Can Anyone ID this Transistor For Me?
Administrator
Joined 2007
I would always recommend powering up with a bulb tester after any work has been done on the amp.
Don't assume that turning presets to the left means minimum bias it may not. If you are not sure then leave them where they are initially.
Used the old bulb tester and there is a short:( It is in the left channel, which is where the original problem was. The 2 left channel outputs were getting hot.
Could be one of the 3 transistors on that side which are just south of the outputs.
Not sure what to do now, since if it is one of those transistors I am not possessing the skills to identify it or find a suitable replacement. Assuming it is one of those transistors.
Recap of what I did on power up - full disclosure:
1.Attached bulb tester and switched on.
2.The bulb did not light:confused:
3.Lights on the amp came on:)
4.Turned left channel pot to left slightly
5. Bulb on tester came on a stayed lit.
6. Power down
7. Felt the outputs and the left channel transistors are warm and the 2 right channel ones are cool. This after only 30 seconds or so of power up.
Administrator
Joined 2007
Have you turned the pot back the other way and tried again ? I'd be surprised if the transistors popped with a bulb tester in circuit. Its normal for the bulb to light as bias increases, it might just have saved you from really doing damage.
OK. I'd be surprised if they had failed. And if they are warm then they are not short circuit :)
Well, she is up and running:):). Only listened to it through headphones though.
Quick measure of the DC offset at the speaker terminals yields .800VDC
Not good I would say.
On further observation I am getting a rushing sound and bit of hum when the volume is up past half way. I need verify if this is through the FM as well as the Aux. I was just using an iPod for source. I notice that the AUX inputs do not have a the grounding wire of the coax connected. They have been cut off. Is this potentially a hum issue area?
Administrator
Joined 2007
The DC offset :D sounds OK to me. I take it that was measured without speakers connected and that it falls to zero when they are connected. If so then try and think why :)
You need to set the bias correctly though as you have disturbed the original settings. That could be crucial on an amp like this to avoid thermal runaway. I would say as low as possible to get rid of audible distortion and no more.
I thought there should be no DC leakage at the terminals, that is as near 0V is optimal and that could be measured without speakers. If I attach speakers are they not subjected to nearly 1VDC?
Should I not be measuring voltages for the bias? Without the schematic could be tough. Or is your reco, as I understand it, turn the pots up from minimum only just enough to get it working. The trannies are not even getting warm right now.
Administrator
Joined 2007
Well I'm thinking that given the age of the amp, that its AC coupled to the speakers. So in that case a voltage measured on the end of an "open" large electrolytic would be normal and would be expected due to the high leakage of big caps. That's why I think you'll find the offset falls to zero when you connect a speaker.
For the bias you need to first of all see if there are any low value resistors either in the emitter of the output devices or maybe just a single one in the collector circuit... old amps... any configuration is likely to be seen. That resistor would allow you to monitor the current (by measuring voltage). If there is no resistor then you have to break the circuit somewhere to measure current directly.
Was tired when measuring offset last night. I had the speakers off:D DC measures 0VDC:)
I will check the resistor configuration after work today.
How do these resistors in the image look to you Mooly? 220Ohm
They near the emitter resistors.
Administrator
Joined 2007
Oooh, it gets better.
Look at it all closely. There has to be an easy point to measure this. I spotted some wire links I think ? See whether they feed the output transistors and whether they look like something that's meant to be opened and an ammeter inserted. The manufacturer won't mess around setting these up, there will be an easy way to get at it.
You are sure there are no really low value resistors around there ?
