Hi gang ,
So , I was hoping to gather any smaart users that are also proficient in REW and rephase.
So , I have been using REW with rephase and making firs….. took me way longer then it should have to learn it because I’m a clunker.
😛 but I’m a master now!
So , here’s what is going on and maybe someone can help
With REW, I have CSL umik2 and a creative sound card (separate clocks separate devices yah de yah etc etc….
I take 9 gated FDW 15cy measurements around my head. I use REW and shift IR, smooth , time align and vector average…
Send average to rephase for work….
Result is fantastic… my goodness it sounds stunning…
So , I get addicted to pushing the envelope with firs, I’ve emailed lots of ppl and annoying them asking for help… wow some smart ppl on here…. Absolutely brilliant!
So , in my quest for accurate fast mag and phase data , I bought smaart (v9LE) and I also bought the Roland octa capture as recommended by
@Rational acoustics.
I also bought works M23R mics… so I have a nice array of very expensive nice mics…
I spend a month getting it to work right, finally getting decent data…. (Except smaart crashes like crazy) watched all 12 , 1hr trainings for smaart on you tube many times for a few of them.
The smaart tunes do not sound anywhere near as good as my REW tunes…. It’s close but it’s not near as good….
RA says to use 1 mic for phase , although I can use up to 8…. All I want is very clean phase data and quickly…. That’s it , I can do the mag stuff in REW, that’s easy,..
Does anyone know how to get smaart to work like REW in this example? I’m not sure it ever will….
Should I ignore RAs recommendation and do multi mic TF for phase anyway? Or what is the key to get the same results as REW or close to?
I got the measured phase preferctly flat on both side to match exactly, following same rules (phase changes only between 100-1600hz)…. The center image is spread out and blurry… it’s still mostly a good center , but I would expect perfect being mic is directly between my ears. I did all the work on same session, same settings, same volume, same mic placement… same everything… did left and right separate on an OpenDrc..
I hope it’s a setting I’m missing….
Much appreciated…
Andrew
@fluid ,
@pos
@mark100 ,
@BYRTT ,
@wesayso
