UGS adventures
Manu said:
Here a little pic.
To give a concrete idea of size , I have put next to the display a box of famous Cachou Lajaunie :D
You certainly want to see it "in action" but unfortunately my uC board is actually configured for Christalfuntz LCD (Backlight current and connections).
As soon as I find the time to make the changes I ll post a new pic.
Manu
I've never seen that famous Cachou Lajaunie
:whazzat:
but i suppose it's against the nice smell of garlic.
:D
The dimensions are clear to me. I have are very beautifull samsung display of the same size (20T202DA1J) it's a VFD module but it doesn't work for this application
:bawling:
When i connect it, the atmell controller goes down and i don't know why.
Your optrex display isn't so expensive and easy to order. It's not such an eye catcher as a blue one but more "easy" i expect.
We wait for the new pic.
Johan
:whazzat:
:D
:bawling:
Johan
:angel:
You cannot imagine how much the use of Cachou have done to establish the reputation of french lovers to be the sexiest of the universe....
:D
Color of display is not an issue as long as type is compatible with the software and pin allocation is correct ... I like the B/W ones because of discrete elegancy
Manu
Manu
Yes, discrete elegancy that's the discription i was looking for.
and about french lovers...
:hot:
maybe it's time for your amie Jacco to say something about this issue.
:D
Johan
My UGS module
UGS module with complete (input / output) balanced.
I used 2n5457 / 2n5461 instead of 2sk389 and 2sj109 and used irf610 / irf9610 instead of zvn3310 / zvp3310.
Its has some problem waveform from high prequency oscilation above 45KHz but if I use for typical amplification case, there's no problem !
Rubydac
