Taramps Bass 12k - Output Issue
Amp came in with shorted FETs on 1 side of the PS and 1 bank of the output, see 1st pic. I replaced the known defective parts. The amp powers up and has drive signal on both output sides and they match. The issue is the output under load at the speaker terminal.
With a 40hz signal input, and a 1ohm resistive output load, 1 side(negative terminal) looks like it is shifted slightly from the other, see pic 2 set to DC. The 3rd pic is set to AC for a better view. When the signal volume is increased to a higher level, the output begins to distort and starts drawing excessive current, see 4th pic. This level is well before clipping point. I have set the DC offset with the 1 pot to zero at idle but I'm not sure what that 2nd pot is used for. I adjusted it but didn't see any change, it's back to it's original set point. With the amp running at a low volume and no output distortion for several minutes I see no abnormal heat build up using a thermal camera. Any clues?
