they can't be used.
I first put some white paint around the mark to make the mark more visible for drilling and used a normal 2,5 mm metal drill bit for the hole.
3,5x13 DIN 7981 screws and washers were used to mounting:
And here is the result from the front:
I think they came out quite nice.
No idea how the sound is yet, though.😱
Reactions: stv
Oversized toroid
Hi all, I'm getting ready to build an audio sector gainclone in monoblock configuration (ordered the lm3875 kit but sounds like Peter may be sold out of those, so maybe lm4780 instead?). I see many people recommending 300va transformers for these, however being a firm believer than anything worth doing is worth overdoing I ordered 2400va [Edit: Two 400VA transformers!] units. I'm now having concerns that these might cause issues due to being too big. Are these fears unfounded? Is it safe to oversize transformers so much? Thank you!
Genuine Tripath evaluation boards RB-TK2350;EB-TA0103;RB-TA0105
I have for sale the following evaluation boards from Tripath.
All evaluation boards include the the cables and plugs, power
supplies are for the power section.
RB-TK2350-70€
EB-TA0103-100€
RB-TA0105-130€
Payment by PP shipment for Europanean Union
For more information PM
SPE21
Hi all was wondering if anyone might have the FRD & ZMA files for the SPE21. Parts express is out of the DAT V2 and the new DATS V3 is not in stock until November and i just can't wait that long if anyone has those files i will pay to get them. Also is anyone in the Tampa Florida area that can measure the speakers for me i will gladly pay you for your help. thank you
Which cheap Peerless midrange? 5" or 6"
The cheap "Party" boxes have been returned by my middle daughter.
They started whizzing and squeeeaking and became unlistenable when turned up to party volume.
I made these from some roadkill boxes I picked up and all the cheap hot melt glue seams look like they have dried out and vibrated loose.
OK I can fix that but I promised my neighbor a pair of cheap speakers for his shed and I want to re-use these repaired boxes.
I also want to use the little 4" midrange in something else.
My mate is a saxophone player and I know he likes a hot top-end in his speakers as he is always turning up the treble control when he's here listening.
I have a pair of the Peerless 830656 here which will work but I'm wondering if the bigger 830657 would be a better choice if I can squeeze it in.
Using two cheap 8" woofers and crossing around 300 to suit the existing coils I have, the tweeter I want to use is a cheap one and needs to be crossed around3K.
I think 3c to 3k is more suitable for the smaller Peerless but just double checking with the experts here
Has anyone tried an Icosahedron (20 sided with triangular facets.)
I share my ~shop with my brother and he is making these for fun.
https://en.wikipedia.org/wiki/Icosahedron#Convex_regular_icosahedron
What would anyone think the downfalls of using this shape for a cabinet be?
I,m thinking that a four inch bezel, 3 to 3.5 inch cone full range might be fun. To have a facet big enough to mount a four inch the inside edge (using 1/2 inch material) is 8.5 inches giving a volume of 0.7753665740741 cubic feet.
(I love to leave all those digits as if my measuring devices are N.A.S.A approved and calibrated.)
Any thoughts??
Jeremy
Horn Loaded NEO 8 test results (modified/stretched Joseph Crowe NEO 3 horn).
I'm building three line arrays with 6x GRS clones of the BG NEO 8 per speaker. I bought the Joseph Crowe Neo3 tweeter horn CAD file and elongated the design to fit the NEO 8. I then 3D printed the design in two different widths. There has been some discussion that blocking the 2 outermost slots in the NEO3/NEO8 speakers improves off-axis dispersion, so one of the designs only allows the center two of the four slots of the speaker to be exposed. I also tested two different sizes of rear chambers. The idea for my line array is to make very large (but shallow) speakers that will fit behind a 100" acoustically transparent projector screen. My modifications of Joseph's original design eliminates the nice round overs that curve to the back, so that the horns would fit flush in a large infinite baffle style speaker.
Here are all of the measurements together.
The complete Line Array would be 6x NEO8s stacked like below.
Here's the two designs, One Narrow/2-Slots Wide, one normal width/4-Slots.
These were rather rough prints with 1.0 x 0.3 mm layers. I printed in ABS because it sands and glues well. I spent minimal effort on sanding.
Here's the flat baffle I tested along with the large rear chamber (Old 6x9 Car audio box), rear chamber (green 3D print), and the two horns (2 and 4 slot).
The small chamber had a weird resonance around 2.4k The difference in level may not be real, as I forgot to test the small chamber, and had to re-set everything up to get the measurement. All of the other measurements below were done with the large chamber.
Small (blue) vs Large (red) chamber:
Large Chamber Distortion:
Small Chamber Distortion:
The flat baffle with flush-mounted GRS NEO8:
Straight-on measurement (0 degrees) of the flat baffle (red), narrow horn (green), wide/normal horn (purple).
15 Degrees. flat baffle (green), narrow horn (orange), wide/normal horn (red).
30 degrees:
Interesting that the narrow slot horn did help off-axis dispersion, but only above 16k.
45 degrees:
Flat baffle (no horn) 0, 15, 30, 45 degrees
Narrow Slot Horn at 0, 15, 30, 45 degrees
Normal Width Slot Horn at 0, 15, 30, 45 degrees
Final thoughts:
The normal-width horn did not have a very smooth output which was surprising, but it did have the same increase in output from 1k to 3k as the narrow horn.
I was also surprised that the off-axis levels diverged lower (1k vs 4k) with the horns.
Interesting that the narrow slot horn did help off-axis dispersion, but only above 16k; also interesting that the narrow slot was actually the loudest everywhere.
I don't think that I'm going to end up using the horns in my line array. The more gently upsloping response of the flat baffle should play well with low end lift that you get from a line array. And the lack of the sudden increase in response around 1k (that the horns have) should allow me to cross over the flat baffle mounted speakers lower (500-700 Hz).
Joseph already posted about a horn he actually made specifically for the NEO8. His wooden horn was much larger, and helps extend the usefull range. My 3D printed horn raised output down to ~1200 Hz, but Josephs's larger horn increased output down to 300 Hz! He posted about it here: https://www.diyaudio.com/community/threads/grs-pt6825-8-planar-test-results-300hz-horn.379684/
The fact that a horn-loaded NEO 8 can play down to 300 HZ is amazing. I'm convinced now that there is really no point to the NEO3. The NEO8 plays the upper range just as well, but allows a 2-way speaker with a lower crossover and probably more headroom as well.
Would anybody else choose one of the horns over the flat baffle in a line array? What do you guys think? Big thank you to Joseph Crowe for making his CAD files available, makes this silliness possible.
Can anyone handle the idea of a CD that costs $1,200 each? I can... .
The audiophile reissue label IMPEX (essentially, a major player in the same marketplace as Mobile Fidelity) last month reissued on Crystal Disc CD the David Hancock-engineered former North Star, former MFSL, former JMR/John Marks Records title "Songs My Mother Taught Me/Romantic Music for Violin and Piano," with violinist Arturo Delmoni and pianist Meg Bachman Vas.
