F5 Turbo Circuit Boards
Joined 2010
OK
To meet popular demand.
Here's the V2 Combo with mosfets now at 65mm centres and board size reduced to 224mm x 50mm
UKToecutter:
Your layouts keep getting better. Good work.
My only concern now is the proximity of the JFETs to the output signal and to the feedback resistors R7-R10. My concern feedback resistors is that their temperature changes dramatically with the output level, and there is likely to be significant thermal coupling to the JFETS. Of course, there is a significant time lag in this coupling, but it could cause some problems for bias balance.
The center of the board could be de-cluttered by moving the cascode circuit to the empty areas away from the center, allowing the JFETs to move to near the power connector.
Another possibility is to move the feedback
