Choice of Transformer or Choice of Design
I have a tube amplifier that I built with a Hammond 270EX power transformer. I understood most of all of this 40 years ago during school. I want to make an amplifier for a friend to play guitar and my question is two-fold:
1. Is there a more economical transformer than the 270EX?
2. I'm assuming that I really need to understand the power "needs" first?
I'm here for a while, so my first thought is (since I didn't design my amp's schematic) to design new circuits around my 12AX7 (two-preamps) and EL34(power) tubes. I want to design an amp that I could legally sell on order from guitar friends. And, back to the Hammond, are their other (cheaper) alternatives that I could look at even if I have to design based on differing power requirements? I know nothing about power transformers other than the curly lines on schematics and in textbooks.
thanks
David
Putting a bunch of wallworts and bricks into an enclosure
First off apologies if this is an already addressed question.
I'm looking to put all of my systems wall warts and power blocks into a single chassis, purely for aesthetic reasons. I'm not looking to do any filtering, surge protection, etc.
Is it kosher to have a standard iec inlet in the chassis that then feeds multiple standard duplex outlets inside? I've never seem it done, so there must be a good reason not too? Basically, it's a power distribution but with the AC outlets inside.
And then for the low volt outputs, there are a few paths, none too complicated.
Thoughts?
Great Heil, great midrange. Needs (super) tweeter?
I have been playing around with my recently bought factory new ESS heil tweeters. Other than the shipping cost and import tarrifs to my country being more than the tweeters themselves, they are absolutely great. They are airy, detailed, full, non fatiguing........BUT
Am I alone in feeling they need a tweeter? I am missing a certain "bite" in the top octave and feel due to their size they don't image all that well.
I was thinking of running 2 Heils per side with a small (super)tweeter sandwiched between them...crossed over at around 10khz 1st order. Either using the same wings (extending them up or down) or with its own horn(as small as possible)....
Added bonus would be a dipole tweeter but I am not ruling out monopoles.
Any tweeter suggestions? I was thinking of using a small neodymium 3/4 inch silk dome without faceplate (or 2 back to back out of phase)....but maybe there are better options?
ROAR15
Hello fellow diy'ers.
I recently received my ROAR15's from the CNC shop and was in the process of loading them with B&C 15SW115 when I noticed something amiss with one of the drivers, coil scratch, so that driver is going to be returned to the dealer.
The other one worked as intended and despite having only one ROAR15 up and running I still wanted to share some pictures and very early impressions (that may change as I get more time with them and both of them working).
They currently reside in our apartment's living room, so I cannot test them properly (you know, neighbors...) but even so I also do not have the means to properly power them, at least not yet.
Anyway, on with some pictures.
The driver baffle and interface:
Next to above we see one of the quarter wave segment inlets into the resonator:
The post summation quarter wave resonator:
The one that worked:
And finally the state of things as present, I will given time arrange things a little better, what you see blow is a work in haste, perhaps I will be moving them into another room seeing as the person I live with has voiced some opinions on the matter, can't say I blame her, they are actually somewhat noticeable.
Preliminary impressions of one ROAR15, corner loaded, in a relatively small room at low levels, is that it sounds massive, in this placement it also digs very deep, and I do notice a lot of bass details both in the lows and higher up in it's range.
It does seem to have the ability to be both punchy and dig deep at the same time, this trait it was also noticeable in the ROAR12 previously evaluated but this is a more of everything sort of experience in comparison.
This is not much to disclose given the conditions described above but it is a start.
I will be putting some more pictures and impressions up once I have the new driver mounted, until then.
signal cable inside amp...shield usage?
With reference to signal cables running inside amplifier/preamps such as from RCAs to boards, volume pots to boards etc. In the past I've used twisted pairs of single strand copper that I've extracted from Cat5/6 cables. I've been careful with wire routing and physical separation of supplies etc. and so far it seems to have worked fine. However, I have so far also avoided putting big linear supplies in the same box.
So, in the context of an amplifier using a big transformer in the same case and using a ground loop breaker / ground lift thingy using shielded cables for small signals seems like a better idea:
It appears that in general people use single core coax cable for their small signal routing on and off boards. They connect the core to the signal and the shield to the return which typically is the `signal/pcb' ground. There is an effective faraday cage around the inner wire, but the signal return/ground (the other half of the circuit), is `exposed' so doesn't this negate the value of using a shield? - I appreciate that the far end of the `signal return'/pcb ground is connected to ground via a ground loop breaking resistor/diode bridge arrangement, but in an ideal world I'd assume you'd want to avoid adding noise anywhere in the signal/return circuit.
Follow up question: Does it make sense to use cable that is two core + shield with the Signal and `return/pcb ground' connected to the two inner cores and the shield connected to the Permanent earth/safety ground/case at one end (...one end only Vasily).
Reactions: Ixnay
What is this brown stuff, and how to clean?
Hi
I was asked to take a look at a pair of Vincent SP-991 amps. Both are dead. That is, no sound, but relay kicks in, and no DC on the outputs.
After some time fiddling with how to take it apart ( no fun task ), I discovered that one of the pcb's ( the input stage on the bottom ) was totally covered in some
brown goo'ish stuff. It is quite sticky. I first thought it might be a leaky cap on the other pcb on top of it, but no. The top pcb is clean.
It is all of the pcb that looks like this, not just a small spot, as if the pcb itself has been sweating, could that be the case?
The way it is build does not allow for air circulation for this pbc. No ventilation holdes around it or on the pcb on top of it.
Sadly i forgot to take pictures before I started to clean. Here are a few images after cleaning round 1
What could this stuff be? and how to clean it ? The caps dont look bad. The goo isnt concentrated around the caps
The other light brownish goes off when using ordinary pcb cleaner and qtips
how do I connect subwoofer cables to a car amplifier?
So I have a Rockford Fosgate T1500-1bd amplifier
Its got 2 channels for speaker cables, channel A and B
On my subwoofer I have 2x 4 subwoofers which lead to a single cable, black and red cable
So how do I connect this speaker cable to the amp?
to channel A plus and negative? that means channel B is empty,
or do I connect the red subwoofer cable to the plus on channel A and connect the black subwoofer cable to negative on channel B? so looking like a bridged connection?
