@ conehead
the lumens output isnt relevant... that means it doesent mathers, even if one got 1000 lumens and another projector got 3000 lumens...
thats because of the different optical units...
just take a look at your lamp!!!
Electrode distance
ac or dc?
wattage
thats all --> post a picture!!!!
@ texando
i think its a jys 250 w DC.... (lamp should have 220w...) but post a few pictures!!
there is a good link for lamp comparison
http://www.donsbulbs.com/cgi-bin/r/b.pl/upc|280|dc.html
Electrode distance
ac or dc?
wattage
@ texando
Psycho, thanks for the reply. When I mentioned my bulb is blown, I meant that it was blown up. It exploded and all that's left is the base which is cemented in the base of the reflector. Therefore I am unable to produce a picture or to test voltage. The only pictures I have found are all of the complete assembly. Almost all the bulbs listed on the data sheet I found when searching the DIY forums were JYd bulbs. As popular a projector as the AE700 was and is I was hoping someone had possibly replaced just the bulb. If I should happen to purcahse a new assembly I may take it apart so I can get a good look at the bulb, and also would be able take some voltage readings.
conehead433 said:Psycho, thanks for the reply. When I mentioned my bulb is blown, I meant that it was blown up. It exploded and all that's left is the base which is cemented in the base of the reflector. Therefore I am unable to produce a picture or to test voltage.
Yeah, my case is the same. Fortunately Psycho and YWH are both quite sure about the bulb in my Sanyo Z1, so I guess that's worth a try.
YWH is not around in the last couple of days... what's up there?
Psycho!
Thanks for the advice on the tool. I know the drill what you mean!
Joepapa
Hi Joepapa
yes! I am selling is just the bulb inside the lamp tube,but not reflector.
150wJYD/AC instead of 132watt will work well.
yes! Order through 18wheeler, the total price is $67.
Hi victor-eyd
some bulb can not be used, break someone to see the electrode.
or, have you seen + - on the ballast? there are two wires contact lamp.
HI ! Psycho
thank you help, I sent mail to you.
Hi texandco 280W Metal Halide
the pdf file is not perfect,280W Metal Halide is right, and it is DC, JYS/DC can do it.
HI ! conehead433
I can not replace a 160wUHM, I sold a factory assembly finally, $200.
I can no sure the cheaper bulb can replace UHM,
Hi victor-eyd
HI ! Psycho
HI ! conehead433
Hi ! everyone!
the JYD/JYS can not replace all projector bulb, so I found these:
Lamp kit model Spec mm price Projector model
UHP120/150W 65*70 105 Epson5350,Infocus755,SonyS900
UHP200W 52*56 187.5 SanyoSU50,Philips3146
UHP200W 65*70 247.5 SanyoXU35,Epson811,SonyPX10
UHP150W 50*55 187.5 SanyoSW20,EIKI SM3
UHP200W 80*80 285 SanyoXP40,
UHP200W Round 85 285 SanyoXP18,EIKI 984,Canon7353,SharpP10
UHP250W 65*70 247.5 Sharp450X,Infocus820,Epson7800
VIP250w 65*70 240 Sharp450X,Infocus820,Epson7800
UHP250W 56*56 232.5 ToshibaD1,benq8225,ViewSonic650D
UHP250W 80*80 292.5 SanyoXT10,XT15
VIP300W 56*56 270 HP 8010 BENQ 8255
VIP150/P22 65*70 150 LG XG22,EIKI NB2W,SanyoSU20N
VIP120/P16 120 LG JT21,3M 7720,Acer700X
VIP150/P16 180 LG JT21,3M 7720,Acer700X,benq2105
VIP150/P24 225 PLUS U2 series
VIP250W 80*80 292.5 SanyoXT10,XT15
VIP300W 80*80 300 FUJITSUC211
SHP180W 50*50 240 SharpBN200X,SHP51
SHP150W 65*70 240 MITSUBISHI51U,Toshiba680
SHP270W 65*70 330 MITSUBISHIXL25,ASK C300,Infocus790
SHP270W 247.5 Infocus340 350
SHP270W 247.5 Infocus530 500
NSH200W 65*70 240 NEC1050,HITACHI2020,SharpCN300S
NSH200W 50*55 225 PLUS U2 210 benq650
NSH250W 80*80 262.5 XP30,MITSUBISHI390
NSH275W 65*70 292.5 HITACHI885,5000
NSH275W 80*80 292.5 SanyoXP41,HITACHI6000
NSH300W 80*80 300 SanyoXP55
UMPRD150W 80*80 255 NEC830
UMPRD160W 60*65 345 NEC440
UMPRD160W 80*80 330 SanyoSP10
NSH180W 50*50 330 MITSUBISHIXL8,SonyEX1
SHL130W 50*50 165 LV2,chenxingseries
HSCR165W 50*50 150 HITACHI 225 1000 1095
HSCR195W 50*55 180 Toshiba220
@ joe + cone
so post the pictures of the blown bulb.... its important that its a good quality........ i dont mean a picture of the produced image i mean a picture of the dead lamp inside and outside...
