Plate load triode amp, resistive load in bafle.
- By santitrucco
- Tubes / Valves
- 2 Replies
Hi at all.
IF i have an DHT triode amp with 3K : 8ohms output transformer.
And If i have a compression driver working since 2.5kz with 8ohms curve and also a 5 ohms resistor in series.
The plate load change with a 8 ohms driver , and the additionaly 5 ohms series resistor ?
Or this resistor does not change the load that the plate tube see since 2.5kz ?
The series resistor Influences in some way ?
Santiago
Santiago