The amp is a constant power amp so its confusing on how to connect this amp to the subwoofer
thnks
Mr Noob
Ikea Unity Horn
I have an extremely difficult time with woodworking. Every time I make a box, it comes out looking wonky.
Ikea now sells MDF cubes measuring 35cm x 35cm x 35cm for $20:
https://www.ikea.com/us/en/p/eket-cabinet-white-80334603/
So I wanted to see how suitable they would be for a Unity horn.
Admittedly, the size isn't ideal; it would be nice if they were bigger. But I can't make a good looking box to save my life, so here we are.
Attached is my first stab at it. It used a waveguide that's 25cm x 25cm. Response is pretty rough because it needs a roundover.
Depth of the waveguide is 2.25" (5.7cm)
Here's the ath model:
Throat.Diameter = 25.4 ; [mm]
Slot.Length = 3 + 9.7*cos(2*p)^2
Throat.Angle = 17.5 ; [deg]
Throat.Profile = 1
Length = 57.15 ; [mm]
Coverage.Angle = 62
;Coverage.Angle = 48.5 - 7*cos(2*p)^5 - 12*sin(p)^12
;Term.s = 0.7 + 0.2*cos(p)^2
Term.s = 0.8
Term.n = 3.7
Term.q = 0.995
Morph.TargetShape = 1
Morph.FixedPart = 0.5
Morph.TargetWidth = 229
Morph.TargetHeight = 229
Morph.Rate = 3
Morph.CornerRadius = 76.2 ; [mm]
Morph.AllowShrinkage = 1
; Mesh Setting
; ABEC
Mesh.AngularSegments = 80
Mesh.LengthSegments = 30
Mesh.CornerSegments = 8
Mesh.Enclosure = {
Spacing = 38.1; 38.1; 38.1 ; 38.1
Depth = 330
;EdgeRadius = 19.05
EdgeType = 1
FrontResolution = 8,8,16,16
BackResolution = 20,20,20,20
Mesh.Quadrants = 1
Mesh.DepthSegments = 20
Mesh.AngularSegments = 60
Mesh.ThroatResolution = 6
Mesh.InterfaceResolution = 12.0
Mesh.InterfaceOffset = 5.0
Mesh.ZMapPoints = 0.5,0.2,0.5,0.8
; ABEC Project Setting
ABEC.SimType = 2
ABEC.f1 = 500 ; [Hz]
ABEC.f2 = 16000 ; [Hz]
ABEC.NumFrequencies = 61
ABEC.MeshFrequency = 1000 ; [Hz]
ABEC.Polars:SPL_H = {
MapAngleRange = 0,90,19
Distance = 2 ; [m]
;Offset = 140
ABEC.Polars:SPL_V = {
Distance = 2 ; [m]
Offset = 140
Inclination = 90
ABEC.Polars:SPL_D = {
Distance = 2 ; [m]
;Offset = 140
Inclination = 42
Output.STL = 1
Output.ABECProject = 1
Report = {
Title = "Feb25_2024_waveguide"
PolarData = "SPL_H"
NormAngle = 20
MaxAngle = 90
Reactions: AllenB
Epos ELS midrange drivers info
I bought a pair of these new unused, just out of interest. EPOS seem to have a following and they seem to employ simple XOs, so I am hoping these are quite easy to implement.....into what I don't know yet!
Anyone know who made them?
Part no. ELS3mb01
They're a 4 ohm driver. Cast chassis. Not sure if the cone is aluminium, though it doesn't feel cold enough as it's been sat outside?! Maybe a coating.
Nice looking things and seem well built.
TS Params to follow.
Something don't look right to me
Im cutting out the mid driver recessed and I've finished my first pass and something doesn't add up. It looks like the mid driver is too close to the tweeter compared to other peoples travelers. I've drawn out where it's supposed to be in the end and drivers are suspiciously close. Is my math not mathing and I'm crazy or did other people move their mid driver down or did the diamater of the tweeter change????
Below are the plans I'm following
Bellow are examples of other peoples travelers where there seems to be atleast half an inch gap compared to 0.2 inch mine
Newbie Just Starting - do wires matter for signal and power?
I'm building an enclosure that holds 3 existing PCB boards that are streamers - basically small pre-amps that you can stream to. Mostly an assembly challenge to house the 3 PCB boards, add a single power switch, a 5V power supply, and 6 RCA terminals for inputs on the back panel along with a way to connect the plug to the mains.
I'll need to run wires from the RCA jacks to the PCB boards and I'll need to run power from the supply to each of the PCB boards.
  1. For the RCA input signals can I just use single stranded wires for these connections or do i need any kind of shielded wires or keep them in pairs in any way?
  2. For Power from the supply to the pre-amp PCB boards I assume i can just use a single positive 5V wire and a single ground wire with a gauge that covers the expected amperage?
While i'm asking...anyone know a good source for where i can get a good regulated 5V power supply for this that I can install in my enclosure?
Last, but (hopefully) best ever modified and complete NAD 3020
So we have done a few of these over the last few years, but im hoping this could be the best one.
I will continue to repair these and other amps because i enjoy doing that side of it, but i want to start concentrating on learning more, and eventualy,if i ever get there, build my own from scratch.
But for now im taking a good condition 3020A(i made the mistake last time of converting one with faults, so this has been servied first) and going to convert it all to gold plated, change the rear terminals to gold plug ins, total recap, remove the driver stages and convert it to Lateral FETS.
I did convert some amps some time ago, but it was either with gold, but BJT's, or with TIP 35'S etc, but never all in one
so this one will be all of that but in one package.
I know NADS are like marmite, you either do or dont like them, so i guess this is for those who do.
