Go Back   Home > Forums > General Interest > diyAudio.com Articles
Old 21st April 2010, 12:00 PM
On Hiatus
SY's Avatar
Default His Master's Noise: A Thoroughly Modern Tube Phono Preamp
After more than 25 years of faithful service, it seemed that it might be time to redo my phono system. After all, I like to think that I've picked up a few tricks in the intervening years... The old system consisted of a VPI HW17-II, a Linn Ittok LVII tonearm, and a Troika cartridge. The Troika was...
8th December 2015
luvdunhill's Avatar
luvdunhill
yeah, that's not clear. The top is the input and the bottom is the output. I left out the bits in between.
8th December 2015
SY's Avatar
SY
On Hiatus
Looks good to go!
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
2nd March 2016
Sabroe
Great work. Really admirable. I want one
@SY. Your article has inspired me to upgrade my turntable.
It’s just an old RP3. Nothing fancy, but it’s simple and easy to modify.
And please. Before any of you read on. Please bear with me, and my entry-/intermediate level.
First I want to replace the old MM Denon cartridge with an Ortofon MC 20 Super II. That demands your RIAA Tube preamp. And so I have a couple of questions, which I sincerely hope you (or anyone) will answer.
1. For my Ortofon, Sowter recommendes the 9990: https://www.sowter.co.uk/phono-cartridge-transformers.php . Does that alter any of the parameters in the schematic? (Please say no)
Great tip, by the way, to create a balanced signal and carry it via CAT5 (or bigger) LAN cable.
2. You write “Yet it is almost invariably done single ended, making a mockery of all further effort. It becomes doubly incredible when one considers that a cartridge (the odd Decca excepted) is not inherently single-ended; it can have both ends float just as well as it can have a leg staked to the ground.” Does that mean that I can alter the connected wires on the cartridge, and get a balanced signal? Without a transformer at the turntable to convert the single ended signal into a balanced?
3. On Figure 9: The raw supplies, high voltage and heater, you illustrate terminal 1-5. Where do they all go? Are some of them supplying the HV Regulators at Raw B+ ?
4. Figure 7: Heater supply regulators.
a. What goes in at H+, H- and Hcommon?
b. What does the down-pointing arrow in the lower right corner indicate? Please bear with me.
I hope to hear from you.
Best regards
Sabroe
27th April 2016
anystereo
Hi, since reading your article when it first come out i've been collecting parts and looking forward to realizing the project. I've really appreciated its simple design and your elegant and affable approach. Thanks so much.
I've got a few questions: I got a nice pair of lundahl transformer 9206's, here's a link to the data sheet: https://www.lundahl.se/wp-content/upl...heets/9206.pdf
Are these comparable to the sowters? would it be a matter only of tuning the secondary?
I am not sure what you mean by re-doing the tonearm wiring. I got an old ortofon arm that's been rewired w/ four, no common ground and a 'chassis' tube grounding wire with a new five pin plug at the bottom of the arm base pivot tube, the mechanics/mass of the arm are configured for the denon 103 & 103r which i use.
both the arm and the xformer seem ready to drop into your design can you confirm?
sure would like to find a set of boards to build on
thanks, David
14th May 2016
jackinnj's Avatar
jackinnj
I have received about a dozen request for boards -- the last set had all of the power supply regulators and filament "heater lifter". I'll do another set but ONLY the amplifier section, i.e. no power supply regulators. Will also leave out PCB mounting for the transformers since some prefer Sowter, Cinemag, ATT, Lundahl and they all have different layouts. I estimate the cost of the boards @$5.10 each. So they are sold at cost in respect of SY's intellectual property.
Since the first run the USPS has significantly raised costs, particularly for "small package overseas airmail" -- figure $7 for US and $13 ROW.
Why, silly hare, are you fleeing from the fierce jaws of the lion now grown tame?
14th May 2016
6L6's Avatar
6L6
But the regulators are a huge part of this circuit! Could you make a 2nd PCB with them?
14th May 2016
luvdunhill's Avatar
luvdunhill
6L6:
I also have a complete design that can be used with an off the shelf enclosure - I just never could get the boards cheap enough. I could be convinced to do a run as well.
14th May 2016
SY's Avatar
SY
On Hiatus
Sorry to the folks who asked questions that I missed.
The Lundahls look great, and yes, it's just a matter of finding the right load for the secondary. The Sowter 9990 are 1:20 which will give you 6dB more gain. Getting the secondary tuned will be a challenge. FWIW, Morgan Jones uses the 8055 with his Ortofon and is quite happy with that. Most tonearms are good to go for balanced as long as you can replace the external cables (many good arms have DIN plugs which make the process easier).
On figure 9, the terminals are as follows:
1. H+
2. H common
3. H-
4. Raw HT+
5. Raw HT- (power supply ground)
On fig 7, the arrow on the right is ground.
14th May 2016
jackinnj's Avatar
jackinnj
Well, yes, but I don't think that there is anything remarkable with the regulators. I would like to see how they compare with the Maida, the LT3080 elevated regulator etc.
Like most of the PCB's for tube stuff, the power supply is connected via an umbilical to the amplifier chassis. I've developed a fondness for the Bulgin connectors.
I put one of the HMN's in a Hammond 1441 chassis and 1451 chassis cover. I still have the one which is in a repurposed Eico instrument case. It will take a bit of reworking
14th May 2016
SY's Avatar
SY
On Hiatus
There isn't; the circuit is designed for high PSR. A Maida should work just as well. I chose the one I did because I had some power supply boards left over from The Heretical Preamp and that made the prototype go together faster and cleaner.
If I were a good storyteller, I'd wax lyrical about the hundreds of hours of listening that went into the regulator and how critical the capacitor types are- unfortunately, I just engineered the thing to work. I'll never get rich this way...
Copyright ©1999-2017 diyAudio
