Aperiodic enclosures
Hi all. I have a question on aperiodic enclosures.
How much audible energy would you expect from the port?
I vented a system yesterday, still doing listening tests. Have done the classic boing, bonk, click test. Damping is very close to optimum with a sharp click on open circuit.
But I have deep mellow sounds radiating from the port. I thought the idea was to absorb it. So the real question is more to do with a heavily damped BR versus aperiodic.
I am very satisfied with the sound. I don't want to change it just to fit the criteria of a design.
Geoff.
Micromega Stage 2 power supply.
I have a Micromega Stage 2 CD player which has developed a fault in that the power transformer (part# DT 18415-6) has developed a loud buzz/hum after a few minutes use. The unit still plays without issue (after regreasing the mech` and fitting a new belt).
Does anyone know where a replacement may be located ? I`ve tried contacting Micromega directly but without response or does anyone have a scrap/parts Stage 1 or 2 which could be used ?
It would be a shame to have to retire my 2 as it makes wonderful music (imho) and, to my ears, sounds superior to my previous Quad and Meridian players.
Many thanks,
David.
dual 8" subfloor tapped horn
I'm currently building a new house,i have everything for the theater except the subs.Iv'e read heaps of threads and changed direction on which way to go several times!
I want the theater to be clean and free on clutter as possible as it will double as a guest room occasionally and i have the space to conceal subs within the floor/walls (the rest of the speakers will be in walls)
after reading the following threads and the comments about impressive outputs from smaller drivers i decided a small sub in a horn could be the way to go
AVS Forum
Reed Exodus Anarchy 25hz Tapped Horn
Well here it is..Exodus Anarchy 6.5" 25hz tapped horn designed by yours truly, LilMike. Much appreciation to lilmike for sliding me the plans and letting me build it early before he measured it and made them available. I Got the pleasure of hanging with lilmike and getting this sub measured...
AVS Forum AVS Forum
Home Theater Forum and Systems
My First DIY Horn Subwoofer
Introduction.. Well actually it's my first ever DIY subwoofer!.. Even though I've been involved in HT for over 30 years and have built many different speakers in that time, I've never built a sub. before! I just recently finished building 3 horn speakers for my fronts (based on the original...
Home Theater Forum and Systems Home Theater Forum and Systems
i then came across this thread and an idea started to form
AVS Forum
The Crawler, A Floor joist horn build
I hate crawl spaces myself. But physicked myself up for this one because of the benefit, So stealth, accurate bass and hopefully a memorable couch ride or two. Got to beat a harley. I think it was way easier on my back than a sealed box would have been. Heaviest part of this one was the motor...
AVS Forum AVS Forum
now, i've never built speakers before but i am a carpenter so the construction of the boxes would be no problem what i would like to know is if the sketch below has any merit?should i continue to pursue the idea?
hopefully there's enough info there to get my idea across(its probably clear why i'm a carpenter and not a graphic designer though!)
MKP and Sikorel capacitor out sale
Hi Guys!
I wish everyone a without covid happy new year!
I am very sorry, but I will close down my business in 2021.
So.. I have a big lot MKP, Sikorel and best quality Nichicon, Rubycon & Elna electrolytic capacitor if someone is interested.
The prices under commercial level ( TME, Mouser, Farnel )
Some capacitor:
B41684-S0684-Q Epcos 680uF / 75V 125°C sikorel axial €1,54
B41696-A7228-Q Epcos 2200uF 40V 125°C sikorel axial €1,66
UVZ1E102MPD Nichicon 1000uF 25V 105°C radial €0,42
B43504J2108M-2 Epcos 1000uF / 200V 105°C radial €2,26
ENB1VM180E09OT Aishi 18uF / 35V 130°C radial €0,22
and more EGPA, RKD, EKY serie from Nichicon, HGX, TXV, ZL serie from Rubycon
MKT
B32521A1155K503 Epcos 1,5uF / 100V
MKT1813522014-3 Roedenstein 2,2uF / 100V
MKP
C42Q2684M9 GD Farah 680nF / 305V
B32522A106K776 Epcos 10uF / 63V
B32796E8106K Epcos 10uF / 350V
and other values, and Siemens R534 through hole mounted resistors 6R8 - 1M2
contact: dielco@dielco.hu
Thanks for wathing!
APT Holman preamp manual, schematic?
Hey all,
Newbie here. Glad to have found this forum as I am puting a "vintage" system together and will be most likely needing some help.
Just purchased an APT Holman preamp, and Adcom 535 amp off of Craig's List. Does anyone have access to schematics and/or owner's manual for the APT Holman pre amp? Can they be bought new? Any "tweaks" for the pre amp?
Thanks!
what do I need to do with power to protect piano?
Hello. I have a new home Kawai digital keyboard, 120 V input, 2x50 W speakers (but I use the headphone amp anyway, or computer VST), >$4000.
What should I put between my keyboard and the outlet to keep the keyboard well? (Hereafter 'power bar', though that might be misleading.)
Power: I don't really have reason to think the power coming to apartment/outlet will be unreliable, besides storms or rare outages, or that I have fancy protection. I'm not sure how to verify this. (See below: I might have had voltage out of 100v-135v magnitude at some point.) Townhouse, probably suburban.
I assume I should at least get a good enough surge protector--what would that mean?
Currently I am deciding which power conditioner to keep (allowing it to count as a surge protector.)
(Any reasons for/against power conditioners?)
If I had reason to be wary of my power, I might consider an Uninterrupted Power Supply instead, since there is a computer component of the keyboard (I have the keyboard off when not in use). I'm not afraid of power outages particularly, so maybe this would be to protect against brownouts etc. (also likely irrelevant).
One of my conditioners that I'm trying is a Panamax that is supposed to turn off power temporarily when it detects 100v to 135v (I think), and otherwise has 331v clamping with 1575 J protection. It has turned off twice now, presumably because of some split-moment of a voltage problem, maybe because it was mistaken. I assume this wasn't due to a surge, just something outside of 100v to 135v. I don't know.
