His Master's Noise: A Thoroughly Modern Tube Phono Preamp
After more than 25 years of faithful service, it seemed that it might be time to redo my phono system. After all, I like to think that I've picked up a few tricks in the intervening years... The old system consisted of a VPI HW17-II, a Linn Ittok LVII tonearm, and a Troika cartridge. The Troika was...
It got me thinking about the possiblity of an MM version, as mentioned a few pages back. Having done a few back-of-an-envelope calculations, I reckon that replacing the D3a with another ECC88/6DJ8 gain stage (identical to the second stage) would work quite nicely.
The equivalent noise resistance is 300 Ohms, giving a 1st stage SNR (assuming no transformer and a 100 Ohm grid stopper) of -79dB, cf. the -81dB figure that you get from a 630 Ohm cartridge.
Adding in a Sowter 1:1 600-600 Ohm transformer (1.9dB insertion loss, 150 Ohm secondary resistance) gives a SNR of -76dB, but no doubt a significant common-mode improvment.
The input capacitance works out to be about 56pF (including the 5pF for strays) although that number varies by 2.7pF between sections of the 6DJ8 - probably better to use the section on pins 6,7, and 8 for the input on both channels for the lower value. I have no experience of de-ringing transformers, but I'd expect that to be low enough to get decent results.
The 1st stage output signal level is about 165mV, and the output impedance is about 2K6 Ohms - perhaps different enough from the D3a's to make re-calculating the RIAA to R1 = 27k worthwhile, to keep the dependance on the tube's Ra down.
The output with the 5mV output of many MM carts would be ~0.54V at 1kHz.
Other possible tubes are the 6DX4 (Ra = 2K7, Mu = 30), or the 6DY4A (Ra = 2K5, Mu = 28) - but they seem to be on the rare side. I haven't looked into the input capacitance or noise resistance, partly because datasheets are thin on the ground.
Does anyone have any immediate thoughts?
Specifically, I'm unsure as to whether the 1:1 transformer should be of the 600 Ohm or 10K variety. My instinct tells me that the lower-impedance variety is the one to go for, as you might want to keep the winding impedances around the value of the cartridge imppedances - but OTOH, the cartridge load is 47K, so should it be the higher-impedance version. TBH, I'd probably build without the input transformer to start with, and then add one as funds become available.