This CD starts with an optical-glass substrate. (That makes for a very heavy CD.) The pits are embedded in a special plastic that is cured under pressure and light (I assume ultraviolet light), and the reflective layer is gold. The liner-notes booklet was signed and numbered by Arturo Delmoni. The packaging is beyond deluxe. The Crystal Discs are made one at a time; each one takes hours, I am told.
The target market is well-heeled audiophiles in Asia, where Dr. Delmoni is something of a cultural demi-god. People put up YouTubes of their stereos playing the North Star LP of what I call "SMMTM" (Songs My Mother Taught Me) just to show off that they own the North Star LP.
North Star LPs have gotten up as high as $400 on eBay. Verified sales, not asking prices.
The CD data on this release is from the Bob Ludwig 1993 digital transfer directly from from David Hancock's 30-ips, half-inch two-track original, in-machine, at-session tapes. David had a unique asymmetrical combination Noise Reduction and Playback EQ encode/decode. Bob Ludwig is the keeper of those keys. Arturo and I attended that session.
To me, the Crystal Disc has more detail and more body. I do plan to send an aluminum JMR CD and the Crystal Disc to Bob Ludwig for his evaluation.
The limited edition was pre-sold about 80%; I don't know if there are any left.
I am not posting this to brag. I think that what is remarkable is that a young recent law-school graduate with no real direct relevant experience managed to put the moving parts together for a shall we say, near-totally underappreciated young violinist to make a recording. 40 years ago.
Thank God money was so tight that we could not afford digital!!
If SMMTM had been recorded in 1982-vintage de-facto 14-bit digital resolution, nobody would care at all today.
In early May of 1982, I never would have dreamed that 40 years later, people on the other side of the world would pay so much money to get just that last little bit closer to one precious moment in time.
Which, thanks to David Hancock, Bob Ludwig, and Abey Fonn at IMPEX, remains ever frozen in amber.
https://www-joyaudio-com-tw.transla...=zh-TW&_x_tr_tl=en&_x_tr_hl=en&_x_tr_pto=wapp
If anyone wants more background, my memoir about Herb Belkin of MFSL tells the story.
https://positive-feedback.com/audio-discourse/mfsl-herb-belkin/
amb,
john
Reactions: JMFahey
For Sale Dayton DC160-8 Woofers For Sale
Pair of new, but tested Dayton Audio DC160 "Classic" 6.5" woofers. Very nice, smooth sounding woofer with great bass response for their size. Have used these in Paul Carmody's "Classix II" DIY speakers and love them. Paul has also designed a TMM which uses two of the DC160s and the Vifa BC25TG tweeter.
Asking A$90.00 for the pair, including standard tracked postage within Australia; also have a used pair, taken from my Classix II, work fine but some cosmetic flaws in the surround and rear gaskets; asking $60.00 including standard tracked post within Australia.
The DC160 is also used in other DIY speakers such as Dayton BR-1 kit with the Dayton DC28F tweeter and Dennis Murphy's "Affordable Accuracy Monitor", which is a BR-1 with revised and better crossover. Or the "Dayton III" MTM with the DC28F. Not the most attractive looking woofer, but that's what speaker grilles are for!
Reason for sale: too many speakers!
Links:
http://www.theloudspeakerkit.com/dayton-audio-dc160-8-6-1-2-classic-woofer
https://sites.google.com/site/undefinition/floorstanding-speakers/classix2-5
https://sites.google.com/site/undefinition/bookshelf-speakers/classix-ii
http://murphyblaster.com/content.php?f=pe_br1.html
https://www.parts-express.com/Dayton-Audio-BR-1-6-1-2-2-Way-Bookshelf-Monitor-Speaker-Kit-300-640
Thank you for looking!
Geoff
DC to DC, Switch Converter
I, usually, prefer to post after a given project has been made and tested, but, this case is different.
I have been requested to make a DC to DC converter. There are many IC's and modules online. I have found this : https://www.amazon.ca/Converter-0-5V-30V-Powering-Speaker-Amplifier/dp/B08KZYSRRG
This can be used without any, additional circuitry, yet, I have decided to make something, which is posted here : https://drive.google.com/drive/folders/1LME3Dg6xhWQB1pt2SPSd0jWdyPnyTgpQ
Please, comment, suggest, correct, inform, etcetera.
EV 1824M/8HD horn mids and T35A Tweeters
TWEETERS ARE SOLD EV T-35A tweeters $90 per pair plus shipping. Taken from my home stereo. Resistance measurements in pictures. I have 2 pairs, and they are very similar. Take both pair for $150. Shipping will be 10x8x6 inches and 4 pounds, shipped from 28601.
MIDS STILL AVAILABLE EV 1824M mid driver with 8hd horns. One pair (A and B) are in excellent condition for $200 per pair plus shipping the other pair (C and D) have small toddler finger indentations on the screen but work and sound fine, $150. Taken from my home stereo. Resistance measurements in pictures. I have 2 pairs, and they are very similar. Take both pair for $300. Shipping will be 16x12x12 and 20 pounds per pair, shipped from 28601.
View attachment 1010061View attachment 1010062View attachment 10100631824M D.JPGIndentation on C.JPGIndentation on D.JPG
Amp for experimentation query
I've been playing around without serious building.
I've been using a Behringer CX crossover for approximations and an old Rotel multi-channel amp.
The amp is OK but being an older amp [ the RMB 1048] the power is limited.
I've managed to put a little money aside and I'm thinking about getting something with a little more Oooomph so I can use it double duty as my party amp as the old ones are slowly losing power and I can't be bothered getting them rebuilt [ I'll be able to sell them tho as "Vintage amplifiers] so looking at second hand multi channel amps which units do people think offer the best bang-for-buck?
I'd like to opt for multi channel amps here to keep the space used for power to a minimum.
I'd like to spend less than $1k- if I can.
Bookshelf speaker with decent bass?
Hello everybody, newbie here:
I'm looking for a pair of bookshelf speakers for my PC (not for monitoring, just play games and listen to music), something better than the typical 2.1 Logitech kit, but in a 2.0 fashion trying not to miss the bass so much.
Searching on internet the DIY project "DINAS - Do I need a sub" was pretty promising:
Login to view embedded media
Until I came across these comments about the amp:
  • "The Lepai LP210PA is based on TPA3118 chips without heatsinks so don't use with 4ohm loads! use TPA3116 instead"
  • "The power supply that usually comes in the kit is completely insufficient to give full power"
I'm not sure about the TPA3116 as alternative due I'm currently using one on a Bluetooth chinese board from Aliexpress and it has noticeable background noise and a 'hiss' noise when a bluetooth device is connected (maybe is another component and not the amp itself):
2022-10-05 12_16_40-AIYIMA Placa amplificadora de altavoz de subgraves, amplificador de audio ...png
On top of that i'm from EU and the Lepai LP210PA ($63 on Parts Express) costs 105€ at soundimports.eu. Almost double the price 😵
So my questions are:
  • Suggestions?