I suspect that having the Panamax shut off power would be more dangerous to the keyboard than having even a few seconds worth of brownout, and that I therefore don't like this particular feature. However, without the Panamax, I can't detect any problems except surges and blackouts, so if something were going on, I wouldn't be doing much to stop it (except noise filtration.)
I also don't know how this feature alters the effectiveness of surge protection. 135v < 331v, after all. Does this affect J rating, either?
The other unit should have 181v clamping and probably more endurance than 1575 J, but no such anti-brownout/swell feature.
Which of these options might be better?
What should I do now?
And for future reference, when I replace the power bar, what should I consider getting? Some sort of surge protector, some UPS? How can I know what I need?
Thank you.
DIY Audio Receiver Atmos 13 channels or more! - Why not?
Why couldn't someone make a DIY audio receiver? Licenses,etc aside (not talking about the legal battle part).
Get the HDMI bit stream via some sort of capture card, decode the bitstream, tons of kodi / ffmpeg code already exists to do this, in pre, then virtualize the objects in as many channels/speakers as you desire, hook up a whole wack of cost effective usb soundcards to DAC it out to external amps. Heck 24.2.10. An RPi4 could easily handle this. Isn't hdmi 2.1 audio max 31Mbit/s? That's nothing for a multi-core arm processor with neon to handle for receiver duties.
I mean anyone could easily do all the software, it would be a weekend project to slap together a bunch of open source stuff and do some digital dsp. Just need to get the bit stream via HDMI, there are already those splitters which do the edid/content protection bit and extract the audio stream.
Is there any HDMI->usb capture card that will get the raw audio bitstream coming in? Does anyone know of any?
Marantz CD73
Hello, although I do not participate much in the forum I am a regular reader.
I have purchased a Marantz cd73.
The player does not work, the drawer opens and closes, the "Laser" led is on and the green LEDs on the top cover light up. But it does nothing else.
You can hear the noise of the drawer motor running, but the arm does not work either.
The recommendations that I have read are about the power supply, I have measured and I have the voltages equal to the diagram.
Someone knows and can guide me where the problem may come from.
The image is borrowed from the web.
synergy.....Take #7
Or at least I'm calling it Take 7.
It's really the 3rd completely different cabinet.
Other 'takes' were trying out different size ports or different drivers, etc.
They've all been desinged to go with subs at 100Hz like my previous synergy thread 100Hz two-way synergy project.
That thread ended up turning into this 60x40
I've truly enjoyed this speaker, to the point I wanted to build another for stereo, but it's too damn big and heavy to move around. About 100 lbs.
One of the biggest joys in audio for me, is being able to move gear around, listen outside, swap stuff around, always making comparisons and learning.
So I've spent a few months researching how to get the synergy goodness, but shed alot of weight.
Anyway here's the outcome.
It's a 90x60, that has very close to the same primary horn width and height, but of course less depth due to its wider pattern.
It weighs in at a glorious 45 lbs !!!
Uses two dirt cheap faital 10FE200's as mids, and one not so cheap b&c dcx 464 coax cd, ...but getting the CD down to 500Hz is what lets it work.
I did a few things different from my previous attempts that all tried to adhere to the conventional synergy wisdom.
Biggest change was putting the mid ports in the center of the horn instead of in the corners.
I made a test horn where I could block ports easily and experimented a bit. I couldn't find a compelling case for corner ports, in terms of how the HF and VHF were effected.
That was a peasant surprise really, because I wanted the ports in the horn center as part of a weight reduction design. It allowed the mid drivers to go on the top and bottom in small cavities, and the horn side walls be all the cabinent there is.
Like this
Plus, ports in the center of the horn are just plain easier to make 🙂
Also made a simple box to test port sizes and shapes, port thickness, and how much port frustrum matters. Picture a sealed box where you just lay a plate with various port tries on top, and move it around over the cone.
I used plates out of 12mm BB and thin steel sheet, and ended up choosing a 10:1 compression ratio in terms of hole size.
Surprisingly, I could not find anything to beat a simple round hole aligned with the center of the cone.
Neither could i find a reason to use thin ports, or even do anything to the wood hole other than a little roundover smoothing.
The port holes' center is 7.5" from the throat. Basically, the 10" drivers sit as close to the horn apex as possible, which also puts the port nearly under the center of the cone.
I always have to give sincere thanks to BWaslo for his speadsheet....I simply could not make a synergy without it.
Also need to thank Makita for my track saw Lol. It makes the bevel/miter cuts so easy and true...much better than i can do by table saw and sleds.
Oh, I've found I like to make the horn start at 1.4" square, and not have to round out the walls to mate the CD. It's been easier to add museum wax to the horn corners in the mouth.
Syn7 may or may not get a secondary flare depending on outdoor testing.
I should be able to make a detachable flare like in the first pic fairly easily.
What I really want to do is add a tractrix flare as the secondary flare.
Ala the K-402. I figure the K-402 first 2/3's from the throat is pretty much straight sided conical, and the last 1/3 tractrix. A conatrix or a tractical, depending on which end you look from haha
3D Printed Back Loaded Horn
Garage Speaker with one driver
Hi Community,
I am new in this forum / this is my first trade so please be patient with my novice question (I think i did read most of the threads about BLH and also did try to understand it as far as possible ..)
I saw on Thingverse a very nice design for a BLH based on a Visaton FRS 8 M an thought about printing it also for me and use it as an Internet Radio in my workshop (Back Horn Speaker V2.0 BL2 - Bluetooth, Active, Passive by guppyk - Thingiverse).
For this purpose i am required to redesign it bymyself in order to add a display on the front. Then i started to play around with Hornresp in order to understand the theory / relations about it a bit more.
Now i want to ask you guys if you have suggestions if there are ways to make more out of the given FRS 8M or if it's worth to build (print) them. If not i could also go with a Bassreflex design ...
Please find attached my Inputs from Hornresp and also my current design (The area inbetween the driver and the Horn output shall be used for the display / electronics).
