Are these 2SC5198 fake?
This sounds even more stupid than the fake manufacturer's position.
Well, the reality is very stupid and in needs of logical explanation.
However, I think Fairchild would have admitted to such a commercial arrangement. These days they avoid it with Korean markings like KSC for 2SC or their own ID like FJP...etc. series, I believe.
Hey, there is similar situation with MT-200 Sanken marking! The most popular Sanken here is marked with 5DY. The price is around $3.6 a pair. A big seller once told me that the first digit is associated with the maximum Vce. 5DY means a maximum of 2x50V. Some years ago, some sellers sell many types of MT-200 Sanken with different pricing. The higher the first digit, the more expensive. But I could only found a marking starting with "5" to "8" (I think the original has "0" marking, or at least "9").
I have seen many fake Sankens marked with "0". That is logical. The question is with the structured unique batch marking scheme.
Just another Moderator
Joined 2003
I'm answering this literally, I hope that is what the intention of the question was :)
Pb is the symbol for lead. Pb free transistors do not have any lead used in their manufacture. Due to Occupational Health and Safety concerns the use of lead in certain countries has been banned.
As for whether the presence or lack of lead affects the performance of the transistors, the datasheets should be able to tell you that.
As a guess, I would say that likely the only place there will be lead present is on the tinning on the leads, in which case the difference will be the use of leaded, or lead free solder for the tinning.
Tony.
What is the differentes between Pb free transistors and non Pb free?
Ok, Pb free=Lead free
WOULD YOU HELP ME ?
View attachment 2SA 1930.pdf
I cannot see the manufacturer admitting to any specification differences between the two types.
I will throw in one of my own.
The lead free plating is not as universally amenable to easy and reliable soldering.
If that is an answer to your question, but I still can't truly understand what you ask.
Joined 2010
Manufacturers are still changing their tinning processes from lead solder and clearing old stock. For example, On-Semi supply part numbers with a G suffix to denote Pb-free, whilst no suffix or A suffix may mean it still uses lead solder tinning. It is easy to read the manufacturer's data sheets to discover such details if you think they help you.
However, it seems you are trying to distinguish fakes with this detail. I think you are bound to have more difficulty with this than you can imagine since your suspicions may be correct or not, depending on the date, package and marking process of the actual manufacturing plant. Many Semiconductor manufacturers are globalized and use licensed production elsewhere so you cannot be certain whether your fakes are identical or very poor substitutes.
Some stocks, globally, are known to exceed 10 years from some sources so you can see that as the manufacturer changes his process and markings, you will need to become an expert historian to identify and predict fakes. Few of us here will ever see some Asian manufactured fakes so there will be limits to our help too.
In my limited experience, it is better to recognize the fonts and precision of markings and check your supplier's integrity and reputation "on the street" - not from official nonsense.
Again, your source's integrity is your only guarantee and you will not be any more satisfied if we can't confidently identify the markings on a particular part you have.
You should test Vceo as a first indication that your part is within that spec. and then consider other faults. A suitable breakdown voltage tester for this is not always available but they are not complex or hard to construct for use with a DVM. :dice:
Is measurement of bipolar transistor Ft any use in determination of fake status? I have a very simple circuit from an old Wireless World that can measure the approx Ft, I built it at the time and it worked but it vanished in a house move many moons ago. I would be willing to build it again if measuring Ft were a good method.
Joined 2010
The single specification for a complementary pair BJT must be very general, by logical consideration alone. However, the spread of Hfe looks to be within grade E limits. Did you anticipate a tighter than specified range?
As a video driver for CRT televisions, a tight or rather, selected range of Hfe is not needed or offered, I think. In audio application, a tighter spec. requirement can not change what the manufacturer supplies just to suit an unknown alternate use.
Perhaps you could consider parameter spreads for any transistors. I believe only expensive power transistors are supplied with close matching to suit high power arrays. This service is not free - you pay more for it.
Whilst Hfe is an easy test, it is easy to fake and exceed using smaller dies for power transistors. What is not so easy is SOA (Safe Operating Area), which really matters.
Vceo is an indicator as well as Ft and Hfe at near working current in power transistors but these may require more effort to prove.
On the good side, so far, with a simple test, your transistors read fine. :)
Joined 2010
TBH, I don't know how telling this will be for small signal transistors but it could sort the substitution of cheap power transistors for modern high Ft types in amplifiers. That would be a huge benefit if it worked for the largest transistors too.
I say 'go for it!' Let's see the details too, if you have the time. :xmastree:
It's based on this Circuit Idea from WW circa Dec 1970. As I say it worked fine. You rotate the switch until there's oscillation output and read off the Ft from the marked switch position. There's no need for the meters, really, a couple of LEDs and switching transistors should be enough to take their place. A reduced oscillation frequency may be better for power transistors, perhaps 2 coils switched for 10MHz & 1 MHz.
If there's copyright problems can a moderator take it down.
