Babbelfish J PCBs
I have done some simulations on my slightly modified version of choky's babbelfish. I need to be able to use it for 4ohm speakers, so I have added an extra pair of output transistors.
Does my frequency response look reasonable?
I have had some trouble reducing the clipping when connecting to a 4ohm load - it was easier with 8ohm.
Is this clipping acceptable with a single ended sinus with amplitude 2V (4Vpp)?
Sorry about the messy schematics - I have added voltage sources with 0V to measure current through some of the nodes.
  • babbelplots.zip
Yes, you are right - it is time to start building. I got my irfp240 (100pcs :D ) today, so I need to do some matching...
OK, you wan't more questions... simulation says the two devices in 2sj109 share ~13mA. Is that too much? According to datasheet, 2sj109BL accepts a drain current of 6-12mA. Is that for ONE of the two devices in the dual package?
Official Court Jester
Joined 2003
per one..........side....so-12-24mA per package
my goal was ~ 5mA through each side
Maybe this has been said & done already in this looong thread but i can,t find it..
So here goes, Is there an "easy" way to convert a Aleph30 to a Aleph J ? :rolleyes:
I have got Peter D,s Aleph30 boards on there way but the more i read about the Aleph J there more i think that i should build that instead... :cool:
Is it just changing the Mosfets or is there more to it.?
/Z
Since you have your flamesuit on, I'll borrow something from you....."very UGLY!":D
Seriously, nice work. I love the jfet sound after hearing it on my Zv4...and because Mr. Kindhearted Bluesman, Steenoe, sent me a couple of hard to find 2SJ109s...I'll try them on an Aleph one of these days unless Mr. Pass spoils your party and shares his AJ soon.;)
Layout for slightly modified babbelfish
Zen Mod said:
here it is
feel free to comment , flame suit is on
:clown:
Great document.
:D
I have made a layout for the fish with two pairs. This will be my first power amp, so I would really appreciate, if some of the more experienced amp builders would spend a few minutes on my layout and offer their comments.
The board is single sided and designed for 40cm heatsinks. Dark blue traces are + AND - rails. Light blue is ground and red is everything else. The brown is just a jumper.
Layout:
http://viller.org/audio/2007jan_jfish/jfish_c.pdf
Schematics:
http://viller.org/audio/2007jan_jfish/alephjfish_r.sch
http://viller.org/audio/2007jan_jfish/alephjfish_l.sch
BTW: Please don't waste your time trying to make this into a B/W version - just mail me and I'll send it to you. ;)
Joined 2003
Re: Layout for slightly modified babbelfish
cviller said:
Great document.
:D
Layout:
Schematics:
I like that pdf
probably even later tonight,when I'll have time to see it better , I'll not have anything to say against ;)
send some graphic files,instead sch.......I haven't anything for opening that
Re: Re: Layout for slightly modified babbelfish
Zen Mod said:
I like that pdf
Cool, thanks! :cool:
I will do some cleanup of the traces before I etch it.
:headbash:
I copied the wrong files.... these should be readable:
http://viller.org/audio/2007jan_jfish/alephjfish_r.pdf
http://viller.org/audio/2007jan_jfish/alephjfish_l.pdf
:clown:
I just ordered a few sj109's from these guys
http://www.slelectronics.net/
Not sure what grade, but I decided to take a chance, since they are almost impossible to find these days.
They are close to me, so I should get them pretty quickly. But, it will be a little while before I get around to using them. I will either use Peter's or Brian's Aleph board, and convert it to a sj109 front end.
Randy