The size is limited by my 3D printer (205mm x 205mm).
regards
Christian
ESL High Voltage supply
I've built a HV supply for my DIY hybrid ESLs based on a CCFL xfmr and capacitive multiplier. Runs from a 12V wall wart and produces ~3KV (adjustable). Also has a music sense circuit which can be left unpopluated and bypassed (always on or on with external switch). There is a SMT LED on the PCB to show when the circuit is active and a connector for an off board LED for same.
The PCB is 2.50" x 4.00" double sided; mixed SMT and thru hole.
If anyone is interested in building this, I can make the gerber files and BOM available. I'm not familiar with how to do a group buy, but if someone else wants to run with it, I'll do what I can to assist.
Resistor getting very hot
ZD3 was broken and R40 became very hot.
After replacing ZD3, ZD4 R40 and R39 i measured the temperature with heat cam. R40 and R39 become very fast hot. About 120°C(250F).
Is that normal ?
I think the original ones were 5 watt resistors, length: 0.94 inch, diameter: 0.29 inch. 270Ohm.
The amp works fine, but i tested only for 20 min.
Center speaker 3 way design question
I have this center and was curious if I could run one woofer as a mid and the far other side woofer as the woofer. Crossed to a larger planar or ribbon tweeter 8” or under.
This current center used the same 6.5”
Woofers, a 4” midrange and a metal dome tweeter.
Has anyone ever made a center channel with one one of the woofers running the mids?
Would this work better then the current setup? I really wanted a better tweeter and these woofers are pretty cable of both bass and midrange.
The midrange is this same speaker but the 4” version.
http:loudspeakerdatabase.com/Peerless/HDS-P830990
capacitor recomendations for crossover
Hi needing suggestions for a capacitor replacement in my crossover. The cap pictured was what was originally in my speakers (Mission 734). I replaced this electrolytic cap with a polypropylene cap and found the sound improved in terms of clarity but became harsh/brash. The replacement cap was a custom designed one that id like to replace with a good brand. Can anyone recommend a cap that will sound softer like the original cap but still offer the improvements in other areas. Please name the brand and cap value that i could use as i dont understand the writing on the cap pictured. Thanks
Denon avr-1913 left surround channel low and noisy
Hi, I bought a Denon avr-1913 receiver used and the left surround channel is low and noisy. I have been doing research and I'm trying to test and see if it's the output transistor, am I in the right ballpark? It's my first time working on an amp, any help or direction would be appreciated.
update: I tested all the transistors and got consistent readings on all of them (I think)
service manual: Table Of Contents - Denon AVR-1913 Service Manual [Page 2] | ManualsLib
Add a second output to a passive summing mixer
I plan to build a passive summing mixer with 8 inputs and 2 outputs.
I follow this diagram :
All inputs resistors are 6.8k ohms
To calculate the summing resistor I use the New York Dave formula (I/N)*R/((I/N)-R, where I is the input impedance, R the desired output impedance, and N the number of channels.
So, here, the summing resistor is 165 ohms
How to calculate the output summing resistors needed if I want to add a second output to this diagram ? Each output need to be at 150 ohm for the mic pre amp that after.
Looking for Advice on Modifying Music Hall Mambo Class A Amp
Hi All!
I picked up a near mint condition Music Hall Mambo integrated amplifier from an acquaintance's mother. She used it but sparingly, which is evident by how clean it is. I got it for a reasonably good deal-- $550.
This is a 50lb Class A integrated. It's really nicely made, but I'm fooling with the idea of making it into an upgrade/modification project. I know that Underwood HiFi and maybe Parts Connexion were offering modifications that cost near $1,600. See Mambo | Underwood HiFi.
I popped it open today to poke around. Here are some photos.
Any advice on where to make modifications?
I was thinking of figuring out the following:
Swap two caps on gain signal --or at least what I think is the signal
Change electrolytic caps from Elna to Mundorf M-Lytics, etc.
Change out the Burr Brown 2604AP OP Amps (x 5)
Any help would be greatly appreciated!
TOPPING D50s Bluetooth range extending mod
For the money this little DAC cost I think its one of if not the best $250 I have ever spent on a piece of stereo equipment. My only complaint was the range of the Bluetooth left something to be desired. It would cut out 15 feet away with good line of sight. BUMMER....
Well as it turns out there is a simple fix for this that I find hard to believe the factory didn't build it this way.
If you unscrew the BT antennae and look at the Brass elbow there is a setscrew like thing. Its actually a very thin cover that when opened reveals the solder connection for the antennae. An electrical radio friend of mine told me the optimum length for a BT antennae is 31mm based on the wavelength and the length it needs to be to resonate, thus making the most of the available signal. This one as it turns out is significantly shorter than that.
The fix is to slip the black plastic cover off the elbow revealing the existing antennae. Remove the elbow cover with a screwdriver and desolder the existing wire. Next measure out your new one FROM THE ELBOW WHERE THE WIRE BECOMES EXPOSED AND IS NO LONGER SHIELDED BY THE METAL. Y our total length of the wire will be a little longer than 31mm. Like 38-40 or so.
Cut it, solder it on and be sure to slip a piece of heatshrink over the wire so the wire and solder joint inside the elbow will not touch the elbow. Verfiy your 31mm length and put the black plastic cover back on.
And enjoy your SIGNIFICANTLY improved BT connection. Mine is a hell of alot better. I haven't measured it but it works great everywhere inside my house. Compared to previously its a huge improvement.
*I can not vouch that the 31mm length is indeed the optimum length but my friend is a pretty smart dude and mine worked great.
Enjoy.
Jeff
Dual Rail PSU for Class-D amplifier module
Power Supply for Class-D amplifier module
I've built several small (~500mA) dual rail power supplies; mostly 12-15V stuff for a pair of opamps each. These have been very simple designs since the current is very low.
However, I'm looking at my first "serious" dual rail linear PSU, something to power one Class-D amp. The module I'm currently considering is the ICEpower 500A, a 500W (@4Ohms) amplifier module. It requires a dual-rail power supply between 45V and 80V, with 75V being "recommended".
