Go Back   Home > Forums > General Interest > diyAudio.com Articles
Old 21st April 2010, 12:00 PM
On Hiatus
SY's Avatar
Default His Master's Noise: A Thoroughly Modern Tube Phono Preamp
After more than 25 years of faithful service, it seemed that it might be time to redo my phono system. After all, I like to think that I've picked up a few tricks in the intervening years... The old system consisted of a VPI HW17-II, a Linn Ittok LVII tonearm, and a Troika cartridge. The Troika was...
22nd October 2015
SY's Avatar
SY
On Hiatus
Yes, exactly.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
22nd October 2015
TUBESMAN's Avatar
TUBESMAN
One last (for now) question. The IR LED is 1.25V, I don't suppose a 1.5-1.6V LED would make a big difference. Yes? No? Thank you!
Dedicated to the proposition that man's innate thirst for knowledge will someday overwhelm his passionate lust for stupidity.
22nd October 2015
SY's Avatar
SY
On Hiatus
It will likely require a higher B+, and increased dissipation in the first stage tube. IR LEDs are super cheap and easily available- for the initial prototype, I pulled a couple out of some old remote controls. For my nicer build,I bought them at Radio Shack.
Classy, that's me!
22nd October 2015
TUBESMAN's Avatar
TUBESMAN
Yeah they are cheap but it seems they are specked at higher than 1.25V on voltage. I know you like the IR diode because of the low forward resistance. I just had an idea, how about two regular Si diodes in series to get the drop, and sets of them in parallel to get the resistance down, sort of like what you did in the RLD
22nd October 2015
SY's Avatar
SY
On Hiatus
That won't get the resistance down because each diode will handle less current.
This one should work fine. 30 cents in onsie-twosies from Mouser.
https://www.mouser.com/ds/2/311/SFH%2...ant-532132.pdf
22nd October 2015
TUBESMAN's Avatar
TUBESMAN
Ok, I will look into it. The data sheet looks good. Thanks!
11th November 2015
poli's Avatar
poli
Thanks a lot for this fine article, Stuart!
11th November 2015
SY's Avatar
SY
On Hiatus
Appreciate the kind words. Update coming soon!
11th November 2015
luvdunhill's Avatar
luvdunhill
Oh?
11th November 2015
SY's Avatar
SY
On Hiatus
In light of Merlin Blencowe's excellent JAES paper on tube noise, I'll be lowering the plate currents of the first and second stages. It won't change the performance significantly, but it will reduce heat and probably extend tube life.
Copyright ©1999-2017 diyAudio