please write here again your datas on the lamp in.... so i can take alook if i find the time...
thanks
thanks
Hi all
now i found out something interessting....
i got a phillips hopper xg20 and it ses that this damn thing got a special bulb.... hmmm
original lamp inside is a UHP 150W G3 Philips 150C
Projector is a AC projector.
now i put in a JYD 150W AC. after 25 hours lamp blown,,,
new JYD 150W AC tested , 67 V 1A means 67 W!!!
lol
ok testet a few bulbs,,,,, no one worked rigth.
then i saw in the phillips catalog they write 120W bu all projectors got a 150W bulb inside..... Long life 6000 hours.....
now i think they got a special 150W inside running at 120 W or something like this....
testet a osram VIP-R 100-120 1.3 E23H
got 68V 1A means 68W.... damn... dont know what to doo...
pehrhaps its a very special bulb, or the lampdriver may be damaged...
someone has a idea?
thanks
lol
someone has a idea?
thanks
hey all
someone screamed for a 265W uhp lamp??
there we go for 1$ starting....
i just dont believe him about the hours..
http://cgi.ebay.ch/Sony-LMP-P260-Pr...ryZ75421QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
replacement lamps
Hi Yhw,
I have read this thread and note that you have many lamps for projectors. I sell dlp rear pro tv lamps to fellow enthusiasts in avforums in uk and I am being constantly asked about projector lamps...I would be very interested in talking to you regarding supply to me in the uk.
thanks
ade
Hi Yhw,
thanks
ade
Hi, alex2cool67.......
It looks like you need a 180W JYd lamp? The specs for the Sanyo PLC-XE30 say that it uses a 180W UHP lamp, which is quite a common type.....
http://www.quantum-micro.co.uk/pcology/pdfs/Projectorxe30.pdf#search="Sanyo PLC-XE30 manual"
or....
http://uk.shopping.com/xPF-Sanyo_Sa...A_1500_ANSI_2_4kg_400_1_Contrast_3Yr_Warranty
I think JYd bulbs generally work OK on projectors with UHP or VIP ballasts, but hopefully ywh will be able to confirm this for you. I think the UHP type is an AC type lamp too?
btw: Does anyone know which methods they might use in the factory to fit the bulbs to the reflector? I'm guessing they use some sort of grommet to keep the cement / paste in place?
I had to move the bulb slightly further towards the front of the reflector in my Sharp PG-M15X PJ because the bulb was too long. This causes very slight dim areas near the edges and corners of the image, but it's not too bad. Also, I still had to snip off the last bit of the screw thread with pliers to get the bulb to fit inside the lamp housing (NOT recommended!!!)
ywh, are the bulbs available without the metal part and screw thread on so that it just has the two wires at either end?
or....
- General Interest
- Everything Else
- The Moving Image
- DIY Projectors
- I got my new lamp. It is for commercial projection use. people use it to replace the
