VSSA Lateral MosFet Amplifier
Expect no troubles if you'll follow the instructions and grounding schematic. :up:
I follow them? You can follow the speaker "-" return path on picture above
=> speaker terminal=> VSSA GND=>PSU GND
Marc
Here's just a preliminary shot of a First One Mosfet Amplifier PCB just in development process. :wiz:
Some "must" features expected from the First One amp:
- 100 Wrms/8 Ohm, 200 Wrms/4 Ohm, 220 Wrms/2 Ohm
- same 3 Mhz/-3 dB bandwidth as in VSSA
- SMPS400A180 power supply per channel
- 2 Ohm normal operation
- 75 x 50 mm dual layer PCB size, copper metalized up to 110 um
Expected group buy in September. :cheers:
LC, it would be nice if we could use some 18 mm diameter caps on this board.
VSSA with BIGBT :confused:, sound interesting....
James
Cross finger, but think you have knowledge in this area so not nessecary to cross.
But exited to hear about your listening report, because you have done other versions too.
Myself am waiting for the last shipment in august from Andrej, so only experience till now is my old DC coupled Sansui's with VFB and SANKEN.
Very interesting to follow a 5 to 10 persons high action on different layout on the VSSA.
BR Ricky
Voltage regulator suggestion
Hey Andrej and others
Because of the output impedance data from installation manual i have been inspired to do serial voltage regulator suggestion.
Please take a look in image and see if it is possible, hope not it is silly.
BR Ricky
BR Ricky
Your PSU is like to be for MM/MC preamp or for some very exotic electronics.
Please do not understand me wrong, technically is perfect, only a little overkill for VSSA don't you think hehe
Some regulated SMPS could also be OK but if you wish to try it, I can only suggest you to go for it. :up:
