His Master's Noise: A Thoroughly Modern Tube Phono Preamp
After more than 25 years of faithful service, it seemed that it might be time to redo my phono system. After all, I like to think that I've picked up a few tricks in the intervening years... The old system consisted of a VPI HW17-II, a Linn Ittok LVII tonearm, and a Troika cartridge. The Troika was...
So the basic approach would be to set up an attenuator circuit ala your figure 2, but can't I get petty close by comparing the datasheets of softer and lundahl? i am not sure how to adjust the 6k8 resistor, by comparing the two, any suggestions?
After thinking about it a bit, I think i get the floating balanced input from the tonearm, I have a nice old denon 103, but would like to accommodate a denon 103r as well or even better.
I am in, if someone wants to have some boards made, including Sy's regulators would be my preference.
The 21' maida's seem like really nice but maybe a bit too much for my budget, anyway I could go either way, with or w/out the regs on the board. I will probably build a tubed rectifier HV supply since i already have the parts.
Instead of over spending on the regs I'd like to consider spending too much on an LCR passive network, has anyone tried this the tango/hashimoto's for example? wouldn't there be a some objective advantages maybe, greater accuracy? I guess i not sure about the functioning of R1 in the eq circuit.
