Mark Audio Full range speaker build help
- By bluehalk
- Full Range
- 38 Replies
Hey Guys,
This forum has helped me a lot in learning and building speakers. In the past, I did do couple of build using Mark Audio Pluvia 7 drivers as per below build thanks to Dave's design plans.
Bass reflex: https://www.diyaudio.com/community/threads/ma-pluvia-7-bass-reflex-bookshelf-speakers.354125/
And
MLTL: https://www.diyaudio.com/community/threads/fullrange-bipole-mltl-speaker-build.351281/
I did not keep the MLTL for long due to their size. but, I still have the bass reflex speaker and have quite enjoyed them over the time.
I am now looking at building another set of speakers, as the Pluvia 7s don't quite offer much in bass region, leaves me wanting more. In the past, I did use them with subwoofer, but now I am simplifying my setup and don't want to add subwoofer in the mix.
What are my options for a fullrange speaker build that offers bass down to 30-40hz region and still sounds good up top and in midband? Being in Australia, options of getting the speaker drivers are bit limited and importing can be costly. As such, I am keeping my options limited to what is currently available locally from darcher.com.au.
So far, her is the list of the drivers that are locally available.
Mark Audio Alpair 10p: http://www.darcher.com.au/store/index.php?route=product/product&path=59_60&product_id=95
Mark Audio Alpair 11ms: http://www.darcher.com.au/store/index.php?route=product/product&path=59_60&product_id=99
Mark Audio Alpair 12P: http://www.darcher.com.au/store/index.php?route=product/product&path=59_60&product_id=67
Before I go ahead and order couple of drivers, I just wanted to get the recommendation on which drivers to get and which design to build.
Here is what I am looking for.
For now, I am thinking of building Pencil design http://frugal-phile.com/boxlib/pensils/Pensil10p-plan-140613.pdf with Alpair 10p, but I am open to other suggestions both in speaker driver and box design (apart from Furgal horns), but as said above, in Australia its bit limited. Will the bigger drivers be better alternatives?
And
- Easy to drive (around 90-91db sensitivity)
- Good bottom end (around 30-40hz)
- Somewhat flat frequency range
- Good soundstage and imaging