  • Alternative /better components?
  • Is there a more convenient way to sound my PC instead of buying 2 amps + 2 good power supply + DAC with volume knob? I've seen some monitors that have all integrated in a single plate:
Thanks!
For Sale Vifa/PAE Shielded BC25SG18-04 Tweeters, New Pair
New but tested pair of these well known tweeters, asking A$50 including standard tracked post within Australia.
Product link:
https://www.wagneronline.com.au/tym...udio-speakers-pa/bc25sg18-04-69688/976499/pd/
The BC25TG family is used in many DIY speaker projects. Have used these in Paul Carmody's Classix II with the Dayton DC160; and in two way speakers with Peerless 830656 and SB Acoustics SB16PFC woofers. Really nice sounding tweeters.
Does not include the mounting screws, as have used in another project.
Geoff
3" or 3.5" full-range driver that works with infinite-baffle ?
I know this is an odd request. So, I'm putting it in the Full-range section where oddball speakers are the name of the game.
I'm replacing the incredibly cheap factory 3.5" speakers that came preinstalled in the top of my enclosed shower unit.
The back of the speaker is infinite baffle, using my entire bathroom as its enclosure.
While the front of the speaker fires into a medium-closet sized shower enclosure.
I know I won't get any bass. But can you think of any drivers that would excel more than something designed for a tiny speaker box and would work from I guess, 120hz-12Khz (or better)?
I'll need something that isn't un-treated paper.
Because it won't get wet but there will be lots of moisture in the air.
Original speakers:
Per my digital calipers, the cutout diameter is a tad over 3.3".
4X8 voltage doubler PSU for higher currents?
To make a long story short, I'm currently in i a situation where I have plenty of tubes and output transformers to play around with but very few mains transformers (and no budget to by new ones everytime I get another idea). Many of my tubes are european sweep tubes with from the P series with 300mA heaters, which allows a bit of creativite thinking when it comes to warming them up. I also have a decent stash of medium to large mains toroids with in the 2*25-40V range and dozens of 160V 680uF Rifa electrolytics.
My latest idea is to use a 77V 5,5A (single secondary winding) 400VA toroid to produce +100Vdc @ 300mA to heat a quad of PL36 (25E5) while simultaneously producing 200Vdc @ 250mA or so for B+. The 4X8-type voltage doubler looks right for the job, but are there any hidden pitfalls to look out for when using this schematic at higher currents?
My instinct tells I would need diodes that can take a bit of flogging.
http://www.bunkerofdoom.com/lit/4x8/index.html
Another option would be to use a regular voltage doubler to produce a single 200V rail and use a quad of PL519 (40KG6), although such an amp would rely heavily on the Vkf ratings of the tubes and not go unnoticed on the electricity bill.
Steeplejack ..... or how F8 met Mighty Babelfish M25 (& Schade)
It started here : https://www.diyaudio.com/community/threads/scryer-or-how-f8-met-mighty-sissysit.388550/
After that one, couldn't avoid my own greediness to try this combo too
Though, clever as I am, God's ways are his own and Buddha is everywhere........ meaning - better name for this one would be Mad Hatter, you'll see from 4R load behavior ........ :rofl:
Ok, for starters usual set of graphic files
Schematic is aggregate, find separate ones for pure Mos and for Schade later
Reactions: Plott
I want to insert a switch to bypass ESL resistor-crossover
using a biamped system with set.amps on the fullrange panel i want to make the basspart switchable to fullrange
bypassing the resistor crossover after the transformer
If that works i can run my system all day (maybe with compromised sq) and not only 2 hours in the evening.
Are there issues regarding voltage if i use 230V rated switches? As often Wago-clamps are used i think that should be ok
soundwise
have a nice day
Carsten
FIR-LADSPA: A LADSPA plugin for FIR filtering
Several weeks ago I started to write code for implementing FIR filters under LADSPA, and mentioned it HERE.
LADSPA plugins were never intended to do intensive processing, or to have highly variable CPU loads between calls to the plugin by the LADSPA host. This means that implementing an FIR convolution inside the plugin itself is probably not advisable, or even possible. So I have taken a different approach:
The FIR convolution is performed in a separate process that is entirely independent of, and is running asynchronously from, the LADSPA plugin and host. I call it an "FIR engine". This separate process is launched using an operating system call as part of the LADSPA plugin setup process. Parameters and other info are passed from the plugin to the FIR engine using a "control" FIFO, and other FIFOs are used to pass unprocessed and processed data.
Performing the FIR convolution in a separate process has several advantages. The LADSPA plugin, once up and running, only needs to put/get data into/out of the FIFOs and this keeps it very computationally lightweight. The FIR convolution can only be performed when the desired length of data has been obtained via LADSPA. Because of the real-time nature of the audio processing, this takes Ndata/sample_rate seconds. For example, at 48kHz if you process 16384 data points per call it will require the FIR engine to collect incoming data for about 0.35 seconds before it can perform one convolution. During that time, the LADSPA plugin might have been called 16 times (given a typical frame of 1024 samples). The speed requirement of the convolution can therefore be as slow as 0.3 seconds or so, by which time the next 16384 samples have been collected and need to be processed. This can be helpful when using low powered Linux hardware such as a Raspberry Pi. Additionally, the OS is free to schedule the FIR engine process around other processes, and there is no need to run it at a high priority, etc.
As part of the set of of the plugin and FIR engine, a uniquely named directory is created in the tmpfs (files in memory) that comes with all Linuxes. The FIR engine collects and writes to this directory a file that lists the mean and longest "cycle time", that is the time to process the data and return it to the LADSPA plugin. The cycle time latency can be obtained in a test run for a given platform and FIR filter set, and then this is supplied to the LADSPA plugin as a parameter during normal use. This latency timing info is used to set up internal buffers so that underruns are prevented.
Because the FIR engine is a separate and independent process and because some LADSPA hosts do not correctly tear down the plugin (by calling deactivate, etc.) I have written the FIR engine to self-terminate and cleanup after itself. This includes deleting the tmpfs directory in which it was operating, and the FIFOs. Once this process is completed there is no sign that the FIR engine was ever there. A pair of error logs are written to the tmpfs and not deleted, however, on reboot the tmpfs filespace is wiped clean. The user can manually delete the error log files anytime. Since these only are used to record fatal error messages, it is not likely they will grow to any appreciable size.
I am currently coding up the FIR convolution using FFTW but have everything else functioning well using a dummy convolution function that simply passes input to output in the FIR engine. I hope to get a test version fully up and running in a week or so and will post updates as I have them.
Beginners question: slightly other geometry
Hi
Apologies for yet another noobie-question, as I have no knowledge of all this but am curious…
I will build a 3w speaker from a kit in the near future. This will be my first ever.
The designer wasn’t too specific about the cabinet except for the front-baffle and the volume.
