Hi all
I know, I know this mide be way out of league but I'm gonna build it anyway
I'm not an expert in any way, but I have make couple speakers and they did sound nice to me.
Now as time goes by, I'm starting to lose interest in diy so this will probably be my last diy project...At least I hope as one is more expensive than the previous one
In a couple days I will start making test cabinets but would like, if someone has time to check my plans about volume for drivers and spacing between those. I would appreciate it.
Below you will find pictures of concept design.
One is a classic box, and the other is a box with tweeter on top to have the option for sliding it forward and back for time alignment (not important as I have DSP..but it look's cool to me
Front baffle is at 5* angle but tweeter is not angled.
At first I liked the option with tweeter on top, but leter I prefer a more classical design...will see....
Thas will be fully active, analog precision DSP, hypex, SB acoustics with RAAL drivers, all in closed boxes ;
in a 3-4 Litres closed box
- 2 X Satori textreme MW19TX-8 + second channel of NC252MP /
satori-mw19tx-8-textreme
in a like 9 litres per driver, total around 18-20L closed box
- 2 X SBA subwoofers SW26DBAC76-8 /
sw26dbac76-8
dual oposite subwoofers in like 20 litres closed box with linkwitz transform (like 9-10 litres per driver)
Crossover points would bi like ;
- sub / 19TX - around 80-85Hz
- 19TX / 13TX - around 500-600Hz ( at about baffle diffraction point ?)
- 13TX / RAAL - from 1.7-2.4kHz will see what sound best
Baffle wide is 220 mm.
What do you think ?
What about driver spacing between drivers in dependence of crossover frequencies ?
RAAL advise me to place center of tweeter at around 95 cm.
And one question how to place all those amplifiers on a plate.
Option A when I have power supply of NC252 and NC500 facing to the top and bottom of plate - speaker cables will cross each other
Option B when I have NC252 and NC500 power supply facing each other - the interconnection cable for subwoofers will be a little longer run by the power supply. Don't know if there will be any interference.
For me option A looks like a safer bet, but option B would be easier to connect once they are inside the cabinet...or not...
Please don't be hard on me, I'm not an expert, and I'm doing my best to not become one
Will play with baffle design around tweeter, to achieve something like wave guide or not...will play and will se where it will take me...
The look is like 90% of the sound so
😉, it's more important how it looks then the sound of it
Here is a video of my previous build, so I'm not total noob, but...
VIDEO 1 or
VIDEO 2
