The output stage is .... no output stage ;-)
Have you tried it from the raw ladder output?
Yes, but why?Have you tried it from the raw ladder output?
I exactly asked about op amps to understand if I need to use RAW output to make buffer myself.
But in case the current amps are in A or A/B class it not so urgent and may be not relevant
I assume you want the best sound and I think the consensus is that skipping the active output stage is the best.
But, class D it is not 🙂 and if you needed to ask that I doubt that you really are up to the task to make a better stage than already exists on the board.... or was that a joke?
But I have asked something different dude. 🙂 Please take look.I assume
In my post with question. Dude are you OK? May be my english isn't really good, but you started commenting my post with question.Look... where?
Not required any sorry - it's OK.Yes- sorry.
I just want to understand if I have on board D class or A class? Thats all. RAW output I had use on my 300B SE, but now I have changed amp to Pathos Logos than RAW output sound not so good. I can't explain sound, just I listen degradation if I'm not using opamps buffer.
Than as you assumed - want to understand can I do some A class buffer for output or not required, as I'm not HW eng. in audio.
- Vendor's Bazaar
- Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
