Go Back   Home > Forums > > >
Vendor's Bazaar Commercial Vendors large & small hawking their wares
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 Khz
Old 7th November 2019, 02:13 AM   #8651
rhythmsandy is offline rhythmsandy
Originally Posted by soekris View Post
That part is not usable with a dam1021, it's a 5V part and a dam1021 need 3.3V inputs, running it at 3.3V probably lower its performance, and it's already spec'ed for just 6 Mbps.... You could put a 5V to 3.3V converter between it and the dam1021, but it's still a 6 Mbps part...
Why not just get the correct part, t.ex. a Everlight PLR135/T10 is just $2 at Digikey and they have over 6000 pcs in stock....
But can that do 24bit 192KHz signal the problem is whenever we use SACD from oppo player it doesnt sync.
Old 7th November 2019, 11:33 AM   #8652
soekris is offline soekris  Denmark
Only with a strong signal. The DLR2160 that zfe recommended is better, but not as easy to get.
I have been using the PLR135/T10 in my DACs, but are also looking for faster ones for my next generation. Recommendations are welcome, but preferable something I can buy in volume in EU or US....
Søren
Old 7th November 2019, 11:35 AM   #8653
TNT is offline TNT  Sweden
Aha - next generation :-)
More distortion to the people!
Old 7th November 2019, 01:26 PM   #8654
paulebappie is offline paulebappie  Netherlands
I'm using DLR2180, also 25MBit/s
Works like a charm.
Old 7th November 2019, 07:34 PM   #8655
zfe is offline zfe
I thought about giving the Broadcom AFBR-2624Z a trial, they are fast enough for even 384kHz
However they are pricey and need other connectors (but it should be possible to cut an ordinary Toslink cable and fit the needed connector).
On the other hand if you really want to go up to 384kHz you need to use a transmitter of that series on the other side and thus can use the fitting cables.
Old 9th November 2019, 03:37 PM   #8656
spikestabber is offline spikestabber  Canada
This goes back to toslink being outdated and nobody having any incentive to update it, had they were interested in upgrading it they would have went to IR lighting and switched to gigabit MMF optics that are cheaper than dirt right now, they don't even require lasers.
The real answer is the industry wouldn't be able to adapt such a new standard without riddling it with DRM, making it useless for DIY anyway.
Soekris dam1021-12v2 dual-mono balanced w/D882/B772 transistor mods & BAL-BAL Headamp: https://imgur.com/gallery/RVBQozq
nc400: https://imgur.com/iORCyna | TT2USB: https://imgur.com/a/p6OiS | HD800 | KEF R300
Old 10th November 2019, 05:37 PM   #8657
Works like a charm.
which make is it? Im finding many on alibaba and aliexpress websites.
Old 11th November 2019, 07:05 AM   #8658
192K Optical SPDIF receiver - DIYINHK
Old 11th November 2019, 02:29 PM   #8659
thank you but which make is the optical receiver in it? Toshiba?
Old 11th November 2019, 02:52 PM   #8660
zfe is offline zfe
The DLR2180 is as well from Aixin. It is the same as the DLR2160 just with an other housing.
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KhzHide this!Advertise here!
e18 DAC - 8 channels at 32bit /384 kHz exa065 exaDevices 30 29th June 2012 06:11 PM
384 Khz DAC? SunRa Digital Source 8 2nd October 2009 12:14 AM
24 bit/192 kHz via USB? gentlevoice Everything Else 3 22nd December 2008 07:24 AM
sign magnitude DAC Bernhard Digital Source 0 30th January 2007 02:40 PM
24 bit / 192 kHz Tube DAC questions Overlord Digital Source 4 29th April 2003 06:14 PM
Search Engine Optimisation provided by DragonByte SEO (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
Copyright ©1999-2020 diyAudio
