CD723/753 tweaking!
Hi all,
Has anyone an electronic copy of the drive modification webpages ? They seem to have vanished from the sever. I still have to solder some (10% of the componants) and I cannot identify them on my poor paper print of the schematics ...
Please help :) I would need the full resolution of the schematics and of the component side of the drive PCB.
Hi all
I read with interest Nuuk`s article in Decibel Dungeon regarding the modification of a Philips CD723, so much so I bought one on ebay for £25. The intention is to do the mechanical mods and use it as a transport in conjunction with a Shek NOS DAC which I am currently running with a Pioneer PD S703. The problems started when I read this post, I admit I do not understand a tenth of what is said here (not anyone’s fault but my own ignorance:confused:) but I assume that I need to do the hack when I start the mods?
Will the hack and mechanical mods produce a better machine than the PD S703?
An alternative is to buy a Micromega stage 1. and mod that.
The final question is how exactly do I do the Hack? I don`t have extensive knowledge in electronics so if I have to re-programme eproms etc then I won`t bother (anyone want a CD723?:))
I really would like to mod the CD723 but if I am going to get something that is not as good as what I already have. The issue I have with the PD S703 is the sound stage it`s not deep or wide. I have listened to a Micromega Stage 1 and the sound stage extends out beyond the speakers which is what I want to achieve.
Hope someone can help.
Thanks in advance
Alan
Hello all,
I am most of the way through modifying my CD723 and in Nuuk's instructions I came across this, "Please note that the caps 2513 and 2514 (470 pF) in parallel with the outputs are to be removed if you add 820 pF + 470 uH"
Does this mean that the two items to be added are in series across the output, or should they be in parallel as the 2513/2514 caps are.
Thanks - Jim
Hello all,
I have noticed something else, in the text it says remove caps 2513 and 2514 yet it is 3513 and 3514 that are outlined in red ?
I think the the 820 pf and the 470 uh inductor should be in series, are the inductors soldered in at points A and C [to the resistor leads] and the caps to the resistor lead at B and to the circuit board at D and then joined ?
Can anyone help, I have already removed 2513 and 2514.
Jim
Hi Jim
It has been a few years ago - but I do recall that at NO time did I drill any holes in the circuit board. I either replaced components, bypassed by soldering under the circuit board or removed parts .
I eventually left the RLC suggestion out and have to agree with Nuuk that it may not be worth doing. I have since taken it to a friend to audition the CD723 (Marantz CD4000) and he was so impressed so I gave it to him - he practically threw out his newer CD7300 :). - it is now in my system as a comparison between standard marantz and modified cd players.
Sorry I could not be of more help with this one. Send me an email and I will try and email you some pics of my mods -if that will help at all.
Good luck.
Hello Nuryev and Hello all,
Thanks for the extra info and for the offer of some pics, I didn't do the RLC mod and put back the original caps.
I turned it on just after lunch and one channel didn't work, some track had broken by the new 10 uf/0.1 uf caps, I soon fixed it with some bare wire.
I've been listening to it on and off for most of the afternoon and everything that has been written about the mods is there. Formerly I listened to a Technics SL-PG520A and when I got the CD723 [£20 on eBay] it sounded much better unmodded, a sound stage which the poor old Technics is incapable of.
The mods have taken this difference up another notch and I must thank Nuuk and everyone whose advice I've found in this thread for the excellent work that allows non-technical people like me to achieve audio standards that would otherwise be unobtainable.
I'm very very pleased indeed and can look forward to hearing my collection all over again :)
Jim
May be you will be interested in that. The mods are not made the usual way people (electronicians) usually start with. I didn't make the main mods but added some personal touches and rebuilt everything in a wooden case. The basic conceptions: clock has not been changed. No regulators added but a very strong PI power (roughly 700,000 µ) built specially for the output AOP which is Audio-GD Moon (people usually don't like it too much but at the right place it does better than Burson I previously tried) + a lot of capacitors at the right place. The 2 big condos help the 5v supply.
The result? It beats every modified 723 or 67 like I compared t, being with or without clock, with regulated PS and many commercial machines costing several Kbucks, believe it or not. No stress at all even in the forte, very musical though precise and detailed in a very natural way.A few pictures in my next messages.
Here are a few pics
IMGDEAD]