With the smaller power supplies it was easy to get started, but this seems like something else. I'm hoping for a few resources / pointers in the right direction as to where I can find information on building something like this. Perhaps I've missed it, but I couldn't really find very much!
Phill
Equal-pressure loudness contours
So, everyone knows the equal-loudness curves, which show the sound pressure (in dB SPL) needed to achieve a particular loudness in phons through different frequencies.
This curve is fundamental for many areas of acoustics and hearing, however, I wanted to bring more information out of it.
Firstly, they don't show the variation in loudness of sounds with a same sound pressure through different frequencies. That is very important, specially if you want to understand how a "flat response" should sound like when you feed it with pure tones of the same amplitude.
Secondly, the unit phon itself isn't the closest to be linear with perceived loudness. The unit sone was made for that, but needs corrections for very loud and very quiet sound (and it's a bit of an approximation anyway, loudness is very subjective, but this is still better for a psychophysical approach than phon).
So, I took the data from ISO 226, converting the values from phons to sones and the values from db SPL to Pa (pascals) to find a loudness curve for each frequency, relating the perceived loudness with sound pressure.
For example, for the 100 Hz frequency, the data is:
I
then performed a fitting to find the values for other sound pressures. The model I used is a simple power-law expression:
L = A·pγ
Where L is the loudness, A is a constant, p is the sound pressure and γ the exponent (a dimensionless constant)
Not only this model provided a near-perfect fit (R² > 0.999 always), it is also the same used for gamma correction, and the value of γ (gamma) tells a lot about dynamics.
If
γ = 1 for a given frequency, then the perceived loudness is directly proportional to the sound pressure. Which only happens in one frequency, around 60 Hz.
If γ < 1, then the perceived loudness is compressed, meaning that doubling the sound pressure doesn't double the perceived loudness. Everything above 60 Hz is compressed, and the most compressed frequencies are exactly those we are most sensitive to, between 2 and 6 kHz.
If γ > 1, which is the case for everything below 60 Hz, then the perceived loudness is expanded, so doubling the sound pressure more-than-doubles the perceived loudness.
The constant A is a different one for each frequency, and also has a different dimension for each. Its unit has to be sone·Pa-γ, so it's only the same dimension if γ is the same. Nevertheless, it's still useful to compare their values, for they tell a lot about how each frequency is "intrinsically loud".
Here's a graph of how the A constants and γ values vary with frequency
The graph on the left will give the overall shape of the equal-pressure loudness contours. The graph on the right tells about the dynamics of each frequency and how the contours will change with different sound pressures.
So, using these data, it's possible to make the contours I wished for.
Here they are:
Each curve in the graph on the left shows the variation in perceived loudness for pure tones of different frequencies with the same sound pressure.
The curves on the graph on the right has been normalized so the loudest frequency of each curve has a value 1, and it helps visualizing how the proportions between the loudness of each frequency changes with sound pressure (due to their different dynamics).
In the curve for 20 mPa (the cyan curve), the frequencies around 15 kHz are just about 40% as loud as the frequencies around 3 kHz (the loudest in all cases). But, for 2 Pa (black curve), they're 80% as loud as 3 kHz. Their loudness relative to 3 kHz double.
The bass frequencies change even more. In this same range (from 20 mPa to 2 Pa), frequencies around 40 Hz go from being 1% as loud as 3 kHz to 10%.
The frequencies between 2 and 6 kHz keep their proportional loudness because their
γ are nearly the same, around 0.585 (they have the same dynamics).
Although the data may be imprecise, this is just an approximation when it comes to your actual loudness perception. But in a way or the other, this is still useful for a ton of qualitative observations.
The main observation being that, no mater how an equipment is good at keeping its profile (flat or whatever other it has), the equalization will sound different at different SPL,
increasing the overall loudness will also increase the bass and mid-bass (from 20 to 600 Hz) and treble (12-17 kHz) relative to mid-highs(2-6 kHz).
These contours also help "equalizing by ear", as they give a notion of how it should sound, taking the loudness of 3 kHz as a reference. The only thing you need to know then it's the sound pressure level you're dealing with.
For a reference, here's a little table I took from wikipedia:
Reactions: Brinkman
Calculating excursion of a compression driver
I found a formula on the Lansing Heritage site, derived by Frank Massa working for RCA at the time in the 1930's for calculating excursion of a compression driver.
I don't however know if the 'area' of the diaphragm is taken as a flat piston or considering the area of the dome. Anyone know which is correct? I am assuming that it is considered a flat disc when calculating the area.
"P = .0034 X f squared X d squared X Ap squared, all the foregoing divided by Ah"
Where:
Ap = diaphragm area in square inches
Ah = throat area in square inches
f = frequency in Hz.
d = peak diaphragm amplitude in inches
P = power output in acoustical watts
Assuming a 3" diaphragm compression driver diaphragm at 800 hz, given 0.060" to the phase plug ( I haven't measured that yet ) and a throat of 1/10th the 3" diaphragm ( 10:1 compression ) I get in the neighborhood of 78 acoustical watts at the point where the diaphragm hits the phase plug.
P = 0.0034 x 640,000 x 0.0036 x 49.96487 divided by 4.99648 = 78.33 Acoustic watts
The formula explicitly states that the area of the slots in the phase plug is considered the throat for the calculation of throat area.
If we say 75 peak acoustical watts, that works out to 138.75 dB sound power level at the phase plug exit. Coupled to a horn with a directivity Q of 10, and measured at a distance of 3 meters, this calculator: Sound power level SWL and sound pressure level SPL distance compare acoustic power sound source noise Conversion of sound pressure to sound intensity conversion sound level energy level strength directivity factor coefficient sound intensity SIL - se
The result of plugging in the above numbers says 128.21 dB pressure level at 3 meters distance.
Am I way off base, or does this seem correct? The driver in question has a 3" diaphragm and a 1.4" exit.
Infinite baffle bass speaker and horn 2.1
Hi everyone,
I want to run an idea past you guys regarding building a 2.1 cinema system
On a 30ft houseboat frequency response down to 16hz.
