I think I originally planned a small guitar practice amp, as I had the idea to add another gain channel suitable for piezo bridge pickups, even if it ended up being IC based...6P6S looked like they might be good for a small push pull output stage. Then I picked up the 6P1P, another possible output stage, rather than something like 6N2P ECC83.
Now I've found some used ECC88, I'll probably end up distracted testing if theres any life left in them.
And a higher Pd. I've run them at 15W without issue
I'm in the process of putting transformers into the Stupendous 6P1P amp...
The Stupendous 6P1P 4PP amplifier!
I hate it when I do that! Awhile ago I ordered a stereo digital volume control kit, and now I can't for the life of me remember what I was going to use it for. ¯\_(ツ)_/¯
An alternate version is when you buy something because you see it and think, " oh, yeah, I need one of those." And never remember why.
Here's a little transformer I decided to need, so far haven't found any info on it.
From the looooong list of things recently ordered:
A 12V 6rpm motor (will operate my Paterson developing tank)
Two 52mm UV-filter, one needed one "just in case ..."
A bunch of buckle rollers
A bunch of steel rings
A clock kit and some simple noise/sound-kits
A set of potentiometers for the MG-1
Some CA3046 and some 2SC1583
Six tube sockets for VFD-tubes
As the shops ran out of hand sanitizers here in Sweden, I had to order that from germany - two BiB 3 litre vodka, two BiB Gin, 1 BiB 3 litre Rum, Xante (pear/chocolate ), Valhalla herbal liquer lickface, Jagdtraum Kräuterlikör drunk and a bottle of Famous Grouse Bourbon cloud9.
I intend to use the hand sanitizers for internal use only.
In a minute I'm off to to the local Radio Shack-type of shop for a 2-pole power switch for the MG-1.
I bought lunch for 3 in a restaurant - yes it was open! I live in Laos - come on down we have no coronavirus!!! (according to the government)
But elsewhere apparently...
if you are American you bought guns/ammo today
if you are British you bought a trolley full of loo roll
if you are Dutch you bought a big stash of weed
LOO ROLL?! Who buys a trolley full????? Never heard of something like that ever before ...
- Member Areas
- The Lounge
- And what did we buy today?