STEP 1
so to start with the rear has to be converted
so the inside has had a first clean, it will get another later
the rear has been stripped, cleaned and resprayed
I have taken an old terminal assembly ,stripped it down and converted it to gold plug in terminals
STEP 2 will be to strip out the old transistors and get to work on what heatsink will be used and start the board conversion for the FETS
STEP 3 will be a second clean and recap
STEP 4 will be to do a dry run with the FET fitting
STEP 5 fit the FETS
STEP 6 mod the circuit
STEP 7 fit all the rear terminals
STEP 8 Testing
STEP 9 If all working ok, long soak testing
STEP 10 respray the main cover and assemble
Diode confusion NAD C356Bee
In my Project to fully recap my NAD 356 BEE i noticed, that the amplifier is distorting in the right Channel. Its barely noticalbe in usual hearing but when i run a freq sweep it is clearly noticable.
So i checked the Amp and noticed that one diode in the feedback cuircuit is damaged. It let run the Signal both ways which it shouldnt and the MM diode checker also says, that the Diode is blown.
I identified the Diode "D12" in the service manual and the it just says "4.7V 500mw"
I was looking for the diode on Digikey and found a replacement but im a bit confused what Diode i should pick.
The "4.7v 500mw" diode is available in different types that have different values in the diode impedance and back leakage etc. and im not shure if i have to be careful here to choose the right one with a specific Value.
So i thought a "Vishay 4.7V 0.5W" with the "lowest" 19 Ohm impedance would be the best choice. But it is available up to 100 Ohm and the
"Current - Reverse Leakage" and
"Voltage - Forward (Vf) (Max)"
values are different in the multiple available 4.7 500mw Diodes.
Thats the one i choosed first
https://www.digikey.com/en/products...iconductor-diodes-division/1N5230B-TR/3104101
These are the available Options :
https://www.digikey.com/en/products/filter/diodes/zener/single-zener-diodes/287?s=N4IgjCBcoGwJxVAYygFwE4FcCmAaEA9lANogAsYYAHHAOwgC6+ADqlCAMoYCWAdgOYgAvvjgAmAAyIQKSBhz4ikUmQB0tAAQA1RizaQQAVV7dUAeQBmAWWwBDAM6Z02YfjBwa02fLyESIKQYREDEwCQRoGTQsXyVSAFYJCQ0AWwB1XRBWdmNTSxsHJxdggFoxL2iFP2UQeMYhYPKarW57AAtbAE8NABNuAh7sDTVaLQ1EiRSAd0yYaW4e9hKwkD12VZBUTuYXA2EhIA
So do i have to look close to these values or is any of the 4.7v 500mw fine?
i would be glad if someone could help me out here so i can get the Amp to run again. I also noticed, that the trimpods to adjust the amp to 6mv are not working anymore. Etherway i turn them with my MM on the Test point the value doesnt change anymore. Is that a logic consequense in case of the blown diode in the way?
Here are the shematic infos
EDIT:
Entire schematic / Page 17
Thanks and Cheers!
Silas
I am doing something wrong with REW - Getting Phase Shift - I need help....
I have been taking measurements this week of a dipole mid planar. I have been getting this crazy phase shift that I thought was just from it being a dipole. I put a back cup on it and its still doing it. I then tested another speaker and its doing it for that speaker as well.
I must have something screwed up in my settings. Can someone please take a look at my settings and tell me what I have input incorrectly get this crazy phase shifting happening?
I'll attach pictures of the phase shift and my settings
Temporal simulation results do not align with compute oscillation frequency
I'm attempting to design a feedback loop for a self-oscillating amplifier (for fun and education). I wrote a script to calculate the parameters outlined in Bruno's article, but upon simulating the feedback network transfer function in LTspice, the oscillation frequency doesn't match what I calculated (it's much higher when the entire FBN is simulated by a VCVS and much lower when the output filter is physically simulated). Does anyone smarter than I know why this might be?
For reference, the feedback network uses a KHN biquad for the proportional and derivative (lead compensator) part (I'm summing the LP and HP outputs), and there's a low-pass MFB filter for the integrator.
I've attached the LTspice file below, and you can open the Python notebook in Google Colab.
Edit: The notebook won't run in Colab I think because there's a conflicting scikit dependency, anyone is welcome to run it locally though!
Sony CDX-T69 making buzzing noise on disk 1
The sony cdx-t69 6 disk cd changer in my cars trunk makes a loud buzzing noise (sounds like an overtorqued motor or skipping gears) whenever its on disk 1. 2-6 work perfectly but whenever its on 1 it stops working and the cars radio says "push reset". I opened it up and located the general source of the noise (photo attached), but i have no idea what im doing or what to look for. Any advice/fixes?
Swan Song? High End Buffalo 9038 build
So. What started out as upgrading Tridents to my old dual mono 9018s in the previous thread here spiralled rapidly out of control- thanks Franco Largo for providing the temptations and suggestions for optimisation.
To be honest its been at the back of my mind for 2-3 years but a bit of free time has finally allowed me to get this project off the ground- The best DAC I can conceive of and build.
An added impetus was noticing its a bit of sunset on Twisted Pear Audio, don't know when Brian will finally shut up shop. So I took the plunge a couple of weeks ago and invested in a 9038 and Mercury while they are still available. Delivery due tomorrow or Tuesday I reckon, looks like they arrived in the UK yesterday accordingn to tracking. Nice!
The design plan is:
2 proper Modushop Chassis; 1 for PSUs, 1 for DAC/Music server
DAC:
  1. Music served by my old BeagleBoneBlack,
  2. Music library stored on onboard SSD
  3. Source clocking using my old Hermes and Cronus.
  4. USB hub to allow connecting more storage to the BBB.
  5. Buffalo 9038
  6. Mercury IV
  7. Option on Analaogue output filter, something like 6 pole.
Regulation
14 x cascoded regulators, 1 for every board in the DAC unit​
PSU
8 Transformers
12 seperate supplies
3 umbilical connectors betweeen PSU and DAC:
So thought Id share the design and build journey, a sort of last salutory swan song to the Twisted Pear digital products. Hope you enjoy, (and it all works out as planned!).