While contemplating various details, the question came up wether changing the cabinet‘s geometry (making it „conical and a little deeper) without changing the volume or front-baffle would affect the sound?
New AD1862 DAC chips and Miro's DAC PCB
I wanted to try Miro's AD1862 DAC. Apparently the only legitimate source fo thse chips is Digi-Key and I had to purchase 14 of the DAC chips. I've already sold some of these but do have 4 chips left. I paid $25 each for the chips and will sell them for the same amount. I also had 10 of Miro's fine PCBs made by JLCPCB. I will give these for free with the chips. Please send me a PM if interested.
Cheers.
Reactions: Paddy Garcia
Denafrips ARES II board repair
I just got a spare Denafrips ARES II board. I bought it used ("in working condition") but I doubt it is the case. The initial plan was to use it in a DIY DAC perhaps with a lithium battery power supply. But first I need to power-up this board, repair it and test it. Can you help me with that ?
I am looking for information about the original transformer and how it is wire on the board (PIN 1 to 8) ?
Here is the top of the board:
I already see two problems on the board :
The two center PIN of the chip (red arrow) were connected.
Any clue of the chip reference ? I think it is a LDO fix the gate voltage the transistor.
On the LT1763 LDO seems defected (yellow, too much heat)
Hiss from TPA3116 amp board that dies away when pot is at max???
Hi folks, this is a strange problem I've never come across before. I stuffed a YJ tpa3116 ( black/blue) board in an enclosure with a 2 way input selector switch and a 10k tocos cosmos pot. I've used this setup before without problems but this time I'm getting quite a loud hiss from both channels that isn't coming from a source and dies away to almost nothing when the pot approaches max (nothing playing) in the max position the hiss can only be heard with my ear to the speakers but at normal listening positions I hear the hiss from my chair across the room. The same pot worked fine previously with a buffer so I'm kind of confused why it's not ok with the the amp board. I have a 20k miniature stepped attenuator I could try but I can't see how that would make any difference. Any ideas would be good to hear as this is both annoying and confusing.
Cheers D
DBX 234 /XL 3way crossover
I had to sell DBX 234 XL 100% working conditions,use only a few hour only ,
They are not no more using after brought fusion 503 .
Price $50 plus world wide shipping
Best regards
Myint
Designing ES982x-based ADC - feedback wanted
After looking at all the existing options I can find for adding an audio ADC to a RPi, I've decided to go ahead with making (or at least, trying to make) a RPi hat based around the ES982x. It will be pretty similar to the datasheet circuit, using ESS's own ES9311 regulator to power the ADC chip. The ESS datasheets use OPA1612 op-amps for the input stage, and I allowed for them, however the first prototypes will use ES9820 + NE5532. The main design requirements are:
1. Single-ended connectors onboard, with headers for diff. input
2. Use I2S, not USB
3. Hopefully >100dB THD+N - significantly better than other options available
4. Parts available (not that easy)
It's really for people who want a high(er)-quality I2S input to their Pi, because there are high-quality USB ADCs (Cosmos) and ~90dB THD+N hats available (e.g. HiFiBerry ADC+DAC and this open source WM8731-based one). I also think that a Linux driver for the ESS chips could be useful for someone else.
There will be a few parts of this project that are new for me (especially the driver). Here is the first version of the schematic... I welcome feedback and suggestions. For example, one thing I'm not sure about is whether the resistor values can be left the same when substituting the NE5532 instead of OPA1612.
FYI, my own use-case is to provide analog input for a RPi DSP+xover for 3-way active speakers. Analog input selection is done on a relay board inside the case and the RPi USB ports will be exposed through the back panel, so a USB interface is not gonna work.
Ultimate Mastering Monitor Speakers
My background is in music production so I know very well all of the commercially available mixing / mastering monitors. I want to explore building my own.
From the monitors I have used I would like to take the general characteristics of:
- the highend from Genelec S30D ribbon tweeters
- the midrange from ATC scm200 soft domes
- the Lowend from Barefoot MM27 but with extended response
For my purpose I would like to be able to go to fairly high SPL's and also frequency linearity is crucial. Budget wise I want to be uncompromising but not needing to go into extreme esoteric territory.
1. What is the most suitable Ribbon Tweeter? (Raal 140-15D / Founteck NeoPro10i / others?)
2. What is the closest available driver to the midrange dome of the scm200's? (Volt VM752 / Morel SCM634 / others?)
3. Not sure what LF drivers would complement the above but would like 2 x 15" drivers in a side firing configuration (a la barefoot MM27) (Volt RV3863 / others?)
Would appreciate thoughts on this configuration with professional audio mastering in mind.
Currently designing a new studio so there are no space limitations - the studio will be big enough to accomodate any design.
Current thinking is to use Hypex amps / power supplies / DSP. But also open to other suitable pairings for the above.
Most likely closed cabinet and not ported design but this also not finalised.
Thanks in advance for any advice for this novice !
Re building Metaxas Solitaire Amplifier
I have a pair of Metaxas Solitaire Amplifiers that drive my Infinity Kappa 9 speakers
The amps were sent to a reputable Perth electronic service outfit ,but were deemed unserviceable by the technician.
The amps in question were revealed on the techs' Hall of Shame
https://liquidaudio.com.au/hall-of-shame/
So I have decided to rebuild myself , but the question is - Is it a Bridge too Far for a novice to undertake?
I have plenty of time at my disposal as I'm retired .
Any comments would be gratefully received.
Thank You.
Reactions: Bonsai
Digital level meter for R-R tape deck
The analog level meter has been designed for use as a recording level meter for a reel to reel tape recorder. But it can also be used as a standalone device. The LED bar can contain up to 50 elements per channel. To reduce the level of interference, static indication is used. A feature of the meter is fully digital signal processing. That allows you to make the meter metrologically accurate, with an exact match of the dynamic characteristics. All parameters are programmed using special software on a computer.
Each meter channel contains two signal processing branches, the readings of the first one are displayed as a bar, the second - as a dot. This can be used to display two values, such as average + quasi-peak, or quasi-peak + true peak. For each of the branches, you can individually set the gain, integration time, response time, decay time, hold time, fall time, peak hold time, peak fall time. The scale type is set by assigning an individual threshold level to each LED with an accuracy of 0.01 dB. This allows you to build a linear, logarithmic, S-shaped with a stretch near 0 dB and other scales. A set of all parameters, including the scale type, is stored in EEPROM as a preset. There can be 4 different presets in total. They can be selected with the control button. The second button can turn on the indication of statistics of maximum levels, as well as reset it.
Here we will talk about how simple things can be made difficult 🙂
Block diagram
The block diagram of the level meter is shown in the figure below. This diagram shows one stereo channel of the meter. The input signal is fed to a differential amplifier implemented on an op-amp (Meter50_v4_sch.pdf). It performs two tasks: it shifts the signal by half the ADC scale and allows you to implement a balanced input. The signal shift is necessary because the built-in ADC is unipolar, its input range is from 0 to the reference voltage. A balanced input is desirable even if the signal source is single ended. It allows you to take the signal relative to "analogue" ground and eliminate the interference present on the ground of the meter circuit. If the level meter is made as a separate device, then balanced inputs with XLR connectors can be implemented.
