AX-14
this is my AX-14 with 2 pair 5200/1943 output and mje15032/15033 drivers. PSU is 2x53 VDC and 30mF per rail. It plays very well,strong bass and clear mid and high. Now i will try to build AX-11 with TO-3 transistors .
Nice work,
OK boys, one more time.
Meet the NX-14 using On-Semi MTW32N20E MOSFETs. I have the bias set to 100mA and it sounds really nice. Here are some pics of the top and underside so you can see the mods I needed to make to the boards to make the layout match the schematic. So now I've done AX-14, SX-14, NX-14 and AX-Slewmaster. I can't think of any other ways to use the boards aside from maybe different outputs.
Blessings, Terry
Blessings, Terry
Blessings, Terry
Nice work,
I'm not sure if On semi makes these anymore. I got them a few years ago to use in my Aleph-X. They didn't make a complementary P-channel device so I have kept my eyes pealed for an amp that used only N-channel so I could give them another try. I was excited to see this design come along. Sounds really good.
Blessings, Terry
Blessings, Terry
i need sir mile class H apm.
can any one help me?
I sugest HX11
thank you
can you give me lattest vertion off this amp and a simple but good protection for that?
Use protect with NE555 from post #2323
AX20
Mile, I have a question (well two):
is it possible to use a balanced input signal to drive two AX11 boards, one with plus &GND, and the other one with minus&GND, with speaker bridged between plus and minus? (so a bridged configuration but with balanced input instead of single-ended input plus phase splitter).
p.s. I also have not decided on PS yet. you had a schematic somewhere earlier. is that one a good performer or I could do better (not sure where taht one came from and if any noise measurements were available?)
Thanks a lot.
Thanks a lot.
AX20
Hi,Can you share AX20 shematic?
Thanks a lot.
It is possible
if you can post a schematic it is more clear .Mile, I have a question (well two):
Thanks a lot.
- 100W Ultimate Fidelity Amplifier
