60Hz hum in this 6DJ8 Headphone Amp I've just built - Poor Layout?
- By dubadub
- Tubes / Valves
- 13 Replies
Greetings friends, I've had a productive couple days and completed work on a compact 6DJ8 Headphone Amp. While I became aware of the project thru @Suncalc I decided to use SS rectification and built the circuit as described in the DiyAiudioProjects website, with the Antek AS-05T160 (160v@150mA) planning to adjust the dropping resistors in the power supply to achieve the 135-150 voltage spec'd in the schematic. Heaters use AC, both coils paralleled and artificial center tap to Ground. It's built in a Hammond 1458VE3 enclosure:
The amp powered up just fine, I saw a little over 200v with no tubes installed. Drained the caps, installed a pair of tubes and fired it up with some headphones plugged in but no signal. The voltage leaving the power supply is about 166v, so I need to increase the dropping resistors. But I heard a savage hum coming from the headphones while they sat on the bench. Not loud enough to break em, but certainly too loud to use the thing. Sounds like 60Hz but I don't have a dummy load built so I can't say for sure. Hum was equal across both channels in the headphones.
As you can see, the open-frame OTs are rather close to the PT. Maybe I could put a steel cover around the PT.
And the leads from the OTs pass under the volume control pot and cross the input leads, but I'd expect any noise from that to be high-pitched...
any ideas, thoughts welcome. thanks for taking a look.
w
w