What i propose is building tanband horn speakers from plans with
A 4"tanband full range driver, a pair of these will be the front speakers
These are bookshelf speaker sized and would be constructed
Using stacked plywood.
The bass speakers, i want to use an infinite baffle as i have read
That its capable of super low frequency bass and is used by
Electronic organ players to get the 16hz fundamental they do this
by fitting a pair of 12" bass drivers in the ceiling and using the loft as the infinite
Baffle, i propose using the floor and bilge as the baffle as its
30ftx9ft and 3ft deep, the floor is made from 20mm marine ply
And is braced every 4ft as the structure of the boat, the hull is
Sea going and extremely thick fibreglass.
Would this work to form an infinite baffle and also do the tanband
Horn plans produce a good sounding speaker?
Thanks, Mat.
Trouble Shoot Relay Switching
All ready to give away a very sweet sounding amp and speaker system to my sister and brother in law when I discovered one channel on one of the three sources not working at all.
Three pairs of RCA input each pair connected to a relay - I managed to desolder the 10 pin relay and replace it with a socket and a new relay but still no joy on the same input source. Relays are triggered by three way toggle switch on the front of the amp. Relays are TQ2 5V DPDT Type Form C
https://b2b-api.panasonic.eu/file_stream/pids/fileversion/4514
Output from the circuit board is the same pair of cables sharing a ground connection and L and R for all three relays. There's a couple of resistors and transistor on each relay - I don't understand why I only get one channel if the relay is working.
Any Ideas very welcome Pictures from Ali Express site with source relay board in the middle.1969 Amp front.JPG
Tapped out tapped super pipe
I believe this is the end of almost what trying to aim at?
And if i folded that 240 cm at 120cm+120cm i would fill in the response and because it would be the harmonic of 120cm which is 214hz to its own and 107 is the Fb /3. i probably have misspoken and theres a variety of ideas and options here including other intervals of 240 or compounded approaches. Paraflex is a good one, roar is great, ODTL is outstanding!!! And ODOE TL is the cats meeow, but the tip of the iceberg for a taped driver might be placing it in the middle of two qw paths which themselves are split at midpoint? Or a mathematical version of pipe harmonics and open ended pipe harmonics, etc?
B@se wave cannon, etc... lots to read and lots of ideas!! Heres half of nothing but close to a unsimmed(wont fit into the programs assigned fuctions) guess? 240 cm @ 120/120 seals the deal? Or ? Its only 30’degrees closer in a compound? Vs standard Qw pipe at 90. And however method we can use to describe the phase at various layouts ‘offset’?
DSD Delay Line
I would like to be able to cut lacquers from a DSD source with lathe automation. This requires four channels. Two channels feed the automation and the other two channels feed the cutterhead. The Modulation signal that feeds the cutterhead needs to be delayed by either 1200ms or 800ms depending on the record speed.
For PCM I just take four channels from my DAW. I don't have a multichannel DSD workstation. There are plenty of two channel DSD playback devices.
Mini DSP sells the MCH Streamer which can stream eight channels of DSD. I asked MiniDSP and they said there wasn't enough memory to delay the stream.
What could be used to delay the DSD stream to give me the Modulation signal?
Pass labs X150 vs. Threshold S/350E
Hello, I owned a Threshold S/300 for several years then sold it about a
year ago.
I drove a pair of Acoustat model 2+2's with it. I am now considering between
a used Pass Labs X150 and a Threshold S/350E. The S/350E was
upgraded by John Soderberg. Both used pieces go for about the same
price and both are rated 150wpc into 8 ohms. I liked the rich, warm
sound quality of the S/300 with my Acoustats.
Which of the 2 amps would be the better
choice as far as rich, warm sound?
HK990 right channel runs hotter
I have an HK990 that functions properly but the right channel runs 10 degrees F hotter than the left when measured at the heat sinks. Is this enough to be concerned about? (I'm a novice at circuit level electronics, so it's something I don't feel qualified to chase down and repair if it is.)
Also, if anyone knows of a good technician within 75 miles or so of Lansng, MI that would be good at servicing this unit, I would appreciate the referral. (Blackies in Grand Rapids, MI is the closest authorized HK service center, but I wasn't overly impressed with them.)
Thanks for your thoughts.
ladder construction: bridge multiple values not possible. right?
Hi friends
I'll build a ladder attenuator with 25K Load resistance.
The calculator I used (attached) shows a few resistors are repeated (say, position 8a - 4a, 3a - 1a etc.)
I have to solder every single one into its position because they're going into a different b-position, is that correct? or would they pass through the respective a-position at the value, and through the next deck into the correct respective value?
scratching my head...
Aikido 6SN7 Cascade
I’ve built this Aikido Cascade using a 6SN7 from Aikido Cascade & 300B Power Boosted. It’s in use as a input gain stage before my phase inverter.
It measures quite well as far as distortion and amplification is concerned. I cannot find much information about this diagram, so it’s hard to check any of my measurements with it’s design parameters.
I wonder what would be the input and output impedance for instance. For which input level would it be designed? What would be the optimum value for a volume control at the input?
I think I already get full drive with only 0.7 V Peak to Peak, so what would be a good way to lower the amplification without losing the Aikido design philosophy?
Regards, Gerrit
OPT Impedance Scaling / Ratio
Quick question: Does the primary impedance of an OPT scale linearly as load on the secondary changes?
In other words: If I connect 8ohm speakers to my 8ohm tap, the primary OPT impedance is 5k - so if I connect 4ohm speakers to my 8ohm tap the primary OPT impedance will drop to 2.5k (4/8=0.5*5000=2500)?
Doing the math for a different scenario:12ohm speakers on the 16ohm taps will result in 75% (12/16=0.75) of 5k = 3750 ohm primary impedance?
Same thing for 3ohm speakers on 4ohm tap?: 3/4=0.75 * 5000 = 3750 ohm primary impedance?