Magnavox model 1ST605R - no schematics/manual
I have a magnavox mystique model 1ST605R and I need to do a cartridge replacement and some repair work on the radio board (can't get FM to work). However, I can find ZERO on this model number. I even looked to the Sam's Technical Library and there is ZERO in the 1ST model range. Can anyone help me? I know it needs a new fantail cartridge, but I really need the number for this item as they are NOT cheap and there is no returns. Anyone have any help for me?
YBA CD2 Delta, Classe CDP .3, Roksan Caspian ... main board
I'm trying to fix my yba cd2 delta player.
The player works perfectly for 20-30 minutes and during that time track poor cd without any trouble.
After that time, it start having troubles reading and at some point wont even initialize a new cd.
The problem seems related to the spinning motor where it try to turn but won't reach proper speed. If I give it some help it will initialize but after some time it will start skipping when slowing down.
I've found a visual problem on the main board which seem a generic board for the sanyo sf-p1. The diode d116 (circled in the picture) is over heating and damaged the board and traces connecting to it. You can see that the diode is lifted from the board to prevent that but it's still hot enough to conduct heat to the pcb and slowly destroy it.
I would relocate the diode to a bigger one using the casing as a heat sink but I need to find the reason that this happened. The player had been repair for the same trouble couple years ago and from what I can see they only replaced that diode.
The main board is the same you will find on many players of this era, classe cdp .3, roksan caspian, cec cd2100 cd3100, krell kav-250 ... I've found some pictures of these cd players over the web that show discoloration around that diode so I don't think it's a problem only related to the implementation in the yba cd player.
I've searched for a schematic for any of these players and only found a service manual for the classe cdp .3 and it doesnt cover the main board at all.
If anyone had experience with this problem or have a schematic it would be of great help.
Hello everyone. I am a new member, I joined the group to learn and exchange knowledge and need your help. I read on the group forum that someone h
Xin chào mọi người. Tôi là thành viên mới, tôi tham gia nhóm để học hỏi và trao đổi kiến thức và cần sự giúp đỡ của mọi người.
Tôi đọc trên diễn đàn nhóm rằng có người có một bộ khuếch đại công suất Counterpoint solid 1E mà tôi có và tôi muốn khôi phục nó. Tôi thực sự hy vọng bạn có thể giúp tôi tìm thông tin về một số thành phần để tôi có thể thay thế chúng.
Thông thường, các thành phần của bóng bán dẫn đã bị loại bỏ và không còn thông tin nào còn sót lại như:
Q2; Q3; Q4; Q5; Q6; Q7; Q9; Q11; Q12; Q14; Q15; Q17; Q18; Q19; Q20; Q21; Q22; Q23; Q24
Nếu bạn có thông tin hoặc sơ đồ mạch của bộ khuếch đại công suất Counterpoint solid 1E, vui lòng gửi cho tôi.
Tôi thực sự hy vọng nhận được sự giúp đỡ của bạn.
Cảm ơn rất nhiều.!!!!!!!
For Sale GM70 copper plate, NOS, tested
hi!
I have in stock excellent electron tubes ГМ70 / GM70 copper plate
All tubes NOS, close data codes.
Each tube was tested.
1) GM70 copper plate, matched 5pcs, price 600 $/quintet SOLD
2) GM70 copper plate, matched 2pcs, price 260 $/pair (i.e. $130 each) SOLD
PayPal payment
Best regards!
Olexandr
Kharkiv, UKRAINE
skype: OAA-1974
PMD100 muted output issue
Hi all!
I'm having trouble with an Audio synthesis DA-X. It's not locking on anything. There is an,,,? error light that comes on when there is no signal and after that goes out it's supposed to lock but the 44.1khz led keeps blinking and there is no sound. I traced the digital signal all the way through the cs8412 input decoder and to the input of the pmd100 but there is nothing on left and right outputs. As soon as I turn the dac on both outputs measure at about 5ohms to ground but both soft and hard mute pins are low. I was wondering if it was somehow possible it was accidentally switched to the maximum attenuation.
Lowering rectifier voltage in tube amplifier
I've been all over the Internet looking for a good answer to lowering the voltage down after The rectifier tube. I have a 5U4GB rectifier tube in A 6l6 GC PP amplifier. 525 on The Plates , 400 on The screen and - 26 Bias. This is with the Rectifier tube in and the output tubes out. Also I have a 100 ohm 1 watt resistor going to the second can getting extremely hot. I'm guessing that it is the one lowering the pre Amp section down to 400 At the second can. My Filter Cans are 500 volts 50/50 and 32/32. A little bit more filtering than the amplifier had in it originally. 40 and 20 were in it originally. I'm going to The 50/50 first. Line is At 123 AC. My plan was to put a 10 watt 100 ohm cement resistor after the rectifier tube and before the first filter can. Also to put one in the place of the one getting hot for the pre Amp power on the second Filter can if the first resistor doesn't cool it down to a reasonable amount of heat. I would think that It should be able to stay cool especially with the two 6l6 tubes out. I also put a 1 ohm resistor on the cathodes so I can read the ma of the tubes..I wasn't sure where to put the two 5k Bias pots At. Or if I really need them or not. I have switched over the chassis with this thing and I don't have any type of wiring diagram for it. It came out of a 1960 Whirlizer Organ and without knowing what organ it came out of the wiring diagram is impossible to find. The amplifier number is pretty much useless in finding it. Whirlizer 501273 is the amplifier number for what it's worth. I've been reading about using chokes also but I don't know if I should go that way without knowing anything about the specifications. Seems much easier to use resistors first to get it under control. It seems like 100 ohms in 10 watts resistance is pretty standard for lowering down the voltage. I've Used 120 ohms Cement resistors At 5 watts before in small tube line amplifiers to get the running voltage down after the rectifier tubes. It seems to work pretty good in them. But A small line amp and this 6l6 GC seem like they are world's apart. I'm also A little concerned with the low amount of bias voltage -26 being supplied. Any help appreciated.
