SMPS Tube kit - Interested?
- By JZatopa
- Tubes / Valves
- 21 Replies
After reading about the SE KT120 car audio amp kit here and the tube SMPS thread here, I thought I would reach out the the developer of the amplifier. I was curious to see if he was interested in developing a stand alone SMPS for tube amplifiers. It turns out that he has done some work on such a design but he plan on having it run off of 13.8V, for car use. He is also looking for some input as to the design itself. Would you guys like to add some input?
I will post our correspondence below.
I have 2 questions. I was wondering if you will be releasing a stand alone SMPS for tube amps that runs off of 12V? There are few people on diyaudio that would be interested in one. I was also wondering if you will be making a 120V of the monobocks? Any chance it would be easy to modify the PCB to work of 120V?
I have a standalone power supply in the works. For the most part it’s the same one that I use in the monoblock. I’m having trouble making a few decisions or I would already be producing them. My dilemma is I’m fairly confident I can come up with a design that produces over 250w but I’m not sure if that much power is really necessary. I’m also on the fence about whether to include a heater voltage supply on the standalone unit. Start a thread and see what people want. If there’s enough interest I will make it. Send me back a link so I can follow along.
I don’t have a 120v solution yet but I’ve been using and suggesting this:
25A 14v DC Power Supply for Chargers (350W)
It runs 2 kt88 monoblocks nicely. It should run 2 kt150’s but I suggest using separate supply’s for that application. The monoblock draws about 8a with an el34 and about 12a with a kt150. The 120v question comes up a lot so I have been putting thought into a 24v version. This will reduce current significantly and make it easier to run on 120v. I’m thinking I can modify my existing design by changing the windings on my transformer to accomplish this. I also plan to make a 120v monoblock at some point. Finding time for all this is the biggest problem.
Would you mind if I used your response in the topic? I don't mind starting one and seeing what interest is out there. I do know that guys on the site are going to want to know more about the design than just the voltages and current abilities. Output impedance, switching frequency, noise, etc. are all things they are going to be interested in. Do you have some of that info available?
You can post my responses. Switching frequency is 60k/2, quesent current is 280ma, efficiency is 84% @50w – 87%@100w and 92%@150w. Output regulation is 4% under 100w. I don’t have a measurement for over 100w. noise is 2.5mvrms. When I designed the power supply I added output capacitance until there was no measurable ripple across my speaker load then used a small filter in the pre section but none is required in the power section. The monoblock I make is dead quite.