Onkyo TX-NR807 HDMI board
Got a Onkyo TX-NR807 MDC with a bad HDMI board. There was a known issue with the soldering on the DTS chip and the factory extended the warranty for quite a while. Unfortunately, that extended warranty is past. The owner had asked me to see what I could do with it, and I was able to reflow that 320 pad BGA with a heat gun, and the repair lasted about 3 months. Started failing again, and additional attempted repair has been futile.
So I am looking for a used, functional HDMI board. The manual calls it
BAHDM-0132-1B, the actual label on the board is BCHDM-0132.
Anyone have any leads on where I might find a good one (for a reasonable price)?
TKD 2CP-2511 motorized stereo log 20K
To sell almost as new, because I did soldered it to a Preamp, a top quality TKD 2C-2511 stereo log 20K motorized pot + Hifi-Collective Glass House control board + IR remote control.
Selling, because the decision went into another direction.
Price is 150€ + transport + 3% PayPal fee.
All box thoroughly.
Super quality pot!
Paid for it one week ago +200€
Thanks for looking
Does 5.3ohms DC signify a 8 ohm drive unit ?
Ok so I'm new to all this , but learning
I have a 3 way speaker , that I need to work out a Xover for it
The midrange is a 5.25" dynaudio driver
I measured 5.3ohms DC resistance ( both measured identically )
Does this mean the drive unit has a 8ohm impedance?
Or maybe 6ohm ?
No idea if dynaudio make 6ohm drivers ...but a reading of 5.3ohms DC seems low for a 8ohm driver ?
Any info greatly appreciated
JLCPCB aternative for mixed tht/smd workload with v-scores
Hello Folks,
I've put a bunch of effort into designing a workload of small PCBs on a 100x100mm board. Some of the small boards contain SMD and THT components, the individual boards are separated by v-scores to easily separate them after manufacturing. I have seen such board workloads in the LT4320 thread, so technically that should work and so far the theory...
A few moments ago I chatted with JLCPCB to verify the right way of ordering my workload. It turns out that JLCPCB cannot (anymore?) produce v-scored PCB workloads containing THT and SMD component layouts.
I'm not experienced in PCB manufacture, this is my first project, so who ever can help, please advise!
Thanks and Regards,
Winfried
Phase Linear Pre 3000...Relays...Need Info??
Working on old PL3000 pre with switching issues. Powers up defaulting to Tuner input correctly. When I switch to another high level input it will switch LED to new in put but the tuner LED stays on also. Doesn't do this every time but at random. See that the relays are no longer available. Uses relay that matches 16pin DIP footprint. Looking for same footprint that matches on small signal relay. Not finding. Service manual talks about a relay regulator circuit but can't find info on that. HELP!
Dumpster Diving for SemiSouth SJEP120R100's ???
Given the scarcity and high prices of new old stock SJEP120R100 transistors, I have been wondering if they could be salvaged some from other equipment.
Based on the following excerpt from a 2009 press release, it looks like they were originally intended for other more industrial uses:
"SemiSouth believes this is the first SiC transistor to enter production in the audio amplifier market. The JFET has traditionally been featured in rapidly growing markets for solar inverters, and server and telecom power supplies, among others."
Link to Press Release
Its a long shot, but does anyone know of specific equipment likely to have used these that might be available as scrap or obsolete?
Choosing a DAC/AMP combo
Hello,
I am in the process of building a pair of Woden Bloodhound speakers for my PC and I would need help figuring out how to choose an amplifier and DAC to drive them. These speakers use MarkAudio Alpair5.2 drivers.
I know this is a diy audio forum but electronics is a bit out of my capacities I think 😱
How do I make sure I am not over/underpowering my new speakers?
Does anyone have recommendations on what to choose?
I don't need anything fancy, only stereo, no bluetooth, etc.
Thanks!
F6 Low profile opinion needed
Hi all,
I have the parts to beuid an F6, sans toroid. But the standard 4U enclosure will not meet with my wife's decorating approval. The amp will go in the living room and there is no place to put it without it looking obtrusive.
I have plenty of places I can put a 2U high unit out of sight and still provide for good ventilation.
So, I was thinking to make two 2U monoblocks but with the output MOSFETs connected to their own heat sinks on each side of the chassis. It will look like a lower profile steroo amp but actually be a monoblock.
Questions: What are the issues in doing this? I'd have to run wires to the SD and G pins from the board to each MOSFET on each side. Probably 4~6 inches for each run. Will this be a problem?
Any suggestions?
Has anyone tried ths?
Many thanks for your help.
Simulation stability with different models - Dado's 200W CFA
Hi everyone, and happy newyear :wave:
Sorry if this has been discussed before, could not find anything on it.
I have very much enjoyed dado's 200W CFA thread and downloaded the .asc file from post #1582 assuming it is the newest.
I did not have the IRFP240Ckst/IRFP240Ckst models handy, so instead I used the following models from Ian Hegglun.
*VDMOS with subthreshold (c) Ian Hegglun
.model IRFP240h VDMOS (Rg=17 Vto=4.0 Kp=6 Lambda=3m
+ Rs=40m Ksubthres=0.15 Mtriode=0.35 Rd=0.15
+ Bex=-2.3 Vtotc=-6m Tksubthres1=4m Trs1=3.5m Trd1=5m
+ Cgdmax=1.3n Cgdmin=10p a=0.35 Cgs=1.2n Cjo=1n
+ m=0.4 VJ=0.75 IS=10n N=1.5 Eg=1.1 Rb=10m Trb1=3m
+ Vds=200 Ron=0.15 Qg=45nC mfg=VishIH1907)
.model IRFP9240h VDMOS (pchan Rg=9 Vto=-3.76 Kp=9
+ Rs=64m Ksubthres=0.15 Mtriode=0.2 Rd=0.25 Lambda=4m
+ Bex=-2.3 Vtotc=+6m Tksubthres1=4m Trs1=3.5m Trd1=5m
+ Cgdmax=1.6n Cgdmin=30p a=0.5 Cgs=1.4n Cjo=1n
+ m=0.4 Vj=0.75 N=7 Is=10u Eg=3.15 Rb=50m Trb1=0
+ Vds=-200 Ron=0.5 Qg=44nC mfg=VishIH1907)
I then ran the bode plot as is, without changing anything else. It gave strange results, with a phasemargin of only ~39°.