Transistor as N.C. Relay
Hi, will this circuit perform as intended ? . A normally closed transistor relay , that when a voltage is applied on the input it cuts the current flow to the Relay Coil .
The use of it is in a speaker DC detect / protect circuit , Instead of using two Relay's I was thinking this would work . Also for the Relay flyback , will a 1n4148 survive?. The relay is rather small ( 350mH inductance ). Thank you.
Mosfet I'll use something in D-Pak like IRFR2405 .
- Bruno.
For Sale SANKEN NOS SAP15N-SAP15P
I have several new pairs, and a lot used ones. The used ones all come from Arcam A85. The main board of these failed and had to be replaced.
I serviced Arcam in Norway for many years.
The new ones originates from Musical Fidelity. I did some of MF amps also.
New $24/pair, used ones at $20/pair.
Shipping st cost.
Open baffle with identical drivers in a sealed enclosure behind it - Cancellation?
Hi all,
Simple question for concept. I was looking at designs and it made me wonder about the idea of using an open baffle speaker, something 100hz to 20khz bandwidth that is a dipole, and then right behind it, identical drivers in a sealed cabinet with a little space between the drivers, aligned. The backwave of the open baffle and the front wave of the sealed with opposing phase should largely cancel each other out. Does that leave only the front wave? And the dipole pattern handles the side to side off axis output too? I've got to be missing something here, other than the obvious requires DSP to do the phase and delay to get the effect and the double drivers, etc. What huge thing am I missing?
Very best,
What kind of recording is suitable as a reference?
I would like to ask you guys specifically which songs or albums you think are suitable as a reference and why.
For example, when evaluating a speaker, one person may say it's the best, while another may say it's the worst. I often think that this is actually just a matter of the music being listened to or the listening habits. There's no way that someone who listens to modern hip hop at high volume and someone who listens to antique chamber music quietly can give the same evaluation.
For myself, I have been using Steely Dan's "Gaucho" as a reference for a very long time. It's a great production, very well balanced, but it's not perfect. In fact, I think that the vocal production on this album is quite poor. However, the reason why I still use it as a reference is simply because I have been listening to it for a very long time. It was my favorite album when I was in college. I feel confident that I can evaluate playback devices fairly well just by listening to the first 30 seconds of this song, which I have been doing consistently for decades since purchasing my first audio system in college. My wife says, "You love this song." but I don't actually listen to it because I fall in love with it. It is rather a cursed relationship. I have several other references for myself, but I think I'll write about those later.
Furthermore, I think that audio forums like this should make it mandatory for users to list a few reference songs on their profile. Otherwise, it would be a waste of time to argue with someone whose taste and listening habits are unknown. It would only lead to the conclusion that it's a matter of personal preference, without any real learning taking place. I believe that information about a member's musical references is much more useful than knowing what kind of equipment they own...
Curved, high WAF, 3-way speaker build
Welcome to this thread about the speakers i'm currently building.
This is my second speaker design/build that i have done.
The goals of the build are as follows:
  1. High Wife Acceptance Factor.
  2. Should not look like a dull ordinary box.
  3. Have a nice flat frequency response.
the project has been going along for some time already, but i have to choose how i am going to do the crossover.
which one should i do?
  • passive crossover
  • active crossover
  • active system with 6 amps and DSP as a crossover
I would love to hear your stories and reasons to choose one of these solutions.
speakers from top to bottom:
Dayton Audio Reference RS225-8 Bass-midwoofer
Dayton Audio DC28F-8 1-1/8'' Silk Dome Tweeter
Dayton Audio PC105-8 4" full range woofer
Tonearm and Cartridge Matching
Hi. I am a bit concerned with whether or not a cartridge that is being sent to me will match well with a tonearm another fellow sent to me as an upgrade for my Micro Seiki BL-51.
The cartridge in question is a Shelter 201. According to the specs, it weighs 6.2-grams, and has a compliance of 15-10 @ 100hz. I figure that this means that it is around 26-10 @ 10hz.
The tonearm in question is a Micro Seiki MA-101 MKII, which is reputed to have an affective armtube mass of 7-grams. In addition, I found a wood headshell that weighs 7-grams as well. Should this not give me a total affective mass of around 12-grams?
Using the best compliance calculator that I can find online (korfaudio.com), it looks like a good match. The "old fashioned" calculator at Vinyl Engine say it isn't, but I have found it to be pretty inaccurate compared to my real-world findings so far.
How many of you have used this cartridge, and what tonearms and headshells have you successfully used with it?
For Sale Burr Brown OPA2228P (2pairs)
Here i have for sale BURR BROWN OPA2228P Opamp, that is NOS, new, newer used. It is DIP8 package, have low input low noise 3 nV/sqrt Hz, Gain Bandwidth of 33 MHz and Slew Rate of 11 V/us.
It is excellent choice for audio preamplifier input stage, and it is made by well known manufacturer BURR BROWN.
Price is €60,00 (for 2 pair) + Shipping Cost and it is selling as 2pair only.
And have 2pcs NOS of ELNA SILMIC II 470uF/16V that is used for NFB capacitor in amplifier. This capacitor have best sonic so it used as NFB capacitor in amplifier.
Price is €6,00 (for 2 pcs) + Shipping Cost and it is selling as 2pcs only. I can do combine shipping.
Need someone to build a power supply for a Mares Connoisseur phono preamp
Help needed, someone knowledgeable to building a power supply for my Mares Connoisseur phono preamp. My rebuilt 20 yr old power supply built by Ric Schulz went kaput, flamed out. Hoping to find someone here who might be able to build one or direct me to someone. After consulting with Ric, says he doesn’t do anymore such work. Thx.
Paul Wong
Located in the Monterey Bay area
559 240-1841 cell
Fullrange and passive radiator
Hello, I'm wondering, because I didn't saw much of this kind of speaker here. I mean compact speakers with a fullrange and a passive radiator. Is this something completelly off the charts ? Something not effective at all ?
Here are the two projects I made around this idea.
-Spherical enclosure made of blanda bowls (2.4L inside) ;
-Dayton Audio RS100-4 fullrange driver direct wired and no filter;
-Dayton Audio DSA115 Passive radiator.