All signal processing is done digitally by the STM32F100/103 microcontroller. To avoid the use of an anti-alias filter at the ADC input, as well as to be able to register short signal peaks, the sampling frequency was chosen quite high - 96 kHz. With DMA, ADC samples are stored in a buffer in RAM. When half of the array is ready, an interrupt occurs, the data is read and processed.
DC removal filter
The first operation on digital data is to remove the DC component from the signal. This must be done before the signal is sent to the detector. With a meter dynamic range of about 60 dB, even such a small DC component as 0.1% of the ADC scale can be equal in magnitude to the useful signal and distort it.
The simplest filter that suppresses the DC component is the differentiator. It has one zero at zero frequency. The DC gain is zero (as required), and as the frequency increases, the gain increases. For a discrete implementation of the differentiator, its difference equation has the following form:
y( n ) = x( n ) – x(n-1)
In fact, this is the simplest FIR filter. When implementing, it must be taken into account that the output value must have a width of at least 1 bit more than the input value. Since the input signal in theory in one cycle can change to the full scale. Increasing the gain with increasing frequency is not satisfactory, since the gain will change in the operating frequency range. Instead, you need to get a linear frequency response above a certain cutoff frequency. Obviously, this requires adding a pole at the desired cutoff frequency. This can be done by connecting the differentiator and the 1st order low-pass filter in series. The overall frequency response will have the desired form. Such a 1st-order low-pass filter in such applications is often called a "leaky integrator". Because in the analog version, such an integrator is implemented by adding a resistor in parallel with the capacitance, through which it will slowly discharge. For a discrete implementation, the difference equation of an ideal integrator is given below:
y( n ) = y(n-1) + x( n )
To add a leakage, you need to multiply the accumulated value by some coefficient less than one:
y( n ) = A*y(n-1) + x( n ), 0 < A < 1
This is the simplest IIR low pass filter. The name "leaky integrator" is used to indicate that this filter is applied in a somewhat unusual way - the operating frequency band lies in the stopband.
The cutoff frequency here should be chosen low compared to the sampling rate, which means that the A coefficient should be close to unity. The cutoff frequency can be calculated using the equation:
f = (1 - A)*Fs/2*pi, or A = 1 – 2*pi*f/Fs, where Fs is the sampling frequency.
The general difference equation for the filter will look like this:
y( n ) = x( n ) – x(n-1) + A*y(n-1)
In fact, this is a first-order IIR high-pass filter. It is equivalent to a differentiating RC chain. Such a filter has one zero and one pole. If you show them on the z-plane, then zero will lie at the point z=1, and a little to the left of it on the axis there will be a pole.
The audio bandwidth starts at 20 Hz. But it is desirable to make the cutoff frequency lower so that a noticeable phase shift does not appear in the audio band. This filter is not phase-linear, so signal components of different frequencies will be delayed for different times. The result of their addition will give a different waveform, the peak level will be incorrect. There are phase-linear FIR high-pass filters, but they require a lot of computing resources to obtain good linearity of the frequency response in the passband at a low cutoff frequency. There is a filter option for removing DC component based on MAF (moving average filter). It doesn't use much computational resources, but it does require a lot of memory to get a high sample rate to cutoff frequency ratio.
In this case, the requirements for the filter are not very strict. It is necessary to remove the DC voltage, which can only change very slowly (for example, due to the temperature drift of the op-amp). A significant part of the compensated bias is generally constant, as it is associated with the error of the bias voltage divider. Therefore, you can simply make the cutoff frequency lower, while minimizing the phase shift. A cutoff frequency of about 5 Hz would be a good choice. The phase shift at a frequency of 20 Hz will be about 17 degrees, which can be considered acceptable.
When implementing a filter in integer arithmetic, one must take care of the ranges of numbers at all stages of the calculation so that overflow does not occur. The leaky integrator and differentiator can be connected in any order. But to avoid overflow, the differentiator should be included first.
Another problem, more complex, is related to rounding errors. For a filter cutoff frequency of 5 Hz at a sampling rate of 96 kHz, the value of the coefficient A = 0.999673. To carry out calculations with such a coefficient with good accuracy, it is required to increase the bit depth. The reverse transition will be a quantization with a larger step, which leads to the appearance of an error, or quantization noise. As a result of such an error in the filter, a parasitic constant component may appear at the output, which is even greater than the one that is suppressed. This error may cause the filter to fail. As a practical test has shown, the filter does not actually work without requantization error correction.
In this case, the ADC is 12-bit, the samples are placed in 16-bit signed integers. Some margin is needed here to protect against overflow. Multiplication is done in 32-bit format. Then, when moving from a 32-bit intermediate result to a 16-bit result, a quantization error will occur. In one of the publications it is proposed to add a quantization noise spectrum shaper to the filter by introducing error feedback. The implementation of this method is very simple. I made my own implementation which uses the same error correction principle.
static const double POLE = 0.999673;
static const int32_t A = (int32_t)(UINT16_MAX * POLE);
static int32_t acc = 0;
static int16_t xx = 0;
static int16_t yy = 0;
x = Input;
acc = LO_W(acc) + A * yy;
yy = x - xx + HI_W(acc);
xx = x;
Output = yy;
Quantization occurs by discarding the lower half of the 32-bit number. The discarded value is the quantization error. The original number is signed, but the error is always negative. For example, if the least significant bits of a positive number are replaced with zeros, the number will decrease, and some positive number will have to be added to correct the error. If the least significant bits of a negative number are replaced by zeros, the number will become large in absolute value, while remaining negative. This means that in order to correct the error, you will again need to add some positive number. Therefore, the error can be extracted from the original 32-bit number by simply zeroing its high half along with the sign bit.
Detector
Next, a full-wave rectification of the signal is performed. This is the easiest part of processing. When the DC component is removed from the signal, the task is to calculate the absolute value.
Filters
Next are several filters that define the dynamic characteristics of the meter.
The main characteristics of level meters are integration time and return time. The integration time determines how quickly the meter reacts to changes in signal level. If the integration time is large (about 300 ms), the so-called VU-meter is obtained. Such a meter will not respond to short signal peaks that can overload the recording path. When pointer instruments were used as the indication device, the integration time could not be made small due to the inertia of the moving system. Therefore, often the VU-meter was combined with a faster LED peak indicator. The use of high-speed information display devices, such as gas discharge tubes or LEDs, removed the problem of obtaining short integration times and made it possible to build peak or quasi-peak meters.
