Babbelfish J PCBs
Official Court Jester
Joined 2003
steenoe said:
I sure am:) Thanks for the kind offer, indeed. No need to hurry or stress your friend Oly. It seems that I have finally got control over my A-X's adjustment. With a little work and some luck they will be hooked up tomorrow:) One monoblock working right now.
Here is a pic of the 100 watt monoblocks to spice up this thread a little:D
Steen:cool:
I told ya before..........ugly!
make a 10W amp for Tanoys ;)
I must make decent one for 16 ohms RCA's hehe
Wow! I'm really impressed.
Dont be :) Usually I like to get things done, but these darn amps has been in the works for way too long now. I have had problems making them behave in a civilized manner. This morning, my mate Magura called and asked: Are those A-X's up and running yet? Nope, I said. He jumped on the train and arriving at my place, we did some detective work together over the course of the day. Voila, it works;)
Since he is a really nice guy to talk to, we had a load of fun too.
I have to announce this in public: Magura is a genious:cool: And I mean it. After some trial back and forth he made a suggestion I had never thought of. What did the trick? Well we upped the source resistor value a little bit, and all of a sudden the amp behaved. Man I was puzzled and still am:xeye:
Steen:cool:
Magura-your wakoo friend with all those veeeeeeeeeeerrrrrry ugly electromechanicall thingies and gadgets................
Excactly:) His homemade attenuator weighs more than the average poweramp. Solid silver contacts and so on. I never saw hifi gear like his. The poweramp he is making is gonna weigh in at 100 kg. I dont think he will re-decorate the livingroom very often after putting that amp in place.
Well have a look at his things here:
http://www.briangt.com/gallery/magura
Just check out those bolts he made for mounting the heatsinks:eek: I can tell you they are gourgous. Fully machined;)
Well the guy is amazing, and he has the possibilty to make those things and what is just as important, he has the skill's and the drive to do it:cool:
You can see where I got my heatsinks from:D
So, tell us about the bass quality from those amazing looking AXs.
I will, when I have finished the other monoblock and had a decent listen:)
Steen:cool:
Joined 2003
Lovan said:
Hello
What kind of PSU would I need to run a pair of these Babelfish J's?
Would a +-18VAC 800VA with 0.2F per rail be adequate?
Maybe CRC? What value for R?
Looking forward to building these :)
/Niclas
go to www.duncanamps.com and download PSUd for free;
after that,you wouldn't ask anyone else that type of Q........
btw-18 V looks little low,but perfectly OK ........who needs to squeeze last watt from any amp.........except steen :devilr:
and-you'll need CLC with lowish AC voltage of xformer
If I would have got decent answers from PSUd I wouldn't have asked the question ;)
Nearest value above 18VAC is 30 :hot:
What's the highest limit I can use?
Thanks for answering :)
Joined 2003
Re: J-Fets and output devices
cviller said:
Could I use 2sj103 instead of 109? They seem to have similar specs except for the fact that they are not dual.
transconductance is not the same ;
unfortunately,in favor of 2SJ109
How much is the max voltage drop on each of the output mosfets? I'm considering using irfz34 (60V/30A).
its OK......just check input capacitance......you need it in ballpark what IRFP150 have
Re: Re: J-Fets and output devices
Thanks for checking this out for me!
I think I might be lucky to get some 2sj109's by mail. :D
But wouldn't it be possible to parallel 2x4 2sj103 and get something roughly similar?
Cool! It is 680pF, so I should be relatively safe. I might pair them like in Aleph 3.
