Any chance for a diy autoformer volume control?
Joined 2002
I wound up to 8k turns with a 0.07mm wire on the 49%Ni core.
I did some THD vs freq at 2.1Vrms signal.
550 Ohm source, 20kOhm load
George
Reactions: 1 user
Joined 2002
Here are some distortion measurements at five taps (1st, 2nd, 6th, 12th, 18th) of the 1k4 turns AVC from post #14.
This time at 2.4Vrms (Motu M2 sound card)
George
Joined 2002
I wound a 7k turns autoformer with a 0.07mm wire.
Joined 2002
I did on it the same distortion measurements as with the 1k4 turns.
It seems that it behaves better.
Compare the attached with those of post #24
I'm pleased to see that your making very good use of the lams. With 7k turns I would think that your primary inductance will be very high
and probably more than you need for good LF response. So I think there is plenty of scope for the "pinstriping" we talked about which would
reduce 3rd harmonic distortion for a given i/p signal level. Keep up the good work.
Joined 2002
Hi Zeta
I enjoy experimenting with your lams.
I tried the high primary inductance for the low THD and the clean multitone FFT they manage.
The stacking I have used is the 1 to 1 alternate long e's and short e's, thus the smallest air gap.
Even with this minimum gap, I haven't managed to approach core saturation. I used a headphone amplifier to raise the drive of the AVC to 7.34Vrms and only when I lowered the freq to 10 Hz I managed to increase the THD from 0.005% to 0.01%.
I will bring-in a hefty power amp to raise the drive further.
It seems there is plenty of oppportunity to test increasing the air gap by changing the stacking order ( your "pinstriping"). This is what I will try next.
George
George
I'm impressed that you managed to wind 7k turns on that bobbin. Do you have a tensioning device on your winder? With my eyesight I would
have a hard time even seeing the wire !
The more turns the lower the flux density in the core. I did a rough calculation and at 10hz with that size core and 7k turns a signal of
20V rms produces a flux density of about 0.85T which is well below the saturation limit.
Getting the distortion below 0.01% at 10hz with a significant signal level with restacking could mean that there is little advantage in going to 80% nickel. Interesting.
Have you done a frequency response plot above 20khz yet ?
Joined 2002
My "winder" is primitive. I rely on fingers feel for the tension "adjustment".
The bobbin window can take some 9k turns with the 0.07mm wire if not much thread interleaving is allowed.
I was borderly sober when I wound this, so I can attest that 7k is a feasible target.;)
FR to 96kHz
Loopback and @1 tap curves are indistinguishable, they overlap.
George
edit. FR dB and phase degrees at the legend, refer to cursor position at 20kHz
Joined 2002
Now, the heavy stuff :nod:
I used Greg Ball's GB150 power amplifier (it's PSU good to some 70W) to drive the AVC at higher levels.
The amplifier can play 10Hz at 22.9Vrms relatively clean (0.018% THD)
When I connected it to the AVC,at the tap #1 (i.e. the whole 7k coil) distortion increase is negligible. It starts increasing from tap #2 and on.
I didn't reach hard clipping but significally distorted waveform.
George
Joined 2002
Happy to announce I managed to evaporate a 10mm length of 0.07mm wire during some high level tests :rofl:
That wire was the one going to the innermost winding.
I will rewind that ex-innermost winding around the outside of the whole coil and see if anything changes dramatically.
If it does, I will scrap the whole thing and rewind it again.
Joined 2002
I rewound the damaged innermost winding , now around the outside of the whole coil.
Fortunately there are no changes to the basic parameters: attenuation ratio, inductance, frequency response, distortion.
Only a slight pick-up of mains subharmonics on tap 23 and 24. Sounds logic (the low level coil is not "shielded" anymore by the large copper mass of the whole coil).
I will continue the testing with this configuration.
Very interesting post, I was thinking too in TVC, but is very complicate wired a small bobbin with 24 secondary wires with a diameter smaller than 0,1mm.
I have a binary remote control with 8 bit give 64 steps, but is possible to do with 8 secondary autoformer ?