Went backwards in the thread and found dado's latest zip file with schematic and models. It sims fine with expected results.
Then I changed the schematic from dado's zipfile to use Ian Hegglun's models, and I get the above strange behavior.
My impression was that the models from Hegglun and Cordell are all good, but they clearly behave differently.
Is there a consensus on which models to use for IRFP 240/9240 ?
Jørgen
Just can’t remove solder on pcb...
I’m new to this so please go easy on me...I have a Boston acoustics sub woofer with an rca jack that I need to replace. Was able to get the old jack off the board but I can’t seem to get the old solder out of the 4 holes so I can install a new one.
I’m looking to recap my old hailer amp and get into some diy audio a bit and figured this was an easy starting point. I got a hakko soldering iron, tried 750 and 850, different tips, lots of flux, suction and wick. It’s like the solder in the board won’t melt at all. I tinned my tip and all that. Not sure this picture helps but I must be doing some newbie mistake...
Need help troublshooting
I've recently got a logitech s220 2.1 speaker system and it works but it has a very low bass.
I've checked the speaker with a multimeter continuity test and it works as it should.
The system has a main volume button and the bass has it's own too both seems to be working but the bass only audible when both is turned to maximum. The satellite speakers are working loud and clear.
I've checked the capacitors and they seem fine visually. I don't have a capacitor meter and haven't taken them out from the board yet.
So my question is that what could be wrong? Am I right suspecting the capacitors or there could be something else too?
Thanks!
TDA2030 BTL with output transistors
Hi!
I am trying to build a mono amp based on bridged TDA2030 (2050) with output transistors TIP35/TIP36. I found a schematic that seems ok here https://320volt.com/wp-content/uploads/2009/03/200watt-anfi-devre-semasi.png and I copied it in EasyEDA to build a PCB. But I am not sure if I've done it correctly, particulary the transistors connections.
Here is my schematic:
attachment.php
and here is an autorouted PCB I want to use as a reference:
attachment.php
BUT with a similar schematic (I don't have the link, but is quite similar, without any input filterning and decoupling), the PCB looks entirely different, regarding the connections of the transistors (BDA249/TIP35C and BDA250/TIP36C):
attachment.php
I used schematics/footprints contributed by other users for TDA2030 and TIP35C/TIP36C and I din't change anything in pins/footprints.
Is my procedure that wrong?
TDA2030 schematic and footprint:
attachment.php
TIP35C schematic and footprint:
attachment.php
TIP36C schematic and footprint:
attachment.php
Room DSP Discovery
Hi, I've been playing around with the DEQX for about a year now and
I've tried many speakers and combinations of measurements/corrections.
While I'm not completely thrilled with the DAC capabilities of the Hd Express II
I think that the room correction capabilities cannot be ignored.
So I wanted to share something I tried that I think sounds really good and also ask a question about it.
The usual method to correct the drivers (in this case Kef LS50's) with open baffle 15" woofers below)
is to measure each driver from up close and then correct and only then do eq corrections on the room.
Well I decided to try something different this time and I was pleasantly surprised. 🙂
I wired BOTH speakers (highs/lows separately) to the same amps so that both speakers
were playing in mono. Then I did my measurements from the listening position and then cut and pasted
the one side side to the the other so that both speakers are using the same FIR filter. I then separated
the drivers so they each get their own amp. And then I took the average response on both speakers playing simultaneously
and applied EQ.
And well it does sound really good. Im wondering if tehre's any explanation for this? Only thing I could think of is that using the same filter sort of 'averages' out the response in the room better.
Anyways there it is, hopefully someone more knowledgable can chime in on whether this is a good idea or a bad one.
  • Locked
Custom Power Distribution Box
I'm looking to build my own power distribution box. And hoping that someone out there can help with a few points.
I'm getting a dedicated 20A circuit installed in my house later this month. And a whole house surge protector. So I'm looking to build a unit without surge protection or power conditioning. Just clean and simple power distribution.
I'd like to build a 10-outlet box using five Hubbell HBL5362 duplex receptacles. One of them will be un-switched, or possibly have a separate switch. For connecting to the wall outlet (also HBL5362), I plan to use a 12AWG shielded cable. I'm a bit of a novice when it comes to things like this, but my trusted audio tech has agreed to mentor me on this one.
So here are a few questions:
1) What's the optimal type of enclosure and material? Seems many go with machined aluminum.
2) Does anyone sell "blanks" for power distribution boxes?
3) How important is a ground terminal? Many (usually higher end boxes) have them. Many don't.
4) Better to somehow solder the power cable in directly or use an IEC socket?
5) Should I install a circuit breaker in the box?
6) I'm assuming each duplex should be wired directly to the IEC socket rather than wired in series.
I think those are my main questions. But I'm happy to take unsolicited advice too. I don't want to show up to my tech knowing nothing...(!)
Multiple setup for a wide room
Hello,
I have a room which is approximately 7x4m, where I watch TV, listen music on my couch which is on one half of the room, or listen music in background while working at my table which is on the other half. In all three cases I'm facing the long side of the room, but pointing towards different points.
I was thinking to place 3 speakers on the long wall so I would use the left and middle one as left/right when listening on the couch, middle and right when listening on the table, and left and right (maybe with some contribution from the middle one) when watching TV.
I also would like to build myself the speakers as two ways using an active crossover. I could use DCX2496 as active crossover and room compensation using three setups for the different listening points.
What do you think about it? Is it a good or a terrible idea?
KAC-X401M Repair stuck in protect
Hello, I am repairing 401m. I've had it for a while (Years) and have just gotten back around to it. This one is a weird one and I'm at a loss. I am thinking that the main IC (IC2) may be faulty.
Checked the power supply and output transistors and all check out fine.
I removed Q20 and Q21 because I couldn't get the amp out of protect. Verified that there was not 5v going to pin5 but the amp is still in protect.