-Pill shaped enclosure made of blanda bowls and layers of MDF (8.6L inside);
-Markaudio Alpair 11MS fullrange driver, direct wired and no filter;
-SB Acoustics SB15SFCR-00 5'' x 8'' passive radiator.
Thank you in advance for your replies on the subject.
Project 3 way in existing box: middle to high end parts
I am in the process of selecting my mids drivers.
There are many products at comparable price: Scan Speak Illuminator and Revelator (why two?), SB Acoustics, Seas and Purify among others.
On what criteria will I choose the driver. It will be paired with same kind of price 6-7-8 inch woofer and a tweeter.
I look for detail and precision. One room 17 by 30 and the other 15 by 17 feet.
I listen to music lower than 90 dB and mostly under 80 dB.
Thanks for your help.
B&O ICEpower 200ASC pictures
Hey guys I'm trying to repair a faulty KEF HTB2 subwoofer that happens to revolve around a 200ASC module from B&O.
The faults lie within the power supply section and during the initial failure a chain reaction of destruction occurred where several components failed. The problem here is that upon failing any markings that would otherwise identify said components ended up either charred black or in pieces.
I have scrounged the internet high and low for detailed images of the power section but haven't been able to find very much. A few images here and there, useful as a starting point, but not really enough.
The version that I've got is revision F.
Schematics for this are unobtanium, so if anyone could take some detailed pictures of the power section that would be most appreciated.
What I'm after are the resistor values for the components surrounding the main SMPS controller, I think this is an NPC1203D6, but that was from an image taken of a different revision. Resistor values for both the top side and bottom side are necessary as the destruction spread wide and far!
So far I've replaced the dead transistors, power MOSFET, controller, aux protection zeners and some resistors with what I could make out but no luck. The device fails to start-up and when the aux supply is provided externally it will start (and then continue working when the external supply is removed) but no regulation occurs.
Why not 4 ohm drivers in series?
The use of two 8 ohm drivers wired in parallel is very common but why don't we see more speakers with two or more 4 ohm drivers wired in series?
It seems to me that would produce a far more tube amp friendly speaker.
For example we could use two 7 0r 8 inch 4 ohm drivers which are around 92 db sensitivity [like some of the Scanspeak Discovery drivers] to give around 95db sensitivity and an 8 ohm impedance.
Drivers like this for example.
https://www.google.com/url?sa=t&sou...4QFnoECBQQAQ&usg=AOvVaw0D3Rizpjdd3KJ5iPTysgum
Weird 7F7 adapters on eBay
I was looking at 7f7 tubes on eBay and came across some head scratchers of adapters. The obvious one is to use 7f7 instead of 6sl7. But how about 7f7 for 6sd7?
https://www.ebay.com/itm/387567242346
Pretty sure it is actually for a 7a7 and the seller made a typo in the title. But then I came across this one :
https://www.ebay.com/itm/205077894462
7f7 instead of 25z5? A 6v twin triode for a 25v double diode? It’s printed right in the adapter. The same seller is also selling a 7f7 to 25v6. What am I missing?
Signal relay contact composition
Does anyone know what the benefits / drawbacks of different relay contact compositions are, specifically gold over silver vs gold over silver palladium?
The context is a SPDT relay used for channel switching in the preamp of a Marshall head. The relay sits between between 12AX7 stages. The original part has gold over silver palladium contacts, but is impossible to find from Marshall or anywhere else (it was discontinued decades ago). What I have been able to find is a model from the same series identical in every specification except that it has gold over silver contacts.
A search online tells me that gold over silver palladium has better resistance to oxidation and sulfidation than gold over silver, but I have no idea if those are likely to be a practical issue in this application. I have no way to know if Marshall specified the contact composition for a reason or just used what was available.
It's appealing to use the one I've found since I know it will drop in to the amp mechanically and electronically without any adjustment whatsoever. If the composition difference is unlikely to make a practical difference then it saves finding a different relay which may require an adapter board or tweaks to the surrounding driver circuitry.
back DIY after many years
Hello
I'm starting a new 3 way speaker project project after many years away from the soldering iron . My first project was a copy a famous french DIY 2 way project based on a foxtex fw208n and scanspeak tweeter. But after moving to a house with a much larger living room I felt the need a system room more capable of rendering the large ensembles and with stronger bass. And I also was bit tired of the somehow systematic sound of the bass reflex in the low register. That’s how I came to open baffle, but for some space reasons and went towards H frame design, and a thread on a French forum lead me to try a circular version of the H frame.
I have a background on acoustics from my studies but limited DIY experience so I’m looking forward to exchange with this community.
I'll post very soon some description of my project and crossover attempts in dedicated subforum
Cheers
Laurent
Small, hopefully fun ripole variations and driver selection
Having recently seen @tubelectron's micro and miniripole designs, it inspired me to play around with different variations to pair with my son's future bookshelf speakers, which are expected to be Zaph ZA5.2s (thanks for the midwoofers, @mordikai!) that could benefit from support below 80 Hz. I'm not looking for high SPL or shaking the whole house, but playing down (to ideally below 30 Hz) at modest volumes would be pretty sweet.
I'm swinging from cheap and cheerful to slightly better but still inexpensive drivers arranged in different ways. It seems that a downside is that it's hard to compete with a pair of inexpensive 12" drivers for one of these things. But, a fun form factor might make it worth not being the highest impact for the dollar. 🙂
I know very little about driver selection, so please take these ideas with a grain of salt!
Version 1: Quadripole... super cheap e.g. GRS 8SW-4 8" Poly Cone Subwoofer 4 Ohm drivers (currently $14 USD) arranged like a plus with 2 opposing pairs firing into a common chamber. The outer profile could be an octagon, perhaps with the "45 degree" sides curved inward a bit for visual cheekiness. Or maybe the outline is almost a pure circle. Not sure these would play that low with such high Fs drivers, though.
