Go Back   Home > Forums > Blogs > RJM Audio Blog
If I put my notes here, I might be able to find them again later!
Rate this Entry
Szekeres Headphone Driver, distortion simulation
Posted 3rd May 2013 at 08:11 AM by rjm
Updated 3rd May 2013 at 08:15 AM by rjm
I've always enjoyed the sound of the Greg Szekeres' Headphone Driver (buffer) and derivatives sharing the MOSFET source follower output stage.
I've often wondered however, whether it's distinctive sound is because it is unusually free from noise and artifacts, or because its unusually prone to heavy second harmonic distortion.
It's not hard to set this up in LTSpice, but I haven't seen it done before. So, for your education and enlightenment, I present the harmonic distortion vs. output power data for the original "classic" circuit as uploaded to Headwize all those years ago. The LTSpice asc file is also included I you want to play along. The harmonic data is generated by hand, reading the FFT peaks for 10 or so different input voltages.
Click image for larger version
Name:	szekeres sim circuit.png
ID:	976   Click image for larger version
Name:	szekeres THD sim 2.png
ID:	978   Click image for larger version
Posted in The Lab
Views 1638 Comments 0
Total Comments 0
Comments
Copyright ©1999-2017 diyAudio