Applied 12v to the pwm IC and the power supply powers up fine. Verified a nice solid +/- 62v and 15v rail. Amp pulls a low 2 -3 amps at idle.
Everything outside of IC2 seems to be functional. It just thinks something is wrong for one reason or another. I'm almost tempted to short the emitter and collector on Q22 to get the relay to turn on to see if I can get audio out of it.
Any suggestions are greatly appreciated and thanks for you help~
Full range driver project
I’m going to build a sealed enclosure with a single full range driver in it for a desktop nearfield audio mixing monitor. An incidental bonus would be a driver that has a ported enclosure size that’s close enough to allow experimenting in the same enclosure but this is not necessary. I’m good at woodworking. I prefer paper and if not then poly. I have been looking at some of the usual suspects: tang band, foster, Mark audio, Dayton audio, visition, etc. after 40 years of rock guitar my hearing is shot above 10k so that doesn’t matter much in this case although some of these speakers have pretty impressive upper extension.
What choices have worked out well for you guys and given the best results?
Thanks,
George
Tweeter faceplates, possible mods
So, I'm starting a project along the lines of a Helium -- just a little tyke (6.5" high, 4.5" W, but 6" D), and rather than the ND16FA-6, was wanting to use the ND25HF-4. It looks a lot smoother and flatter, and it should let me push the X-over frequency down (which I think I want to do), and if I'm not mistaken I think it is a step up from the ND16. I built a pair of overnight sensations, and I think the ND20FA-6 sounded pretty decent. Maybe they aren't that different (same family)?
Here's the problem:
Tweeter be big -- box be small!
Dayton Audio ND25FA-4 1" Soft Dome Neodymium Tweeter
There are a couple of options here:
1) buy the version without the face-plate and figure out how to mount it
Dayton Audio ND25FN-4 1" Silk Dome Neodymium Tweeter Element 4 Ohm
2) modify the face-plate into a square 2 1/16", which looks doable I could do that, but it looks like it might make the face-plate a bit flimsy, but I could reinforce that if necessary
Has anyone done either of those two things? Or, does anyone know if there are options for changing the face-plate. It's not clear whether the voice coils can be replaced, or whether the tweeters can be disassembled (which would make modifying the tweeter a bit easier).
Thoughts?
Other tweeters to consider:
HiVi TN25 Fabric Dome Tweeter (small rectangular flange that would work)
Tang Band 25-1166SJ 1" Neodymium Soft Dome Tweeter (flange could be modified)
Peerless by Tymphany D26NC56-06 1" Fabric Dome Tweeter 6 Ohm (might work as-is, or could modify)
Paradigm blown low pass driver
Hi looking to install a cheap speaker like Timpano
TPT-MD8 8 ohm in place of the stock speaker. Do I need to adjust the cross over cap etc...no help from manufacturer
  • Nominal Diameter8"
  • Power Handling (RMS)130 Watts
  • Power Handling (max)260 Watts
  • Impedance8 ohms
  • Frequency Response80 to 9,500 Hz
  • Sensitivity95 dB 1W/1m
  • Voice Coil Diameter1.5"
Thiele-Small Parameters
  • Resonant Frequency (Fs)72.6 Hz
  • DC Resistance (Re)5.8 ohms
  • Mechanical Q (Qms)19.3
  • Electromagnetic Q (Qes)0.69
  • Total Q (Qts)0.66
6v6 Musical Machine - Clipping & power expectations
First post on the forum, and seeking a bit of advice. 🙂
As a first attempt at building a valve amplifier, with an aim of learning more about valves in general, I've built a version of Pointdexter's Audio Tropic 6v6 musical machine.
It's up and running, adjusted as per the design, and various threads from back in the day. Sounds nice, and I'm quite happy with it. Doesn't hum, hasn't caught fire, arced over or anything else amusing. 😀
I've just been doing a few measurements to see what it's actually turned out like; I've no more fancy test equipment than a cheap multimeter, Hantek USB scope, and REW.
I should add that I aimed to build this as cheap as possible, primarily because I wasn't entirely sure I'd get it to work. So it's a lab experiment rather than aimed for perfection like some of the lovely builds on the forum.
I designed the board trying to keep the input audio route straight and the heaters away from the input side as far as possible. Laser transfer and etched at home effort. 😉
I redesigned the PSU to take advantage of the most cost-effective transformers I could get hold of shipped to/in the UK in a sensible timeframe. More relevantly I'm also running extremely cheap 100v line transformers as OPTs. This was inspired by http://home.alphalink.com.au/~cambie/6AN8amp/M1115.htm ... 😀
I've attached Poinz' schematic here (again), along with my schematic, a few photos and some measurements.
The issue I'm seeing is that I can drive the amplifier into clipping at 1khz just beyond a measured output power of 2.5w, which seems on the early side.
I'm assuming the bass rolloff I'm seeing is from the tiny OPTs. The -3db point at 1W is around 44hz, and at full power, more like 56hz. I'm okay with that, so long as it's the OPT causing it. Limitations are fine! 🙂
It makes about 5.5w into 8ohm, at 1khz flat out. That's for a 2v measured p2p input. Haven't tried driving it harder, as it's already firmly clipping at that point.
Basically wondering if what I'm seeing power/clipping wise is about right?
Cheers! Paul
Definition of "push-push"
This seems fairly basic/fundamental, but I cannot find a definition
of "push-push" for two drivers. I read what seems like mis-used or
perhaps contradictory or unclear usage of this term.
Does "push-push" strictly refer to two drivers mounted with opposite
direction of cone motion, without ANY mention of:
1.) wiring polarity
2.) shared air volume
3.) firing direction (although I presume it means "facing opposite directions")
4.) Isobaric or not
So what is the definition ?
Does it ONLY refer to force-cancellation for purposes of controlling
cabinet vibration ?
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,772
Members
7,887,922
Messages
Filter
Forum Statistics
Threads
406,206
Messages
7,887,922
Members
507,772
Latest member
Hypertone