Most often, quasi-peak level meters are used to measure the signal level in audio paths. Unlike true peak meters, which in theory have zero integration time, for quasi-peak meters this time is defined by the standards. It would seem that it is necessary to achieve the minimum possible integration time so that the indicator can register the shortest signal peaks without overloading the path. This approach is used in digital paths, where even a short-term overload leads to undesirable consequences. For analog magnetic recording, a short overload may not be audible at all. If you want to completely eliminate the overload at the peaks of the signal, you will have to reduce the average recording level, which will lead to a more audible problem - a decrease in the signal-to-noise ratio. Therefore, for analog magnetic recording, it makes sense to choose some optimal value for the integration time of the level meter so that it allows short-term overloads.
The integration time for quasi-peak meters is defined by IEC 60268-10 as "...the duration of a burst of sinusoidal voltage of 5000 Hz at reference level which results in an indication 2 dB below reference indication". This standard defines an integration time value of 5 ms for quasi-peak meters.
The integration time is not numerically equal to the charging time constant of the smoothing RC circuit. If an RC circuit with a charge time constant of 5 ms is installed at the output of the peak detector, then the level of -2 dB (about 0.8) will be reached in about 20 ms. To reach -2dB in 5ms, the charging time constant of the RC circuit would need to be around 1.25ms. Thus, the integration time is approximately 4 tau RC circuit.
In addition to the integration time, quasi-peak meters have a return time that is much longer. This time determines how fast the reading will fall after the signal is removed. If this time is made small (for example, equal to the integration time), then the indicator readings will change too quickly, making them difficult to read. For VU meters, such a problem did not arise due to their low speed, one time constant could be dispensed with. In high-speed quasi-peak meters, it is necessary to artificially slow down the fall in readings so that the operator can read the information.
The return time determines how quickly the meter reading will fall by 20 dB after the signal is removed. It is also not equal to the discharge time constant of the RC circuit, but is approximately 2.3 tau. The return time value is also set by the standards. It differs for indicators of different purposes. For indicators of the first type, which serve to check the signal level during its operational adjustment (this is just the case of adjusting the recording level in a tape recorder), the return time should be 1.7±0.3 sec. Accordingly, the discharge time constant of the RC circuit should be approximately 740 ms.
Level meters have another dynamic characteristic - response time. It may not be entirely clear. For inertialess devices, ballistics is artificially formed, similar to pointer devices. Increasing the response time in this case should not increase the integration time of the meter. The short signal pulses should still display correctly. To do this, the detector must "wait" until the reading reaches the measured value, and only then start the fall. In amateur designs of quasi-peak meters, with a fast increase in the signal level, the bar immediately jumps from one length to another. This is not the case with professional quasi-peak meters, because the increase in response time has a positive effect on the perception of readings by the operator. In VU meters, this is also not the case, there the smoothness of movement is obtained due to the large integration time. The response time is defined as the interval from the moment the test tone burst begins until the reading reaches -1 dB.
Integration time
To obtain a given integration time, the detector output must be smoothed with a filter. The smoothing filter is not a simple low-pass filter, but a more complex filter with different charge and discharge time constants. The charge must be fast to provide the specified meter integration time. And the discharge must occur slowly to provide a given return time, which is much longer. Therefore, the integration time filter is turned on only when the signal rises; when the signal decreases, it is kept at the same level. A separate filter is used for signal decay.
The difference filter equation has the following form:
y( n ) = y(n-1) + A*(x( n ) - y(n-1)), where A = 0.0083 for Fs = 96 kHz
A 32-bit accumulator is used to obtain the required calculation accuracy. Filter coefficients are 16-bit unsigned. They are defined as A = 65536 / 96000 / tau.
  • Meter50_v4_sch.pdf
    Meter50_v4_sch.pdf
  • Meter50_v4_pcb.pdf
    Meter50_v4_pcb.pdf
  • Pcb.zip
    Pcb.zip
  • Mask.zip
    Mask.zip
  • Firmware.zip
    Firmware.zip
Are you really fine with IC voltage regulators ?
Hi ! looking for some information about dual voltage power supplies for preamps in an interview with the Conrad Johnson designer he states that they prefer to realize voltage regulators with discrete parts and not using single chip voltage regulators. In their opinion they can have an impact on the sound ... and not for the good.
Looking then at some preamps schematic i see that in the late '70s and early '80s many of the TOTL solid state preamps actually used voltage regulators made out of discrete parts.
I guess the reason was that this IC regulators were not available ? 🙄
They are clearly handy ... but are they also completely fine to use in preamps ?
i would like to get some opinions ... i have a feeling that i was looking at the wrong part of the story ... the preamp circuit ... instead the secret of good sound could lie in the power supply design and construction 😕
I am attaching one schematic just to explain what i have in mind ... more or less
Why no flat piston subs?
Except for the KEF B139 (and discounting the few odd Japanese novelty offerings) no piston-type drivers seem to have ever caught on, and apart from expense - which shouldn't be excessive anyway - are there any reasons not to make 'cones' this way for LF applications, and any reasons they should be? I could see a Kevlar/Nomex honeycomb/Kevlar piston as having some merit.
Rotel RD-30F tape deck rewind/ff not engaging
Hello!
I just picked up a Rotel RD-30f and it’s need of some repairs and could use some help pointing in the right direction.
First up is the eject mechanism is super sluggish and almost doesn’t open on its own. I have a video of that here:
Video
Second is the rewind/fast forward doesn’t work. I press down to engage it but then it immediately stops but the button remains pressed down. If I hold down the button more it will run.
Dali Concept 8 woofer configuration
Good evening all,
I got a pair of these Dalis as part of a recent rubbish collection, ie for free.
First thing I noticed was there are 2 ports, front and back, for the 2 woofers and reading online seemed to suggest this Dali series used separate enclosures for each woofer.
However removing the woofers showed that there is only one woofer enclosure with 2 ports. Why would Dali do this? A first inspection shows the 2 woofers are wired in parallel. Is it just for looks?
Cheers, sp
PPI 2300AM
What would cause this on Q16 ?
Is it from stress or the legs being bent and then bent back ?
Everything appears to be factory ampnhas never been repaired as far as I can tell .
The client bought the amp off someone and wanted it checked over before install .
I cleaned the wire strands from the board that I found so far
Measuring bias (Cyrus amp)
From the diagram below, there appears to be a connector that allows for bias to be measured.
Am I correct that to do that I need to remove the jumper (I will check the board tomorrow morning) and connect an DVM between those point (set to amps) to measure the current?
The VR allows the bias current to be set - can anyone tell me what this should be?
PeeCeeBee V4 GB!
Hello guys!
A fresh new PeeCeeBee is here, the V4! In this thread group-buys for the printed circuit boards are arranged.
It's a Lateral MOSFET based Class-AB amplifier with symmetrical "current feedback", evolved from from the diverse PeeCeeBee series, and now with excellent sonics coupled with excellent looks. 🙂
The new design is electrically and sonically a step forward from the "stubbornly" simple but very good sounding designs released in the original PeeCeeBee thread. I say a step forward partly because it incorporates some extra well-known techniques to handle some of the problem areas in the old designs and allows a quicker and safer mode of set-up and operation, but mostly because while doing so it didn't become a fatigue-inducing clinical sounding amplifier. The layout is designed by myself and the amplifier is very stable, both thermally and electrically. The amplifier has similar sonic signature to the previous peeceebees in the mid and high frequency band, but the low-frequency performance has been substantially improved so that it can be used as a full-range amplifier with effortless bass as well as beautiful midrange and highs.