Version 2: Version 1 but with a better driver, e.g. GRS 8SW-4HE 8" High Excursion Subwoofer 4 Ohm. . Currently on sale for $40 USD. 10.5 mm xmax driver with 25 Hz Fs. Kind of expensive for a kid's ripole that still needs an amp, though, with 4 of them.
Versions 3 and 4: Trioripole... same notion as above, but with 3 drivers firing equilaterally into a common chamber. Could look pretty cute. Assumes an amp that's stable to 2 ohms or so, I'd imagine. Version 3 is cheap drivers, version 4 is the slightly better ones.
Version 5: fairly straightforward ripole using something like the GRS 8SW-4HE.
Version 6: fairly straightforward ripole using an inexpensive 12" driver like the GRS 12SW-4 12" Poly Cone Subwoofer 4 Ohm, currently 27 USD.
Thoughts? Other suggestions?
Audio, Power Supply, Inverter and Voltage Regulators
https://drive.google.com/drive/folders/11BpBLBlzvXQZEr_oiTbX5Bwy19xwU24E
This publication discusses :
1. Audio, Power Supply, Voltage Inverter, 5V to - 5V made with a few, unregulated MAX1680 IC's with a maximum output resistance of 0.6 Ohms. Discussed is MAX889, which is the similar, but, regulated.
2. + - 3.3V, Audio, Power Supply, Voltage Regulators, made with a voltage reference, amplifiers and TIP31 and TIP32 transistors. Many, other audio, voltage regulators have been discussed.
3. Based on the resources used for these, some ideas have been proposed for a power amplifier, which, is not the main subject of this publication and was introduced in the addendum.
Search the document or scroll down to the sections, named " Schematics " and Pictures.
As usually, mistakes are, always, possible with such a long document.
Miro AD1862N-J DACs choice of boards
One pair of AD1862N-J DAC chips with a choice of board types. Either with Shift registers for Amanero or XMOS I2S modules or with JLSounds XMOS module on board.
Price is the same for both types. Perfectly built with quality components. Both boards come with AD797SQ op-amps installed - will include 82pF caps + 100R resistors for RC filter mod as shown in AD797 datasheet
JLsounds board comes with pin headers and connector blocks for I2S module.
Both DAC boards have pin headers installed for separate direct supply to op-amps.
JLSounds SOLD.
More to come... stay tuned folks
Building phono stage pre. How much AC shielding?
I recently put together a nice phono stage pre-amp board. It is a VSPS. Anyway, I stuffed it into my source selector and wasn't happy with the crowding, and how I had to arrange the power (dual rail for the VSPS, single for the relays and dac board). So, now I have decided to put the VSPS board in it's own chassis, and I am going to include the power supply.
My question is, how much shielding or distance between the transformer and the pre-amp board is needed to be more or less hum free? The chassis is 10x6x2 inches. I will have the IEC power and transformer (50VA +- 12VDC) on the left, and the board on the right. About 4-5 inches separation. The chassis is steel. What additional shielding if any should I expect to need to keep hum to a minimum?
Thanks in advance,
Roger
Mains ground on B&K av5000 question
I just received my new to me amp. I opened it up for a visual inspection before plugging in to the wall. I notice there is no ground on the IEC receptacle. There is also n empty ring connector on the star ground. Did these units come like that from the factory? I know my Denon receiver has a 2 prong IEC receptacle, so not sure if I need to connect a ground to the amp. I assume that the ground is lifted to reduce hum.
Transistors replacement for my Technics SA-5200 receiver
Hello, somebody can help a newbie to find some equivalent/replacement Transistors for my old Technics SA-5200 receiver? I Would appreciate very much your guys help to bring this guy back to life.
Each transistor is marked in the schematics image, and their role in the circuit is also marked on the parts list image below.
Thank you all !!!
TR 705, 706, 709, 710 -> 2SC1318R , Q
TR 110, 707, 708 -> 2SC828Q , R
TR 711, 712 -> 2SA720R , Q
TR 713, 714, 715, 716 -> 2SD318Q , P
For Sale Tubes
For sale tubes that I dont need anymore!!
1 x JJ 5y3S totaly new
1 x JJ ECC832 totaly new
2 x Tungsram ECC82 pair- SOLD !!!
Buyed by Tube depot Usa
2 x 6x5gt CV574 Brimar Nos
Buyed by Langrex UK
2 x 6x5gt Sylvania Nos
All together 100 eu plus 7,90 euro tracked shipping inside EU.
For the buyer I will put some new and used tube socket in the package.
Payment by Paypal Friends.
For more info cantact me.
Room FULL of speakers near Vancouver
Fellow diy'ers, the time has come.
Shipping is limited to small items only.
Selling the house, so must clear out 30 years worth of the world's best hobby.
Some large, some small, some short, some tall.
Bring your friends, for a spending spree,
Some are expensive, but some are free.
Commercial speakers, bare wood hobby types, and lots of raw drivers. Some NOS, some just old.
This is not my retirement fund so you will be pleased with the prices, except of course with the expensive stuff.
Come rummage around, way too much to dig through and try to list it. Not all items are displayed in the photos.
Altec Lansing, Dynaco, Advent, Paisley, Sony, Selenium, CSS, Realistic, Cerwin Vega, Dahlquist, Community, JVC, HiVi, Motorola, Foster, Polk, Sammi, Airborne, Koss, Mission and Sharp are the ones I remember off the top of my head.
Includes:
Dust, at no extra charge.
Partial proceeds will be donated back to diyAudio. Amount depends on how much support this gets.
For Sale Rythmik Audio A300SE
I'm selling an old Rythmik Audio A300SE DirectServo subwoofer plate amplifier.
According to previous owner the amplifier is not working. I got this when I bought a 12" Rythmik driver.
I have no way to test this and therefore do not know what is the problem. But based on the capacitor brand alone those would be my best guess.
Date code seems to be from 2008.
Should be fixable.
Price 30€+shipping
The XA60.8 is rated at 60 Watts per chassis into 8...
