Peter Daniel said:Those are Phoenix SFR16S type: http://dkc3.digikey.com/PDF/T061/1218.pdf
or Caddocks MK132
Does those Phoenix SFR16S type are as good as Caddocks MK132?
meanman64 said:I'am thinking to build an encloser around it and use a fan.
As it is, without a fan, I have doubts whether it would dissipate enough heat. I've just got working a stero amp using PD's boards and the amount of heat really surprised me .
I also tried a fan to force cool one channel and it made a huge difference to the temperatures, so if you intend fan cooling then go for it, if you design it right I'm sure it'd be OK.
BTW I'm listening to mine now great
Kev
meanman64 said:Are the fins to short are what?
Yes, the fins are too short. Using fan may help.
Banned
Joined 2002
That heat sink, it would be enough for a aleph Mini A. Not a A 30.
Re: input ground
I described all the options here:
http://www.diyaudio.com/forums/showthread.php?postid=617068#post617068
meanman64 said:Peter,I'am planning to use single ended input.What connection do I've to make or can I make?
I picked up a large bonded fin heat sink the other day and cut it in half for this project. Size is 6.125 high 3" thick and 8" wide, base plate is .230 thick. I can add a couple of small computer fans running slowly if needed below each sink bit I would prefer to stay convection. Do you guys think this is adaquate sinking for convection cooling? It is alot of square inches of area but I'm not sure what the thermal resistance is for this sort of sink.
Thanks!
Mark
Thanks!
Mark
- The Aleph30 PCB layout
