HaLo6 said:I am going to need 4 heatsinks.... but the heat sinks are going to cost more than all the boards and BOM put togehter for the BPA300 build. Would these be overkill for the BPA300?
How many devices per channel and how much is each device dissapating?
Anthony
BobEllis said:I'm interested in four sides whether a single width or two pieces.
Do you mean four times 14" of heatsink whether that is made of 4 or 8 pieces? I assume you want to build 2 monoblocks?
Anthony
Tube Noob said:I'd be interested in 3 pairs or so as well.
I'm very happy with the R-Thetas from the last GB
What size of heat sinks are you looking for, 1x8" 2x8" or 1x14"?
Anthony
BobEllis said:Sorry for being unclear. Two chassis with heat sinks on both sides - either 4 pieces of 14" sinks or 8 piece of 8" wide sink.
cool
I have some updates regarding buying 65605 Profiles from R-Theta. This pricing is all for 8" hieght.
The pricing is in CAD, Shipping is extra, Taxes where applicable
If you are going to use 2 heatsinks per chassis, 1 per side, say for a BrianGT Mini A 20W Sereo, you could get them regular cut.
$29 ea. MOQ 25
If you are going for a much bigger amp and use 4 per chassis, 2 per side, say for a 40W or 50W stereo unit you should get them fly cut. This is so the Heat sinks line up to a tight tolerance. You can make a simple box frame with 1/4" square stock to mount everything together.
$36 ea MOQ 25
Now if you want to get a set of 4 all machined up for a real snappy look direct from R-Theta, you can have that for:
$212 (Set of 4) MOQ 25 Sets
For that you get recesses for flush mounting back, top and bottom plates. Drilled and tapped for attaching plates. Drilled and tapped for top cross brace left and right side. Drilled and tapped for attaching a blind bracket for front panel mounting.
There is better pricing available for larger MOQ's.
I think it may be near impossible to get 25 orders of the machined sets together and the 10 set MOQ is $275.
However if we pushed the numbers up on the Fly Cut profile to the 50 MOQ the price drops to $33 ea.
Here are some photos of what the machining would allow you to do.
Anthony
$29 ea. MOQ 25
$36 ea MOQ 25
Anthony
- Group Buys
- Aavid Thermalloy Possible Group Buy
