Hi everyone.
I ask for your help to understand where the problem lies and possibly how to try to solve it once and for all.
I'm dealing with the classic, usual Fullbridge amplifier Chinese copy of the Brazilian sounddigital.
It seems that there are various Chinese brands that copy them.
One in particular is really excellent and builds amplifiers for a handful of brands here in Italy, while others appear to be very poor, as they have (factory new) enormous and very annoying background hiss if used on the front speakers.
I've compared all 3 models (sounddigital, good Chinese brand and bad Chinese brand) and they really look the same, except for a few things, but they basically work the same.
The thing that immediately struck me are the output inductors, which are different between the 2 Chinese brands.
I'll try to attach 2 images of a good Chinese 5000 and a poor Chinese 5000, to show the "differences" that I struggle to find.
The tests that have been done on the bad Chinese amplifier:
1) the background hiss seems to decrease significantly if the supply voltage is </=10v, so I thought that by regulating the feedback circuit to have a coincident rail even at 14.8v I would have solved the problem, but not it solves.
2) I thought of a preamplifier problem, but separating it from the rest of the amplifier by removing the "DC decoupling cap" I correctly separated the preamplifier from the amplifier, but the hiss remains.
3) I tried to level and strengthen the power supply of the entire preamplification, but the hiss remains.
4) I tried to somehow modify the values of the filter capacitors on the amplification stage, but the problem remains, indeed it could get worse (I did this test, because I noticed that the values of the Chinese amplifier are different from those of the sounddigital original)
5) I tried to install additional 6.8uf 400V ceramic capacitors, as close as possible on the pins of the output mosfets, but the problem is not solved.
After doing all these USELESS tests, I'm seriously starting to think that the fault lies with the output inductors, which are literally terrible.
But I ask you, maybe someone has already understood something, and wants to help me.
As you can see from the photos, although all 3 are 5000w, the sounddigital and the good chinese copy, use only one power terminal block and a single output terminal block, also, the diodes are to220 format, while in the bad chinese copy, we have even 2 power terminal blocks, a double output terminal block and the diodes are in TO247 format.
The latter would be very favorable factors to a bad Chinese copy, if it weren't for the fact that, in practice, the amplifier is worthless.
A thousand thanks.
