His Master's Noise: A Thoroughly Modern Tube Phono Preamp
After more than 25 years of faithful service, it seemed that it might be time to redo my phono system. After all, I like to think that I've picked up a few tricks in the intervening years... The old system consisted of a VPI HW17-II, a Linn Ittok LVII tonearm, and a Troika cartridge. The Troika was...
lehmanhill
You are correct. The intention by SY was to connect the positive regulator to one side of the heater and the negative regulator to the other side of the heater. The HMN heater schematic shows a connection to common, but that connection doesn't exist. The total across the voltage across the heaters on the ECC88 should be 6.3 VDC as you noted. Even with that set-up, the regulators are working at a voltage difference from common. Since common is lifted well above ground, noise is reduced from a balanced set-up where common is at ground. At least that's how I understand it.
You are correct about the heater regulator power supply voltage being key in the temperature issue. It would take a good size heatsink for +/- 13 V. Even with a lower voltage transformer, I was happier using a heatsink on the regulators.
Jac