It uses a simple but effective diode-clamp based soft-clipping so that occasional overloads don't bother listening enjoyment. The two jumpers, when open, remove the chance of overloading Q9/Q10 while setting-up. The constant current sources keep the input/VAS bias much less affected by power supply variation during loud playback and/or mains fluctuation.
The following two screenshots show the design:
NmP6djgiQemEEJ6ulRHneov_72vVjiTZ9m4BI3cpO2QfjeALR5SlxKm8w0Gi1XCOE4CK5j0wXDgvFAs=w640
79M-Sjnh5trf3F_kybX_kqhk2f0YDxv8R5qIQNxPcSLeHsp_RCwc-LA8Y6ekX462vT1igjCUtzWiah4=w640
This is how the PCB looks in real world:
A fully assembled channel:
Some specs (measured with generic components/passives and basic unregulated linear PSU):
Maximum Power - 50WRMS/90WRMS into 8R/4R load with +/-35V PSU
Maximum allowed PSU voltage for 4R operation - +/-35V (with default clamp diodes and BD BJTs for Q9/Q10) and +/-42V (with higher voltage rated clamp diodes and MJE BJTs for Q9/Q10)
Frequency response(simulated) - ~2Hz to ~800KHz (-3dB)
AC gain - 23 (27dB)
DC gain - Unity
Input level for 50WRMS into 8R - 1VRMS
THD 100Hz 10W - 0.0005%, 1KHz 10W - 0.001%, 10KHz 10W - 0.002%
Slew Rate - 100V/uS
SNR - >100dB
Offset variation - +/-10mV
Screenshot of 1KHz THD spectrum (10W into 8R resistive load, 0.002% source THD):
nBqxTvAn3leWaiaw0BxzZnGnoMSmcwOihGFiLyx2lDkHB9puaaCMxlO8C8rfYXBP7BjLFiJmCNPjWg8=w640
Screenshot of 1KHz + 5.5KHz IMD spectrum (1.7W into 8R load):
Sk9ZuWGXEtFqEJcykNQKpl9qe03Hl58IhLL5OHWrQAbtGe4UA3Jl92Pv-YsnkN_uQd1ZxPH-D6iPxC4=w640
__________________________________________
Group Buy Information:
The PCBs are 92mmx64mm 2-Layer and I plan to batch-print 50, 75 or 100 PCBs depending on interest and how many people join in the GB list. The boards are made with 2.4mm FR4, 60micron copper, HASL finish, white silkscreen and black solder mask, as shown in the above pictures.
> The PCBs cost US$10 a piece.
> After the GB list is full, each user will be contacted and sent the first invoice for PCB cost, and the rest (including shipping charge, packing and processing charge and PayPal charge) is to be paid before shipping the boards, for which the second invoice will be sent.
> International payments are accepted through PayPal and payments from within India are accepted through bank account transfer/deposit, NEFT etc.
> Delay between placing the batch order to PCB plant and delivery of the boards to me will be 18-20 days.
Shipping Information:
Two forms of shipping available. International Air Parcel and Registered Post. Former takes about 15-20 days to deliver and the latter takes about 30-40 days. Both support tracking.
_____________________________________________________
GB1 (April 26 2017)
Update: Pending members and anyone wishing to join, Please notice:
PM/invoices will be sent up-to 5th May.
Last day of confirming order is 7th May.
PCBs will be ordered on 8th May.
Update(May 9 2017): Total 120 boards ordered. There are still 10 spare PCBs so join in if interested in a couple.
Update(May 11 2017): GB list full. No new entries are being taken until June 1 2017.
GB1 Ended.
GB2 (June 15 2017)
Second group buy has started.
GB2 Ended.
GB3 (Sept 12 2017)
Third group buy is now open for entry. Join in if interested!
GB3 Ended
GB4 (Dec 23 2017)
Fourth group buy has started.
GB4 Ended.
GB5 (Aug 17 2018)
Fifth Group Buy arranged. Boards available.
Important Links:
Download Latest BOM for PeeCeeBee V4 >Here<
Download Setup Guide And Component Indication >Here< (Follow this to populate and start the PCBs)
Heat Sink Drill Template >Here<
Thanks.
shaan
For Sale FS Scak Speak Sonus Faber Cremona units in KIT
UPDATED SALE.
Here for sale some Sonus Faber Cremona units.
Some units came from my Cremonas (damaged when my son pushed the dust cap of a woofer with his finger). A pair of woofers came from SF SAT. I will explain:
2x SF Cremona Tweeters. Perfect condition. No damages. They are used and in perfect working and cosmetic condition.
Asking 100€ +pp fees + shipping for the pair
2x SF Cremona Scan Speak 18W8531/G03 Woofers from my Original Cremonas.
One was repaired because the dust cap was damaged by my son. Speakers leads changed as well. Everything was repaired in a Professional service. I can provide invoice.
They measure the same. Perfect working condition. Some minor cosmetic issues (7/10).
Asking 190€ +pp fees + shipping for the pair
This pair of woofers came from one friend from SF SAT.
The owner coated them. They measure the same than original ones.
Perfect working condition. Average looking condition due to coating (5/10)
Asking 160€ +pp fees + shipping for the pair
I can make lots at discounted price and I can include for free a pair of front baffle for woofers
Each (mm) 758H x 210W x 19D Capable for 2x Scan Speak 18W8531 woofers and a jantzen Ø100mm Bass Refflex port (Ø138,50mm hole)
Reactions: vassilis1984
1978 Rotel RA-1412 - slight hissing and pops in the headphone port
Hello!
I just bought this 1978 Rotel RA-1412. Its my first vintage amp and am pretty excited. So far so good aside from a couple things. I noticed while listening through one of the headphone ports im hearing a slight hiss and some crackle pops but its not consistent... only seems to happen once and awhile for a few minutes. I dont hear it when I source isnt playing but it could be by chance.
The way im getting the source is like this: hi-res audio from Windows PC> out through an optical cable> into a newer Rotel RA12 > Pre-Out > to RA-1412 Aux in.
Any place I should look to improve the noise?
The buttons on the right side of the unit (which picks the source) are also kind of finnicky and stick. The bottom button pops completely off if I push it in all the way and I push another button above in. Anyone know where I can find the parts to replace the switch?
Thanks again for everyone's time!
TDA1541A DAC Project Discussion
I am sharing the file I got from my friend, it's a TDA1541A DAC with multiple input interface including I2S.
Also, for convenience there is a InterActive BOM that helps a lot while soldering components.
The attached .Zip file contains
A) GERBER files in Zip, ready for fabrication.