...and 120WPC into 4 Ohms.. Stereophile's John Atkinson measured one and got maximums of 150 Watts into 8 Ohms at 1% THD, 240 into 4, and 380 into 2. VERY impressive!
My question--are those large outputs achieved with the amp still in Class-A biasing or does the amp fall into class-AB biasing beyond, say, 60 Watts into 8?
Here's my system recently.. Amps are PS Audio BHK600s and Pass X260.8s; speakers are SoundLab Majestic 745s.
AX11 Building - Dealing with both electronics and autism
Hello Community,
I hope this message finds you all in good health and high spirits. I'm reaching out to this knowledgeable forum with a humble request for assistance that holds significant importance to me.
I recently registered here, driven by my passion for electronics and music, to embark on a project that's close to my heart: crafting my very own audio amplifier. This journey has been incredibly rewarding so far, but I've reached a point where I could use a helping hand from experienced minds who understand the intricate world of electronics design and PCB layout.
I must admit that the learning curve has posed some challenges, and my autistic traits have added a layer of complexity to this process. I have always hesitated to share my personal journey, as I've encountered instances where discussing my condition led to misunderstanding or undesired pity. But today, I've decided to reach out because I believe there might be individuals here who can empathize with my journey.
This journey has brought me to the "Apex AX11", a project that struck a deep chord within me due to its intentional omission of a variable resistor and its unique approach to grounding. However, despite my enthusiasm, I've encountered challenges that have left me feeling somewhat stuck. While it's conceivable that the creator of this schematic may be a member of this forum, I remain uncertain about his current level of activity.
In essence, I'm hoping to connect with someone who understands the complexities of dealing with both electronics and autism. Any support and guidance, no matter how small, would be immeasurably valuable to me.
I've dedicated time to studying schematics and electronics, often navigating the journey alone. The process can be incredibly frustrating, especially when the path forward isn't clear. This is where I now find myself, seeking to navigate the realm of components selection, schematics and PCB layout.
I discovered EasyEDA, a software that breathed new life into my project by offering ready-made component designs. However, my struggle now centers on translating my schematic into a coherent PCB layout. I find that as I move components around, lines appear to shift connections unpredictably. While I understand that components ultimately interconnect, this uncertainty leaves me concerned that I might unintentionally make errors.
In short, I'm reaching out for assistance. Opening up and seeking help is challenging for me, but my intuition tells me that the incredible minds of this forum might hold the solutions I seek. This project means the world to me, and I believe that the understanding and knowledge within this community can help me overcome these obstacles.
To provide some context about the project, I've made a few component substitutions:
BC546 to BC546ABU
MPSA92 to KSP92BU
BD249C to TIP35C
BD250C to TIP36C
MPSA13 - Did not find a candidate
I'm seeking your valuable input on whether these component swaps are suitable for the audio amplifier design. Additionally, do you recommend any adjustments to resistor and capacitor values to ensure compatibility and optimal performance?
I've also noticed a particular detail within the schematic that has prompted a query. In regard to the speaker (-) input, I've observed an arrow denoted as GND. Could you kindly provide clarification regarding whether the speaker (-) input should be linked to this designated GND arrow? Furthermore, I'm inquisitive about whether the ground stemming from the input should be connected to the left-ground point. Alternatively, is the GND originating from the power supply intended to be connected to the GND point on the right side? Additionally, should both the (+) and (-) speaker inputs be connected to the Output?
I extend my deepest gratitude in advance for any insights, guidance, or assistance you might offer. Your willingness to help me on this journey is a gesture that I deeply appreciate.
Thank you for taking the time to read my message. Your kindness and expertise mean more than words can express.
Warm regards,
Prognosis
Hello
Hello everyone
Kosie here. I am firmly in my middle age and geek out on all things gadgety. I have been working with computers for more than thirty years. Came across the site researching building the next level after wanting to upgrade my pi/hifiberry streamer and wanting to create the absolute best (within reason) listening experience while working on the PC. Binge watching Gabster on YouTube. Obsessing 🙂
Need.to figure it out.
Bye
Mesh settings for simulating diffraction (fin) horns via Akabak
Dear @DonVK and @fluid ,
I’am trying to design a diffraction horn for use with a B&C DCX50 compression driver. I’ve read yuichi arai’s book about diffraction horn design and build a CAD model. Now im interested if I can further optimize the design. I’ve tried to simulate the horn in Akabak but I came by the problems you describe in your blog post:
„Especially the individual fins or separate channels and their integration as BEM model at throat and at the end of the fins is tricky. You could either simulate them as individual channels but in this case several interfaces are necessary and you could end up with interface issues (one to many and many to one subdomain). Or the BEM model is one single mesh including the fins but then at fin start and end you encounter very close vertices when the fins are very sharp which is a problem with BEM.“ -> https://sphericalhorns.net/2023/04/09/the-mk3b2-radial-fin-horn/
With the individual channels as separate domains I not only struggle with interface issues, importing the model into akabak is incredible tedious. With all in one domain the fin ends are getting displayed in purple, indicating that the mesh is not sufficient dense.
Which of the modeling options yielded you the best results? What were your mesh settings? Did you use Gmesh for meshing?
For non-fin-horns i found this mesh settings:
"For examples a 400Hz horn simulated up to 10Khz, needs the driver membrane meshed at 5mm (150 elements), the inner horn at 10mm (2800 elements), outer horn at 30mm (1000 elements) mouth interface at 10mm (1000 elements), and edge at 20mm (100 elements). This 5050 element model, with 64 frequencies on an 8 thread 3.5Ghz processor takes approx. 3-4 hrs to solve." ->https://sphericalhorns.net/2019/10/20/bem-simulation-for-a-freestanding-horn/
How did you model the exterior of the horn? As the horn mouth is not straight I placed the horn inside an infinite baffle and modeled the outside of the quarter horn.
Projects by fanatics, for fanatics
Get answers and advice for everyone wanting to learn the art of audio.
Join the Community
507,783
Members
7,888,320
Messages
Filter
Forum Statistics
Threads
406,236
Messages
7,888,320
Members
507,783
Latest member
ys.zhu
