no, what is your recommendation?Your circuit shows about 1.5mA idling current - are you sure that's enough?
nice video about Gate Loop Ringing at 07:25
Approximately half of your B+ supply voltage will appear across the ? resistor, so it will also dissipate about the same power as the MOSFET. It's value is simple Ohms Law: R = Volts (about 150 for your case) divided by Current desired.
Only you can know what current is desired because you're keeping that a secret.
YOS,
Chris
YOS,
Chris
Joined 2009
Perhaps get a couple of 15k, use one for 10mA which will likely be plenty and both resistor and FET will run a bit cooler - generally a good thing in my view.
Put a second 15k in parallel with the first for 20mA, which will generate more heat, see if it sounds any better to your ears
hi again.
All the parts arrived, I started building the pre amplifier.
It works well, makes a bit of noise, probably power or GND.
12au7 works great for gain.
The spectrum picture is not so good. no 2nd harmonics
The 12ax7 has a lot of gain so any noise around will be amplified too...
Which is it? 12AU7 or 12AX7? If it's 12AU7, those plate and cathode values are way off, and therein lies the problem most likely.
i try with 12ax7 and 12at7, but the volume is jump to high level about 9 o'clock. so i put 12au7.Which is it? 12AU7 or 12AX7?
what is you're recommendation?those plate and cathode values are way off,
OKTry extra decoupling on B+
If you have the parts, you can try 47k plate resistor and 220R - 330R on the cathode for a 12AU7. With a 300k plate load, the 12AU7 is so current starved it's virtually worthless
Otherwise, use 12AX7, and a voltage divider on the input to reduce the gain (or install negative feedback).
work good. thanksIf you have the parts, you can try 47k plate resistor and 220R - 330R on the cathode for a 12AU7. With a 300k plate load, the 12AU7 is so current starved it's virtually worthless
yes it helpTry extra decoupling on B+.
Summary:
pcm56p DAC 1ma output to 100ohm
12au7 with 47k plate resistor and 220R - 330R on the cathode
- Tubes / Valves
- simple preamp from half 12ax7