B) BOM in HTML.
Please let me know if there is problems.
J
Need Some Advice on Caps to use in Nikko Alpha ii Filter Caps
Hello, I have a set of two different brands of capacitors to install in my Nikko alpha ii power amp and can't decide which are better to use.
When the amp was new, it came with 10,000uf 63V 85 degree ones that had been changed out to others before I got the amp.
The ones that were in it when I got it were Jamico 10,000uf 100V 85 degree units.
I am doing a total re-cap of the entire amp and figured I would replace the filter caps as well while I have it all apart.
I purchased a kit with all caps for the amp, and have no issues with any of them except the filter caps..... and reading all of the forums has got me a bit confused.
Have new caps from Mouser here or new caps that came with the kit.
The choices are: EKMH630VSN103MA50S Nippon United Chemi-Con 10,000uf 63v 105 degrees or Kemet ALC70A103EH100 10,000uf 100v 85 degrees.
I have read some bad things about the Kemets used as power supply filter caps, but not sure if it pertains to these particular ones. Specs are not too bad on either....
So hoping I can get some suggestions from those who know more about this than I do.
Thanks!!!
Russ
Sonos/IKEA Symfonisk hack
Hi there,
I read this article about hacking the Sonos / IKEA Symfonisk, and thought I'd try it with a nice old radio I have in my kitchen. It earns its keep as a decoration alone, but it sure would be nice to get it playing as well.
Now, the first issue that I've run in to (I'm sure there will be more), is that the radio only has one single woofer, while the Sonos looks like some sort of bi-amp setup. I'm not familiar with such. Would it be possible to wire both sets of cables to the same woofer?
From makezine.com:
Project Madness
Hello all
Everyone who know me understand that I am a big Audio Physic fan, so when I see this one launched at hi end München show, I am getting really stunned... at every point. There are many things that tick boxes here
https://www.audiophysic.com/en/medeos/
  • Point source, or really close to point source, the whole passband down to around 300 Hz is managed by the central 3 drivers really close together, the other drivers symmetrically around this point.
  • Lot of cone area in the mid-bass up to 300 Hz, must leave us with unreal dynamics, and there is nothing like lots of cone area
  • Woofers for midbass located low and high which means it triggers different room modes and so should be more even mid-bass and less room influence with mid-bass, the same gows for the lower bass
  • Integrated subwoofers, an all in one solution that makes it feasible to place even in a medium size flat (like mine)
    With four large / tall towers my place would look like Stonehenge, I don´t want that.... this is also going into the main living room
  • Really really really cool design, the way it looks, IMHO 😍
Somehow this ticks all the boxes for me, except for the price of €160.000, no matter how I look upon it, this is out of reach for me, so it makes me thinking, is it possible to build something with this geometry?
This is a really complex thing to do, 5 way with 3 separate cabinets each side.... Call me absolutely insanely crazy but I am thinking, is this a project I would like to consider?, maybe 😱
It could be a setup with Bliesma beryllium tweeters and hi mids, Purify mids and woofers, several possibilities with subwoofers. But to have any chance it must be active with digital crossovers, this would easily be a €20K to €30K project, so there is pretty high risk here.... I have a working title of "project madness" 🤣
I have not been doing any simulations or calculations on cabinets sizes and/or setup yet.....
Any thoughts guys
Stax DA100 Link For Download The Schematic
Hi to all diyAudio friends
Here is a link for downloading the STAX DA-100 schematic.
http://fileshare.eshop.bg
and enter da100
This is are a rare and hard to find original japanese schematic.
Some years ago i built this amp,whit 2SC3381 and 2SA1349 double transistors.
Currently a friend has this unit,the amp work perfectly from 8 years.
The listen features ,he said,are very good.
If someone download this schematic a little discussion can be started 😱 😱 😱
ESL diaphragm film
Hi whoever's reading this.
I've been planning to build a pair of ESLs for a while now, and I've figured out where I'm buying everything from, except for the mylar film.
I've been looking for mylar film which is about 5 microns thick for a few months now, and the closest thing I can find is 12 micron mylar or 6 micron composite film for RC planes.
Does anyone know of an online vendor who sells 5-6 micron mylar film?
Sorry that it's such a boring question.
Thanks in advance,
Jo
Pam8610 and 4ohm 20w speaker driver (jbl xtreme 2)
Hi all, I'm a newbie in this area, and I want to learn more about it. So anyway, I'm trying to make a portable speaker with a Bluetooth module and Pam8610, a speaker driver (JBL Xtreme 2, 4 ohms - 20w). I power up the Pam86010 with an 8v power supply and the Bluetooth module with a 5v external power source. After playing around with the volume, there are a few problems:
1. When the volume reaches 3/4 of the volume bar, the sound drops at a certain part of the song.
2. Because of "1", I thought maybe power was the problem, so I increased the power from 8v to 9v, and the volume was more stable than before. But the amp got heated up.
3. After 5 songs, the amp was fried.
What should I do? Is it possible to create a portable speaker with my setup?
Thank all
Anyone intimately familiar with the Threshold CAS-1?
Got one for a fine price and am now restoring it internally/electrically, as well as cosmetically, when possible. The fat electrolytes chilling in the center will be replaced, but I'm still afraid that there are more troubles up ahead (the tantalums will be taken care of as well). I actually have very little knowledge about this creation so I would like to ask another question; is this product made to be calibrated/finetuning transistors working current easily by the customer?
Also, how do I send PMs to members?
If "wputera" sees this, please send me a PM regarding the 2sd188 and the 2sa627 I posted as WTB in the market with my old account (Been a member here for a very long time) which unknowingly were linked to my old email adress that's not in use anymore, and in order for me to do anything here with that account, I need to answer that email. Impossible. Happened to me exactly the same way but with Facebook (Old phone number as well) but didn't give the ***** about that as I give about this fantastic place. Cheers.
Running the Scan-Speak 15w8530k00 full-range with no x-over
Any opinions/ suggestions on running the Scan-Speak 15w8530k00 full-range with no x-over?
http://www.scan-speak.dk/datasheet/pdf/15w-8530k00.pdf
I am currently using the Seas W12CY003 E0044 in a .25 ft3 Parts-Express cabinet with a tweeter/L-Pad added above 12kHz.
As you can see, the bass drops off much quicker than the Scan-Speak. It does have a phase plug so maybe better H-F than the Scan-Speak?
http://www.seas.no/images/stories/excel/pdfdataheet/e0044_w12cy003_datasheet.pdf
Madisound recommends trying a passive radiator to eliminate the 40hz bump but I like the coherency of a single driver. Wouldn't the P-R be like a separate bass driver and not be in-phase? That is 2 sound sources, not one so there will be sound wave interactions between the two.
That is why I am looking at the Scan-Speak for the flatter bass response - IF you can trust the published curves.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
508,483
Members
7,921,521
Messages
Filter
Forum Statistics
Threads
407,854
Messages
7,921,521
Members
508,483
Latest member
Erictam
