If I put my notes here, I might be able to find them again later!
capacitance measurements with the hp 4192A
Posted 10th June 2015 at 01:10 PM by rjm
Work stuff. I was writing Labview vis for an hp 4192A LF impedance analyzer and needed something to measure to check the data acquisition program. So I stuck some of my audio capacitors I happened to have into the 16047A test fixture "just to see".
I have no idea what these measurements are telling me other than yes, the 0.47 uF capacitors are indeed 0.47 uF ... up to about 0.5 MHz anyway. Maybe someone can do some technical analysis. I was struck though by just how quickly the inductance of these big film caps kicks in. As audio coupling caps they are fine, but if you are silly enough to use them as power supply bypass for example...
There are some reproducibility issues I'm still coming to grips with, but the differences shown in the plots is definitely from the capacitors themselves and not the leads or random variations. I've measured them several times over with similiar result.
Total Comments 0
