If I put my notes here, I might be able to find them again later!
Voltage Regulators for Line Level Audio. Part VIII : The Teddyreg
Part of a series.
The circuit is described here.
I'm not going to spend too much time on this one. The idea is to increase the input impedance of the pass transistor by buffering it with a jFET so it will support a high-impedance passive CRCRC filter section that generates a low noise reference voltage. The reference is defined not by a Zener or diode stack, but by a simple voltage divider. There is a LM317 pre-regulator on the front, but it is traditionally configured and works independent of the following circuit so it is omited here together with the additional transistor that speeds up the charging of the reference voltage filter capacitors.
The basic problem is that lowering the noise of the reference cannot lower the output noise indefinitely. After a point the output noise is defined by the performance of the pass transistor instead.
As you can see from the simulation, the circuit has the same ripple rejection as the filtered zener-referenced one-transistor regulator, and considerably worse output impedance.
Total Comments 0
