Hi Oliver,
Tube-I-zator can do I/V for PCM1704?
Thank you,
Felipe
Hi Felipe,
you could use the Tube-I-zator for all current output DAC chips, also the PCM1704.
This one needs a R I/V value of 100R.
Oliver
V2.0 ? Did I miss any major upgrades, or is this just another batch?
You don´t miss anything.
I am working on the V2.0 revision.
Hi Felipe,
Oliver
Thanks Oliver, please could you link me the schematic & BOM?
Felipe
Felipe
PM send.
A new batch of the HV-Shunt Modules arrived today!
northcool - 1xSure. Add yourself into the list below.
Tube-I-zator Pre-Orders:
Cris H. - 1x (please change to your nickname yourself!)
Jacques Merde - 2x
northcool - 1x
acccruz - 1x
hawall841 1x
morpheous 1x
neoinc 1x
HV-Shunt Module Pre-Order for 2nd Batch:
Jean-Charles - 1x
kamaths - 3x
bequerel - 2x
Hi Oliver,
do you have some of HV-shunt modules left? I would take 2 pcs.
I have Salas shunt V11/2009 HV PCB made my quanghao, but those are to big for my project (as I'm going to place already ordered from you TDA1541 shunt regulators and power modules in same box).
I'm gonna place power traffos and rectification + primary CLC decoupling modules outside the box of DAC - simply to built oversized PSU. Secondary CLC and all Salas shunt modules should be inside box of DAC - just to minimise resistance and capacities in power cabling.
I would take:
2 pcs of HV shunt-module
1 pcs of power module (from your "reference TDA1541")
3 pcs of TDA1541 Shunt regulator modules (from your "reference TDA1541")
Maybe you still haven't sent my previuos order and this looks funny, but two my friends just asked me to upgrade their cd players by shunt regs
Please advice, do you have all those PCBs - can I send request to diyaudiopcb@gmx.com?
Or you can simply send me invoice to my Paypal account - you have my last payment done just yesterday.
Best wishes
noizas
I would take:
Best wishes
noizas
Hi Oliver,
I would take:
Best wishes
noizas
All modules are in stock.
northcool - 1x
Hi northcool,
please let me know what you want to pre order.
Thanks,
Oliver
Hello Oliver... happy new year!!!
just to inform you that i solved the problem with the shunt regulator, the problem was the transformer that was suggested, the r-core in the firsts pages of this thread.
That unit is completely useless, lot of hum and the current ratings are very optimistic to be polite.. the 9V 1A wasn't enough to run the heaters... and probably the 165v 0,1A was less than 30mA in real world
now with the new one is running fine 170Vin and 150Vout
that's it... thanks for everything
Where did you get the new R-Core transformer from? Unfortunately, I got the same transformers. I have not hooked them up yet, but if there is a better one could you direct me to it please? Thank you very much.
Greg
- Group Buys
- Tube-I-zator Professional PCB
